Laderungssteuerung
Wikinger
Re: Laderungssteuerung
Beitrag von Wikinger »
Es sieht zwar besser aus, aber leider zu früh gefreut. Der payload-Fehler (am Schluss des Logs) ist noch da...:(
2023-10-17 20:32:00,677 - {root:66} - {INFO:MainThread} - # ***Start***
2023-10-17 20:32:00,723 - {modules.common.component_context:51} - {DEBUG:device0} - Update Komponenten ['SMA Home Manager Zähler']
2023-10-17 20:32:00,725 - {modules.devices.sma_sunny_boy.device:72} - {DEBUG:device1} - Start device reading {'component1': <modules.devices.sma_sunny_boy.inverter.SmaSunnyBoyInverter object at 0x722dc2f8>}
2023-10-17 20:32:00,726 - {modules.devices.sma_sunny_island.device:47} - {DEBUG:device2} - Start device reading {'component2': <modules.devices.sma_sunny_island.bat.SunnyIslandBat object at 0x71a81418>}
2023-10-17 20:32:00,730 - {modules.common.component_context:24} - {DEBUG:set values cp3} - Update Komponente ['Ladepunkt']
2023-10-17 20:32:00,731 - {modules.common.component_context:24} - {DEBUG:device2} - Update Komponente ['SMA Sunny Island Speicher']
2023-10-17 20:32:00,750 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-10-17 20:32:00,785 - {modules.common.store._api:26} - {DEBUG:device2} - Raw data BatState(imported=11736900, exported=8494100, power=-500, soc=72)
2023-10-17 20:32:00,884 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SMA Home Manager Zähler']
2023-10-17 20:32:00,885 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[-1.902, 1.623, 1.064], powers=[-445.9, 297.6, 167.0], voltages=[237.928, 239.002, 237.478], power_factors=[0.991, 0.913, 0.683], imported=17865633.2, exported=28634447.1, power=18.7, frequency=50)
2023-10-17 20:32:00,886 - {modules.devices.sma_shm.device:29} - {DEBUG:device0} - All components updated
2023-10-17 20:32:01,368 - {modules.devices.sma_sunny_boy.inverter:72} - {DEBUG:device1} - WR 192.168.0.XX: InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=58017064, dc_power=4294967296)
2023-10-17 20:32:01,368 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=58017064, dc_power=4294967296)
2023-10-17 20:32:01,372 - {modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-10-17 20:32:01,373 - {modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=58017064, dc_power=None)
2023-10-17 20:32:01,374 - {modules.common.store._api:30} - {INFO:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=58017064, dc_power=None)
2023-10-17 20:32:01,375 - {modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SMA Sunny Island Speicher']
2023-10-17 20:32:01,377 - {modules.common.component_context:24} - {DEBUG:update values cp3} - Update Komponente ['Ladepunkt']
2023-10-17 20:32:01,382 - {modules.common.store._api:30} - {INFO:component2} - Saving BatState(imported=11736900, exported=8494100, power=-500, soc=72)
2023-10-17 20:32:01,417 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SMA Home Manager Zähler']
2023-10-17 20:32:01,418 - {modules.common.store._api:30} - {INFO:component0} - Saving CounterState(currents=[-1.902, 1.623, 1.064], powers=[-445.9, 297.6, 167.0], voltages=[237.928, 239.002, 237.478], power_factors=[0.991, 0.913, 0.683], imported=17865633.2, exported=28634447.1, power=18.7, frequency=50)
2023-10-17 20:32:01,535 - {control.bat_all:153} - {DEBUG:MainThread} - Verbleibende Speicher-Leistung durch maximale Ausgangsleistung auf 550W begrenzt.
