2021-08-14 09:05:01: ##### cron5min.sh started ##### (LV0) at 8 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:20: ##### cron5min.sh finished ##### (LV0) at 355 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:20: logfile cleanup triggered (LV1) at 352 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: starting evsecheck (LV1) at 348 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: modbus tcp server not running! restarting process (LV0) at 337 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: external openWB or daemon mode not configured; checking network setup (LV1) at 270 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: smarthome handler is already running (LV1) at 253 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: mqtt handler is already running (LV1) at 244 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: current ip: 192.168.50.122 (LV1) at 239 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: updating daily yield stats (LV1) at 140 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: electricity provider not set up; skipping price update (LV2) at 136 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:19: Netzschutz konfiguriert; aktuelle Frequenz: 0 (LV1) at 85 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:18: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20210814.csv (LV1) at 77 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 09:00:18: ##### cron5min.sh started ##### (LV0) at 8 main /var/www/html/openWB/runs/cron5min.sh
2021-08-14 08:59:11: boot done
![Smile :-)](./images/smilies/icon_e_smile.gif)
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
fix upload limit...OS Buster
not activated, skipping
etprovider...
update broker...
load versions...
display update...
clear warning...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 41 0 0 100 41 0 539 --:--:-- --:--:-- --:--:-- 539
Dload Upload Total Spent Left Speed
% Total % Received % Xferd Average Speed Time Time Time Current
version...
jq installed...
pymodbus installed...
aiohttp installed...
certifi installed...
docopt installed...
mqtt installed...
packages 2...
Reloading network daemon configuration:: mosquitto.
updating mosquitto config file
mosquitto...
timezone...
evdev installed...
packages 1...
crontab 2...
...changed
apache...
LAN/WLAN...
crontab 1...
mqtt handler...
smarthome handler...
Ramdisk init done.
Trigger update of logfiles...
'mqttwizzarddone' missing: Setting to provided default value '-1'
'mqttwattbezug' missing: Setting to provided default value '-1'
'mqttversion' missing: Setting to provided default value '-1'
'mqttverbraucher2_name' missing: Setting to provided default value 'notset'
'mqttverbraucher2_aktiv' missing: Setting to provided default value '-1'
'mqttverbraucher1_name' missing: Setting to provided default value 'notset'
'mqttverbraucher1_aktiv' missing: Setting to provided default value '-1'
'mqttupdateinprogress' missing: Setting to provided default value '-1'
'mqttu1p3pstandby' missing: Setting to provided default value '-1'
'mqttu1p3psofort' missing: Setting to provided default value '-1'
'mqttu1p3pnurpv' missing: Setting to provided default value '-1'
'mqttu1p3pnl' missing: Setting to provided default value '-1'
'mqttu1p3pminundpv' missing: Setting to provided default value '-1'
'mqttu1p3paktiv' missing: Setting to provided default value '-1'
'mqttstopchargepvpercentagelp2' missing: Setting to provided default value '-1'
'mqttstopchargepvpercentagelp1' missing: Setting to provided default value '-1'
'mqttstopchargepvatpercentlp2' missing: Setting to provided default value '-1'
'mqttstopchargepvatpercentlp1' missing: Setting to provided default value '-1'
'mqttspeicherwattnurpv' missing: Setting to provided default value '-1'
'mqttspeichersocnurpv' missing: Setting to provided default value '-1'
'mqttspeichersocminpv' missing: Setting to provided default value '-1'
'mqttspeichersochystminpv' missing: Setting to provided default value '-1'
'mqttspeicherpvui' missing: Setting to provided default value '-1'
'mqttspeicherpveinbeziehen' missing: Setting to provided default value '-1'
'mqttspeichermaxwatt' missing: Setting to provided default value '-1'
'mqttsofortsocstatlp2' missing: Setting to provided default value '-1'
'mqttsofortsocstatlp1' missing: Setting to provided default value '-1'
'mqttsofortsoclp2' missing: Setting to provided default value '-1'
'mqttsofortsoclp1' missing: Setting to provided default value '-1'
'mqttsocvorhanden' missing: Setting to provided default value '-1'
'mqttsoc' missing: Setting to provided default value '-1'
'mqttsoc1vorhanden' missing: Setting to provided default value '-1'
'mqttrfidakt' missing: Setting to provided default value '-1'
'mqttrestzeitlp3' missing: Setting to provided default value '-1'
'mqttrestzeitlp2' missing: Setting to provided default value '-1'
