Feedback Release Candidate 1
Benny
Re: Feedback Release Candidate 1
Beitrag von Benny »
Etwas ausführlicher:
2023-06-24 10:37:17,211 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:17,213 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:141} - {DEBUG:Internal Chargepoint} - Zweiter Ladepunkt für Duo konfiguriert.
2023-06-24 10:37:17,217 - {modules.internal_chargepoint_handler.clients:121} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0-port0')]
2023-06-24 10:37:17,223 - {modules.internal_chargepoint_handler.clients:123} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-24 10:37:17,224 - {modules.internal_chargepoint_handler.clients:132} - {ERROR:Internal Chargepoint} - LP1 gleiches Device wie LP0
2023-06-24 10:37:17,371 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-24 10:37:17,372 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b3a688>
2023-06-24 10:37:17,372 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP1: 2
2023-06-24 10:37:18,385 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x71b3a688>
2023-06-24 10:37:18,386 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:6 antwortet nicht.
2023-06-24 10:37:18,442 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 106
2023-06-24 10:37:18,602 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-24 10:37:18,809 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-24 10:37:18,953 - {modules.common.evse:62} - {DEBUG:Internal Chargepoint} - Angabe der Ströme in 0,1A-Schritten ist aktiviert.
2023-06-24 10:37:19,128 - {modules.common.evse:62} - {DEBUG:Internal Chargepoint} - Angabe der Ströme in 0,1A-Schritten ist aktiviert.
2023-06-24 10:37:19,129 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 1']
2023-06-24 10:37:19,165 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:19,166 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:169} - {DEBUG:Internal Chargepoint} - ***Start***
2023-06-24 10:37:19,170 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:171} - {DEBUG:Internal Chargepoint} - {'cp0': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='1', phases_to_use=0, set_current=0, trigger_phase_switch=False), 'cp1': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='2', phases_to_use=0, set_current=0, trigger_phase_switch=False), 'global_data': GlobalHandlerData(heartbeat=1687595830, parent_ip='localhost', configured=True), 'rfid_data': RfidData(last_tag=None)}
2023-06-24 10:37:19,173 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:19,688 - {modules.common.evse:42} - {DEBUG:Internal Chargepoint} - Gesetzte Stromstärke EVSE: 0, Status: 1, Modbus-ID: 1
2023-06-24 10:37:19,688 - {modules.common.store._api:26} - {DEBUG:Internal Chargepoint} - Raw data ChargepointState(voltages=[241.64439392089844, 239.78152465820312, 240.01683044433594], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7515929.19921875, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:19,689 - {modules.common.store._api:30} - {INFO:Internal Chargepoint} - Saving ChargepointState(voltages=[241.64439392089844, 239.78152465820312, 240.01683044433594], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7515929.19921875, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:19,709 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:225} - {DEBUG:Internal Chargepoint} - Published plug state False
2023-06-24 10:37:19,839 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:87} - {DEBUG:Internal Chargepoint} - Values from parentWB: InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='1', phases_to_use=0, set_current=0, trigger_phase_switch=False)
2023-06-24 10:37:19,840 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:19,847 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 1']
2023-06-24 10:37:20,376 - {modules.common.evse:42} - {DEBUG:Internal Chargepoint} - Gesetzte Stromstärke EVSE: 0, Status: 1, Modbus-ID: 2
2023-06-24 10:37:20,376 - {modules.common.store._api:26} - {DEBUG:Internal Chargepoint} - Raw data ChargepointState(voltages=[241.12295532226562, 238.95008850097656, 239.19488525390625], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=29961.999893188477, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:20,377 - {modules.common.store._api:30} - {INFO:Internal Chargepoint} - Saving ChargepointState(voltages=[241.12295532226562, 238.95008850097656, 239.19488525390625], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=29961.999893188477, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:20,386 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:225} - {DEBUG:Internal Chargepoint} - Published plug state False
2023-06-24 10:37:20,522 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:87} - {DEBUG:Internal Chargepoint} - Values from parentWB: InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='2', phases_to_use=0, set_current=0, trigger_phase_switch=False)
2023-06-24 10:37:20,523 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 1']
2023-06-24 10:37:21,630 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:169} - {DEBUG:Internal Chargepoint} - ***Start***
