Rückmeldung Stable 1.9.288
LarsBr87
Has thanked: 6 times
Re: Rückmeldung Stable 1.9.288
Beitrag von LarsBr87 »
Seid dem Update auf die Version, habe ich im Debug folgende Meldung. Kann damit jemand etwas anfangen?
Danke Gruß Lars
pymodbus.exceptions.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.193.15:8899)]
File "/usr/local/lib/python3.5/dist-packages/pymodbus/client/sync.py", line 119, in __enter__
self.delegate.__enter__()
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 52, in __enter__
with self.__tcp_client:
File "/var/www/html/openWB/packages/modules/devices/openwb_flex/counter.py", line 36, in update
self.components[component].update()
File "/var/www/html/openWB/packages/modules/devices/openwb_evu_kit/device.py", line 55, in update
2022-12-05 09:11:37: PID: 31816: soc.modules.common.fault_state: EVU-Kit: FaultState FaultStateLevel.ERROR, FaultStr <class 'pymodbus.exceptions.ConnectionException'> Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.193.15:8899)], Traceback:
2022-12-05 09:11:37: PID: 31816: pymodbus.client.sync: Connection to (192.168.193.15, 8899) failed: timed out
2022-12-05 09:11:29: PID: 12382: **** FATAL ********************************* (LV0)
2022-12-05 09:11:29: PID: 12382: **** FATAL Regulation loop needs 9 seconds (LV0)
2022-12-05 09:11:27: PID: 31816: soc.modules.common.fault_state: EVU-Kit: FaultState FaultStateLevel.ERROR, FaultStr <class 'pymodbus.exceptions.ConnectionException'> Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.193.15:8899)], Traceback:
2022-12-05 09:11:27: PID: 31816: pymodbus.client.sync: Connection to (192.168.193.15, 8899) failed: timed out
2022-12-05 09:11:19: PID: 10994: **** FATAL ********************************* (LV0)
2022-12-05 09:11:19: PID: 10994: **** FATAL Regulation loop needs 9 seconds (LV0)
Has thanked: 20 times
Been thanked: 156 times
Von welcher Version kommst Du?
Das EVU-Kit antwortet nicht. Eventuell wurden beim Update von einer älteren Version die maximalen Verbindungen des Netzwerk/Modbus Adapters überschritten. Fahr die openWB mal herunter und mach den Netzwerk-Adapter des EVU-Kits kurz stromlos. Dann in umgekehrter Reihenfolge wieder einschalten.
LarsBr87
Vielen Dank für die Rückmeldung. Ich war vorher auf der Beta.
Ich habe das mal umgesetzt und werde den Fehler weiter beobachten (wenn er dann überhaupt wieder auftaucht)
Gruß Lars
LarsBr87 hat geschrieben: Mo Dez 05, 2022 10:22 am Vielen Dank für die Rückmeldung. Ich war vorher auf der Beta.
Gruß Lars
Der Fehler darf im laufenden Betrieb nicht mehr vorkommen. Voraussetzung ist, dass kein weiteres Gerät das Kit abfragt.
LarsBr87
Der Fehler kommt leider immer noch.
Das ist das originale EVU Kit aus dem Shop und ich nutze dieses nur für die OpenWB‘s (1 Master und 1 Slave)
Die EVU Werte werden ja angezeigt, aber scheinbar gibts zwischendurch immer mal wieder eine Unterbrechung.
Wäre ein Update auf die neuste Nightly sinnvoll?
LarsBr87 hat geschrieben: Mo Dez 05, 2022 10:59 am Der Fehler kommt leider immer noch.
Nein, da hat sich nichts in dieser Richtung geändert.
LarsBr87
Fehler ist leider immer noch vorhanden. Ich bin kann aber jetzt nicht genau sagen, seid welcher Version das so ist, weil es im Alltag nicht auffällt.
Habe es jetzt zufällig im Debug gesehen und es tritt ja auch unregelmäßig auf. Gibt es sonst noch einen Tipp, den ich probieren könnte?
Gruß Lars
M_aus_BW
Beitrag von M_aus_BW »
Ich warte immer eine Weile, bevor ich ein Update anstosse, um eventuell weniger Probleme zu bekommen.