'mqttrestzeitlp1' missing: Setting to provided default value '-1'
'mqttpvwatt' missing: Setting to provided default value '-1'
'mqttpvbezugeinspeisung' missing: Setting to provided default value '-1'
'mqttpreisjekwh' missing: Setting to provided default value '-1'
'mqttoffsetpv' missing: Setting to provided default value '-1'
'mqttnurpv70dynw' missing: Setting to provided default value '-1'
'mqttnurpv70dynact' missing: Setting to provided default value '-1'
'mqttnlakt_standby' missing: Setting to provided default value '-1'
'mqttnlakt_sofort' missing: Setting to provided default value '-1'
'mqttnlakt_nurpv' missing: Setting to provided default value '-1'
'mqttnlakt_minpv' missing: Setting to provided default value '-1'
'mqttnachtladens1' missing: Setting to provided default value '-1'
'mqttnachtladen' missing: Setting to provided default value '-1'
'mqttminnurpvsoclp1' missing: Setting to provided default value '-1'
'mqttminnurpvsocll' missing: Setting to provided default value '-1'
'mqttminimalstromstaerke' missing: Setting to provided default value '-1'
'mqttminimalapv' missing: Setting to provided default value '-1'
'mqttminimalampv' missing: Setting to provided default value '-1'
'mqttminimalalp2pv' missing: Setting to provided default value '-1'
'mqttmindestuberschuss' missing: Setting to provided default value '-1'
'mqttmaxnurpvsoclp1' missing: Setting to provided default value '-1'
'mqttmaximalstromstaerke' missing: Setting to provided default value '-1'
'mqttlastlademodus' missing: Setting to provided default value '-1'
'mqttlademstats2' missing: Setting to provided default value '-1'
'mqttlademstats1' missing: Setting to provided default value '-1'
'mqttlademstatlp8' missing: Setting to provided default value '-1'
'mqttlademstatlp7' missing: Setting to provided default value '-1'
'mqttlademstatlp6' missing: Setting to provided default value '-1'
'mqttlademstatlp5' missing: Setting to provided default value '-1'
'mqttlademstatlp4' missing: Setting to provided default value '-1'
'mqttlademstat' missing: Setting to provided default value '-1'
'mqttlademkwhlp8' missing: Setting to provided default value '-1'
'mqttlademkwhlp7' missing: Setting to provided default value '-1'
'mqttlademkwhlp6' missing: Setting to provided default value '-1'
'mqttlademkwhlp5' missing: Setting to provided default value '-1'
'mqttlademkwhlp4' missing: Setting to provided default value '-1'
'mqttlademkwh' missing: Setting to provided default value '-1'
'mqtthook3_aktiv' missing: Setting to provided default value '-1'
'mqtthook2_aktiv' missing: Setting to provided default value '-1'
'mqtthook1_aktiv' missing: Setting to provided default value '-1'
'mqttheutegeladen' missing: Setting to provided default value '-1'
'mqtthausverbrauchstat' missing: Setting to provided default value '-1'
'mqtthausverbrauch' missing: Setting to provided default value '-1'
'mqttevuglaettungakt' missing: Setting to provided default value '-1'
'mqttetprovider' missing: Setting to provided default value 'notset'
'mqttetprovideraktiv' missing: Setting to provided default value '-1'
'mqtteinschaltverzoegerung' missing: Setting to provided default value '-1'
'mqttdurchslp1' missing: Setting to provided default value '-1'
'mqttdisplayspeichermax' missing: Setting to provided default value '-1'
'mqttdisplaypvmax' missing: Setting to provided default value '-1'
'mqttdisplayhausmax' missing: Setting to provided default value '-1'
'mqttdisplayhausanzeigen' missing: Setting to provided default value '-1'
'mqttdisplayevumax' missing: Setting to provided default value '-1'
'mqttdatenschutzack' missing: Setting to provided default value '-1'
'mqttdailychargelp3' missing: Setting to provided default value '-1'
'mqttdailychargelp2' missing: Setting to provided default value '-1'
'mqttdailychargelp1' missing: Setting to provided default value '-1'
'mqttaktgeladens2' missing: Setting to provided default value '-1'
'mqttaktgeladens1' missing: Setting to provided default value '-1'
'mqttaktgeladen' missing: Setting to provided default value '-1'
'mqttadaptpv' missing: Setting to provided default value '-1'
'mqttadaptfaktor' missing: Setting to provided default value '-1'
'mqttabschaltverzoegerung' missing: Setting to provided default value '-1'
'mqttabschaltuberschuss' missing: Setting to provided default value '-1'
'mqttRandomSleepValue' missing: Setting to provided default value '-1'
