Einstellungen für Min+PV-Laden werden bei Speichern nicht übernommen
Has thanked: 143 times
Been thanked: 344 times
Re: Einstellungen für Min+PV-Laden werden bei Speichern nicht übernommen
Alle Einstellungen oder nur gewisse?
Was gibt derweil das MQTT Log aus?
PanaMax
Beitrag von PanaMax »
es gibt nur Probleme an den Einstellungen unter Ladeeinstellung, sowie die umschaltung des lademodus oben mittig auf dem home screen...
wo erhalte ich die MQTT Logs?
/var/www/html/openWB/ramdisk/mqtt.log
PanaMax
1
2020-10-06 10:36:45 Topic: openWB/set/ChargeMode
Message: 3
2020-10-06 10:40:03 Topic: openWB/set/ChargeMode
Message: 3
2020-10-06 10:45:02 Topic: openWB/set/ChargeMode
Message: 1
2020-10-06 10:45:02 Topic: openWB/set/system/topicSender
Message: local client uid: pvlyh sent: openWB/set/ChargeMode
2020-10-06 10:45:02 Topic: openWB/config/set/global/maxEVSECurrentAllowed
Message: 16
2020-10-06 10:45:02 Topic: openWB/config/set/pv/lp/1/minSocAlwaysToChargeToCurrent
Message: 6
2020-10-06 10:45:02 Topic: openWB/config/set/pv/minBatteryDischargeSocAtBattPriority
Message: 80
2020-10-06 10:45:02 Topic: openWB/config/set/pv/socStartChargeAtMinPv
Message: 90
2020-10-06 10:50:02 Topic: openWB/set/graph/RequestLiveGraph
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/graph/RequestDayGraph
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/graph/RequestLLiveGraph
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/graph/RequestMonthGraph
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/graph/RequestMonthLadelog
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/RenewMQTT
Message: 0
2020-10-06 10:50:02 Topic: openWB/set/ChargeMode
Message: 3
2020-10-06 10:50:02 Topic: openWB/set/lp/1/AutolockStatus
Message: 0
2020-10-06 10:50:02 Topic: openWB/config/set/SmartHome/Device1/device_manual_control
Message: 1
2020-10-06 10:55:02 Topic: openWB/set/graph/RequestLiveGraph
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/graph/RequestDayGraph
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/graph/RequestLLiveGraph
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/graph/RequestMonthGraph
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/graph/RequestMonthLadelog
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/RenewMQTT
Message: 0
2020-10-06 10:55:02 Topic: openWB/set/lp/1/AutolockStatus
Message: 0
2020-10-06 10:55:02 Topic: openWB/config/set/SmartHome/Device1/device_manual_control
Message: 1
2020-10-06 10:55:02 Topic: openWB/config/set/global/maxEVSECurrentAllowed
Message: 16
2020-10-06 11:00:02 Topic: openWB/set/graph/RequestLiveGraph
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/graph/RequestDayGraph
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/graph/RequestLLiveGraph
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/graph/RequestMonthGraph
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/graph/RequestMonthLadelog
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/RenewMQTT
Message: 0
2020-10-06 11:00:02 Topic: openWB/set/lp/1/AutolockStatus
Message: 0
2020-10-06 11:00:02 Topic: openWB/config/set/SmartHome/Device1/device_manual_control
Message: 1
2020-10-06 11:00:02 Topic: openWB/config/set/global/maxEVSECurrentAllowed
Message: 16
2020-10-06 11:05:02 Topic: openWB/set/graph/RequestLiveGraph
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/graph/RequestDayGraph
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/graph/RequestLLiveGraph
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/graph/RequestMonthGraph
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/graph/RequestMonthLadelog
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/RenewMQTT
Message: 0
2020-10-06 11:05:02 Topic: openWB/set/lp/1/AutolockStatus
Message: 0
2020-10-06 11:05:02 Topic: openWB/config/set/SmartHome/Device1/device_manual_control
Message: 1
2020-10-06 11:05:02 Topic: openWB/config/set/global/maxEVSECurrentAllowed
Message: 16
PanaMax
habe soeben Festgestellt das er die Einstellungen nun doch irgendwann übernommen hat, möchte jetzt aber nichts weiter verstellen zum testen
Komisch ist das +- nur alle 5 Minuten etwas passiert.
Ich vermute da passt etwas an der installation ist, daher läuft die mqttsub nicht durch.
Kannst du mal ein
ps -ef |grep python
machen?
PanaMax
pi@raspberrypi:~ $ ps -ef |grep python
pi 2702 1753 0 12:19 pts/0 00:00:00 grep --color=auto python
pi 18706 1 0 10:40 ? 00:00:25 python3 /var/www/html/openWB/runs/smarthomehandler.py
pi@raspberrypi:~ $
mqttsub.py läuft nicht.
Nun wäre interessant zu wissen warum er nur kurz läuft und sich dann beendet. Scheint irgendwas zu fehlen.
bitte mal händisch starten und prüfen.
Der-Kieler
Has thanked: 7 times
Beitrag von Der-Kieler »
openWBSupport hat geschrieben: Di Okt 06, 2020 10:26 am mqttsub.py läuft nicht.
Wenn ich mal wieder dazwischen reden darf :oops:
Bei mir läuft mqttsub.py genau solange, bis ich den Button "Speicher" in den Ladeeinstellungen anklicke.
Beim erneuten Aufruf ist die Zeile dann weg mit den bekannten Effekten:
Vorher:
pi@Solar-Pi-OWB:~ $ ps -ef |grep python
pi 1520 1 0 10:30 ? 00:00:03 python3 /var/www/html/openWB/runs/mqttsub.py
pi 9576 8037 0 12:36 pts/0 00:00:00 grep --color=auto python
pi 12421 1 0 10:35 ? 00:00:27 python3 /var/www/html/openWB/runs/smarthomehandler.py
pi@Solar-Pi-OWB:~ $
Nachher:
pi 12421 1 0 10:35 ? 00:00:28 python3 /var/www/html/openWB/runs/smarthomehandler.py
pi 23716 21949 0 12:37 pts/0 00:00:00 grep --color=auto python
pi@Solar-Pi-OWB:~ $
Wenn ich dann das openWB Backup wieder einspiele, das ich mit dem aktivierten Button "EV" gemacht habe, ist die Zeile nach einem erneuten reboot wieder da. Es muss also etwas mit den "Speicher" und "EV" Button zu tun haben, in meinen Augen.
Ebenso funktioniert es wieder, wenn ich python3 /var/www/html/openWB/runs/mqttsub.py manuell starte.
welche Fehlermeldung kommt dann wenn händisch aufgerufen wird?