Heute nun habe ich auf 1.9.288 umgestellt. Letzte Version habe ich mir nicht genau gemerkt, weil ich noch nie Fehlfunktionen hatte; es könnte 1.9.274 oder 276 gewesen sein.
Beim Anschließen des Autos, ein Peugeot e2008, nun folgendes:
Der SoC wird nicht ausgelesen, der Ladevorgang ist jedoch gestartet.
In der Übersicht des GUI wird die Ladeleistung dem Hausverbrauch zugeschlagen, rechts daneben wo sie erscheinen soll aber nicht.
Der Ladepunkt wird korrekt dargestellt, grün mit grünem Stecker, Parameter ebenfalls richtig jedoch die geladenen kWh bleiben auf null.
Nun habe ich also keinen Überblick, welchen Status der Akku hat und ob zu dem von mir eingestellten SoC die Ladung beendet wird.
Vermutlich unabhängig davon liefert die Peugeot-App ebenfalls keinen bzw. nur einen alten Status.
Aber dieses verkorkste Teil ist ohnehin nervend.
Ich versuche nun, das Backup wieder in die Box zu kriegen.
Michael
M_aus_BW
Noch eine Ergänzung zu meinem Beitrag von gestern:
Die Ladeleistung kann ich auf der Hauptseite zwar verändern, das hat aber keine Auswirkung auf die tatsächliche Stromstärke, mit welcher geladen wird.
Das ist nur über die Einstellungen > Ladeeinstellungen > Sofortladen mit dem Schalter für die Mindeststromstärke möglich.
Michael
M_aus_BW
Hier noch die bisher fehlenden Angaben:
Ladepunkt 1
Anbindung: openWB Daemon
SOC Modul PSA
Abfragen wenn angesteckt: ja
Peugeot
Kombiniere PSA und manuell: ja
Akku 47 kWh, Wirkungsgrad 99
SmartHome 2.0
Elwa
kann schalten: ja
Bei Autoladen: ausschalten
In Hausverbrauch einrechnen: nein
Separate Leistungsmessung: nein
Modul PV
SMA ModbusTCP WR, Standard
keine Webbox
kein Hybrid-System
Modul Speicher
SMA Sunny Boy Storage
Smart Energy: nein
Modul EVU
Bezugsmodul: SMA HomeManager
EVU Glättung: aus
[["modules.devices.sma_sunny_boy.device","bat","192.168.178.36"]
2022-12-06 08:54:13: PID: 3084: soc.modules.common.store._api: Saving BatState(imported=3575159, soc=0, exported=2957109, power=0)
2022-12-06 08:54:13: PID: 3084: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy Speicher']
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: Start device reading {'componentNone': <modules.devices.sma_sunny_boy.bat.SunnyBoyBat object at 0x74e0bb90>}
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Hybrid: None
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Version: None
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus weitere IPs: None, None, None
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Webbox: None
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.178.36
2022-12-06 08:54:13: PID: 3084: legacy run server: Received command ["modules.devices.sma_sunny_boy.device","bat","192.168.178.36"]
2022-12-06 08:54:13: PID: 4708: RET: 0 (LV2) at 12 main modules/wr_tripower9000/main.sh
2022-12-06 08:54:13: PID: 3084: legacy run server: WR 1 nach Korrektur: InverterState(dc_power=-184, exported=11570089, power=-106, currents=[0.0, 0.0, 0.0])
2022-12-06 08:54:13: PID: 3084: legacy run server: Completed running command in 0.23s: ["modules.devices.sma_sunny_boy.device","inverter","192.168.178.37","0","none","none","none","0","0"
2022-12-06 08:54:13: PID: 3084: soc.modules.common.store._api: Saving InverterState(dc_power=None, exported=11570089, power=-106, currents=[0.0, 0.0, 0.0])
2022-12-06 08:54:13: PID: 3084: modules.devices.sma_sunny_boy.inverter: WR 192.168.178.37: InverterState(dc_power=-184, exported=11570089, power=-106, currents=[0.0, 0.0, 0.0])
2022-12-06 08:54:12: PID: 3084: soc.modules.common.component_context: Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2022-12-06 08:54:12: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Hybrid: 0
2022-12-06 08:54:12: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Version: 0
2022-12-06 08:54:12: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus weitere IPs: none, none, none
2022-12-06 08:54:12: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Webbox: 0
2022-12-06 08:54:12: PID: 3084: modules.devices.sma_sunny_boy.device: SMA Modbus Ip-Adresse: 192.168.178.37
2022-12-06 08:54:12: PID: 3084: legacy run server: Log level changed WARNING -> DEBUG
