System - Fehlersuche
Protokollierung
Debug Level
Achtung! In den Einstellungen "Info" und "Details" können in den Logdateien sensible Daten wie Benutzernamen und Kennwörter enthalten sein. Diese sollten vor dem Veröffentlichen z.B. im Forum unkenntlich gemacht werden. Private IP-Adressen (z.B. 192.168.x.x) müssen nicht maskiert werden, da diese nicht über das Internet erreichbar sind.
Main-Log
-- noch nicht geladen --
Log des internen Ladepunktes
MQTT-Log
2023-07-11 13:54:55,992 - Topic: openWB/vehicle/0/name, Payload: "Standard-Fahrzeug"
2023-07-11 13:54:56,000 - Topic: openWB/vehicle/0/charge_template, Payload: 0
2023-07-11 13:54:56,001 - Topic: openWB/vehicle/0/soc_module/config, Payload: {"type": null, "configuration": {}}
2023-07-11 13:54:56,002 - Topic: openWB/vehicle/0/soc_module/interval_config, Payload: {"request_interval_charging": 5, "request_interval_not_charging": 720, "request_only_plugged": false}
2023-07-11 13:54:56,002 - Topic: openWB/vehicle/0/ev_template, Payload: 0
2023-07-11 13:54:56,003 - Topic: openWB/vehicle/0/tag_id, Payload: []
2023-07-11 13:54:56,004 - Topic: openWB/vehicle/0/get/soc, Payload: 0
2023-07-11 13:54:56,005 - Topic: openWB/vehicle/0/control_parameter/state, Payload: 0
2023-07-11 13:54:56,006 - Topic: openWB/vehicle/template/ev_template/0, Payload: {"name": "Standard-Fahrzeug-Vorlage", "max_current_multi_phases": 16, "max_phases": 3, "phase_switch_pause": 2, "prevent_phase_switch": false, "prevent_charge_stop": false, "control_pilot_interruption": false, "control_pilot_interruption_duration": 4, "average_consump": 17000, "min_current": 6, "max_current_single_phase": 16, "battery_capacity": 82000, "nominal_difference": 0.5, "keep_charge_active_duration": 40}
2023-07-11 13:54:56,008 - Topic: openWB/vehicle/template/ev_template/1, Payload: {"name": "Enyaq", "max_current_multi_phases": 16, "max_phases": 3, "phase_switch_pause": 2, "prevent_phase_switch": false, "prevent_charge_stop": false, "control_pilot_interruption": false, "control_pilot_interruption_duration": 4, "average_consump": 17000, "min_current": 6, "max_current_single_phase": 16, "battery_capacity": 82000, "nominal_difference": 1, "keep_charge_active_duration": 40}
2023-07-11 13:54:56,010 - Topic: openWB/vehicle/template/charge_template/0, Payload: {"name": "Standard-Ladeprofil-Vorlage", "disable_after_unplug": false, "prio": false, "load_default": false, "time_charging": {"active": false}, "chargemode": {"selected": "stop", "pv_charging": {"min_soc_current": 6, "min_current": 6, "feed_in_limit": false, "min_soc": 50, "max_soc": 80}, "scheduled_charging": {}, "instant_charging": {"current": 16, "limit": {"selected": "soc", "amount": 1000, "soc": 80}}}}
2023-07-11 13:54:56,016 - Topic: openWB/vehicle/1/charge_template, Payload: 0
2023-07-11 13:54:56,017 - Topic: openWB/vehicle/1/ev_template, Payload: 0
2023-07-11 13:54:56,018 - Topic: openWB/vehicle/1/name, Payload: "Enyaq"
2023-07-11 13:54:56,019 - Topic: openWB/vehicle/1/tag_id, Payload: []
2023-07-11 13:54:56,020 - Topic: openWB/vehicle/1/get/soc, Payload: 0.0
2023-07-11 13:54:56,021 - Topic: openWB/vehicle/1/get/soc_timestamp, Payload: "07/11/2023, 12:41:41"
2023-07-11 13:54:56,021 - Topic: openWB/vehicle/1/get/fault_str, Payload: "Kein Fehler."
2023-07-11 13:54:56,022 - Topic: openWB/vehicle/1/get/fault_state, Payload: 0
2023-07-11 13:54:56,023 - Topic: openWB/vehicle/1/soc_module/config, Payload: {"name": "Manueller SoC", "type": "manual", "configuration": {"efficiency": 0.9, "soc_start": 0}}
2023-07-11 13:54:56,025 - Topic: openWB/vehicle/1/soc_module/interval_config, Payload: {"request_interval_charging": 5, "request_interval_not_charging": 720, "request_only_plugged": false}
2023-07-11 13:54:56,027 - Topic: openWB/vehicle/1/control_parameter/state, Payload: 0
2023-07-11 13:54:56,028 - Topic: openWB/vehicle/1/set/soc_error_counter, Payload: 0
2023-07-11 13:54:56,028 - Topic: openWB/chargepoint/get/power, Payload: 0
2023-07-11 13:54:56,030 - Topic: openWB/chargepoint/get/imported, Payload: 0
2023-07-11 13:54:56,031 - Topic: openWB/chargepoint/get/exported, Payload: 0
2023-07-11 13:54:56,031 - Topic: openWB/chargepoint/get/daily_imported, Payload: 0
2023-07-11 13:54:56,032 - Topic: openWB/chargepoint/get/daily_exported, Payload: 0
2023-07-11 13:54:56,033 - Topic: openWB/chargepoint/template/0, Payload: {"autolock": {"active": false, "wait_for_charging_end": false}, "id": 0, "max_current_multi_phases": 16, "max_current_single_phase": 16, "name": "Standard Ladepunkt-Vorlage", "rfid_enabling": false, "valid_tags": []}
2023-07-11 13:54:56,035 - Topic: openWB/pv/get/daily_exported, Payload: 0
2023-07-11 13:54:56,038 - Topic: openWB/pv/get/monthly_exported, Payload: 0
2023-07-11 13:54:56,039 - Topic: openWB/pv/get/yearly_exported, Payload: 0
2023-07-11 13:54:56,039 - Topic: openWB/pv/get/exported, Payload: 0
2023-07-11 13:54:56,040 - Topic: openWB/pv/get/power, Payload: 0
2023-07-11 13:54:56,041 - Topic: openWB/pv/config/configured, Payload: true
2023-07-11 13:54:56,042 - Topic: openWB/pv/13/config/max_ac_out, Payload: 4000
2023-07-11 13:54:56,043 - Topic: openWB/pv/13/get/currents, Payload: [0.0, 0.0, 0.0]
2023-07-11 13:54:56,045 - Topic: openWB/pv/13/get/daily_exported, Payload: 0
2023-07-11 13:54:56,046 - Topic: openWB/pv/13/get/monthly_exported, Payload: 0
2023-07-11 13:54:56,046 - Topic: openWB/pv/13/get/yearly_exported, Payload: 0
2023-07-11 13:54:56,047 - Topic: openWB/pv/13/get/exported, Payload: 0
2023-07-11 13:54:56,048 - Topic: openWB/pv/13/get/fault_state, Payload: 0
2023-07-11 13:54:56,049 - Topic: openWB/pv/13/get/power, Payload: 0
2023-07-11 13:54:56,049 - Topic: openWB/bat/get/soc, Payload: 100
2023-07-11 13:54:56,052 - Topic: openWB/bat/get/daily_exported, Payload: 2300
2023-07-11 13:54:56,052 - Topic: openWB/bat/get/daily_imported, Payload: 5800
2023-07-11 13:54:56,053 - Topic: openWB/bat/get/imported, Payload: 10674500
2023-07-11 13:54:56,054 - Topic: openWB/bat/get/exported, Payload: 8396000
2023-07-11 13:54:56,055 - Topic: openWB/bat/get/power, Payload: 20
2023-07-11 13:54:56,055 - Topic: openWB/bat/config/configured, Payload: true
2023-07-11 13:54:56,057 - Topic: openWB/bat/set/charging_power_left, Payload: -50
2023-07-11 13:54:56,058 - Topic: openWB/bat/set/switch_on_soc_reached, Payload: true
2023-07-11 13:54:56,059 - Topic: openWB/bat/10/get/power, Payload: 20
2023-07-11 13:54:56,061 - Topic: openWB/bat/10/get/fault_str, Payload: "Kein Fehler."
