Du hast recht.35 kWh sind es mittlerweile. Ich hatte den Tagesertag dahinter vermutet, aber es ist ja der Gesamtertrag. Die 0.652 kann ich mir auch nicht erklären.
Ich frage mit dem String
http://192.168.178.96/api/livedata/status
ab. Vielleicht liegt da der Fehler. Damit werden mir aber die Werte aus der . txt angezeigt.
Json abfrage PV
Re: Json abfrage PV
13.3 KwP ost-west PV-Anlage
BKW 1.7 KwP 800VA AC
Sungrow SH10RT
BYD HVS 7.7
OpenWB Custom series 2. Release 2.1.7 Patch 1
Kia EV6
Cupra Tavascan Endurance
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
- Has thanked: 11 times
- Been thanked: 46 times
Re: Json abfrage PV
Dann ruf das noch mal ab, was hinter der URL kommt und schreib es hier rein. Besser aber als Code Block oben das </> Icon
Re: Json abfrage PV
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Re: Json abfrage PV
{"inverters":[{"serial":"116484422211","name":"BKW Gartenhaus","order":0,"data_age":0,"poll_enabled":true,"reachable":true,"producing":true,"limit_relative":37.5,"limit_absolute":600,"AC":{"0":{"Power":{"v":29.39999962,"u":"W","d":1},"Voltage":{"v":230.1999969,"u":"V","d":1},"Current":{"v":0.119999997,"u":"A","d":2},"Power DC":{"v":30.80000114,"u":"W","d":1},"YieldDay":{"v":4108,"u":"Wh","d":0},"YieldTotal":{"v":36.10100174,"u":"kWh","d":3},"Frequency":{"v":50,"u":"Hz","d":2},"PowerFactor":{"v":0.999000013,"u":"","d":3},"ReactivePower":{"v":0,"u":"var","d":1},"Efficiency":{"v":95.45453644,"u":"%","d":3}}},"DC":{"0":{"name":{"u":""},"Power":{"v":7.800000191,"u":"W","d":1},"Voltage":{"v":38.90000153,"u":"V","d":1},"Current":{"v":0.200000003,"u":"A","d":2},"YieldDay":{"v":1018,"u":"Wh","d":0},"YieldTotal":{"v":8.272000313,"u":"kWh","d":3},"Irradiation":{"v":1.793103456,"u":"%","d":3}},"1":{"name":{"u":""},"Power":{"v":7.900000095,"u":"W","d":1},"Voltage":{"v":38.40000153,"u":"V","d":1},"Current":{"v":0.200000003,"u":"A","d":2},"YieldDay":{"v":1036,"u":"Wh","d":0},"YieldTotal":{"v":8.734000206,"u":"kWh","d":3},"Irradiation":{"v":1.816092014,"u":"%","d":3}},"2":{"name":{"u":""},"Power":{"v":7.5,"u":"W","d":1},"Voltage":{"v":38.79999924,"u":"V","d":1},"Current":{"v":0.189999998,"u":"A","d":2},"YieldDay":{"v":1020,"u":"Wh","d":0},"YieldTotal":{"v":9.232000351,"u":"kWh","d":3},"Irradiation":{"v":1.724137902,"u":"%","d":3}},"3":{"name":{"u":""},"Power":{"v":7.599999905,"u":"W","d":1},"Voltage":{"v":38.70000076,"u":"V","d":1},"Current":{"v":0.189999998,"u":"A","d":2},"YieldDay":{"v":1034,"u":"Wh","d":0},"YieldTotal":{"v":9.862999916,"u":"kWh","d":3},"Irradiation":{"v":1.74712646,"u":"%","d":3}}},"INV":{"0":{"Temperature":{"v":21.20000076,"u":"°C","d":1}}},"events":1}],"total":{"Power":{"v":29.39999962,"u":"W","d":1},"YieldDay":{"v":4108,"u":"Wh","d":0},"YieldTotal":{"v":36.10100174,"u":"kWh","d":3}},"hints":{"time_sync":false,"radio_problem":false,"default_password":false}}13.3 KwP ost-west PV-Anlage
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Re: Json abfrage PV
Ich habe es hinbekommen, Dank deiner Unterstützung.
Vielen Dank dafür.
Vielen Dank dafür.
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
Sungrow SH10RT
BYD HVS 7.7
Kia EV6