2022-12-06 08:54:12: PID: 4562: **** Regulation loop start **** (LV1) at 77 main /var/www/html/openWB/regel.sh
2022-12-06 08:50:03: PID: 5171: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:50:02: PID: 5405: Starting OpenWB services (LV0)
2022-12-06 08:50:01: PID: 5171: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:49:51: PID: 2602: **** FATAL ********************************* (LV0)
2022-12-06 08:49:51: PID: 2602: **** FATAL Regulation loop needs 10 seconds (LV0)
2022-12-06 08:45:03: PID: 31801: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:45:02: PID: 32043: Starting OpenWB services (LV0)
2022-12-06 08:45:02: PID: 31801: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:40:03: PID: 26125: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:40:02: PID: 26356: Starting OpenWB services (LV0)
2022-12-06 08:40:02: PID: 26125: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:35:03: PID: 20367: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:35:02: PID: 20607: Starting OpenWB services (LV0)
2022-12-06 08:35:01: PID: 20367: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:30:03: PID: 14693: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:30:01: PID: 14940: Starting OpenWB services (LV0)
2022-12-06 08:30:01: PID: 14693: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:25:03: PID: 8990: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:25:02: PID: 9248: Starting OpenWB services (LV0)
2022-12-06 08:25:01: PID: 8990: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:20:03: PID: 3244: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:20:02: PID: 3482: Starting OpenWB services (LV0)
2022-12-06 08:20:01: PID: 3244: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:19:42: PID: 500: **** FATAL ********************************* (LV0)
2022-12-06 08:19:42: PID: 500: **** FATAL Regulation loop needs 11 seconds (LV0)
2022-12-06 08:19:41: PID: 954: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
500
2022-12-06 08:15:03: PID: 31025: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:15:02: PID: 31246: Starting OpenWB services (LV0)
2022-12-06 08:15:01: PID: 31025: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:10:03: PID: 25342: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:10:02: PID: 25578: Starting OpenWB services (LV0)
2022-12-06 08:10:02: PID: 25342: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:05:03: PID: 19596: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:05:02: PID: 19836: Starting OpenWB services (LV0)
2022-12-06 08:05:01: PID: 19596: ##### cron5min.sh started ##### (LV0)
2022-12-06 08:00:03: PID: 13834: ##### cron5min.sh finished ##### (LV0)
2022-12-06 08:00:02: PID: 14072: Starting OpenWB services (LV0)
2022-12-06 08:00:01: PID: 13834: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:55:04: PID: 8121: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:55:02: PID: 8360: Starting OpenWB services (LV0)
2022-12-06 07:55:01: PID: 8121: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:50:05: PID: 2325: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:50:02: PID: 2575: Starting OpenWB services (LV0)
2022-12-06 07:50:01: PID: 2325: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:45:03: PID: 29078: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:45:02: PID: 29303: Starting OpenWB services (LV0)
2022-12-06 07:45:01: PID: 29078: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:40:03: PID: 23356: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:40:02: PID: 23585: Starting OpenWB services (LV0)
2022-12-06 07:40:01: PID: 23356: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:35:04: PID: 17550: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:35:02: PID: 17785: Starting OpenWB services (LV0)
2022-12-06 07:35:01: PID: 17550: ##### cron5min.sh started ##### (LV0)
2022-12-06 07:30:04: PID: 11837: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:30:01: PID: 12057: Starting OpenWB services (LV0)
2022-12-06 07:30:01: PID: 11837: ##### cron5min.sh started ##### (LV0)
Terminated
2022-12-06 07:28:58: at_reboot: checking for stalled atreboot after 10 minutes
2022-12-06 07:25:03: PID: 6151: ##### cron5min.sh finished ##### (LV0)