2023-10-17 20:32:01,537 - {control.bat_all:192} - {DEBUG:MainThread} - Erlaubte Entlade-Leistung nutzen 550W
2023-10-17 20:32:01,538 - {control.bat_all:164} - {INFO:MainThread} - 550W verbleibende Speicher-Leistung
2023-10-17 20:32:01,542 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [17.92, 14.4, 14.97]A
2023-10-17 20:32:01,544 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 10981.3W
2023-10-17 20:32:01,549 - {control.chargepoint.chargepoint:271} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-10-17 20:32:01,557 - {modules.common.simcount._simcount:38} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1697567511.2662632, power=505.9, imported=13981.463472053461, exported=0)
2023-10-17 20:32:01,560 - {modules.common.simcount._calculate:13} - {DEBUG:MainThread} - time passed: 0.00285873, power1: 505.9, power2: 518.7
2023-10-17 20:32:01,561 - {modules.common.simcount._calculate:29} - {DEBUG:MainThread} - power did not change sign. Total energy: 1.46453
2023-10-17 20:32:01,561 - {modules.common.simcount._simcount:47} - {DEBUG:MainThread} - imported: 1.46453 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1697567521.5576773, power=518.7, imported=13982.927997443378, exported=0)
2023-10-17 20:32:01,564 - {control.data:337} - {INFO:MainThread} - bat2
BatData(get=Get(soc=72, daily_exported=1500, daily_imported=4300, imported=11736900, exported=8494100, fault_state=0, fault_str='Kein Fehler.', power=-500))
2023-10-17 20:32:01,566 - {control.data:307} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=72, daily_exported=1500, daily_imported=4300, imported=11736900, exported=8494100, power=-500), set=Set(charging_power_left=550, switch_on_soc_reached=True))
2023-10-17 20:32:01,567 - {control.data:308} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=770, daily_exported=0, power=0, imported=3936290, exported=0))
2023-10-17 20:32:01,569 - {control.data:337} - {INFO:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.02, 0.02, 0.03], daily_imported=770, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=3936290, phases_in_use=1, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[237.9, 238.8, 237.2]), set=Set(change_ev_permitted=[True, ''], charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x70651fa0>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='Goette', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=3))
2023-10-17 20:32:01,570 - {control.data:337} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=0, max_current_multi_phases=16, max_current_single_phase=16, name='Standard Ladepunkt-Profil', rfid_enabling=False, valid_tags=[])
2023-10-17 20:32:01,574 - {control.data:337} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[16, 16, 16], max_total_power=11000), get=Get(powers=[-445.9, 297.6, 167.0], currents=[-1.9, 1.62, 1.06], voltages=[237.93, 239.0, 237.48], power_factors=[0.99, 0.91, 0.68], unbalanced_load=0, frequency=50, daily_exported=13998.8, daily_imported=3648.099999998, imported=17865633.2, exported=28634447.1, fault_state=0, fault_str='Kein Fehler.', power=18.7), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=10981.3, raw_currents_left=[17.92, 14.4, 14.97], surplus_power_left=0, state_str=''))
2023-10-17 20:32:01,576 - {control.data:312} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=518.7, invalid_home_consumption=0, daily_yield_home_consumption=12339.46944593414, imported_home_consumption=13982.927997443378, disengageable_smarthome_power=0))
2023-10-17 20:32:01,578 - {control.data:337} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Lade-Profil', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, limit=Limit(selected='none', amount=1000, soc=50))))
2023-10-17 20:32:01,581 - {control.data:337} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=1, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', imported_instant_charging=None, imported_at_plan_start=None, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2023-10-17 20:32:01,582 - {control.data:337} - {INFO:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=32, battery_capacity=82000, nominal_difference=1, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, imported_instant_charging=None, imported_at_plan_start=None, current_plan=None, state=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-10-17 20:32:01,585 - {control.data:337} - {INFO:MainThread} - et0
2023-10-17 20:32:01,587 - {control.data:316} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=4500, phase_switch_delay=7, phases_to_use=3, rundown_power=1000, rundown_soc=30, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=200, switch_on_delay=5, switch_on_soc=60, switch_on_threshold=1300), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='primary', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.32, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-10-17 20:32:01,589 - {control.data:317} - {INFO:MainThread} - general_data-display
primary
2023-10-17 20:32:01,591 - {control.data:318} - {INFO:MainThread} - graph_data
2023-10-17 20:32:01,592 - {control.data:319} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=False, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x70663400>), led=Led(active=False), rfid=Rfid(active=False))
2023-10-17 20:32:01,594 - {control.data:337} - {INFO:MainThread} - pv1