'mqttCp1Configured' missing: Setting to provided default value '-1'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp8max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp8name' missing: no MQTT topic set: Setting to default of 'Lp8'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp8sofortll' missing: Setting from MQTT topic 'lp8sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp8enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp8phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp8' missing: Setting from MQTT topic 'pluggedladungaktlp8' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp8startkwh' missing: Setting from MQTT topic 'pluggedladunglp8startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp7max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp7name' missing: no MQTT topic set: Setting to default of 'Lp7'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp7sofortll' missing: Setting from MQTT topic 'lp7sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp7enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp7phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp7' missing: Setting from MQTT topic 'pluggedladungaktlp7' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp7startkwh' missing: Setting from MQTT topic 'pluggedladunglp7startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp6max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp6name' missing: no MQTT topic set: Setting to default of 'Lp6'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp6sofortll' missing: Setting from MQTT topic 'lp6sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp6enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp6phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp6' missing: Setting from MQTT topic 'pluggedladungaktlp6' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp6startkwh' missing: Setting from MQTT topic 'pluggedladunglp6startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp5max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp5name' missing: no MQTT topic set: Setting to default of 'Lp5'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp5sofortll' missing: Setting from MQTT topic 'lp5sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp5enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp5phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp5' missing: Setting from MQTT topic 'pluggedladungaktlp5' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp5startkwh' missing: Setting from MQTT topic 'pluggedladunglp5startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp4max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp4name' missing: no MQTT topic set: Setting to default of 'Lp4'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp4sofortll' missing: Setting from MQTT topic 'lp4sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp4enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp4phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp4' missing: Setting from MQTT topic 'pluggedladungaktlp4' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp4startkwh' missing: Setting from MQTT topic 'pluggedladunglp4startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp3max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp3name' missing: no MQTT topic set: Setting to default of 'Lp3'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp3sofortll' missing: Setting from MQTT topic 'lp3sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp3enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp3phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp3' missing: Setting from MQTT topic 'pluggedladungaktlp3' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp3startkwh' missing: Setting from MQTT topic 'pluggedladunglp3startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp2max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp2name' missing: no MQTT topic set: Setting to default of 'Lp2'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp2sofortll' missing: Setting from MQTT topic 'lp2sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp2enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp2phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp2' missing: Setting from MQTT topic 'pluggedladungaktlp2' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp2startkwh' missing: Setting from MQTT topic 'pluggedladunglp2startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp1max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp1name' missing: no MQTT topic set: Setting to default of 'Lp1'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp1sofortll' missing: Setting from MQTT topic 'lp1sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp1enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp1phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp1' missing: Setting from MQTT topic 'pluggedladungaktlp1' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp1startkwh' missing: Setting from MQTT topic 'pluggedladunglp1startkwh' to value '0'
Initializing Ramdisk /var/www/html/openWB/ramdisk
Config file Update done.
Updating /var/www/html/openWB/openwb.conf...
touch: '/var/www/html/openWB/web/backup/.donotdelete' kann nicht berührt werden: Keine Berechtigung
loading config
atreboot.sh started