2023-06-24 10:37:21,631 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:171} - {DEBUG:Internal Chargepoint} - {'cp0': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='1', phases_to_use=0, set_current=0, trigger_phase_switch=False), 'cp1': InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='2', phases_to_use=0, set_current=0, trigger_phase_switch=False), 'global_data': GlobalHandlerData(heartbeat=1687595840, parent_ip='localhost', configured=True), 'rfid_data': RfidData(last_tag=None)}
2023-06-24 10:37:21,632 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:22,136 - {modules.common.evse:42} - {DEBUG:Internal Chargepoint} - Gesetzte Stromstärke EVSE: 0, Status: 1, Modbus-ID: 1
2023-06-24 10:37:22,137 - {modules.common.store._api:26} - {DEBUG:Internal Chargepoint} - Raw data ChargepointState(voltages=[241.6708221435547, 239.72647094726562, 239.898681640625], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7515929.19921875, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:22,139 - {modules.common.store._api:30} - {INFO:Internal Chargepoint} - Saving ChargepointState(voltages=[241.6708221435547, 239.72647094726562, 239.898681640625], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=7515929.19921875, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:22,155 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:225} - {DEBUG:Internal Chargepoint} - Published plug state False
2023-06-24 10:37:22,187 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:87} - {DEBUG:Internal Chargepoint} - Values from parentWB: InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='1', phases_to_use=0, set_current=0, trigger_phase_switch=False)
2023-06-24 10:37:22,188 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:22,197 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 1']
2023-06-24 10:37:22,755 - {modules.common.evse:42} - {DEBUG:Internal Chargepoint} - Gesetzte Stromstärke EVSE: 0, Status: 1, Modbus-ID: 2
2023-06-24 10:37:22,755 - {modules.common.store._api:26} - {DEBUG:Internal Chargepoint} - Raw data ChargepointState(voltages=[241.1224822998047, 238.91099548339844, 239.187255859375], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=29961.999893188477, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:22,756 - {modules.common.store._api:30} - {INFO:Internal Chargepoint} - Saving ChargepointState(voltages=[241.1224822998047, 238.91099548339844, 239.187255859375], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=29961.999893188477, exported=0, power=0, phases_in_use=0, charge_state=False, plug_state=False, rfid=None)
2023-06-24 10:37:22,758 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:225} - {DEBUG:Internal Chargepoint} - Published plug state False
2023-06-24 10:37:22,778 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:87} - {DEBUG:Internal Chargepoint} - Values from parentWB: InternalChargepointHandlerData(cp_interruption_duration=0, parent_cp='2', phases_to_use=0, set_current=0, trigger_phase_switch=False)
2023-06-24 10:37:22,779 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 1']
2023-06-24 10:37:25,891 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as duo
2023-06-24 10:37:25,892 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 1']
2023-06-24 10:37:25,893 - {modules.internal_chargepoint_handler.clients:121} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0-port0')]
2023-06-24 10:37:25,894 - {modules.internal_chargepoint_handler.clients:123} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-24 10:37:25,895 - {modules.internal_chargepoint_handler.clients:127} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-06-24 10:37:26,048 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-06-24 10:37:26,048 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x723cdb68>
2023-06-24 10:37:26,049 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-06-24 10:37:27,062 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x723cdb68>
2023-06-24 10:37:27,063 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-06-24 10:37:27,118 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-06-24 10:37:27,279 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-06-24 10:37:27,485 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-06-24 10:37:27,486 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Ladepunkt 0']
2023-06-24 10:37:27,489 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:141} - {DEBUG:Internal Chargepoint} - Zweiter Ladepunkt für Duo konfiguriert.
2023-06-24 10:37:27,499 - {modules.internal_chargepoint_handler.clients:121} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0-port0')]
2023-06-24 10:37:27,505 - {modules.internal_chargepoint_handler.clients:123} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-24 10:37:27,505 - {modules.internal_chargepoint_handler.clients:132} - {ERROR:Internal Chargepoint} - LP1 gleiches Device wie LP0
2023-06-24 10:37:27,662 - {modules.common.evse:55} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-24 10:37:27,662 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x723cdb68>
2023-06-24 10:37:27,663 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP1: 2
2023-06-24 10:37:28,676 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x723cdb68>
2023-06-24 10:37:28,677 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:6 antwortet nicht.
NeuenrothC
Beitrag von NeuenrothC »
Wenn das Auto fast voll ist und wenig Strom möchte, dreht die Phasenumschaltung durch...