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=26023, monthly_exported=0, yearly_exported=0, exported=58017064, fault_state=0, fault_str='Kein Fehler.', power=0))
2023-10-17 20:32:01,595 - {control.data:321} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=26023, monthly_exported=0, yearly_exported=0, exported=58017064, power=0))
2023-10-17 20:32:01,596 - {control.data:337} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.0.XX', 'current_commit': '2023-09-27 10:18:20 +0200 [380ac109e]', 'current_branch': 'Release', 'current_branch_commit': '2023-09-27 10:18:20 +0200 [380ac109e]', 'current_missing_commits': [], 'boot_done': True, 'datastore_version': 21, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.1', 'lastlivevaluesJson': {'timestamp': 1697567511, 'time': '20:31:51', 'grid': 0.006, 'house-power': 0.506, 'charging-all': 0.0, 'pv-all': -0.0, 'cp3-power': 0.0, 'bat-all-power': -0.5, 'bat-all-soc': 72}, 'module_update_completed': True}
2023-10-17 20:32:01,597 - {control.data:350} - {INFO:MainThread} - device0
{'name': 'SMA Home Manager', 'type': 'sma_shm', 'id': 0, 'configuration': {}}
2023-10-17 20:32:01,599 - {control.data:352} - {INFO:MainThread} - component0
{'name': 'SMA Home Manager Zähler', 'type': 'counter', 'id': 0, 'configuration': {'serials': 1234567}}
2023-10-17 20:32:01,600 - {control.data:350} - {INFO:MainThread} - device1
{'name': 'SMA Sunny Boy/Tripower', 'type': 'sma_sunny_boy', 'id': 1, 'configuration': {'ip_address': '192.168.0.XX'}}
2023-10-17 20:32:01,602 - {control.data:352} - {INFO:MainThread} - component1
{'name': 'Sma Sunny Boy/Tripower Wechselrichter', 'type': 'inverter', 'id': 1, 'configuration': {'hybrid': False, 'version': 0}}
2023-10-17 20:32:01,602 - {control.data:350} - {INFO:MainThread} - device2
{'name': 'SMA Sunny Island', 'type': 'sma_sunny_island', 'id': 2, 'configuration': {'ip_address': '192.168.0.xx'}}
2023-10-17 20:32:01,604 - {control.data:352} - {INFO:MainThread} - component2
{'name': 'SMA Sunny Island Speicher', 'type': 'bat', 'id': 2, 'configuration': {}}
2023-10-17 20:32:01,605 - {control.data:324} - {INFO:MainThread} -
2023-10-17 20:32:01,606 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-10-17 20:32:01,608 - {control.algorithm.algorithm:31} - {INFO:MainThread} - **Mindestrom setzen**
2023-10-17 20:32:01,612 - {control.algorithm.algorithm:33} - {INFO:MainThread} - **Sollstrom setzen**
2023-10-17 20:32:01,616 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 646.2999999999993W
2023-10-17 20:32:01,617 - {control.counter:470} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 646.2999999999993W
2023-10-17 20:32:01,619 - {control.algorithm.algorithm:39} - {INFO:MainThread} - **PV-geführten Strom setzen**
2023-10-17 20:32:01,622 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-10-17 20:32:01,629 - {modules.common.component_context:24} - {DEBUG:set current cp3} - Update Komponente ['Ladepunkt']
2023-10-17 20:32:01,654 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-10-17 20:32:01,865 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-10-17 20:32:02,463 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-10-17 20:32:04,324 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-10-17 20:32:05,889 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-10-17 20:32:06,075 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-10-17 20:32:07,900 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-10-17 20:32:09,763 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-10-17 20:32:10,909 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-10-17 20:32:10,912 - {root:66} - {INFO:MainThread} - # ***Start***
Has thanked: 10 times
Been thanked: 147 times
Beitrag von LenaK »
Wikinger hat geschrieben: Di Okt 17, 2023 6:49 pm Es sieht zwar besser aus, aber leider zu früh gefreut. Der payload-Fehler (am Schluss des Logs) ist noch da...:(
primary
Was für ein Zähler ist in Deinem Ladepunkt verbaut?
Der Leistungsfaktor dient nur den Anzeigezwecken im Status, sollte also die Funktion nicht beeinträchtigen. Behoben wird die Fehlermeldung trotzdem.
Wikinger
LenaK hat geschrieben: Mi Okt 18, 2023 7:23 am Was für ein Zähler ist in Deinem Ladepunkt verbaut?
Vielen Dank für die Erläuterung. Der Zähler ist ein Bernecker-Austria MPM3PM.
Leider gerade wieder das Phänomen, des nicht erkannten Fahrzeugs. Nach Neustart des Systems startet die Ladung sofort. Ich habe das Gefühl, dass das Problem meist dann auftritt, wenn das Fahrzeug gewechselt wird. Manchmal funktioniert es aber auch direkt nach einem Wechsel.
Fahrzeuge sind Passat GTE und E-Smart (1-phasig vs. 3-phasig).
Vielleicht gibt's hier noch ne Idee, was ich ausprobieren/prüfen kann.
Elchkopp
Has thanked: 21 times
Been thanked: 70 times
Beitrag von Elchkopp »
Wikinger hat geschrieben: Fr Okt 27, 2023 7:43 am Leider gerade wieder das Phänomen, des nicht erkannten Fahrzeugs. Nach Neustart des Systems startet die Ladung sofort. Ich habe das Gefühl, dass das Problem meist dann auftritt, wenn das Fahrzeug gewechselt wird. Manchmal funktioniert es aber auch direkt nach einem Wechsel.
Wird das Fahrzeug nicht erkannt (also Steckersymbol nicht da) oder startet die Ladung nicht? Und wenn letztes, startet die Ladung nicht seitens der Wallbox oder seitens des Autos?