2023-07-11 13:54:56,062 - Topic: openWB/bat/10/get/fault_state, Payload: 0
2023-07-11 13:54:56,063 - Topic: openWB/bat/10/get/soc, Payload: 100
2023-07-11 13:54:56,063 - Topic: openWB/bat/10/get/imported, Payload: 10674500
2023-07-11 13:54:56,064 - Topic: openWB/bat/10/get/exported, Payload: 8396000
2023-07-11 13:54:56,065 - Topic: openWB/bat/10/get/daily_imported, Payload: 5800
2023-07-11 13:54:56,066 - Topic: openWB/bat/10/get/daily_exported, Payload: 2300
2023-07-11 13:54:56,067 - Topic: openWB/general/chargemode_config/instant_charging/phases_to_use, Payload: 3
2023-07-11 13:54:56,071 - Topic: openWB/general/chargemode_config/pv_charging/bat_prio, Payload: true
2023-07-11 13:54:56,072 - Topic: openWB/general/chargemode_config/pv_charging/switch_on_soc, Payload: 95
2023-07-11 13:54:56,073 - Topic: openWB/general/chargemode_config/pv_charging/switch_off_soc, Payload: 90
2023-07-11 13:54:56,074 - Topic: openWB/general/chargemode_config/pv_charging/rundown_power, Payload: 0
2023-07-11 13:54:56,074 - Topic: openWB/general/chargemode_config/pv_charging/rundown_soc, Payload: 100
2023-07-11 13:54:56,075 - Topic: openWB/general/chargemode_config/pv_charging/charging_power_reserve, Payload: 200
2023-07-11 13:54:56,076 - Topic: openWB/general/chargemode_config/pv_charging/control_range, Payload: [-230, 0]
2023-07-11 13:54:56,077 - Topic: openWB/general/chargemode_config/pv_charging/switch_off_threshold, Payload: 50
2023-07-11 13:54:56,077 - Topic: openWB/general/chargemode_config/pv_charging/switch_off_delay, Payload: 60
2023-07-11 13:54:56,078 - Topic: openWB/general/chargemode_config/pv_charging/switch_on_delay, Payload: 30
2023-07-11 13:54:56,079 - Topic: openWB/general/chargemode_config/pv_charging/switch_on_threshold, Payload: 1500
2023-07-11 13:54:56,080 - Topic: openWB/general/chargemode_config/pv_charging/feed_in_yield, Payload: 1000
2023-07-11 13:54:56,080 - Topic: openWB/general/chargemode_config/pv_charging/phase_switch_delay, Payload: 4
2023-07-11 13:54:56,081 - Topic: openWB/general/chargemode_config/pv_charging/phases_to_use, Payload: 0
2023-07-11 13:54:56,082 - Topic: openWB/general/chargemode_config/scheduled_charging/phases_to_use, Payload: 0
2023-07-11 13:54:56,084 - Topic: openWB/general/chargemode_config/time_charging/phases_to_use, Payload: 3
2023-07-11 13:54:56,086 - Topic: openWB/general/chargemode_config/unbalanced_load, Payload: true
2023-07-11 13:54:56,087 - Topic: openWB/general/chargemode_config/unbalanced_load_limit, Payload: 18
2023-07-11 13:54:56,088 - Topic: openWB/general/control_interval, Payload: 10
2023-07-11 13:54:56,089 - Topic: openWB/general/extern, Payload: false
2023-07-11 13:54:56,090 - Topic: openWB/general/extern_display_mode, Payload: "local"
2023-07-11 13:54:56,091 - Topic: openWB/general/external_buttons_hw, Payload: false
2023-07-11 13:54:56,091 - Topic: openWB/general/grid_protection_configured, Payload: true
2023-07-11 13:54:56,092 - Topic: openWB/general/notifications/selected, Payload: "none"
2023-07-11 13:54:56,093 - Topic: openWB/general/notifications/plug, Payload: false
2023-07-11 13:54:56,094 - Topic: openWB/general/notifications/start_charging, Payload: false
2023-07-11 13:54:56,094 - Topic: openWB/general/notifications/stop_charging, Payload: false
2023-07-11 13:54:56,095 - Topic: openWB/general/notifications/smart_home, Payload: false
2023-07-11 13:54:56,096 - Topic: openWB/general/notifications/configuration, Payload: {}
2023-07-11 13:54:56,097 - Topic: openWB/general/price_kwh, Payload: 0.3
2023-07-11 13:54:56,098 - Topic: openWB/general/range_unit, Payload: "km"
2023-07-11 13:54:56,098 - Topic: openWB/general/ripple_control_receiver/configured, Payload: false
2023-07-11 13:54:56,099 - Topic: openWB/graph/config/duration, Payload: 120
2023-07-11 13:54:56,100 - Topic: openWB/graph/lastlivevaluesJson, Payload: {"timestamp": 1689076420, "time": "13:53:40", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:54:56,101 - Topic: openWB/graph/alllivevaluesJson1, Payload: {"timestamp": 1689076361, "time": "13:52:41", "grid": -2.488, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
{"timestamp": 1689076370, "time": "13:52:50", "grid": -2.505, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
{"timestamp": 1689076380, "time": "13:53:00", "grid": -2.51, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
{"timestamp": 1689076390, "time": "13:53:10", "grid": -2.52, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
{"timestamp": 1689076401, "time": "13:53:21", "grid": -2.513, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