Installierte Version:
2023-06-12 11:59:03 +0200 [8b9a8a116]
2023-06-24 13:39:40,808 - {root:65} - {INFO:MainThread} - # ***Start***
2023-06-24 13:39:40,870 - {modules.devices.solaredge.device:100} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solaredge.counter.SolaredgeCounter object at 0x723dc940>, 'component1': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0x71b8d7c0>, 'component2': <modules.devices.solaredge.bat.SolaredgeBat object at 0x71b7f778>}
2023-06-24 13:39:40,871 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-24 13:39:40,874 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Zähler']
2023-06-24 13:39:40,961 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [6677, 2218, 2284, 2174], Scale 0
2023-06-24 13:39:40,992 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [98, 100, 95], Scale -1
2023-06-24 13:39:41,010 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [23371, 23470, 23331, 0, 0, 0, 0], Scale -2
2023-06-24 13:39:41,030 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5000], Scale -2
2023-06-24 13:39:41,049 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [-9819, -9879, -9879], Scale -2
2023-06-24 13:39:41,070 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [11100433, 3823745, 4676627, 3808596, 2270955, 1481208, 693898, 1304384], Scale 0
2023-06-24 13:39:41,071 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[233.71, 234.70000000000002, 233.31], powers=[-2218.0, -2284.0, -2174.0], currents=[-9.8, -10.0, -9.5], power_factors=[-0.9819, -0.9879000000000001, -0.9879000000000001], imported=2270955.0, exported=11100433.0, power=-6677.0, frequency=50.0)
2023-06-24 13:39:41,073 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Wechselrichter']
2023-06-24 13:39:41,094 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [8533], Scale 0
2023-06-24 13:39:41,119 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [16673998], Scale 0
2023-06-24 13:39:41,160 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [1210, 1210, 1209], Scale -2
2023-06-24 13:39:41,180 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [8662], Scale 0
2023-06-24 13:39:41,180 - {modules.common.component_state:95} - {DEBUG:device0} - currents sign wrong [12.1, 12.1, 12.09]
2023-06-24 13:39:41,181 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[12.1, 12.1, 12.09], power=-8533.0, exported=16673998.0, dc_power=-8662.0)
2023-06-24 13:39:41,182 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Speicher']
2023-06-24 13:39:41,229 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1687606771.0618622, power=0.0, imported=19167.69902897311, exported=15535.415914640771)
2023-06-24 13:39:41,229 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00282427, power1: 0, power2: 0
2023-06-24 13:39:41,230 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: 0
2023-06-24 13:39:41,230 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1687606781.2292166, power=0.0, imported=19167.69902897311, exported=15535.415914640771)
2023-06-24 13:39:41,230 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=19167.69902897311, exported=15535.415914640771, power=0.0, soc=100.0)
2023-06-24 13:39:41,233 - {modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SolarEdge Speicher']
2023-06-24 13:39:41,233 - {modules.common.store._api:30} - {INFO:component2} - Saving BatState(imported=19167.69902897311, exported=15535.415914640771, power=0.0, soc=100.0)
2023-06-24 13:39:41,268 - {modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['SolarEdge Wechselrichter']
2023-06-24 13:39:41,269 - {modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-8533.0, exported=16677630.28, dc_power=None)
2023-06-24 13:39:41,270 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-24 13:39:41,270 - {modules.common.store._api:30} - {INFO:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-8533.0, exported=16677630.28, dc_power=None)
2023-06-24 13:39:41,292 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SolarEdge Zähler']
2023-06-24 13:39:41,293 - {modules.common.store._api:30} - {INFO:component0} - Saving CounterState(voltages=[233.71, 234.70000000000002, 233.31], powers=[-2218.0, -2284.0, -2174.0], currents=[-9.8, -10.0, -9.5], power_factors=[-0.9819, -0.9879000000000001, -0.9879000000000001], imported=2270955.0, exported=11100433.0, power=-6677.0, frequency=50.0)
2023-06-24 13:39:41,376 - {control.bat_all:164} - {INFO:MainThread} - -50W verbleibende Speicher-Leistung
2023-06-24 13:39:41,378 - {control.counter:126} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [75.4, 75.49, 75.21000000000001]A
2023-06-24 13:39:41,379 - {control.counter:149} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 53422.479999999996W
2023-06-24 13:39:41,379 - {control.chargepoint:1116} - {INFO:MainThread} - Keine Sperrung durch Autolock, weil keine Zeitpläne konfiguriert sind.
2023-06-24 13:39:41,382 - {control.chargepoint:739} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-06-24 13:39:41,385 - {control.chargepoint:909} - {INFO:MainThread} - LP 3, EV: Mini SE (EV-Nr.2): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.PV_CHARGING, Phasen: 3, Priorität: False, max. Ist-Strom: 2.71