Wikinger
Elchkopp hat geschrieben: Fr Okt 27, 2023 9:22 am
Meiner Meinung nach wird das Fahrzeug nicht erkannt. Die Meldung lautet in etwa: Keine Ladung, da kein Fahrzeug angesteckt. Ob das Steckersymbol da war, kann ich aktuell nicht sagen, aber ich werde beim nächsten Mal drauf achten.
Wikinger
So, endlich mal daran gedacht, nicht sofot neu zu starten um zu laden und nach dem Steckersymbol geschaut. Wie ich erwartet habe, war es nicht da.
Folgendes Szenario:
Die Nacht von Do auf Fr habe ich den Smart (3-phasig) geladen. Auto genutzt, KEIN weiteres Fahrzeug geladen/NICHTS an der OpenWB umgestellt. Si blieb einfach vollständig ungenutzt. Jetzt grade, Smart wieder angeschlossen - nichts. Abgezogen, Neustartet, angesteckt: Lädt als sei nichts gewesen. Bin wirklich mit meinem Latein am Ende. Neben dem SOC-Python-Error, der evtl. ein Ergebnis einer falschen Einstellung(?) sein könnte, wundern mich weiterhin die negative payload sowie der negative Hausverbrauch. Wenn nicht mit der 1er Version alles jahrelang super funktioniert hätte, würde ich ja einen Installationsfehler vermuten; eventuell liegt auch ein Konfigurationsfehler vor - ich wüsste aber echt nicht wo....
Das main.log ist voll mit diesem Eintrag (ca. alle 1-2 Sekunden), egal ob ein Auto angeschlossen ist oder nicht:
2023-12-08 02:05:38,562 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
Hier dann der Rest der verfügbaren Loginhalte(habe wegen max Zeichen redundante Teile weggelassen):
2023-12-08 01:41:03,775 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 01:41:24,919 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 05:42:18,884 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 05:42:40,851 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 07:18:01,925 - {helpermodules.setdata:339} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/vehicle/0/control_parameter/imported_instant_charging, Payload None darf nicht 'None' sein.
2023-12-08 07:18:01,928 - {helpermodules.setdata:339} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/vehicle/0/control_parameter/imported_at_plan_start, Payload None darf nicht 'None' sein.
2023-12-08 10:18:50,970 - {modules.update_soc:38} - {ERROR:SoC} - Fehler im update_soc-Modul
  File "/var/www/html/openWB/packages/modules/update_soc.py", line 30, in update
    threads_update, threads_store = self._get_threads()
  File "/var/www/html/openWB/packages/modules/update_soc.py", line 43, in _get_threads
    ev_data = copy.deepcopy(data.data.ev_data)
  File "/usr/lib/python3.9/copy.py", line 146, in deepcopy
    y = copier(x, memo)
  File "/usr/lib/python3.9/copy.py", line 229, in _deepcopy_dict
    for key, value in x.items():
RuntimeError: dictionary changed size during iteration
2023-12-08 10:20:03,340 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:20:03,342 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:25:02,903 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:25:02,907 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:30:03,226 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:30:03,231 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:35:03,168 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:35:03,176 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:40:03,726 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:40:03,732 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:45:02,906 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:45:02,911 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:50:02,906 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:50:02,910 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:50:20,260 - {modules.update_soc:38} - {ERROR:SoC} - Fehler im update_soc-Modul
    y = copier(x, memo)
2023-12-08 10:55:03,003 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 10:55:03,013 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 11:00:02,679 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 11:00:02,684 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 11:05:02,660 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 14:50:02,658 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 14:55:02,801 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 14:55:02,805 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 14:59:20,985 - {control.counter_all:101} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -353.29999999999995W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}]
2023-12-08 15:00:03,382 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:00:03,386 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:05:02,748 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:05:02,753 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:10:03,229 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:10:03,234 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:15:03,345 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:15:03,349 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:16:20,803 - {control.counter_all:101} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -59.799999999999955W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}]
2023-12-08 15:20:03,282 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:20:03,293 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:25:03,430 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:25:03,434 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 15:30:03,251 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:20:03,543 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:20:03,551 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:25:02,573 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:25:02,577 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:30:03,476 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:30:03,479 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:35:03,552 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:35:03,556 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:40:03,558 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:40:03,561 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:45:03,237 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:45:03,242 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:50:02,477 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:50:02,481 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:55:03,123 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-08 23:55:03,127 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/get/daily_imported, Payload -4101470 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 00:22:41,195 - {control.counter_all:101} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -504.1999999999998W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}]
2023-12-09 08:23:21,005 - {modules.update_soc:38} - {ERROR:SoC} - Fehler im update_soc-Modul
    y = copier(x, memo)
no factory reset pending, normal startup
atreboot.sh started
checking init in /boot/config.txt...
watchdog for atreboot.sh on pid 352 started, waiting for 900s
already up to date
Group membership...
