Seite 2 von 3
Re: Umstieg von 1.9 auf 2.0 inkl. Anlagenausbau
Verfasst: Do Jun 06, 2024 5:05 pm
von wb-2020
Danke für die schnelle Rückmeldung. Im Log habe ich folgendes gefunden. Ich weiß aber nicht, ob das der zum Problem passende Bereich ist.
2024-06-06 15:33:17,079 - {pymodbus.client.sync:218} - {ERROR:Subdata} - Connection to (None, 8899) failed: [Errno 111] Connection refused
2024-06-06 15:33:17,086 - {modules.common.fault_state:49} - {ERROR:Subdata} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr <class 'pymodbus.exceptions.ConnectionException'> ('Failed to connect[ModbusTcpClient(None:8899)]', 'Modbus-Client konnte keine Verbindung zu None:8899 aufbauen. Bitte Einstellungen, IP-Adresse und Port sowie Netzwerk-Anschluss prüfen.'), Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/openwb_series2_satellit/chargepoint_module.py", line 41, in __init__
    self._create_client()
  File "/var/www/html/openWB/packages/modules/chargepoints/openwb_series2_satellit/chargepoint_module.py", line 51, in _create_client
    self._client = ClientHandler(
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/clients.py", line 40, in __init__
    self.evse_client = self._evse_factory(client, evse_ids)
  File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/clients.py", line 49, in _evse_factory
    with client:
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 65, in __enter__
    raise e
  File "/var/www/html/openWB/packages/modules/common/modbus.py", line 61, in __enter__
    self._delegate.__enter__()
  File "/home/openwb/.local/lib/python3.9/site-packages/pymodbus/client/sync.py", line 120, in __enter__
pymodbus.exceptions.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(None:8899)]
2024-06-06 15:33:20,090 - {pymodbus.client.sync:218} - {ERROR:set values cp5} - Connection to (None, 8899) failed: [Errno 111] Connection refused
2024-06-06 15:33:20,107 - {modules.common.fault_state:49} - {ERROR:set values cp5} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr <class 'pymodbus.exceptions.ConnectionException'> ('Failed to connect[ModbusTcpClient(None:8899)]', 'Modbus-Client konnte keine Verbindung zu None:8899 aufbauen. Bitte Einstellungen, IP-Adresse und Port sowie Netzwerk-Anschluss prüfen.'), Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/openwb_series2_satellit/chargepoint_module.py", line 105, in get_values
    with client:
    raise e
Der letzte Block wiederholt sich dann immer.
Ich hänge auch noch den Status der Satellit an, den die Primary anzeigt.
Auf dem Aufkleber der Box habe ich gesehen, dass das Produktionsdatum der 10.10.23 ist. Ist dann vielleicht noch die 1.9-Software installiert? Und könnte ich das nachsehen?
An anderen Stellen im Forum habe ich gelesen, dass ein Update der Satellit über die Primary möglich ist. Das finde ich aber nicht. Gilt dann vermutlich für die 1.9-Version und nicht für 2.x, oder?
Verfasst: Do Jun 06, 2024 5:13 pm
von rleidner
Der nächste Schritt steht im Log:
Verfasst: Do Jun 06, 2024 5:59 pm
von wb-2020
rleidner hat geschrieben: Do Jun 06, 2024 5:13 pm Der nächste Schritt steht im Log:
Gibt es noch Einstellungen, die ich nicht gefunden habe?
Ich sehe in der Ladepunkt-Konfiguration nur die IP-Adresse, die ich eintragen kann. Einen Port sehe ich dort nicht.
Der Netzwerkanschluss sollte funktionieren. Die Box wird in meiner Fritz!Box angezeigt und auch der Status den die Primary für die Satellit anzeigt sieht für mich so aus, dass die Kommunikation zumindest grundlegend vorhanden ist.
Meine laienhafte Vermutung wäre, dass die Satellit vielleicht nur ein Software-Update braucht. Aber dazu finde ich bisher keine Informationen.
Verfasst: Do Jun 06, 2024 6:26 pm
von rleidner
wb-2020 hat geschrieben: Do Jun 06, 2024 5:59 pm
Statt der IP-Adresse steht im Log None.
Da scheint also etwas nicht zu passen.
Poste doch mal einen Screenshot der Ladepunkt-Einstellung.
Verfasst: Do Jun 06, 2024 6:46 pm
von wb-2020
Ah. Stimmt!
Die Konfiguration des Ladepunkts und die Fritz!Box-Infos habe ich angehängt.
Verfasst: Do Jun 06, 2024 7:27 pm
von rleidner
Sieht OK aus - mehr fällt mir dazu nicht ein.
Ich würde mich an den support wenden.
Verfasst: Do Jun 06, 2024 8:25 pm
von wb-2020
Danke!
Das mache ich dann auch.
Verfasst: Do Jun 06, 2024 8:51 pm
von wb-2020
Es scheint doch noch ein längerer Weg zu sein, bis alles korrekt funktioniert.
Die Einstellungen der SolarEdge-Komponenten scheinen noch nicht zu passen. Der Wechselrichter zeigt eine PV-Leistung an, obwohl es dunkel ist ... Die Leistung gleich fast exakt der Leistung, die zeitgleich dem Speicher entnommen wird.
Ich habe Screenshots von allen Einstellungen, die mir relevant erscheinen angehängt. Über einen Tipp würde ich mich freuen!
Hier nochmal meine Geräte:
Wechselrichter SE 8KRWB + SE Speicher + Backupmodul
openWB series2 standard+ mit Software 2.1.4
2x Solarmax-Wechselrichter, die über das http-PV-Modul eingebunden sind.
Verfasst: Do Jun 06, 2024 8:54 pm
von wb-2020
Hier noch die SolarEdge-Einstellungen.
Verfasst: Fr Jun 07, 2024 12:05 am
von ChristophR
Bei meinem RWS Wechselrichter von Solaredge muss der Speicher im Lastmanagement in den WR geschoben werden (Hybrid), wie in Deinen ersten Beispielen in Struktur 2.
Nachts habe ich dann eine negative PV Produktion, die dem Verbrauch des WR entspricht, so lange aus dem Speicher geliefert wird.
Wenn der Speicher leer ist, geht der WR in den Standby und dann ist die PV-Produktion auch Nachts 0.
PS: Wie viel kWp hast Du eigentlich an Deinem Solaredge WR? Du hast heute exakt die Gleiche Produktion wie bei mir, allerdings habe ich sehr starke Verschattung auf meiner Anlage.
