Soc Modul Kia E-Niro 2020
Re: Soc Modul Kia E-Niro 2020
Hi
Hab die Datei bluelinksoc.py mal abgeändert in:
in main.sh . /var/www/html/openWB/openwb.conf hinzugefügt.
Fehlermeldung ist:
Wo liegt der Fehler?
import sys
import requests
import uuid
import json
import urllib.parse as urlparse
from urllib.parse import parse_qs
email = str(sys.argv[1])
password = str(sys.argv[2])
pin = str(sys.argv[3])
#vin = str(sys.argv[4])
def main():
#diviceID
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/notifications/register'
headers = {
'ccsp-service-id': 'fdc85c00-0a2f-4c64-bcb4-2cfb1500730a',
'Content-type': 'application/json;charset=UTF-8',
'Content-Length': '80',
'Host': 'prd.eu-ccapi.kia.com:8080',
'Connection': 'close',
'Accept-Encoding': 'gzip, deflate',
'User-Agent': 'okhttp/3.10.0'}
data = {"pushRegId":"1","pushType":"GCM","uuid": str(uuid.uuid1())}
response = requests.post(url, json = data, headers = headers)
if response.status_code == 200:
response = json.loads(response.text)
deviceId = response['resMsg']['deviceId']
#print(deviceId)
else:
print('NOK diviceID')
return
#cookie für login
session = requests.Session()
response = session.get('https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/authorize?response_type=code&state=test&client_id=fdc85c00-0a2f-4c64-bcb4-2cfb1500730a&redirect_uri=https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/redirect')
cookies = session.cookies.get_dict()
#print(cookies)
else:
print('NOK cookie für login')
return
#login
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin'
headers = {'Content-type': 'application/json'}
data = {"email": email,"password": password}
response = requests.post(url, json = data, headers = headers, cookies = cookies)
response = response['redirectUrl']
parsed = urlparse.urlparse(response)
authCode = ''.join(parse_qs(parsed.query)['code'])
#print(authCode)
else:
print('NOK login')
return
#token
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/token'
headers = {
'Authorization': 'Basic ZmRjODVjMDAtMGEyZi00YzY0LWJjYjQtMmNmYjE1MDA3MzBhOnNlY3JldA==',
'Content-type': 'application/x-www-form-urlencoded',
'Content-Length': '154',
data = 'grant_type=authorization_code&redirect_uri=https%3A%2F%2Fprd.eu-ccapi.kia.com%3A8080%2Fapi%2Fv1%2Fuser%2Foauth2%2Fredirect&code=' + authCode
response = requests.post(url, data = data, headers = headers)
access_token = response['token_type'] + ' ' + response['access_token']
#print(access_token)
else:
print('NOK token')
return
#vehicles
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles'
headers = {
'Authorization': access_token,
'ccsp-device-id': deviceId,
'ccsp-application-id': '693a33fa-c117-43f2-ae3b-61a02d24f417',
'offset': '1',
response = requests.get(url, headers = headers)
vehicleId = response['resMsg']['vehicles'][0]['vehicleId']
#print(vehicleId)
else:
print('NOK vehicles')
return
#vehicles/profile
#prewakeup
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles/' + vehicleId + '/control/engine'
headers = {
'offset': '1',
'Content-Type': 'application/json;charset=UTF-8',
'Content-Length': '72',
data = {"action":"prewakeup","deviceId": deviceId}
#print(response.text)
response = ''
else:
print('NOK prewakeup')
return
#pin
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin'
headers = {
'Content-Length': '64',
data = {"deviceId": deviceId,"pin": pin}
response = requests.put(url, json = data, headers = headers)
controlToken = 'Bearer ' + response['controlToken']
#print(controlToken)
else:
print('NOK pin')
return
#status
url = 'https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/' + vehicleId + '/status'
headers = {
'Authorization': controlToken,
'offset': '1',
'Host': 'prd.eu-ccapi.kia.com::8080',
soc = response['resMsg']['evStatus']['batteryStatus']
#print(soc)
f = open('/var/www/html/openWB/ramdisk/soc', 'w')
f.write(str(soc))
f.close()
else:
print('NOK status')
return
if __name__ == '__main__':
main()
Fehlermeldung ist:
main.sh: 12: main.sh: cannot open tmpintervall: No such file
main.sh: 12: main.sh: soctimer: not found
root@raspberrypi:/var/www/html/openWB/modules/soc_bluelink# Traceback (most recent call last):
File "/var/www/html/openWB/modules/soc_bluelink/bluelinksoc.py", line 168, in <module>
main()
File "/var/www/html/openWB/modules/soc_bluelink/bluelinksoc.py", line 157, in main
File "/usr/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
- mattle1957
- Been thanked: 1 time
- Kontaktdaten:
könnte es daran liegen, dass es bei Kia nicht "Bluelink", sondern "UVO" heisst?
