SoC Modul Hyundai Ioniq PHEV
Ulli268
Re: SoC Modul Hyundai Ioniq PHEV
Beitrag von Ulli268 »
So ich habe ich habe die Kommunikation zwischen App und Server mit geschnitten und folgendes Modul geschrieben.
Ordner: soc_bluelink
main.sh
#!/bin/bash
. /var/www/html/openWB/openwb.conf
soctimer=$(</var/www/html/openWB/ramdisk/soctimer)
soc_bluelink_email='xxx@xxx.xxx'
soc_bluelink_password='xxx'
soc_bluelink_pin='xxxx'
if (( soctimer < 60 )); then
	soctimer=$((soctimer+1))
	echo $soctimer > /var/www/html/openWB/ramdisk/soctimer
else
    re='^-?[0-9]+$'
	soclevel=$(sudo python3 /var/www/html/openWB/modules/soc_bluelink/bluelibksoc.py $soc_bluelink_email $soc_bluelink_password $soc_bluelink_pin)
	if  [[ $soclevel =~ $re ]] ; then
		if (( $soclevel != 0 )) ; then
			echo $soclevel > /var/www/html/openWB/ramdisk/soc
		fi
	fi
    echo 0 > /var/www/html/openWB/ramdisk/soctimer
fi
bluelinksoc.py
import sys
import requests
import uuid
import json
import urllib.parse as urlparse
from urllib.parse import parse_qs
email = str(sys.argv[1])
password = str(sys.argv[2])
pin = str(sys.argv[3])
#vin = str(sys.argv[4])
def main():
    #diviceID
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/notifications/register'
    headers = {
        'ccsp-service-id': '6d477c38-3ca4-4cf3-9557-2a1929a94654',
        'Content-type': 'application/json;charset=UTF-8',
        'Content-Length': '80',
        'Host': 'prd.eu-ccapi.hyundai.com:8080',
        'Connection': 'close',
        'Accept-Encoding': 'gzip, deflate',
        'User-Agent': 'okhttp/3.10.0'}
    data = {"pushRegId":"1","pushType":"GCM","uuid": str(uuid.uuid1())}
    response = requests.post(url, json = data, headers = headers)
    if response.status_code == 200:
        response = json.loads(response.text)
        deviceId = response['resMsg']['deviceId']
        #print(deviceId)
    else:
        print('NOK diviceID')
        return
    #cookie für login
    session = requests.Session()
    response = session.get('https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/authorize?response_type=code&state=test&client_id=6d477c38-3ca4-4cf3-9557-2a1929a94654&redirect_uri=https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/redirect')
        cookies = session.cookies.get_dict()
        #print(cookies)
    else:
        print('NOK cookie für login')
        return
    #login
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin'
    headers = {'Content-type': 'application/json'}
    data = {"email": email,"password": password}
    response = requests.post(url, json = data, headers = headers, cookies = cookies)
        response = response['redirectUrl']
        parsed = urlparse.urlparse(response)
        authCode = ''.join(parse_qs(parsed.query)['code'])
        #print(authCode)
    else:
        print('NOK login')
        return
    #token
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token'
    headers = {
        'Authorization': 'Basic NmQ0NzdjMzgtM2NhNC00Y2YzLTk1NTctMmExOTI5YTk0NjU0OktVeTQ5WHhQekxwTHVvSzB4aEJDNzdXNlZYaG10UVI5aVFobUlGampvWTRJcHhzVg==',
        'Content-type': 'application/x-www-form-urlencoded',
        'Content-Length': '154',
    data = 'grant_type=authorization_code&redirect_uri=https%3A%2F%2Fprd.eu-ccapi.hyundai.com%3A8080%2Fapi%2Fv1%2Fuser%2Foauth2%2Fredirect&code=' + authCode
    response = requests.post(url, data = data, headers = headers)
        access_token = response['token_type'] + ' ' + response['access_token']
        #print(access_token)
    else:
        print('NOK token')
        return
    #vehicles
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles'
    headers = {
        'Authorization': access_token,
        'ccsp-device-id': deviceId,
        'ccsp-application-id': '99cfff84-f4e2-4be8-a5ed-e5b755eb6581',
        'offset': '1',
    response = requests.get(url, headers = headers)
        vehicleId = response['resMsg']['vehicles'][0]['vehicleId']
        #print(vehicleId)
    else:
        print('NOK vehicles')
        return
    #vehicles/profile
    #prewakeup
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles/' + vehicleId + '/control/engine'
    headers = {
        'offset': '1',
        'Content-Type': 'application/json;charset=UTF-8',
        'Content-Length': '72',
    data = {"action":"prewakeup","deviceId": deviceId}
        #print(response.text)
        response = ''
    else:
        print('NOK prewakeup')
        return
    #pin
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/pin'
    headers = {
        'Content-Length': '64',
    data = {"deviceId": deviceId,"pin": pin}
    response = requests.put(url, json = data, headers = headers)
        controlToken = 'Bearer ' + response['controlToken']
        #print(controlToken)
    else:
        print('NOK pin')
        return
    #status
    url = 'https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/' + vehicleId + '/status'
    headers = {
        'Authorization': controlToken,
        'offset': '1',
        soc = response['resMsg']['evStatus']['batteryStatus']
        print(soc)
    else:
        print('NOK status')
        return
if __name__ == '__main__':
    main()
Es ist ziemlich schmutzig, aber funktioniert mit einer Aufrufzeit von ca. 7 sec, solange sich das Auto nicht schlafen gelegt hat, sonst dauert es länger.