{"timestamp": 1689076410, "time": "13:53:30", "grid": -2.519, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:54:56,102 - Topic: openWB/graph/alllivevaluesJson, Payload: {"timestamp": 1689076361, "time": "13:52:41", "grid": -2.488, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:54:56,102 - Topic: openWB/graph/alllivevaluesJson2, Payload: -
2023-07-11 13:54:56,103 - Topic: openWB/graph/alllivevaluesJson3, Payload: -
2023-07-11 13:54:56,104 - Topic: openWB/graph/alllivevaluesJson4, Payload: -
2023-07-11 13:54:56,104 - Topic: openWB/graph/alllivevaluesJson8, Payload: -
2023-07-11 13:54:56,105 - Topic: openWB/graph/alllivevaluesJson6, Payload: -
2023-07-11 13:54:56,105 - Topic: openWB/graph/alllivevaluesJson5, Payload: -
2023-07-11 13:54:56,106 - Topic: openWB/graph/alllivevaluesJson7, Payload: -
2023-07-11 13:54:56,106 - Topic: openWB/graph/alllivevaluesJson10, Payload: -
2023-07-11 13:54:56,107 - Topic: openWB/graph/alllivevaluesJson13, Payload: -
2023-07-11 13:54:56,107 - Topic: openWB/graph/alllivevaluesJson14, Payload: -
2023-07-11 13:54:56,108 - Topic: openWB/graph/alllivevaluesJson16, Payload: -
2023-07-11 13:54:56,108 - Topic: openWB/graph/alllivevaluesJson12, Payload: -
2023-07-11 13:54:56,109 - Topic: openWB/graph/alllivevaluesJson9, Payload: -
2023-07-11 13:54:56,110 - Topic: openWB/graph/alllivevaluesJson11, Payload: -
2023-07-11 13:54:56,110 - Topic: openWB/graph/alllivevaluesJson15, Payload: -
2023-07-11 13:54:56,111 - Topic: openWB/optional/et/active, Payload: false
2023-07-11 13:54:56,115 - Topic: openWB/optional/et/config/max_price, Payload: 0
2023-07-11 13:54:56,116 - Topic: openWB/optional/et/config/provider, Payload: {}
2023-07-11 13:54:56,116 - Topic: openWB/optional/int_display/active, Payload: true
2023-07-11 13:54:56,815 - Topic: openWB/optional/int_display/on_if_plugged_in, Payload: true
2023-07-11 13:54:56,817 - Topic: openWB/optional/int_display/pin_active, Payload: false
2023-07-11 13:54:56,819 - Topic: openWB/optional/int_display/pin_code, Payload: "0000"
2023-07-11 13:54:56,821 - Topic: openWB/optional/int_display/standby, Payload: 120
2023-07-11 13:54:57,602 - Topic: openWB/optional/int_display/rotation, Payload: 180
2023-07-11 13:54:58,324 - Topic: openWB/optional/int_display/theme, Payload: {"name": "Cards", "type": "cards", "configuration": {"lock_changes": false, "lock_changes_code": null, "enable_dashboard_view": true, "enable_dashboard_card_grid": true, "enable_dashboard_card_home_consumption": true, "enable_dashboard_card_battery_sum": true, "enable_dashboard_card_inverter_sum": true, "enable_dashboard_card_charge_point_sum": true, "enable_charge_points_view": true, "enable_status_view": true}}
2023-07-11 13:54:58,325 - Topic: openWB/optional/led/active, Payload: false
2023-07-11 13:54:58,326 - Topic: openWB/optional/rfid/active, Payload: true
2023-07-11 13:54:58,327 - Topic: openWB/counter/get/hierarchy, Payload: [{"id": 6, "type": "counter", "children": [{"id": 13, "type": "inverter", "children": []}, {"id": 10, "type": "bat", "children": []}]}]
2023-07-11 13:54:58,329 - Topic: openWB/counter/config/reserve_for_not_charging, Payload: false
2023-07-11 13:54:58,330 - Topic: openWB/counter/set/invalid_home_consumption, Payload: 3
2023-07-11 13:54:58,332 - Topic: openWB/counter/set/home_consumption, Payload: 0
2023-07-11 13:54:58,333 - Topic: openWB/counter/set/disengageable_smarthome_power, Payload: 0
2023-07-11 13:54:58,334 - Topic: openWB/counter/set/daily_yield_home_consumption, Payload: 3.8000000010001713
2023-07-11 13:54:58,335 - Topic: openWB/counter/6/config/max_currents, Payload: [32, 32, 32]
2023-07-11 13:54:58,338 - Topic: openWB/counter/6/config/max_total_power, Payload: 28000
2023-07-11 13:54:58,339 - Topic: openWB/counter/6/get/currents, Payload: [-15.17, 0.96, 3.92]
2023-07-11 13:54:58,340 - Topic: openWB/counter/6/get/voltages, Payload: [246.06, 240.41, 243.47]
2023-07-11 13:54:58,341 - Topic: openWB/counter/6/get/power_factors, Payload: [0.96, 1.0, 0.99]
2023-07-11 13:54:58,342 - Topic: openWB/counter/6/get/frequency, Payload: 50.006
2023-07-11 13:54:58,343 - Topic: openWB/counter/6/get/daily_exported, Payload: 4123.400000001
2023-07-11 13:54:58,344 - Topic: openWB/counter/6/get/daily_imported, Payload: 38.9
2023-07-11 13:54:58,346 - Topic: openWB/counter/6/get/imported, Payload: 10762321.6
2023-07-11 13:54:58,347 - Topic: openWB/counter/6/get/exported, Payload: 11054093.2
2023-07-11 13:54:58,348 - Topic: openWB/counter/6/get/fault_state, Payload: 1
2023-07-11 13:54:58,349 - Topic: openWB/counter/6/get/power, Payload: -2526.2
2023-07-11 13:54:58,350 - Topic: openWB/counter/6/get/fault_str, Payload: "Der Wert f\u00fcr den Hausverbrauch ist nicht plausibel (negativ). Bitte die Leistungen der Komponenten und die Anordnung in der Hierarchie pr\u00fcfen."