2023-06-24 13:39:41,401 - {control.data:335} - {INFO:MainThread} - bat2
BatData(get=Get(soc=100, daily_exported=2357.22, daily_imported=4015.51, imported=19167.7, exported=15535.42, fault_state=0, fault_str='Kein Fehler.', power=0.0))
2023-06-24 13:39:41,402 - {control.data:305} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=100, daily_exported=2357.22, daily_imported=4015.51, imported=19167.7, exported=15535.42, power=0.0), set=Set(charging_power_left=-50, switch_on_soc_reached=True))
2023-06-24 13:39:41,402 - {control.data:306} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=21710.0, daily_exported=0, power=1745.48, imported=101798.0, exported=0))
2023-06-24 13:39:41,403 - {control.data:335} - {INFO:MainThread} - cp3
ChargepointData(get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=99), currents=[2.6, 2.49, 2.71], daily_imported=21710.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=101798.0, phases_in_use=1, plug_state=True, power=1745.48, rfid_timestamp=None, rfid=None, state_str=None, voltages=[233.83, 234.87, 233.39]), set=Set(change_ev_permitted=[True, ''], charging_ev=2, charging_ev_prev=2, current=7.64, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', imported_at_mode_switch=91538.0, imported_at_plugtime=91538.0, imported_since_mode_switch=10255.0, imported_since_plugged=10255.0, range_charged=60.32352941176471, time_charged='1:41', timestamp_start_charging='06/24/2023, 11:58:11'), manual_lock=False, phases_to_use=3, plug_state_prev=True, plug_time='06/24/2023, 11:56:30', required_power=4140, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x711cbf28>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 1}, ev=2, name='Garage', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-06-24 13:39:41,403 - {control.data:335} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=True, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=32, max_current_single_phase=32, name='Standard Ladepunkt-Vorlage', rfid_enabling=False, valid_tags=[])
2023-06-24 13:39:41,404 - {control.data:335} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[63, 63, 63], max_total_power=45000), get=Get(powers=[-2218.0, -2284.0, -2174.0], currents=[-9.8, -10.0, -9.5], voltages=[233.71, 234.7, 233.31], power_factors=[-0.98, -0.99, -0.99], unbalanced_load=0, frequency=50.0, daily_exported=7097.0, daily_imported=156.0, imported=2270955.0, exported=11100433.0, fault_state=0, fault_str='Kein Fehler.', power=-6677.0), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=53422.479999999996, raw_currents_left=[75.4, 75.49, 75.21000000000001], surplus_power_left=0, state_str=''))
2023-06-24 13:39:41,404 - {control.data:310} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=True), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=110.52000000000044, invalid_home_consumption=0, daily_yield_home_consumption=4357.0, disengageable_smarthome_power=0))
2023-06-24 13:39:41,404 - {control.data:335} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=True, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={'0': ScheduledChargingPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), current=14, name='Zielladen-Standard', limit=ScheduledLimit(selected='amount', amount=1000, soc_limit=90, soc_scheduled=80), time='07:00')}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-06-24 13:39:41,406 - {control.data:335} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=20, battery_capacity=82, nominal_difference=0.5, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-06-24 13:39:41,407 - {control.data:335} - {INFO:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=32, battery_capacity=82, nominal_difference=0.5, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-06-24 13:39:41,408 - {control.data:335} - {INFO:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=32, battery_capacity=82, nominal_difference=0.5, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=0), charge_template=0, ev_template=1, name='BMW iX1', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str=''))
2023-06-24 13:39:41,409 - {control.data:335} - {INFO:MainThread} - ev2
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Mini SE', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=20, battery_capacity=29, nominal_difference=0.5, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=6, required_currents=[6, 6, 6], phases=3, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.PV_CHARGING: 'pv_charging'>, chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None, state=3), charge_template=0, ev_template=2, name='Mini SE', tag_id=[], get=Get(soc=99, soc_timestamp='06/24/2023, 13:37:11', force_soc_update=False, range=188.0, fault_state=0, fault_str='Kein Fehler.'))
2023-06-24 13:39:41,410 - {control.data:335} - {INFO:MainThread} - et0
2023-06-24 13:39:41,411 - {control.data:335} - {INFO:MainThread} - et1
EvTemplateData(name='BMW iX1', max_current_multi_phases=32, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=20, min_current=6, max_current_single_phase=32, battery_capacity=66, nominal_difference=0.5, keep_charge_active_duration=40)