Die Login Daten sind aktuell in der main.sh definiert.
Und es wird das erste Auto aus der Server-Liste genommen, da sonst erst die Fahrzeug Profile einzeln geladen werden müssen um sie mit der Vin zu vergleichen und aktuell habe ich nur ein Auto im BlueLink Konto, kann daher nicht testen.
Aktuell wird die Abfrage alle 10 Minuten gestartet, da ich keine Info darüber habe wie oft abgefragt werden darf.
Has thanked: 153 times
Been thanked: 358 times
7 Sekunden ist ziemlich lang.
Idee:
alle 10 Sekunden ramdisk/soc einlesen und alle $intervall die Python triggern mit & am Ende das sie parallel läuft.
die Python dann nach ramdisk/soc schreiben lassen.
Einverstanden?
Ulli268
Ja, Parallel laufen lassen macht sinn.
Ist abgeändert und Ich habe noch ein Parameter hinzugefügt für den Intervall in Minuten.
Parameter für openwb.conf:
soc_bluelink_email
E-Mail Adresse zum BlueLink Konte
Passwort zum BlueLink Konte
soc_bluelink_pin
Pin zum BlueLink Konte
soc_bluelink_interval
Abfrage Intervall in Minuten
Hier die angepassten Dateien:
/var/www/html/openWB/modules/soc_bluelink/main.sh
#!/bin/bash
#soc_bluelink_email='xxx@xxx.xxx'
#soc_bluelink_password='xxx'
#soc_bluelink_pin='xxx'
#soc_bluelink_interval='5'
tmpintervall=$(( soc_bluelink_interval * 6 ))
if (( soctimer < tmpintervall )); then
else
	sudo python3 /var/www/html/openWB/modules/soc_bluelink/bluelibksoc.py $soc_bluelink_email $soc_bluelink_password $soc_bluelink_pin &
fi
/var/www/html/openWB/modules/soc_bluelink/bluelinksoc.py
import sys
import requests
import uuid
import json
def main():
    #diviceID
    headers = {
        #print(deviceId)
    else:
        return
    #cookie für login
        #print(cookies)
    else:
        return
    #login
        #print(authCode)
    else:
        print('NOK login')
        return
    #token
    headers = {
    else:
        print('NOK token')
        return
    #vehicles
    headers = {
        'offset': '1',
        #print(vehicleId)
    else:
        return
    #vehicles/profile
    #prewakeup
    headers = {
        'offset': '1',
        response = ''
    else:
        return
    #pin
    headers = {
    else:
        print('NOK pin')
        return
    #status
    headers = {
        'offset': '1',
        #print(soc)
        f = open('/var/www/html/openWB/ramdisk/soc', 'w')
        f.write(str(soc))
        f.close()
    else:
        print('NOK status')
        return
    main()
In der nightly implementiert, bitte testen!
Pritt500
Beitrag von Pritt500 »
Ich habe es probiert. Bei mir tut sich nichts... Anzeige 0%.
openWB 1.7.306Nightly
OS: Linux 4.19.75-v7+
Pritt500
Habe es gerade noch einmal probiert. Es funktioniert! Danke!
Super, klappt das auch mit Electric?
Pritt500
Hallo Kevin,
nachdem gestern Abend ein Wert im SoC war, dachte ich es funktioniert. Heute hat er aber den ganzen Tag kein update gemacht, obwohl ich denn Akku fast leer gefahren habe. Ich bin mir auch gar nicht sicher, ob der gestern angezeigte Wert tatsächlich vom Ioniq war, zufällig hatte meine Zoe auch genau 91%.
Auf der Ramdisk habe ich nur zoereq und zoereplydateien gefunden, ist das richtig? Oder gibt es extra Dateien für das Bluelinkmodul?
Grüße,
Thomas
foobar123
Beitrag von foobar123 »
Wie kann ich prüfen ob bei mir das Modul richtig funktioniert? In der Modulkonfiguration habe ich alle Werte eingetragen. Bin aber noch neu beim Thema OpenWB. D.h.
1) wo kann ich als Nutzer die Werte sehen? SoC LP1?
2) Wie kann ich Logs mit potentiellen Fehlern finden?
3) Wie könnte ich selbst Verbesserungen einbringen auf meiner WB?
Danke für die Hilfe.
Has thanked: 197 times
Been thanked: 232 times
zu 1)
Die Ist-SoC-Werte werden rechts unter dem Diagramm in der Hauptseite angezeigt.