2023-07-11 13:54:58,351 - Topic: openWB/counter/6/get/powers, Payload: [-3578.7, 172.1, 880.3]
2023-07-11 13:54:58,352 - Topic: openWB/system/ip_address, Payload: "192.168.178.xx"
2023-07-11 13:54:58,356 - Topic: openWB/system/current_commit, Payload: "2023-07-06 18:28:52 +0200 [db321f5ab]"
2023-07-11 13:54:58,357 - Topic: openWB/system/available_branches, Payload: {
"feature-web-themes": {
"commit": "2023-07-07 08:45:27 +0200 [47a1e5fb5]",
"tags": {
"1.99.002": "1.99.002: Alpha 2",
"1.99.003": "1.99.003: Alpha 3",
"1.99.004": "1.99.004: Alpha 4",
"1.99.100": "1.99.100: Beta 1",
"1.99.100.1": "1.99.100.1: Beta.2-RC1",
"1.99.101.0": "1.99.101.0: Beta 2",
"1.99.102.0": "1.99.102.0: Beta 3",
"1.99.103.0": "1.99.103.0: Beta 4",
"1.99.RC1.0": "1.99.RC1.0: Release Candidate 1",
"1.99.RC2.0": "1.99.RC2.0: Release Candidate 2"
"feature-mercedeseq": {
"commit": "2023-07-07 07:36:14 +0200 [8b6a3f8ab]",
"tags": {
"Release": {
"commit": "2023-07-06 16:23:59 +0200 [d264fa5e7]",
"tags": {
"master": {
"commit": "2023-07-06 18:28:52 +0200 [db321f5ab]",
"tags": {
"Beta": {
"commit": "2023-06-30 14:21:30 +0200 [ba9587142]",
"tags": {
2023-07-11 13:54:58,357 - Topic: openWB/system/current_branch, Payload: "master"
2023-07-11 13:54:58,358 - Topic: openWB/system/current_branch_commit, Payload: "2023-07-06 18:28:52 +0200 [db321f5ab]"
2023-07-11 13:54:58,359 - Topic: openWB/system/current_missing_commits, Payload: []
2023-07-11 13:54:58,360 - Topic: openWB/system/update_in_progress, Payload: false
2023-07-11 13:54:58,361 - Topic: openWB/system/boot_done, Payload: true
2023-07-11 13:54:58,362 - Topic: openWB/system/datastore_version, Payload: 16
2023-07-11 13:54:58,363 - Topic: openWB/system/dataprotection_acknowledged, Payload: true
2023-07-11 13:54:58,364 - Topic: openWB/system/debug_level, Payload: 10
2023-07-11 13:54:58,366 - Topic: openWB/system/release_train, Payload: "master"
2023-07-11 13:54:58,367 - Topic: openWB/system/version, Payload: "2.0.0"
2023-07-11 13:54:58,368 - Topic: openWB/system/lastlivevaluesJson, Payload: {"timestamp": 1689076420, "time": "13:53:40", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:54:58,369 - Topic: openWB/system/usage_terms_acknowledged, Payload: true
2023-07-11 13:54:58,370 - Topic: openWB/system/subdata_initialized, Payload: true
2023-07-11 13:54:58,372 - Topic: openWB/system/backup_cloud/config, Payload: {"type": null, "configuration": {}}
2023-07-11 13:54:58,374 - Topic: openWB/system/device/module_update_completed, Payload: true
2023-07-11 13:54:58,376 - Topic: openWB/system/mqtt/bridge/0, Payload: {"name": "openWBCloud", "active": true, "remote": {"is_openwb_cloud": true, "username": "xxxxxxxxxx", "password": "xxxxxxxxxxxxxxxx ", "client_id": "openWB", "host": "web.openwb.de", "port": 1883, "prefix": "xxxxxxxxxx/", "protocol": "mqttv311", "tls_version": "auto", "try_private": true}, "data_transfer": {"status": true, "graph": true, "configuration": true}, "access": {"partner": false}}
2023-07-11 13:54:58,387 - Topic: openWB/set/system/version, Payload: 2.0.0
2023-07-11 13:54:58,390 - Topic: openWB/set/system/configurable/backup_clouds, Payload: [{'value': None, 'text': 'keine Backup-Cloud', 'defaults': {'type': None, 'configuration': {}}}, {'value': 'nextcloud', 'text': 'NextCloud', 'defaults': {'name': 'NextCloud', 'type': 'nextcloud', 'configuration': {'ip_address': None, 'user': None, 'password': None}}}]
2023-07-11 13:54:58,393 - Topic: openWB/set/system/configurable/display_themes, Payload: [{'value': 'cards', 'text': 'Cards', 'defaults': {'name': 'Cards', 'type': 'cards', 'configuration': {'lock_changes': False, 'lock_changes_code': None, 'enable_dashboard_view': True, 'enable_dashboard_card_grid': True, 'enable_dashboard_card_home_consumption': True, 'enable_dashboard_card_battery_sum': True, 'enable_dashboard_card_inverter_sum': True, 'enable_dashboard_card_charge_point_sum': True, 'enable_charge_points_view': True, 'enable_status_view': True}}}]
2023-07-11 13:54:58,396 - Topic: openWB/set/system/configurable/soc_modules, Payload: [{'value': 'bmw', 'text': 'BMW', 'defaults': {'name': 'BMW', 'type': 'bmw', 'configuration': {'user_id': None, 'password': None, 'vin': None}}}, {'value': 'evnotify', 'text': 'EVNotify', 'defaults': {'name': 'EVNotify', 'type': 'evnotify', 'configuration': {'id': 0, 'akey': '', 'token': ''}}}, {'value': 'http', 'text': 'HTTP SOC Module', 'defaults': {'name': 'HTTP SOC Module', 'type': 'http', 'configuration': {'soc_url': None, 'range_url': None}}}, {'value': None, 'text': 'kein Modul', 'defaults': {'type': None, 'configuration': {}}}, {'value': 'manual', 'text': 'Manueller SoC', 'defaults': {'name': 'Manueller SoC', 'type': 'manual', 'configuration': {'efficiency': 0.9, 'soc_start': 0}}}, {'value': 'mqtt', 'text': 'mqtt', 'defaults': {'name': 'mqtt', 'type': 'mqtt', 'id': 0, 'configuration': {}}}, {'value': 'psa', 'text': 'PSA', 'defaults': {'name': 'PSA', 'type': 'psa', 'configuration': {'user_id': None, 'password': None, 'client_id': None, 'client_secret': None, 'manufacturer': None, 'calculate_soc': False, 'vin': None}}}, {'value': 'renault', 'text': 'Renault', 'defaults': {'name': 'Renault', 'type': 'renault', 'configuration': {'user_id': None, 'password': None, 'country': None, 'vin': None}}}, {'value': 'smarteq', 'text': 'SmartEQ', 'defaults': {'name': 'SmartEQ', 'type': 'smarteq', 'configuration': {'user_id': None, 'password': None, 'vin': None}}}, {'value': 'tesla', 'text': 'Tesla', 'defaults': {'name': 'Tesla', 'type': 'tesla', 'configuration': {'tesla_ev_num': 0, 'token': {'refresh_token': '', 'access_token': '', 'expires_in': 0, 'created_at': 0}}}}, {'value': 'vwid', 'text': 'VWId', 'defaults': {'name': 'VWId', 'type': 'vwid', 'configuration': {'user_id': None, 'password': None, 'vin': None, 'refreshToken': None}}}]