Final group membership: openwb : openwb adm dialout cdrom sudo audio video plugdev games users input render netdev spi i2c gpio
Network...
Wait for connection...RTNETLINK answers: Network is unreachable
my primary IP: 192.168.XXX.YYY
my primary interface: eth0
running as primary, enabling plug'n'play network
apt configuration already up to date
install required packages with 'apt-get'...
OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
Es wurden 15,0 kB in 4 s geholt (4.271 B/s).
Paketlisten werden gelesen…
Abhängigkeitsbaum wird aufgebaut…
Statusinformationen werden eingelesen…
accountsservice ist schon die neueste Version (0.6.55-3).
apache2 ist schon die neueste Version (2.4.56-1~deb11u2).
bc ist schon die neueste Version (1.07.1-2+b1).
chromium ist schon die neueste Version (106.0.5249.119-1~deb11u1).
chromium-l10n ist schon die neueste Version (106.0.5249.119-1~deb11u1).
git ist schon die neueste Version (1:2.30.2-1+deb11u2).
jq ist schon die neueste Version (1.6-2.1).
libapache2-mod-php ist schon die neueste Version (2:7.4+76).
lightdm-autologin-greeter ist schon die neueste Version (1.0-3).
mmc-utils ist schon die neueste Version (0+git20180327.b4fe0c8c-1).
mosquitto ist schon die neueste Version (2.0.11-1+deb11u1).
mosquitto-clients ist schon die neueste Version (2.0.11-1+deb11u1).
openbox-lxde-session ist schon die neueste Version (0.99.2-4).
php-curl ist schon die neueste Version (2:7.4+76).
php-gd ist schon die neueste Version (2:7.4+76).
php-json ist schon die neueste Version (2:7.4+76).
php-xml ist schon die neueste Version (2:7.4+76).
socat ist schon die neueste Version (1.7.4.1-3).
sshpass ist schon die neueste Version (1.09-1).
ssl-cert ist schon die neueste Version (1.1.0+nmu1).
sudo ist schon die neueste Version (1.9.5p2-3+deb11u1).
vim ist schon die neueste Version (2:8.2.2434-3+deb11u1).
x11-xserver-utils ist schon die neueste Version (7.7+8).
xserver-xorg ist schon die neueste Version (1:7.7+22).
lightdm ist schon die neueste Version (1.26.0-7+rpt1).
python3-pip ist schon die neueste Version (20.3.4-4+rpt1+deb11u1).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 11 nicht aktualisiert.
done
openwb.cron already up to date
openwb2.service already up to date
openwbRemoteSupport.service already up to date
no restore pending, normal startup
cleaning obsolete python cache folders...
python cache cleanup done
display setup...
autologin configured
mouse cursor configured
lxde session autostart already configured
apache default site...
...ok
checking required apache modules...
headers (enabled by site administrator)
headers already enabled
ssl (enabled by site administrator)
ssl already enabled
proxy_wstunnel (enabled by site administrator)
proxy_wstunnel already enabled
check mosquitto installation...
mosquitto.conf already up to date
mosquitto openwb.conf already up to date
mosquitto_local.conf already up to date
mosquitto openwb_local.conf already up to date
mosquitto done
install required python packages with 'pip3'...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: jq==1.1.3 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 1)) (1.1.3)
Requirement already satisfied: paho_mqtt==1.6.1 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 2)) (1.6.1)
Requirement already satisfied: pymodbus==2.5.2 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 3)) (2.5.2)
Requirement already satisfied: pytest==6.2.5 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 4)) (6.2.5)
Requirement already satisfied: requests_mock==1.9.3 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 5)) (1.9.3)
Requirement already satisfied: lxml==4.9.1 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 6)) (4.9.1)
Requirement already satisfied: aiohttp==3.7.4 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 7)) (3.7.4)
Requirement already satisfied: schedule==1.1.0 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 8)) (1.1.0)
Requirement already satisfied: PyJWT==2.6.0 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 9)) (2.6.0)
Requirement already satisfied: ipparser==0.3.8 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 10)) (0.3.8)
Requirement already satisfied: bs4==0.0.1 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 11)) (0.0.1)
Requirement already satisfied: pkce==1.0.3 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 12)) (1.0.3)
Requirement already satisfied: evdev==1.5.0 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 14)) (1.5.0)
Requirement already satisfied: python-dateutil==2.8.2 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 16)) (2.8.2)
Requirement already satisfied: yarl<2.0,>=1.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (1.8.1)
Requirement already satisfied: typing-extensions>=3.6.5 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (4.4.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (3.0.1)
Requirement already satisfied: chardet<4.0,>=2.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (3.0.4)
Requirement already satisfied: multidict<7.0,>=4.5 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (6.0.2)
Requirement already satisfied: attrs>=17.3.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (22.1.0)
Requirement already satisfied: beautifulsoup4 in /home/openwb/.local/lib/python3.9/site-packages (from bs4==0.0.1->-r /var/www/html/openWB/requirements.txt (line 11)) (4.11.1)
Requirement already satisfied: dnspython in /home/openwb/.local/lib/python3.9/site-packages (from ipparser==0.3.8->-r /var/www/html/openWB/requirements.txt (line 10)) (2.3.0)