Grüße
Martin
Grüße
Martin
PV-Axitec: 9,92 kWp
Alpha ESS Smile 5 (Inverter) + SMA Sunnyboy (WR) in Hybridschaltung
Alpha ESS Speicher: 10,7 kWh (nutzbar)
WB: openWB Standalone mit go e Charger
Fiat 500e Cabrio LaPrima
BMW iX1 xDrive30
Das Modul ist das selbe es müssen nur andere ids und Adressen eingetragen werden.
- Has thanked: 97 times
- Been thanked: 228 times
Weißt du / kannst du alles nötige abändern?
Hi
Bin ein gutes stück weiter.Anmelden geht. Leider funktioniert das Auslesen nicht.
Fehlermeldung:
Hat noch einer eine Idee?
def main():
#diviceID
headers = {
print(deviceId)
else:
return
#cookie für login
#print(cookies)
else:
return
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/language'
data = {"lang": "en"}
#login
#print(authCode)
else:
print('NOK login')
return
#token
headers = {
'Content-Length': '150',
else:
print('NOK token')
return
#vehicles
headers = {
'offset': '1',
#print(vehicleId)
else:
return
#vehicles/profile
#prewakeup
headers = {
'offset': '1',
response = ''
else:
return
#pin
headers = {
else:
print('NOK pin')
return
#status
url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles/' + vehicleId + '/status'
headers = {
'offset': '1',
print(soc)
f.write(str(soc))
f.close()
else:
print('NOK status')
return
main()
Fehlermeldung:
<!doctype html>
<html lang="en">
<head>
<meta charset="UTF-8">
<title>Blocking Page</title>
</head>
<body>
<div align="center">
<br />
<br />
<form action="login.php" method="post">
<fieldset>
<br> <span style="color:#FF0000"> <접근 제한>
<br>
<br> <span style="color:#000000"> 보안 운영팀에 문의 바랍니다
<br>
<br> 당신의 차단 ID 는 15663020050990421609 입니다.
<a href='javascript:history.back();'>
<br>
<p class="submit"><input type="submit" value="Go Back" name="Go Back"></p>
</fieldset>
</form>
<br />
<br />
<div>
</body>
</html>
File "/var/www/html/openWB/modules/soc_bluelink/bluelinksoc.py", line 174, in <module>
main()
File "/var/www/html/openWB/modules/soc_bluelink/bluelinksoc.py", line 163, in main
Erwartet wird eine JSON Antwort die aber nicht kommt und der Decoder daher einen Error wirft.
Fertig es funktioniert.
Mein Dank geht an Plips-nl
Angabe der Vin ist erforderlich.
Ausgabe SoC und Ladestatus.
soc: 96
charging: False
soc: 96
charging: False
import sys
import requests
import uuid
import json
def main():
#diviceID
headers = {
print(deviceId)
else:
return
#cookie für login
#print(cookies)
else:
return
#login
#print(authCode)
else:
print('NOK login')
return
#token
headers = {
else:
print('NOK token')
return
#vehicles
headers = {
'offset': '1',
#print(vehicleId)
else:
return
#vehicles/profile
#prewakeup
headers = {
'offset': '1',
response = ''
else:
return
#pin
headers = {
else:
print('NOK pin')
return
#status
headers = {
'Content-Type': 'application/json'}
statusresponse = json.loads(response.text)
#log (statusresponse)
soc = statusresponse['resMsg']['evStatus']['batteryStatus']
print('soc: ',soc)
charging = statusresponse['resMsg']['evStatus']['batteryCharge']
print('charging: ', charging)
f.write(str(soc))
f.close()
else:
print('NOK status')
return
main()
- mattle1957
- Kontaktdaten:
Bitte um Info, wenn das Modul implementiert ist und wie die Einstellung aussehen sollte.
Fahre einen e Soul und würde dies auch gerne nutzen.
Danke!
Martin
Danke!
Martin
PV-Axitec: 9,92 kWp
BMW iX1 xDrive30
Habe es mal in die Nightly übernommen - bitte testen.Cobra hat geschrieben: Do Jul 16, 2020 10:48 am Fertig es funktioniert.