2023-07-11 13:54:58,404 - Topic: openWB/set/system/configurable/devices_components, Payload: [{'value': 'alpha_ess', 'text': 'Alpha ESS', 'component': [{'value': 'bat', 'text': 'Alpha ESS Speicher'}, {'value': 'counter', 'text': 'Alpha ESS Zähler'}, {'value': 'inverter', 'text': 'Alpha ESS Wechselrichter'}]}, {'value': 'batterx', 'text': 'BatterX', 'component': [{'value': 'bat', 'text': 'BatterX Speicher'}, {'value': 'counter', 'text': 'BatterX Zähler'}, {'value': 'inverter', 'text': 'BatterX Wechselrichter'}, {'value': 'external_inverter', 'text': 'BatterX externer Wechselrichter'}]}, {'value': 'byd', 'text': 'BYD', 'component': [{'value': 'bat', 'text': 'BYD Speicher'}]}, {'value': 'carlo_gavazzi', 'text': 'Carlo Gavazzi', 'component': [{'value': 'counter', 'text': 'Carlo Gavazzi Zähler'}]}, {'value': 'discovergy', 'text': 'Discovergy', 'component': [{'value': 'counter', 'text': 'Discovergy Zähler'}, {'value': 'inverter', 'text': 'Discovergy Wechselrichter'}]}, {'value': 'e3dc', 'text': 'E3DC', 'component': [{'value': 'bat', 'text': 'E3DC Speicher'}, {'value': 'counter', 'text': 'E3DC Zähler'}, {'value': 'inverter', 'text': 'E3DC Wechselrichter'}, {'value': 'external_inverter', 'text': 'E3DC externer Wechselrichter'}]}, {'value': 'enphase', 'text': 'Enphase', 'component': [{'value': 'counter', 'text': 'Enphase Zähler'}, {'value': 'inverter', 'text': 'Enphase Wechselrichter'}]}, {'value': 'openwb_evu_kit', 'text': 'EVU-Kit', 'component': [{'value': 'bat', 'text': 'Speicher-Zähler an EVU-Kit'}, {'value': 'counter', 'text': 'EVU-Kit'}, {'value': 'inverter', 'text': 'PV-Zähler an EVU-Kit'}]}, {'value': 'fronius', 'text': 'Fronius', 'component': [{'value': 'bat', 'text': 'Fronius Speicher'}, {'value': 'counter_sm', 'text': 'Fronius SM Zähler'}, {'value': 'counter_s0', 'text': 'Fronius S0 Zähler'}, {'value': 'inverter', 'text': 'Fronius Wechselrichter'}]}, {'value': 'good_we', 'text': 'GoodWe', 'component': [{'value': 'bat', 'text': 'GoodWe Speicher'}, {'value': 'counter', 'text': 'GoodWe Zähler'}, {'value': 'inverter', 'text': 'GoodWe Wechselrichter'}]}, {'value': 'http', 'text': 'HTTP', 'component': [{'value': 'bat', 'text': 'HTTP Speicher'}, {'value': 'counter', 'text': 'HTTP Zähler'}, {'value': 'inverter', 'text': 'HTTP Wechselrichter'}]}, {'value': 'huawei', 'text': 'Huawei', 'component': [{'value': 'bat', 'text': 'Huawei Speicher'}, {'value': 'counter', 'text': 'Huawei Zähler'}, {'value': 'inverter', 'text': 'Huawei Wechselrichter'}]}, {'value': 'janitza', 'text': 'Janitza', 'component': [{'value': 'counter', 'text': 'Janitza Zähler'}]}, {'value': 'json', 'text': 'Json', 'component': [{'value': 'bat', 'text': 'Json Speicher'}, {'value': 'counter', 'text': 'Json Zähler'}, {'value': 'inverter', 'text': 'Json Wechselrichter'}]}, {'value': 'kostal_piko', 'text': 'Kostal Piko', 'component': [{'value': 'counter', 'text': 'Kostal Piko Zähler'}, {'value': 'inverter', 'text': 'Kostal Piko Wechselrichter'}]}, {'value': 'kostal_steca', 'text': 'Kostal Piko MP oder Steca Grid Coolcept', 'component': [{'value': 'inverter', 'text': 'Kostal Piko MP oder Steca Grid Coolcept Wechselrichter'}]}, {'value': 'kostal_plenticore', 'text': 'Kostal Plenticore', 'component': [{'value': 'bat', 'text': 'Kostal Plenticore Speicher'}, {'value': 'counter', 'text': 'Kostal Plenticore Zähler'}, {'value': 'inverter', 'text': 'Kostal Plenticore Wechselrichter'}]}, {'value': 'kostal_sem', 'text': 'Kostal Smart Energy Meter oder TQ EM 410', 'component': [{'value': 'counter', 'text': 'Kostal Smart Energy Meter oder TQ EM 410 Zähler'}]}, {'value': 'lg', 'text': 'LG ESS V1.0', 'component': [{'value': 'bat', 'text': 'LG ESS V1.0 Speicher'}, {'value': 'counter', 'text': 'LG ESS V1.0 Zähler'}, {'value': 'inverter', 'text': 'LG ESS V1.0 Wechselrichter'}]}, {'value': 'mqtt', 'text': 'MQTT', 'component': [{'value': 'bat', 'text': 'MQTT-Speicher'}, {'value': 'counter', 'text': 'MQTT-Zähler'}, {'value': 'inverter', 'text': 'MQTT-Wechselrichter'}]}, {'value': 'fems', 'text': 'openEMS, Fenecon FEMS, Kaco Hy-Control', 'component': [{'value': 'bat', 'text': 'openEMS, Fenecon FEMS, Kaco Hy-Control Speicher'}, {'value': 'counter', 'text': 'openEMS, Fenecon FEMS, Kaco Hy-Control Zähler'}, {'value': 'inverter', 'text': 'openEMS, Fenecon FEMS, Kaco Hy-Control Wechselrichter'}]}, {'value': 'openwb_flex', 'text': 'openWB-Kit flex', 'component': [{'value': 'bat', 'text': 'Speicher-Kit flex'}, {'value': 'counter', 'text': 'EVU-Kit flex'}, {'value': 'inverter', 'text': 'PV-Kit flex'}]}, {'value': 'powerdog', 'text': 'Powerdog', 'component': [{'value': 'counter', 'text': 'Powerdog Zähler'}, {'value': 'inverter', 'text': 'Powerdog Wechselrichter'}]}, {'value': 'powerfox', 'text': 'Powerfox', 'component': [{'value': 'counter', 'text': 'Powerfox Zähler'}, {'value': 'inverter', 'text': 'Powerfox Wechselrichter'}]}, {'value': 'openwb_pv_kit', 'text': 'PV-Kit', 'component': [{'value': 'inverter', 'text': 'PV-Kit'}]}, {'value': 'rct', 'text': 'RCT', 'component': [{'value': 'bat', 'text': 'RCT Speicher'}, {'value': 'counter', 'text': 'RCT Zähler'}, {'value': 'inverter', 'text': 'RCT Wechselrichter'}]}, {'value': 'saxpower', 'text': 'Saxpower', 'component': [{'value': 'bat', 'text': 'Saxpower Speicher'}]}, {'value': 'shelly', 'text': 'Shelly', 'component': [{'value': 'inverter', 'text': 'Shelly Wechselrichter'}]}, {'value': 'siemens', 'text': 'Siemens', 'component': [{'value': 'bat', 'text': 'Siemens Speicher'}, {'value': 'counter', 'text': 'Siemens Zähler'}, {'value': 'inverter', 'text': 'Siemens Wechselrichter'}]}, {'value': 'siemens_sentron', 'text': 'Siemens Sentron', 'component': [{'value': 'counter', 'text': 'Siemens Sentron Zähler'}]}, {'value': 'sma_shm', 'text': 'SMA Home Manager', 'component': [{'value': 'counter', 'text': 'SMA Home Manager Zähler'}, {'value': 'inverter', 'text': 'SMA Home Manager Wechselrichter'}]}, {'value': 'sma_sunny_boy', 'text': 'SMA Sunny Boy', 'component': [{'value': 'bat_smart_energy', 'text': 'Sma Sunny Boy Smart Energy Speicher'}, {'value': 'bat', 'text': 'Sma Sunny Boy Speicher'}, {'value': 'counter', 'text': 'Sma Sunny Boy Zähler'}, {'value': 'inverter', 'text': 'Sma Sunny Boy/Tripower Wechselrichter'}]}, {'value': 'sma_sunny_island', 'text': 'SMA Sunny Island', 'component': [{'value': 'bat', 'text': 'SMA Sunny Island Speicher'}]}, {'value': 'sma_webbox', 'text': 'SMA Webbox', 'component': [{'value': 'inverter', 'text': 'SMA Wechselrichter Webbox'}]}, {'value': 'smart_me', 'text': 'smart-me', 'component': [{'value': 'counter', 'text': 'smart-me Zähler'}, {'value': 'inverter', 'text': 'smart-me Wechselrichter'}]}, {'value': 'smartfox', 'text': 'Smartfox', 'component': [{'value': 'counter', 'text': 'Smartfox Zähler'}]}, {'value': 