2023-06-24 13:39:41,412 - {control.data:335} - {INFO:MainThread} - et2
EvTemplateData(name='Mini SE', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=20, battery_capacity=29, nominal_difference=1, keep_charge_active_duration=40)
2023-06-24 13:39:41,412 - {control.data:314} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=0, control_range=[-100, -50], feed_in_yield=7000, phase_switch_delay=2, phases_to_use=0, rundown_power=0, rundown_soc=100, switch_off_delay=60, switch_off_soc=0, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=0, switch_on_threshold=1400), scheduled_charging=ScheduledCharging(phases_to_use=0), standby=Standby(phases_to_use=1), stop=Stop(phases_to_use=1), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=20, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-06-24 13:39:41,414 - {control.data:315} - {INFO:MainThread} - general_data-display
local
2023-06-24 13:39:41,416 - {control.data:316} - {INFO:MainThread} - graph_data
2023-06-24 13:39:41,417 - {control.data:317} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x71b5d400>), led=Led(active=False), rfid=Rfid(active=False))
2023-06-24 13:39:41,418 - {control.data:335} - {INFO:MainThread} - pv1
PvData(config=Config(max_ac_out=10000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=34666.29, monthly_exported=0, yearly_exported=0, exported=16677630.28, fault_state=0, fault_str='Kein Fehler.', power=-8533.0))
2023-06-24 13:39:41,419 - {control.data:319} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=34666.29, monthly_exported=0, yearly_exported=0, exported=16677602.28, power=-8628.0))
2023-06-24 13:39:41,420 - {control.data:335} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.0.20', 'current_commit': '2023-06-12 11:59:03 +0200 [8b9a8a116]', 'current_branch': 'master', 'current_branch_commit': '2023-06-23 16:28:23 +0200 [e4756a2ef]', 'current_missing_commits': ['2023-06-23 16:28:23 +0200 [e4756a2ef] - Fix debug formular (#966)', '2023-06-23 16:13:52 +0200 [23d4c1d21] - Merge pull request #965 from openWB/send_debug', '2023-06-23 16:10:57 +0200 [1e100e508] - improve sent debug', '2023-06-23 15:12:06 +0200 [ffb06c13d] - Merge pull request #964 from openWB/web', '2023-06-23 15:10:40 +0200 [2b420e039] - UI', '2023-06-23 14:41:49 +0200 [4eccdb4f6] - Merge pull request #962 from LKuemmel/error_manager', '2023-06-23 14:40:37 +0200 [2665db4a7] - fix default value', '2023-06-23 14:30:42 +0200 [004f2bd64] - Merge pull request #963 from LKuemmel/rfid', '2023-06-23 14:27:05 +0200 [c575e4021] - fix message', '2023-06-23 10:40:18 +0200 [e2ed61231] - refactor chargepoint', '2023-06-22 15:51:46 +0200 [9580872c2] - satellit Duo', '2023-06-21 09:48:08 +0200 [7dfe7f8a0] - Merge pull request #961 from openWB/wiki', '2023-06-21 09:45:56 +0200 [706512119] - Update Wiki-Links', '2023-06-21 08:49:09 +0200 [75818ddfb] - Merge pull request #729 from LKuemmel/configurable_vehicle', '2023-06-21 08:48:00 +0200 [0a1ebeaf8] - fix', '2023-06-21 08:46:48 +0200 [97e1a60d5] - sample vehicle', '2023-06-21 08:24:22 +0200 [5b1d73106] - use configurable_vehicle instead of Device-class', '2023-06-19 16:49:42 +0200 [7acf4aec2] - Merge pull request #960 from LKuemmel/changes_snaptec_repo', "2023-06-19 16:47:34 +0200 [1b555286e] - Merge remote-tracking branch 'openWB/master' into changes_snaptec_repo", '2023-06-19 16:47:08 +0200 [28fcbf181] - Merge pull request #2745 from LKuemmel/fix', '2023-06-19 16:44:54 +0200 [2652566f9] - fix factor of b23', '2023-06-19 16:21:14 +0200 [422bc0dd8] - trigger phase switch explicitly (#954)', '2023-06-19 16:12:25 +0200 [876863325] - Merge pull request #959 from LKuemmel/fix', '2023-06-19 16:06:16 +0200 [98f361fe1] - set default value for nominal_difference to 1A', '2023-06-19 15:45:30 +0200 [288565c72] - Merge pull request #958 from openWB/web', '2023-06-19 15:44:22 +0200 [c8239229f] - UI', '2023-06-19 15:42:51 +0200 [6fc84248d] - Merge pull request #957 from LKuemmel/changes_snaptec_repo', "2023-06-19 15:40:59 +0200 [58830afd3] - Merge remote-tracking branch 'openWB/master' into changes_snaptec_repo", '2023-06-19 15:40:25 +0200 [ddf1510d8] - Merge pull request #2744 from LKuemmel/fix_sungrow_counter', '2023-06-19 15:34:57 +0200 [ac7dd686d] - improve sungrow error handling', '2023-06-19 15:02:47 +0200 [ebb3f17b9] - Merge pull request #956 from LKuemmel/cloud_backup', '2023-06-19 15:01:05 +0200 [293984abb] - UI', '2023-06-19 14:34:58 +0200 [fba53ab89] - Cloud-Backup (#948)', '2023-06-19 14:22:47 +0200 [e1e6c3fe8] - fix duo (#955)', '2023-06-16 12:10:26 +0200 [50bdc8f5b] - Merge pull request #953 from LKuemmel/fix', '2023-06-16 12:07:50 +0200 [5a66a2062] - add reason for phase switch delay stop', '2023-06-16 10:30:19 +0200 [0dd18889d] - Merge pull request #952 from LKuemmel/fix', '2023-06-16 10:28:53 +0200 [dc6e55f79] - pause for evse', '2023-06-15 16:37:17 +0200 [f0467a3e9] - Merge pull request #951 from LKuemmel/fix', '2023-06-15 16:22:31 +0200 [02c9ee316] - Fix: wait for bat_all and pv_all data', '2023-06-15 15:29:29 +0200 [91b5e6b58] - Merge pull request #950 from openWB/web', '2023-06-15 15:28:05 +0200 [1e7fcd1a8] - UI', '2023-06-15 