2022-12-06 07:25:01: PID: 6384: Starting OpenWB services (LV0)
2022-12-06 07:25:01: PID: 6151: ##### cron5min.sh started ##### (LV0)
modules/soc_psa/main.sh: Zeile 140: /var/www/html/openWB/ramdisk/psasoclastlp1: Datei oder Verzeichnis nicht gefunden
2022-12-06 07:20:20: PID: 3365: **** FATAL ********************************* (LV0)
2022-12-06 07:20:20: PID: 3365: **** FATAL Regulation loop needs 11 seconds (LV0)
tail: '/var/www/html/openWB/ramdisk/soc1-live.graph' kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
'device reports readiness to read but returned no data '
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 501, in read
result = self.socket.read(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 555, in _recv
return self._recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 88, in recv
result = self.client.recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/framer/rtu_framer.py", line 286, in recvPacket
result = self.client.framer.recvPacket(expected_response_length)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 276, in _recv
result = self._recv(response_length, full)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 212, in _transact
full=full
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 140, in execute
return self.transaction.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 108, in execute
return self.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 114, in read_holding_registers
request = client.read_holding_registers(readreg, reganzahl, unit=modbusid)
File "runs/readmodbus.py", line 11, in <module>
loadvars.sh: Zeile 1900: ramdisk/mqttslavemode: Datei oder Verzeichnis nicht gefunden
2022-12-06 07:20:11: PID: 3513: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
3500 3365
2022-12-06 07:20:02: at_reboot: 2022-12-06 07:20:02: boot done :-)
2022-12-06 07:20:02: at_reboot: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
2022-12-06 07:20:01: PID: 3227: ##### cron5min.sh Ramdisk not set up. Maybe we are still booting. (LV0)
2022-12-06 07:20:01: at_reboot: fix upload limit...OS Stretch
2022-12-06 07:20:01: at_reboot: not activated, skipping
2022-12-06 07:20:01: at_reboot: etprovider...
2022-12-06 07:20:01: PID: 3240: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:59: PID: 3182: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:51: at_reboot: update broker...
2022-12-06 07:19:50: PID: 3084: legacy run server: Changing log level DEBUG -> WARNING
2022-12-06 07:19:49: PID: 3032: isss handler not running! restarting process (LV0)
2022-12-06 07:19:49: at_reboot: Starting legacy run server
2022-12-06 07:19:49: PID: 3032: legacy run server is not running. Restarting process (LV0)
2022-12-06 07:19:49: PID: 3032: smart home handler not running! restarting process (LV0)
2022-12-06 07:19:49: PID: 3032: mqtt handler not running! restarting process (LV0)
2022-12-06 07:19:49: PID: 3032: modbus tcp server not running! restarting process (LV0)
2022-12-06 07:19:49: PID: 3032: Starting OpenWB services (LV0)
2022-12-06 07:19:49: PID: 3032: OpenWB services stopped (LV0)
2022-12-06 07:19:49: PID: 3032: Stopping OpenWB services (LV0)
2022-12-06 07:19:49: at_reboot: clear warning...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
100 43 0 0 100 43 0 22 0:00:01 0:00:01 --:--:-- 22
2022-12-06 07:19:49: PID: 3016: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:47: at_reboot: Dload Upload Total Spent Left Speed
2022-12-06 07:19:47: at_reboot: % Total % Received % Xferd Average Speed Time Time Time Current
2022-12-06 07:19:47: at_reboot: version...
2022-12-06 07:19:46: at_reboot: Successfully installed urllib3-1.26.9
2022-12-06 07:19:45: at_reboot: Installing collected packages: urllib3
2022-12-06 07:19:45: at_reboot: Using cached https://files.pythonhosted.org/packages ... ne-any.whl
2022-12-06 07:19:41: at_reboot: Collecting urllib3
2022-12-06 07:19:39: PID: 2989: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:33: at_reboot: lxml installed...
2022-12-06 07:19:33: at_reboot: ipparser installed...
2022-12-06 07:19:33: at_reboot: jq installed...
2022-12-06 07:19:33: at_reboot: python requests installed...
2022-12-06 07:19:30: at_reboot: pymodbus installed...