'solar_log', 'text': 'Solar-Log', 'component': [{'value': 'counter', 'text': 'Solar-Log Zähler'}, {'value': 'inverter', 'text': 'Solar-Log Wechselrichter'}]}, {'value': 'solaredge', 'text': 'SolarEdge', 'component': [{'value': 'bat', 'text': 'SolarEdge Speicher'}, {'value': 'counter', 'text': 'SolarEdge Zähler'}, {'value': 'inverter', 'text': 'SolarEdge Wechselrichter'}, {'value': 'external_inverter', 'text': 'SolarEdge externer Wechselrichter'}]}, {'value': 'solarmax', 'text': 'Solarmax', 'component': [{'value': 'inverter', 'text': 'Solarmax Wechselrichter'}]}, {'value': 'solar_view', 'text': 'SolarView', 'component': [{'value': 'counter', 'text': 'SolarView Zähler'}, {'value': 'inverter', 'text': 'SolarView Wechselrichter'}]}, {'value': 'solar_watt', 'text': 'Solarwatt/My Reserve', 'component': [{'value': 'bat', 'text': 'Solarwatt/My Reserve Speicher'}, {'value': 'counter', 'text': 'Solarwatt/My Reserve Zähler'}, {'value': 'inverter', 'text': 'Solarwatt/My Reserve Wechselrichter'}]}, {'value': 'solar_world', 'text': 'SolarWorld', 'component': [{'value': 'counter', 'text': 'SolarWorld Zähler'}, {'value': 'inverter', 'text': 'SolarWorld Wechselrichter'}]}, {'value': 'solax', 'text': 'Solax', 'component': [{'value': 'bat', 'text': 'Solax Speicher'}, {'value': 'counter', 'text': 'Solax Zähler'}, {'value': 'inverter', 'text': 'Solax Wechselrichter'}]}, {'value': 'sonnenbatterie', 'text': 'SonnenBatterie', 'component': [{'value': 'bat', 'text': 'SonnenBatterie Speicher'}, {'value': 'counter', 'text': 'SonnenBatterie Zähler'}, {'value': 'inverter', 'text': 'SonnenBatterie Wechselrichter'}]}, {'value': 'openwb_bat_kit', 'text': 'Speicher-Kit', 'component': [{'value': 'bat', 'text': 'Speicher-Kit'}]}, {'value': 'studer', 'text': 'Studer', 'component': [{'value': 'bat', 'text': 'Studer Speicher'}, {'value': 'inverter', 'text': 'Studer Wechselrichter'}]}, {'value': 'sungrow', 'text': 'Sungrow', 'component': [{'value': 'bat', 'text': 'Sungrow Speicher'}, {'value': 'counter', 'text': 'Sungrow Zähler'}, {'value': 'inverter', 'text': 'Sungrow Wechselrichter'}]}, {'value': 'sunways', 'text': 'Sunways', 'component': [{'value': 'inverter', 'text': 'Sunways Wechselrichter'}]}, {'value': 'tesla', 'text': 'Tesla', 'component': [{'value': 'bat', 'text': 'Tesla Speicher'}, {'value': 'counter', 'text': 'Tesla Zähler'}, {'value': 'inverter', 'text': 'Tesla Wechselrichter'}]}, {'value': 'varta', 'text': 'Varta', 'component': [{'value': 'bat_api', 'text': 'Varta Speicher (Abfrage per API)'}, {'value': 'bat_modbus', 'text': 'Speicher Varta Pulse, Element, Neo, u.a. (Abfrage per Modbus)'}, {'value': 'counter', 'text': 'Varta Zähler'}]}, {'value': 'victron', 'text': 'Victron', 'component': [{'value': 'bat', 'text': 'Victron Speicher'}, {'value': 'counter', 'text': 'Victron Zähler'}, {'value': 'inverter', 'text': 'Victron Wechselrichter'}]}, {'value': 'virtual', 'text': 'Virtuelles Gerät', 'component': [{'value': 'counter', 'text': 'Virtueller Zähler'}]}, {'value': 'vzlogger', 'text': 'VZLogger', 'component': [{'value': 'counter', 'text': 'VZLogger Zähler'}, {'value': 'inverter', 'text': 'VZLogger Wechselrichter'}]}, {'value': 'youless', 'text': 'Youless', 'component': [{'value': 'inverter', 'text': 'Youless LS120 Wechselrichter'}]}]
2023-07-11 13:54:58,409 - Topic: openWB/set/system/configurable/chargepoints, Payload: [{'value': 'external_openwb', 'text': 'Externe openWB'}, {'value': 'internal_openwb', 'text': 'Interne openWB'}, {'value': 'mqtt', 'text': 'MQTT-Ladepunkt'}, {'value': 'openwb_pro', 'text': 'openWB Pro'}, {'value': 'openwb_series2_satellit', 'text': 'openWB series2 satellit, openWB series2 satellit Duo'}, {'value': 'smartwb', 'text': 'smartWB / EVSE-Wifi (>= v1.x.x/v2.x.x)'}]
2023-07-11 13:54:58,411 - Topic: openWB/set/system/configurable/chargepoints_internal, Payload: [{'value': 'internal_openwb', 'text': 'Interne openWB'}]
2023-07-11 13:54:58,413 - Topic: openWB/set/command/max_id/autolock_plan, Payload: -1
2023-07-11 13:54:58,416 - Topic: openWB/set/command/max_id/mqtt_bridge, Payload: 0
2023-07-11 13:54:58,418 - Topic: openWB/set/command/max_id/charge_template, Payload: 0
2023-07-11 13:54:58,420 - Topic: openWB/set/command/max_id/charge_template_scheduled_plan, Payload: -1
2023-07-11 13:54:58,423 - Topic: openWB/set/command/max_id/charge_template_time_charging_plan, Payload: -1
2023-07-11 13:54:58,426 - Topic: openWB/set/command/max_id/chargepoint_template, Payload: 0
2023-07-11 13:54:58,428 - Topic: openWB/set/command/max_id/device, Payload: 9
2023-07-11 13:54:58,430 - Topic: openWB/set/command/max_id/ev_template, Payload: 1
2023-07-11 13:54:58,432 - Topic: openWB/set/command/max_id/vehicle, Payload: 1
2023-07-11 13:54:58,435 - Topic: openWB/set/command/max_id/hierarchy, Payload: 13
2023-07-11 13:54:58,716 - Topic: openWB/system/device/3/config, Payload: {"name": "SMA Home Manager", "type": "sma_shm", "id": 3, "configuration": {}}
2023-07-11 13:54:58,719 - Topic: openWB/system/device/8/config, Payload: {"name": "SMA Sunny Boy", "type": "sma_sunny_boy", "id": 8, "configuration": {"ip_address": "192.168.178.xx"}}
2023-07-11 13:54:58,723 - Topic: openWB/system/device/9/config, Payload: {"name": "SMA Sunny Island", "type": "sma_sunny_island", "id": 9, "configuration": {"ip_address": "192.168.178.xx"}}
2023-07-11 13:54:58,726 - Topic: openWB/system/subdata_initialized, Payload:
2023-07-11 13:54:58,727 - Topic: openWB/system/version, Payload: "2.0.0"
2023-07-11 13:54:58,729 - Topic: openWB/system/device/3/component/6/config, Payload: {"name": "SMA Home Manager Z\u00e4hler", "type": "counter", "id": 6, "configuration": {"serials": xxxxxxxxxxx}}
2023-07-11 13:54:58,734 - Topic: openWB/system/device/8/component/13/config, Payload: {"name": "Sma Sunny Boy/Tripower Wechselrichter", "type": "inverter", "id": 13, "configuration": {"hybrid": false, "version": 0}}
2023-07-11 13:54:58,737 - Topic: openWB/system/device/9/component/10/config, Payload: {"name": "SMA Sunny Island Speicher", "type": "bat", "id": 10, "configuration": {}}
2023-07-11 13:55:11,000 - Topic: openWB/set/system/time, Payload: 1689076510
2023-07-11 13:55:11,030 - Topic: openWB/system/time, Payload: 1689076510
2023-07-11 13:55:11,104 - Topic: openWB/set/bat/10/get/fault_str, Payload: Kein Fehler.