15:13:05 +0200 [1ec1354a5] - Merge pull request #949 from LKuemmel/changes_snaptec_repo', "2023-06-15 15:10:35 +0200 [0ab74bac9] - Merge remote-tracking branch 'openWB/master' into changes_snaptec_repo", '2023-06-15 15:08:45 +0200 [01d9a4ead] - Merge pull request #2693 from MBungalski/feature-sma-data-manager', '2023-06-15 15:07:43 +0200 [0e55c4f10] - Merge pull request #2580 from LKuemmel/batterx', '2023-06-15 15:04:50 +0200 [6bff67106] - review', '2023-06-15 15:02:58 +0200 [124f47e59] - add batterx external inverter', '2023-06-15 15:00:25 +0200 [b19ebfd9d] - Merge pull request #2741 from LKuemmel/smartfox', '2023-06-15 14:56:41 +0200 [5a9b63eac] - fix smartfox', '2023-06-15 14:50:53 +0200 [f7e427952] - Merge pull request #2731 from LKuemmel/sdm120', '2023-06-15 14:49:46 +0200 [6e0d3e7f1] - FIX for colors theme: correct display of chargepoint energy (#2735)', '2023-06-15 14:47:36 +0200 [c5337d729] - Merge pull request #913 from LKuemmel/restructure', '2023-06-15 14:41:24 +0200 [a3ab9589e] - refactor chargepoint', '2023-06-14 14:31:38 +0200 [3c274a4cd] - Merge pull request #945 from MartinRinas/fix_inverter', '2023-06-14 11:02:07 +0200 [da5ebb6d1] - Manual soc (#947)', '2023-06-14 10:15:30 +0200 [1dae2347e] - Merge pull request #946 from LKuemmel/fix', '2023-06-14 10:12:23 +0200 [46ed6a488] - UI', '2023-06-14 08:44:20 +0200 [845064cd9] - fix factor of battery_capacity and average_consump', '2023-06-13 16:20:35 +0000 [3353c83fa] - fix inverter export counter', '2023-06-13 13:59:04 +0200 [e5472aa0a] - Merge pull request #944 from LKuemmel/vzlogger', '2023-06-13 13:57:46 +0200 [91dde778d] - UI', '2023-06-13 13:00:28 +0200 [54d71e9a3] - fix', '2023-06-13 12:20:44 +0200 [681e00aa1] - VZLogger', '2023-06-13 10:41:58 +0200 [e35dbd33b] - Merge pull request #943 from openWB/web', '2023-06-13 10:39:58 +0200 [08dbdb5cb] - Settings for Kostal Steca, FEMS, RCT', '2023-06-13 09:47:49 +0200 [566cd453f] - Merge pull request #942 from LKuemmel/changes_snaptec_repo', "2023-06-13 09:30:18 +0200 [0cce3a971] - Merge remote-tracking branch 'openWB/master' into changes_snaptec_repo", '2023-06-13 09:19:55 +0200 [76d882eb1] - Fems (#2716)', '2023-06-13 09:16:48 +0200 [01cfee651] - Kostal steca (#2729)', '2023-06-13 09:15:58 +0200 [ce7ab95e4] - Rct v2 (#2730)', '2023-06-12 16:19:44 +0200 [e683c1dba] - Smarthome... (#2739)', '2023-05-30 09:59:51 +0200 [7fb12ce42] - SDM120 an openWB LAN Konverter', '2023-04-23 13:04:36 +0200 [71251215f] - Korrektur Unit-ID für "Energiezähler Summe"', '2023-04-18 00:39:31 +0200 [ead77d999] - Added new version in PV Module / SMA ModbusTCP WR: "SMA Cluster Controller/Data Manager". This commit has been tested in live use.'], 'boot_done': True, 'datastore_version': 10, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.RC1.1', 'lastlivevaluesJson': {'timestamp': 1687606771, 'time': '13:39:31', 'grid': -6.792, 'house-power': 0.155, 'charging-all': 1.681, 'pv-all': 8.621, 'cp3-power': 1.681, 'ev2-soc': 99, 'bat-all-power': 0.0, 'bat-all-soc': 100}, 'module_update_completed': True}
2023-06-24 13:39:41,421 - {control.data:348} - {INFO:MainThread} - device0
{'name': 'SolarEdge', 'type': 'solaredge', 'id': 0, 'configuration': {'port': 502, 'ip_address': '192.168.0.19'}}
2023-06-24 13:39:41,424 - {control.data:350} - {INFO:MainThread} - component0
2023-06-24 13:39:41,424 - {control.data:350} - {INFO:MainThread} - component1
2023-06-24 13:39:41,428 - {control.data:350} - {INFO:MainThread} - component2
{'name': 'SolarEdge Speicher', 'type': 'bat', 'id': 2, 'configuration': {'modbus_id': 1}}
2023-06-24 13:39:41,429 - {control.data:322} - {INFO:MainThread} -
2023-06-24 13:39:41,429 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-06-24 13:39:41,430 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-06-24 13:39:41,436 - {control.algorithm.min_current:18} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 0
2023-06-24 13:39:41,437 - {control.counter:157} - {DEBUG:MainThread} - Zähler 0: [69.4, 69.49, 69.21000000000001]A verbleibende Ströme, 49282.479999999996W verbleibende Leistung
2023-06-24 13:39:41,443 - {control.algorithm.common:87} - {INFO:MainThread} - LP3: Stromstärke 6A
2023-06-24 13:39:41,448 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-06-24 13:39:41,454 - {control.counter:199} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 4157.479999999996W
2023-06-24 13:39:41,457 - {control.counter:458} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 4157.479999999996W
2023-06-24 13:39:41,461 - {control.algorithm.algorithm:39} - {INFO:MainThread} - **PV-geführten Strom setzen**
2023-06-24 13:39:41,465 - {control.algorithm.filter_chargepoints:118} - {DEBUG:MainThread} - Geordnete Ladepunkte [3]
2023-06-24 13:39:41,466 - {control.algorithm.surplus_controlled:42} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 0
2023-06-24 13:39:41,466 - {control.loadmanagement:82} - {DEBUG:MainThread} - Leistungsüberschreitung auf 4157.479999999996W korrigieren: [10.0, 10.0, 10.0]
2023-06-24 13:39:41,467 - {control.chargepoint:356} - {INFO:MainThread} - LP 3: Es darf um max 5A über den aktuell genutzten Strom geregelt werden.