2022-12-06 07:19:30: at_reboot: aiohttp installed...
2022-12-06 07:19:29: PID: 2959: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:28: at_reboot: certifi installed...
2022-12-06 07:19:11: at_reboot: docopt installed...
2022-12-06 07:19:11: at_reboot: mqtt installed...
2022-12-06 07:19:10: at_reboot: packages 2...
2022-12-06 07:19:10: at_reboot: updating mosquitto config file
2022-12-06 07:19:10: at_reboot: mosquitto...
2022-12-06 07:19:10: at_reboot: cp: '/usr/share/zoneinfo/Europe/Berlin' und '/etc/localtime' sind die gleiche Datei
2022-12-06 07:19:10: at_reboot: timezone...
2022-12-06 07:19:10: at_reboot: 2022-12-06 07:19:10: PID: 2897: upgradeChargeLogs: upgrading charge logs done
2022-12-06 07:19:10: at_reboot: 2022-12-06 07:19:10: PID: 2897: upgradeChargeLogs: upgrading charge logs with a price of 0.34 per kWh
2022-12-06 07:19:09: at_reboot: evdev for python3 installed...
2022-12-06 07:19:08: at_reboot: evdev for python2 installed...
2022-12-06 07:19:08: at_reboot: packages 1...
2022-12-06 07:19:08: at_reboot: crontab 2...
2022-12-06 07:19:08: at_reboot: ...changed
2022-12-06 07:19:08: at_reboot: apache...
2022-12-06 07:19:08: at_reboot: LAN/WLAN...
2022-12-06 07:19:08: at_reboot: crontab 1...
2022-12-06 07:19:08: at_reboot: deleting browser cache
2022-12-06 07:19:08: at_reboot: already up to date
2022-12-06 07:19:08: at_reboot: display...
2022-12-06 07:19:03: at_reboot: triginit...
2022-12-06 07:19:03: at_reboot: Ramdisk init done.
2022-12-06 07:19:03: at_reboot: Trigger update of logfiles...
2022-12-06 07:19:02: at_reboot: 'mqttwizzarddone' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttwattbezug' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttversion' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttverbraucher2_name' missing: Setting to provided default value 'notset'
2022-12-06 07:19:02: at_reboot: 'mqttverbraucher2_aktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttverbraucher1_name' missing: Setting to provided default value 'notset'
2022-12-06 07:19:02: at_reboot: 'mqttverbraucher1_aktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttupdateinprogress' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3pstandby' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3psofort' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3pnurpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3pnl' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3pminundpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttu1p3paktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttstopchargepvpercentagelp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttstopchargepvpercentagelp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttstopchargepvatpercentlp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttstopchargepvatpercentlp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeicherwattnurpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeichersocnurpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeichersocminpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeichersochystminpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeicherpvui' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeicherpveinbeziehen' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttspeichermaxwatt' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsofortsocstatlp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsofortsocstatlp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsofortsoclp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsofortsoclp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsocvorhanden' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsoc' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttsoc1vorhanden' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttrfidakt' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttrestzeitlp3' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttrestzeitlp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttrestzeitlp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttpvwatt' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttpvbezugeinspeisung' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttpreisjekwh' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttoffsetpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnurpv70dynw' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnurpv70dynact' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnlakt_standby' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnlakt_sofort' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnlakt_nurpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnlakt_minpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnachtladens1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttnachtladen' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminnurpvsoclp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminnurpvsocll' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminimalstromstaerke' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminimalapv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminimalampv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttminimalalp2pv' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttmindestuberschuss' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttmaxnurpvsoclp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttmaximalstromstaerke' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlastlademodus' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlademstats2' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlademstats1' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlademstatlp8' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlademstatlp7' missing: Setting to provided default value '-1'
2022-12-06 07:19:02: at_reboot: 'mqttlademstatlp6' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademstatlp5' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: PID: 2331: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2022-12-06 07:19:01: at_reboot: 'mqttlademstatlp4' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademstat' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwhlp8' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwhlp7' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwhlp6' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwhlp5' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwhlp4' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttlademkwh' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtthook3_aktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtthook2_aktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtthook1_aktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttheutegeladen' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtthausverbrauchstat' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtthausverbrauch' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttevuglaettungakt' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttetprovider' missing: Setting to provided default value 'notset'