soc: 96
charging: False
import sys import requests import uuid import json import urllib.parse as urlparse from urllib.parse import parse_qs email = str(sys.argv[1]) password = str(sys.argv[2]) pin = str(sys.argv[3]) vin = str(sys.argv[4]) def main(): #diviceID url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/notifications/register' headers = { 'ccsp-service-id': 'fdc85c00-0a2f-4c64-bcb4-2cfb1500730a', 'Content-type': 'application/json;charset=UTF-8', 'Content-Length': '80', 'Host': 'prd.eu-ccapi.kia.com:8080', 'Connection': 'close', 'Accept-Encoding': 'gzip, deflate', 'User-Agent': 'okhttp/3.10.0'} data = {"pushRegId":"1","pushType":"GCM","uuid": str(uuid.uuid1())} response = requests.post(url, json = data, headers = headers) if response.status_code == 200: response = json.loads(response.text) deviceId = response['resMsg']['deviceId'] print(deviceId) else: print('NOK diviceID') return #cookie für login session = requests.Session() response = session.get('https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/authorize?response_type=code&state=test&client_id=fdc85c00-0a2f-4c64-bcb4-2cfb1500730a&redirect_uri=https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/redirect') if response.status_code == 200: cookies = session.cookies.get_dict() #print(cookies) else: print('NOK cookie für login') return url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/language' headers = {'Content-type': 'application/json'} data = {"lang": "en"} response = requests.post(url, json = data, headers = headers, cookies = cookies) #login url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin' headers = {'Content-type': 'application/json'} data = {"email": email,"password": password} response = requests.post(url, json = data, headers = headers, cookies = cookies) if response.status_code == 200: response = json.loads(response.text) response = response['redirectUrl'] parsed = urlparse.urlparse(response) authCode = ''.join(parse_qs(parsed.query)['code']) #print(authCode) else: print('NOK login') return #token url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/token' headers = { 'Authorization': 'Basic ZmRjODVjMDAtMGEyZi00YzY0LWJjYjQtMmNmYjE1MDA3MzBhOnNlY3JldA==', 'Content-type': 'application/x-www-form-urlencoded', 'Content-Length': '150', 'Host': 'prd.eu-ccapi.kia.com:8080', 'Connection': 'close', 'Accept-Encoding': 'gzip, deflate', 'User-Agent': 'okhttp/3.10.0'} data = 'grant_type=authorization_code&redirect_uri=https%3A%2F%2Fprd.eu-ccapi.kia.com%3A8080%2Fapi%2Fv1%2Fuser%2Foauth2%2Fredirect&code=' + authCode response = requests.post(url, data = data, headers = headers) if response.status_code == 200: response = json.loads(response.text) access_token = response['token_type'] + ' ' + response['access_token'] #print(access_token) else: print('NOK token') return #vehicles url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles' headers = { 'Authorization': access_token, 'ccsp-device-id': deviceId, 'ccsp-application-id': '693a33fa-c117-43f2-ae3b-61a02d24f417', 'offset': '1', 'Host': 'prd.eu-ccapi.kia.com:8080', 'Connection': 'close', 'Accept-Encoding': 'gzip, deflate', 'User-Agent': 'okhttp/3.10.0'} response = requests.get(url, headers = headers) if response.status_code == 200: response = json.loads(response.text) vehicleId = response['resMsg']['vehicles'][0]['vehicleId'] #print(vehicleId) else: print('NOK vehicles') return #vehicles/profile #prewakeup url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles/' + vehicleId + '/control/engine' headers = { 'Authorization': access_token, 'ccsp-device-id': deviceId, 'ccsp-application-id': '693a33fa-c117-43f2-ae3b-61a02d24f417', 'offset': '1', 'Content-Type': 'application/json;charset=UTF-8', 'Content-Length': '72', 'Host': 'prd.eu-ccapi.kia.com:8080', 'Connection': 'close', 'Accept-Encoding': 'gzip, deflate', 'User-Agent': 'okhttp/3.10.0'} data = {"action":"prewakeup","deviceId": deviceId} response = requests.post(url, json = data, headers = headers) if response.status_code == 200: #print(response.text) response = '' else: print('NOK prewakeup') return #pin url = 'https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin' headers = { 'Authorization': access_token, 'Content-type': 'application/json;charset=UTF-8', 'Content-Length': '64', 'Host': 'prd.eu-ccapi.kia.com:8080', 'Connection': 'close', 'Accept-Encoding': 'gzip, deflate', 'User-Agent': 'okhttp/3.10.0'} data = {"deviceId": deviceId,"pin": pin} response = requests.put(url, json = data, headers = headers) if response.status_code == 200: response = json.loads(response.text) controlToken = 'Bearer ' + response['controlToken'] #print(controlToken) else: print('NOK pin') return #status url = 'https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/' + vehicleId + '/status' headers = { 'Authorization': controlToken, 'ccsp-device-id': deviceId, 'Content-Type': 'application/json'} response = requests.get(url, headers = headers) if response.status_code == 200: statusresponse = json.loads(response.text) #log (statusresponse) soc = statusresponse['resMsg']['evStatus']['batteryStatus'] print('soc: ',soc) charging = statusresponse['resMsg']['evStatus']['batteryCharge'] print('charging: ', charging) f = open('/var/www/html/openWB/ramdisk/soc', 'w') f.write(str(soc)) f.close() else: print('NOK status') return if __name__ == '__main__': main()