2023-07-11 13:55:11,108 - Topic: openWB/bat/10/get/fault_str, Payload: "Kein Fehler."
2023-07-11 13:55:11,109 - Topic: openWB/set/bat/10/get/fault_state, Payload: 0
2023-07-11 13:55:11,113 - Topic: openWB/bat/10/get/fault_state, Payload: 0
2023-07-11 13:55:11,636 - Topic: openWB/set/counter/6/get/fault_str, Payload: Kein Fehler.
2023-07-11 13:55:11,645 - Topic: openWB/counter/6/get/fault_str, Payload: "Kein Fehler."
2023-07-11 13:55:11,647 - Topic: openWB/set/counter/6/get/fault_state, Payload: 0
2023-07-11 13:55:11,656 - Topic: openWB/counter/6/get/fault_state, Payload: 0
2023-07-11 13:55:11,662 - Topic: openWB/set/bat/10/get/power, Payload: 20
2023-07-11 13:55:11,667 - Topic: openWB/bat/10/get/power, Payload: 20
2023-07-11 13:55:11,671 - Topic: openWB/set/bat/10/get/soc, Payload: 100
2023-07-11 13:55:11,676 - Topic: openWB/bat/10/get/soc, Payload: 100
2023-07-11 13:55:11,679 - Topic: openWB/set/bat/10/get/imported, Payload: 10674500
2023-07-11 13:55:11,682 - Topic: openWB/set/bat/10/get/exported, Payload: 8396000
2023-07-11 13:55:11,685 - Topic: openWB/bat/10/get/imported, Payload: 10674500
2023-07-11 13:55:11,689 - Topic: openWB/set/system/device/module_update_completed, Payload: True
2023-07-11 13:55:11,690 - Topic: openWB/bat/10/get/exported, Payload: 8396000
2023-07-11 13:55:11,694 - Topic: openWB/system/device/module_update_completed, Payload: true
2023-07-11 13:55:11,715 - Topic: openWB/set/counter/6/get/voltages, Payload: [246.07, 238.89, 244.13]
2023-07-11 13:55:11,719 - Topic: openWB/set/counter/6/get/currents, Payload: [-15.24, 0.95, 3.98]
2023-07-11 13:55:11,723 - Topic: openWB/set/counter/6/get/powers, Payload: [-3587.2, 169.5, 891.7]
2023-07-11 13:55:11,724 - Topic: openWB/counter/6/get/voltages, Payload: [246.07, 238.89, 244.13]
2023-07-11 13:55:11,727 - Topic: openWB/set/counter/6/get/power_factors, Payload: [0.96, 1.0, 0.99]
2023-07-11 13:55:11,729 - Topic: openWB/counter/6/get/currents, Payload: [-15.24, 0.95, 3.98]
2023-07-11 13:55:11,733 - Topic: openWB/set/counter/6/get/imported, Payload: 10762321.6
2023-07-11 13:55:11,734 - Topic: openWB/counter/6/get/powers, Payload: [-3587.2, 169.5, 891.7]
2023-07-11 13:55:11,737 - Topic: openWB/counter/6/get/power_factors, Payload: [0.96, 1.0, 0.99]
2023-07-11 13:55:11,738 - Topic: openWB/set/counter/6/get/exported, Payload: 11054157.0
2023-07-11 13:55:11,740 - Topic: openWB/counter/6/get/imported, Payload: 10762321.6
2023-07-11 13:55:11,743 - Topic: openWB/set/counter/6/get/power, Payload: -2525.9
2023-07-11 13:55:11,744 - Topic: openWB/counter/6/get/exported, Payload: 11054157.0
2023-07-11 13:55:11,747 - Topic: openWB/set/counter/6/get/frequency, Payload: 50.031
2023-07-11 13:55:11,749 - Topic: openWB/counter/6/get/power, Payload: -2525.9
2023-07-11 13:55:11,754 - Topic: openWB/set/system/device/module_update_completed, Payload: True
2023-07-11 13:55:11,758 - Topic: openWB/counter/6/get/frequency, Payload: 50.031
2023-07-11 13:55:11,764 - Topic: openWB/system/device/module_update_completed, Payload: true
2023-07-11 13:55:11,775 - Topic: openWB/set/system/device/module_update_completed, Payload: True
2023-07-11 13:55:11,778 - Topic: openWB/system/device/module_update_completed, Payload: true
2023-07-11 13:55:11,786 - Topic: openWB/set/pv/get/daily_exported, Payload: 0
2023-07-11 13:55:11,788 - Topic: openWB/set/pv/get/monthly_exported, Payload: 0
2023-07-11 13:55:11,791 - Topic: openWB/pv/get/daily_exported, Payload: 0
2023-07-11 13:55:11,793 - Topic: openWB/set/pv/get/yearly_exported, Payload: 0
2023-07-11 13:55:11,795 - Topic: openWB/pv/get/monthly_exported, Payload: 0
2023-07-11 13:55:11,797 - Topic: openWB/set/pv/get/exported, Payload: 0
2023-07-11 13:55:11,798 - Topic: openWB/pv/get/yearly_exported, Payload: 0
2023-07-11 13:55:11,802 - Topic: openWB/set/pv/get/power, Payload: 0
2023-07-11 13:55:11,803 - Topic: openWB/pv/get/exported, Payload: 0
2023-07-11 13:55:11,807 - Topic: openWB/set/pv/config/configured, Payload: True
2023-07-11 13:55:11,808 - Topic: openWB/pv/get/power, Payload: 0
2023-07-11 13:55:11,812 - Topic: openWB/set/bat/config/configured, Payload: True
2023-07-11 13:55:11,814 - Topic: openWB/pv/config/configured, Payload: true
2023-07-11 13:55:11,817 - Topic: openWB/set/bat/get/soc, Payload: 100
2023-07-11 13:55:11,818 - Topic: openWB/bat/config/configured, Payload: true
2023-07-11 13:55:11,823 - Topic: openWB/bat/get/soc, Payload: 100
2023-07-11 13:55:11,825 - Topic: openWB/set/bat/get/daily_exported, Payload: 2300
2023-07-11 13:55:11,826 - Topic: openWB/set/bat/get/daily_imported, Payload: 5800
2023-07-11 13:55:11,828 - Topic: openWB/set/bat/get/imported, Payload: 10674500
2023-07-11 13:55:11,830 - Topic: openWB/bat/get/daily_exported, Payload: 2300
2023-07-11 13:55:11,831 - Topic: openWB/set/bat/get/exported, Payload: 8396000
2023-07-11 13:55:11,833 - Topic: openWB/bat/get/daily_imported, Payload: 5800