2023-06-24 13:39:41,468 - {control.counter:164} - {DEBUG:MainThread} - Zähler 0: [67.69000000000001, 67.78, 67.50000000000001]A verbleibende Ströme, 2977.5799999999963W verbleibender Überschuss
2023-06-24 13:39:41,479 - {control.algorithm.common:87} - {INFO:MainThread} - LP3: Stromstärke 7.71A
2023-06-24 13:39:41,480 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-06-24 13:39:41,483 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 10260.0 counter 101798.0
2023-06-24 13:39:41,490 - {control.chargepoint:654} - {DEBUG:MainThread} - Lp 3: Ladung aktiv halten 40s
2023-06-24 13:39:41,493 - {control.phase_switch:36} - {DEBUG:MainThread} - Thread zur Phasenumschaltung an LP3 gestartet.
2023-06-24 13:39:41,494 - {control.chargepoint:658} - {DEBUG:MainThread} - start phase switch phases_to_use 3control_parameter phases 3
2023-06-24 13:39:41,496 - {control.chargepoint:356} - {INFO:MainThread} - LP 3: Umschaltung von 1 auf 3 Phasen.
2023-06-24 13:39:41,498 - {control.process:115} - {INFO:MainThread} - LP3: set current 0 A, state PERFORMING_PHASE_SWITCH
2023-06-24 13:39:41,505 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-24 13:39:41,534 - {control.counter:174} - {INFO:MainThread} - 13800W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-06-24 13:39:41,787 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-06-24 13:39:41,840 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-24 13:39:45,885 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-06-24 13:39:46,494 - {modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-06-24 13:39:50,899 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
14,025 kWp, SolarEdge Hybrid-WR SE10K-RWS, LG Resu 10
Benny
Beitrag von Benny »
Nachdem es kurz lief ist nun der alte Status wieder da. Kein laden an LP2 möglich.
dboxwal
Beitrag von dboxwal »
Bei Lademodus PV an einem externen Ladepunkt (smartwb mit 3 Phasen) startet die Ladung bereits bei ca. 1500 Watt Überschuss. Unter Ladeeinstellungen - PV-Laden ist bei Eischaltschwelle 1,5 kW pro Phase eingetragen.
Grüße Rudi
Benny
Beitrag von Benny »
Bei der Einstellung "Manueller SoC" werden die eingetragen Werte nicht übernommen.
Bzw. werden nicht immer übernommen? Werden erst nach einiger Zeit übernommen?
b3n
Has thanked: 8 times
Beitrag von b3n »
Bei mir sind bei der Migration auf die 2.0 (master branche aktuellste Version 2023-06-23 16:28:23 +0200 [e4756a2ef]) ein paar Dinge aufgefallen, vielleicht mache hier auch etwas falsch.
1. Was richtig gut ist, ist die Phasendefinition der WB, da man jetzt endlich bei den häufig üblichen geringen PV Leistungen zielgenauer und effizienter auf 3 Phasenladen umschalten kann. Das freut mich sehr und bringt mE gerade bei den doch in der Regel üblichen niedrigen PV Leistungen einen großen Vorteil.
viewtopic.php?p=64857#p64857
2. Die Einspielung einer Sicherung funktioniert leider nicht. Der Log wird eingeladen, die Konfiguration etc. bleibt komplett außen vor. Aber laut Info-Kasten wird da ja noch dran gearbeitet.
3. Wenn ich unter Einstellungen // Konfiguration // Ladepunkte entsprechende WBen anlege bzw. Änderungen vornehme muss ich sehr schnell klicken, sagen wir mal innerhalb von 2 sec auf Speichern drücken da sonst wie von Geisterhand alles auf den Vorzustand zurückgesetzt wird. Das ist jetzt Reproduzierbar auf drei verschiedenen Systemen schon seit einigen Monaten auch auf den vorangegangenen Installationen so. Ich benutze ausschließlich die Pro.
4. Beim Neustart und insbesondere beim Versionsupdate der Standalone "verlieren" die Pro Boxen irgendwie die Verbindung. Die Standalone zeigt keinen Fehler an, die Verbindung steht auch. Soll ein Laden gestartet werden läuft das trotz Freigabe nicht an, an der Pro ist zumindest auch im Web-Menü nichts von einer erteilten Freigabe zu sehen. Das passiert quasi fast immer. Was auch schon mal bei einer Version vor einigen Wochen passiert ist, dass die Standalone eine Ladeleistung der Pro angezeigt und geloggt hat obwohl die gar nicht geladen hat. Das ist mir jetzt aber nur ein Mal passiert. Was geholfen hat war die Pro über den Webbrowser neu zu starten. Dann ging wieder alles normal.