Requirement already satisfied: pyserial>=3.4 in /home/openwb/.local/lib/python3.9/site-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (3.5)
Requirement already satisfied: six>=1.15.0 in /usr/lib/python3/dist-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (1.16.0)
Requirement already satisfied: iniconfig in /home/openwb/.local/lib/python3.9/site-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.1.1)
Requirement already satisfied: toml in /usr/lib/python3/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (0.10.1)
Requirement already satisfied: py>=1.8.2 in /home/openwb/.local/lib/python3.9/site-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.11.0)
Requirement already satisfied: pluggy<2.0,>=0.12 in /home/openwb/.local/lib/python3.9/site-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.0.0)
Requirement already satisfied: packaging in /home/openwb/.local/lib/python3.9/site-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (21.3)
Requirement already satisfied: requests<3,>=2.3 in /usr/lib/python3/dist-packages (from requests_mock==1.9.3->-r /var/www/html/openWB/requirements.txt (line 5)) (2.25.1)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp==3.7.4->-r /var/www/html/openWB/requirements.txt (line 7)) (2.10)
Requirement already satisfied: soupsieve>1.2 in /home/openwb/.local/lib/python3.9/site-packages (from beautifulsoup4->bs4==0.0.1->-r /var/www/html/openWB/requirements.txt (line 11)) (2.3.2.post1)
Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in /home/openwb/.local/lib/python3.9/site-packages (from packaging->pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (3.0.9)
done
load versions...
chgrp: Zugriff auf '/var/www/html/openWB/data/restore/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
chgrp: Zugriff auf '/var/www/html/openWB/data/data_migration/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Zugriff auf '/var/www/html/openWB/data/restore/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Zugriff auf '/var/www/html/openWB/data/data_migration/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
2023-12-09 09:22:35: boot done :-)
2023-12-09 09:22:38,023 - {root:154} - {DEBUG:MainThread} - Start openWB2.service
2023-12-09 09:22:38,024 - {helpermodules.update_config:451} - {DEBUG:MainThread} - Broker-Konfiguration aktualisieren
2023-12-09 09:22:39,438 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/system/time
2023-12-09 09:22:39,446 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/3/set/plug_state_prev
2023-12-09 09:22:39,455 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/3/get/powers
2023-12-09 09:22:39,458 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/3/get/frequency
2023-12-09 09:22:39,460 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/3/get/power_factors
2023-12-09 09:22:39,474 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/counter/0/set/error_counter
2023-12-09 09:22:39,477 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/counter/0/set/reserved_surplus
2023-12-09 09:22:39,480 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/counter/0/set/released_surplus
2023-12-09 09:22:39,511 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/vehicle/set/vehicle_update_completed
2023-12-09 09:22:39,573 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/command_completed
2023-12-09 09:22:39,576 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_b359bd2f/messages/1702110053658
2023-12-09 09:22:39,594 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/fault_str
2023-12-09 09:22:39,597 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/fault_state
2023-12-09 09:22:39,600 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/voltages
2023-12-09 09:22:39,603 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/currents
2023-12-09 09:22:39,606 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/imported
2023-12-09 09:22:39,610 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/exported
2023-12-09 09:22:39,613 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/power
2023-12-09 09:22:39,616 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/phases_in_use
2023-12-09 09:22:39,619 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/charge_state
2023-12-09 09:22:39,622 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/plug_state
2023-12-09 09:22:39,626 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/internal_chargepoint/0/get/power_factors
2023-12-09 09:22:39,630 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/isss/heartbeat
2023-12-09 09:22:39,633 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/isss/parentWB
2023-12-09 09:22:39,636 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/isss/parentCPlp1
2023-12-09 09:22:39,638 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/isss/Current
2023-12-09 09:22:39,641 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/LegacySmartHome/Status/maxspeicherladung
2023-12-09 09:22:39,644 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/LegacySmartHome/Status/wattnichtschalt
2023-12-09 09:22:39,647 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/LegacySmartHome/Status/wattnichtHaus
2023-12-09 09:22:39,650 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/LegacySmartHome/Status/uberschuss
2023-12-09 09:22:39,653 - {helpermodules.update_config:482} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/LegacySmartHome/Status/uberschussoffset
2023-12-09 09:22:46,245 - {modules.internal_chargepoint_handler.rfid:24} - {DEBUG:MainThread} - Input-Event event0 nicht gefunden.