2023-07-11 13:55:11,834 - Topic: openWB/set/bat/get/power, Payload: 20
2023-07-11 13:55:11,836 - Topic: openWB/bat/get/imported, Payload: 10674500
2023-07-11 13:55:11,841 - Topic: openWB/set/system/device/module_update_completed, Payload: True
2023-07-11 13:55:11,842 - Topic: openWB/bat/get/exported, Payload: 8396000
2023-07-11 13:55:11,848 - Topic: openWB/bat/get/power, Payload: 20
2023-07-11 13:55:11,850 - Topic: openWB/system/device/module_update_completed, Payload: true
2023-07-11 13:55:11,871 - Topic: openWB/set/bat/set/charging_power_left, Payload: -50
2023-07-11 13:55:11,879 - Topic: openWB/set/bat/set/switch_on_soc_reached, Payload: True
2023-07-11 13:55:11,880 - Topic: openWB/bat/set/charging_power_left, Payload: -50
2023-07-11 13:55:11,883 - Topic: openWB/set/counter/6/set/error_counter, Payload: 0
2023-07-11 13:55:11,887 - Topic: openWB/set/chargepoint/get/power, Payload: 0
2023-07-11 13:55:11,888 - Topic: openWB/bat/set/switch_on_soc_reached, Payload: true
2023-07-11 13:55:11,894 - Topic: openWB/set/chargepoint/get/imported, Payload: 0
2023-07-11 13:55:11,895 - Topic: openWB/counter/6/set/error_counter, Payload: 0
2023-07-11 13:55:11,903 - Topic: openWB/chargepoint/get/power, Payload: 0
2023-07-11 13:55:11,904 - Topic: openWB/chargepoint/get/imported, Payload: 0
2023-07-11 13:55:11,912 - Topic: openWB/set/chargepoint/get/exported, Payload: 0
2023-07-11 13:55:11,915 - Topic: openWB/set/counter/6/set/reserved_surplus, Payload: 0
2023-07-11 13:55:11,917 - Topic: openWB/chargepoint/get/exported, Payload: 0
2023-07-11 13:55:11,919 - Topic: openWB/set/counter/6/set/released_surplus, Payload: 0
2023-07-11 13:55:11,927 - Topic: openWB/set/counter/6/get/fault_state, Payload: 1
2023-07-11 13:55:11,931 - Topic: openWB/counter/6/set/reserved_surplus, Payload: 0
2023-07-11 13:55:11,934 - Topic: openWB/set/counter/6/get/fault_str, Payload: Der Wert für den Hausverbrauch ist nicht plausibel (negativ). Bitte die Leistungen der Komponenten und die Anordnung in der Hierarchie prüfen.
2023-07-11 13:55:11,949 - Topic: openWB/counter/6/set/released_surplus, Payload: 0
2023-07-11 13:55:11,957 - Topic: openWB/set/counter/set/home_consumption, Payload: 0
2023-07-11 13:55:11,961 - Topic: openWB/counter/6/get/fault_state, Payload: 1
2023-07-11 13:55:11,967 - Topic: openWB/counter/6/get/fault_str, Payload: "Der Wert f\u00fcr den Hausverbrauch ist nicht plausibel (negativ). Bitte die Leistungen der Komponenten und die Anordnung in der Hierarchie pr\u00fcfen."
2023-07-11 13:55:11,970 - Topic: openWB/counter/set/home_consumption, Payload: 0
2023-07-11 13:55:11,973 - Topic: openWB/set/vehicle/0/control_parameter/state, Payload: 0
2023-07-11 13:55:11,976 - Topic: openWB/vehicle/0/control_parameter/state, Payload: 0
2023-07-11 13:55:11,978 - Topic: openWB/set/vehicle/1/control_parameter/state, Payload: 0
2023-07-11 13:55:11,980 - Topic: openWB/vehicle/1/control_parameter/state, Payload: 0
2023-07-11 13:55:11,983 - Topic: openWB/set/counter/6/set/reserved_surplus, Payload: 0
2023-07-11 13:55:11,987 - Topic: openWB/set/counter/6/set/released_surplus, Payload: 0
2023-07-11 13:55:11,989 - Topic: openWB/counter/6/set/reserved_surplus, Payload: 0
2023-07-11 13:55:11,992 - Topic: openWB/set/graph/lastlivevaluesJson, Payload: {'timestamp': 1689076511, 'time': '13:55:11', 'grid': -2.526, 'house-power': 0.0, 'charging-all': 0.0, 'pv-all': -0.0, 'ev1-soc': 0.0, 'bat-all-power': 0.02, 'bat-all-soc': 100}
2023-07-11 13:55:11,996 - Topic: openWB/counter/6/set/released_surplus, Payload: 0
2023-07-11 13:55:12,000 - Topic: openWB/graph/lastlivevaluesJson, Payload: {"timestamp": 1689076511, "time": "13:55:11", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:55:12,009 - Topic: openWB/set/system/lastlivevaluesJson, Payload: {'timestamp': 1689076511, 'time': '13:55:11', 'grid': -2.526, 'house-power': 0.0, 'charging-all': 0.0, 'pv-all': -0.0, 'ev1-soc': 0.0, 'bat-all-power': 0.02, 'bat-all-soc': 100}
2023-07-11 13:55:12,013 - Topic: openWB/system/lastlivevaluesJson, Payload: {"timestamp": 1689076511, "time": "13:55:11", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:55:12,022 - Topic: openWB/graph/alllivevaluesJson1, Payload: {"timestamp": 1689076511, "time": "13:55:11", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:55:12,030 - Topic: openWB/graph/alllivevaluesJson, Payload: {"timestamp": 1689076511, "time": "13:55:11", "grid": -2.526, "house-power": 0.0, "charging-all": 0.0, "pv-all": -0.0, "ev1-soc": 0.0, "bat-all-power": 0.02, "bat-all-soc": 100}
2023-07-11 13:55:12,132 - Topic: openWB/graph/alllivevaluesJson3, Payload: -
2023-07-11 13:55:12,134 - Topic: openWB/graph/alllivevaluesJson2, Payload: -
SoC-Log
Protokoll des letzten Updates
Open Source made with love!
Jede Spende hilft die Weiterentwicklung von openWB voranzutreiben
Sie befinden sich hier: Einstellungen / System - Fehlersuche
