Very good question. You have to swipe the card again, but there is a trick. I put openwb in direct mode, then swipe the card. The rfid is then accepted. I then put openwb in pv mode. Once that is done, the rfid session remains connected as long as the car is not disconnected. So it can stay on pv mode for several days and I do not need to swipe the rfid. Only when I drive and connect again I need to make sure that either the sun shines or to put it in direct mode for a few seconds when swiping the RFID.Gero hat geschrieben: Do Aug 25, 2022 5:22 am
For me, just one question is left: If there is not enough sun when you swipe your RFID-card loading does not start - ok. But do you have to swipe the card again when there is enough sun or does the keba remember the card and starts loading on itself when the sun shines? (or better: when openWB tells the keba to set charging current to given amperage)
So all in all a solution that works quite well.