2023-12-09 09:22:46,245 - {modules.internal_chargepoint_handler.rfid:24} - {DEBUG:MainThread} - Input-Event event1 nicht gefunden.
2023-12-09 09:22:48,519 - {helpermodules.subdata:428} - {DEBUG:Subdata} - Neustart des Handlers für den internen Ladepunkt.
2023-12-09 09:22:49,787 - {helpermodules.subdata:779} - {DEBUG:Subdata} - Neustart des Handlers für den internen Ladepunkt.
2023-12-09 09:22:54,497 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:22:54,609 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:22:56,379 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:22:58,188 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:00,005 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:01,855 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:03,544 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:05,377 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:07,202 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:08,994 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:10,816 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:10,865 - {control.chargepoint.chargepoint:612} - {ERROR:MainThread} - Phasenumschaltung an Ladepunkt3 nicht möglich, da der Ladepunkt keine Phasenumschaltung unterstützt.
2023-12-09 09:23:12,690 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:14,645 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:16,443 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:18,299 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:20,089 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:21,898 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:21,984 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:23,915 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:23,995 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 100.0 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:25,773 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 96.1 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:25,856 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 96.1 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:27,631 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.8 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:27,701 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.8 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:29,477 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:29,563 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:31,353 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:31,471 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:33,212 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:33,282 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:35,075 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:36,929 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:36,984 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:38,733 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:38,775 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:40,537 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:40,596 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:42,391 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:44,364 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:44,445 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:46,219 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:46,302 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.7 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:48,091 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:48,138 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:49,930 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:51,787 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:53,612 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:53,687 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:55,511 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:55,597 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:57,387 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:23:59,225 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:01,052 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:02,823 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:04,695 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:06,528 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:08,349 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:10,107 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:11,955 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:11,997 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:13,782 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:15,627 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:15,681 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:17,473 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:19,273 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:21,087 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:22,944 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:24,784 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:26,645 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:28,444 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:30,248 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:30,299 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:32,088 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:33,920 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:33,949 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:35,736 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:35,809 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:37,548 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:37,624 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:39,359 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:39,433 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:41,254 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:41,298 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:43,064 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:44,902 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:44,963 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:46,698 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:48,501 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:48,585 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:50,377 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:50,421 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:52,193 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:54,003 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:54,077 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:55,817 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:55,893 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:57,663 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:24:59,527 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:01,395 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:03,203 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:05,000 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:05,083 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:06,848 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:06,929 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:08,701 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:08,783 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:10,556 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:10,619 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:12,396 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:12,466 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:14,247 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:16,056 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:17,909 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:19,750 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:21,599 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:23,436 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:23,511 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.6 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:25,262 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:25,345 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:27,146 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
2023-12-09 09:25:29,002 - {helpermodules.setdata:330} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/internal_chargepoint/0/get/power_factors, Payload 99.4 liegt in keinem der angegebenen Wertebereiche.
Wikinger
Re: Laderungssteuerung
Beitrag von Wikinger »
Nachdem ich einen Konfigurationsfehler beim Energy Meter behoben habe (deutlich zu wenig Leistung konfiguriert) lief das System erstmal einige Tage ohne Probleme. Nun ist aber leider wieder ein Fehler aufgetreten, der sich auf die EVSE bezieht:
2023-12-30 08:46:37,363 - {modules.internal_chargepoint_handler.chargepoint_module:113} - {ERROR:Internal Chargepoint} - Anhaltender Fehler beim Auslesen von EVSE und/oder Zähler. Lade- und Stecker-Status werden zurückgesetzt.