-> Keine Lösung für das Problem aber eine allgemeine Idee wäre es zusätzlich zu dem "Pro Software Aktualisieren" - Button vielleicht noch einen "Pro Restart" Button einzubauen? Dann spart man sich den Umweg über die IP im Browser usw. Ggf. könnte man dann auch noch zukünftig den PWM Status einstellen...
5. Wie ist die End-Benutzer-Bedienung für die Pro Box über die 2.0 in einem Mehrparteiensystem gedacht? Knöpfe, Display oder RFID Reader gibt es ja nicht.
Wie kann ein Nutzer am besten auch nur für seine eigene WB und nicht für die anderen eine Freigabe und die Ladeeinstellungen festlegen? Über das "Display" oder den Browser erwischt man ja gleich alle Boxen.
Das geht wohl mit verschiedenen RFID Tags, die müssen dann aber auch noch über irgendeinen Leser gelesen werden, aber die Tags sind ja statisch und man bräuchte dann ganz schön viele .... Vielleicht hat hier jemand eine Idee oder einen Link im Forum, den ich nicht gefunden habe?[/list][/list]
Been thanked: 89 times
zu 1.
Danke für die positive Rückmeldung.
zu 2., 3., 4.
Kann ich nicht nachvollziehen. Bei unseren laufenden Systemen gibt es kein auffälliges Verhalten in diesen Punkten.
zu 5.
Es wird noch eine komplette Benutzerverwaltung dafür geben, um solche Situationen abbilden zu können. Ebenfalls ist Zusatzhardware für die Pro in Entwicklung, um auch an diesen WB eine Bedienung und Rückmeldung zu ermöglichen.
Beides wird aber nich etwas Zeit brauchen.
seaspotter
Has thanked: 42 times
Been thanked: 33 times
Beitrag von seaspotter »
seaspotter hat geschrieben: Fr Jun 23, 2023 6:22 am
LenaK hat geschrieben: Mo Jun 19, 2023 1:50 pm Ich habe gerade noch die Hilfetexte aus 1.9 nachgeführt. Bitte nochmal in die Texte bei den ? reinschauen. Bei Variante SH muss der LAN-Anschluss des WiNet-S genutzt werden.
Gibt es dazu etwas Neues?
Siehe: viewtopic.php?p=87703#p87703
viewtopic.php?p=87694#p87694
viewtopic.php?p=87707#p87707
Ich finde es schade, dass es seitens des openWB Teams keine Antwort mehr gibt. Es ist offensichtlich das man fälschlicherweise nicht funktionierenden Code für Sungrow Anbindung sowohl in die 2.0 als auch 1.9 Software übernommen hat und jetzt damit gar nichts mehr funktioniert und alle Sungrow Nutzer keine 2.0 testen können. Dabei wäre es einfach die Änderungen rückgängig zu machen und es funktioniert wieder (tut es ja mit der 1.9.300 auch)
Und vom Urheber der Änderungen ist seit über 3 Wochen auch nix mehr zu sehen.
Schade...
15,36 kWp mit Sungrow SH10RT V112 und 12,8kWh SBR128 Speicher und SMA Tripower STP6.0-3AV-40 - 2 mal openWB series2 - IDM Wärmepumpe - Renault Megane E-Tech EV60 und VW Golf8 Hybrid
Elchkopp
Has thanked: 16 times
Been thanked: 37 times
Beitrag von Elchkopp »
Mir ist gestern noch etwas auf der Startseite/Übersichtsseite aufgefallen:
Der Wert in der Spalte „geladen“ wird scheinbar neuerdings bei jedem abziehen des Ladesteckers vom Auto sofort zurück gesetzt. Soweit okay - nur passierte das bei mir auch jedesmal, wenn von 3 auf 1 Phase und zurück geschaltet wurde. Damit ist die Anzeige allerdings fast wertlos, wenn an wolkigen Tagen mehrmals umgeschaltet wird…
Ist das nur bei mir so?
Hab leider gerade keinen Log-Auszug parat, liefere ich aber gerne bei Bedarf einen nach, sobald ich die Möglichkeit dazu habe…
Sascha
steckea
Beitrag von steckea »
Sungrow Anbindung funktioniert unter Release 1.9.300 einwandfrei. Mit RC1 der 2.0 kommen leider keine Daten mehr an.
Bei mir wird das Lan über den WinNet-S verwendet.
Ich werde es nun noch einmal den separaten Lan Anschluss testen und falls es nicht klappt, gehe ich wieder auf die Release Version zurück.
15,01kW Peak mit 3 Strings, 1 x Sungrow SH10RT und 1 X SG5.0RT, openWB series2 custom mit AddOn Platine und RFID
Renault ZOE Bj. 2021 und VW ID5 Bj. 2023