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 90, in __read_registers
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 62, in get_values
    powers, power = self.__client.meter_client.get_power()
  File "/var/www/html/openWB/packages/modules/common/mpm3pm.py", line 23, in get_power
    powers = [val / 100 for val in self.client.read_input_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 143, in read_input_registers
    return self.__read_registers(self.delegate.read_input_registers, address, types, byteorder, wordorder, **kwargs)
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 105, in __read_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] No Response received from the remote unit/Unable to decode response', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
2023-12-30 08:46:37,403 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr Anhaltender Fehler beim Auslesen von EVSE und/oder Zähler. Lade- und Stecker-Status werden zurückgesetzt., Traceback:
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 242, in update
    state = self.module.get_values(phase_switch_cp_active, rfid_data.last_tag)[0]
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 122, in get_values
    raise FaultState.error(msg)
modules.common.fault_state.FaultState: ('Anhaltender Fehler beim Auslesen von EVSE und/oder Zähler. Lade- und Stecker-Status werden zurückgesetzt.', <FaultStateLevel.ERROR: 2>)
Ein reboot hat den Fehler "behoben", aber es geht weiter mit:
2023-12-30 09:02:17,194 - {asyncio:59} - {DEBUG:Internal Chargepoint} - Using selector: EpollSelector
2023-12-30 09:02:19,284 - {modules.internal_chargepoint_handler.clients:143} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-12-30 09:02:19,437 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:02:19,440 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-12-30 09:02:19,503 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID: 5
2023-12-30 09:02:19,658 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:02:19,865 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:02:21,900 - {modules.internal_chargepoint_handler.clients:143} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-12-30 09:02:22,050 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:02:22,051 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-12-30 09:02:22,113 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID: 5
2023-12-30 09:02:22,266 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:02:22,481 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:08:13,456 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2023-12-30 09:08:13,527 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr modules.internal_chargepoint_handler.chargepoint_module <class 'modules.common.fault_state.FaultState'> ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 80, in get_values
    plug_state, charge_state, self.set_current_evse = self.__client.evse_client.get_plug_charge_state()
  File "/var/www/html/openWB/packages/modules/common/evse.py", line 39, in get_plug_charge_state
    set_current, _, state_number = self.client.read_holding_registers(
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 123, in read_holding_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 125, in get_values
    raise FaultState.error(__name__ + " " + str(type(e)) + " " + str(e)) from e
modules.common.fault_state.FaultState: ('modules.internal_chargepoint_handler.chargepoint_module <class \'modules.common.fault_state.FaultState\'> ("modules.common.modbus <class \'modules.common.fault_state.FaultState\'> (\'modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)\', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)', <FaultStateLevel.ERROR: 2>)
Has thanked: 10 times
Been thanked: 147 times
Beitrag von LenaK »
Wenn der Fehler sporadisch auftritt, beeinträchtigt dieser die Funktion nicht und wird im Laufe der nächsten Updates behoben.
Wikinger
Hallo und vielen Dank für die Hilfe.
Sporadisch ist in diesem Fall relativ. Der Fehler taucht eigentlich immer relativ schnell wieder auf. Ich habe nun einmal den Ladepunkt gelöscht, einen reboot gemacht und während der Neuerstellung des Ladepunkts einen tail -f ramdisk/internal_chargepoint.log gemacht. Schon beim Anlegen tritt der Fehler auf:
2024-01-14 13:50:08,934 - {asyncio:59} - {DEBUG:Internal Chargepoint} - Using selector: EpollSelector
2024-01-14 13:51:20,447 - {modules.internal_chargepoint_handler.clients:143} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2024-01-14 13:51:20,598 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2024-01-14 13:51:20,600 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2024-01-14 13:51:20,675 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID: 5
2024-01-14 13:51:20,834 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2024-01-14 13:51:21,042 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2024-01-14 13:51:23,072 - {modules.internal_chargepoint_handler.clients:143} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2024-01-14 13:51:23,224 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2024-01-14 13:51:23,227 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2024-01-14 13:51:23,290 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID: 5
2024-01-14 13:51:23,445 - {modules.common.evse:57} - {DEBUG:Internal Chargepoint} - FW-Version: 12
2024-01-14 13:51:24,463 - {modules.common.fault_state:55} - {ERROR:Internal Chargepoint} - Interner Ladepunkt 0: FaultState FaultStateLevel.ERROR, FaultStr <class 'Exception'> Der Zähler konnte nicht ausgelesen werden. Vermutlich ist der Zähler falsch konfiguriert oder defekt.  Bitte nehme über die Support-Funktion in den Einstellungen Kontakt mit uns auf., Traceback:
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 153, in __init__
    self.cp0_client_handler = client_factory(0)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/clients.py", line 168, in client_factory
    return ClientHandler(local_charge_point_num, serial_client, evse_ids)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/clients.py", line 39, in __init__
    self.check_hardware()
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/clients.py", line 92, in check_hardware
    raise Exception(meter_error_msg)
Exception: Der Zähler konnte nicht ausgelesen werden. Vermutlich ist der Zähler falsch konfiguriert oder defekt.  Bitte nehme über die Support-Funktion in den Einstellungen Kontakt mit uns auf.
2024-01-14 13:51:24,466 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:296} - {ERROR:Internal Chargepoint} - Fehler im internem Ladepunkt
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 292, in handler
    self.internal_chargepoint_handler.loop()
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 193, in loop
    with SingleComponentUpdateContext(self.cp0.module.component_info):
AttributeError: 'InternalChargepointHandler' object has no attribute 'cp0'
Fahrzeug lädt nicht. Nach Neustart fängt das Fahzeug sofort an zu laden. Version 2024-01-03 12:21:20 +0100 [06bcf54f9]
Beitrag von LenaK »
Bei Hardware-Problemen bitte ein Support-Ticket erstellen.