2022-12-06 07:19:01: at_reboot: 'mqttetprovideraktiv' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqtteinschaltverzoegerung' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdurchslp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdisplayspeichermax' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdisplaypvmax' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdisplayhausmax' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdisplayhausanzeigen' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdisplayevumax' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdatenschutzack' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdailychargelp3' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdailychargelp2' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttdailychargelp1' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttaktgeladens2' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttaktgeladens1' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttaktgeladen' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttadaptpv' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttadaptfaktor' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttabschaltverzoegerung' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttabschaltuberschuss' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttRandomSleepValue' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: 'mqttCp1Configured' missing: Setting to provided default value '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp8' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp8max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp8name' missing: no MQTT topic set: Setting to default of 'Lp8'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp8' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp8' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp8' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:19:01: at_reboot: '/var/www/html/openWB/ramdisk/lp8sofortll' missing: Setting from MQTT topic 'lp8sofortll' to value '10'
2022-12-06 07:19:00: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:19:00: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp8' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:19:00: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp8' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:19:00: at_reboot: '/var/www/html/openWB/ramdisk/lp8enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:19:00: at_reboot: '/var/www/html/openWB/ramdisk/lp8phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:59: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp8' missing: Setting from MQTT topic 'pluggedladungaktlp8' to value '0'
2022-12-06 07:18:58: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp8startkwh' missing: Setting from MQTT topic 'pluggedladunglp8startkwh' to value '0'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp7' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp7max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp7name' missing: no MQTT topic set: Setting to default of 'Lp7'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp7' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp7' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp7' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:57: at_reboot: '/var/www/html/openWB/ramdisk/lp7sofortll' missing: Setting from MQTT topic 'lp7sofortll' to value '10'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp7' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp7' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp7enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp7phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp7' missing: MQTT topic 'pluggedladungaktlp7' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: Error: Connection refused
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp7startkwh' missing: MQTT topic 'pluggedladunglp7startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp6' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp6max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp6name' missing: no MQTT topic set: Setting to default of 'Lp6'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp6' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp6' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp6' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp6sofortll' missing: MQTT topic 'lp6sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp6' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp6' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp6enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp6phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp6' missing: MQTT topic 'pluggedladungaktlp6' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp6startkwh' missing: MQTT topic 'pluggedladunglp6startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp5' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp5max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp5name' missing: no MQTT topic set: Setting to default of 'Lp5'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp5' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp5' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp5' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp5sofortll' missing: MQTT topic 'lp5sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp5' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp5' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp5enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/lp5phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp5' missing: MQTT topic 'pluggedladungaktlp5' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:56: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp5startkwh' missing: MQTT topic 'pluggedladunglp5startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp4' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp4max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp4name' missing: no MQTT topic set: Setting to default of 'Lp4'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp4' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp4' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp4' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp4sofortll' missing: MQTT topic 'lp4sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:55: at_reboot: Error: Connection refused
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp4' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp4' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp4enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp4phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp4' missing: MQTT topic 'pluggedladungaktlp4' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp4startkwh' missing: MQTT topic 'pluggedladunglp4startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp3' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp3max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp3name' missing: no MQTT topic set: Setting to default of 'Lp3'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp3' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp3' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp3' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp3sofortll' missing: MQTT topic 'lp3sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp3' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp3' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp3enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp3phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp3' missing: MQTT topic 'pluggedladungaktlp3' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp3startkwh' missing: MQTT topic 'pluggedladunglp3startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp2' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp2max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp2name' missing: no MQTT topic set: Setting to default of 'Lp2'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp2' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp2' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp2sofortll' missing: MQTT topic 'lp2sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp2' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp2' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp2enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp2phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp2' missing: MQTT topic 'pluggedladungaktlp2' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp2startkwh' missing: MQTT topic 'pluggedladunglp2startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp1' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp1max' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp1name' missing: no MQTT topic set: Setting to default of 'Lp1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp1' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp1' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '-1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp1sofortll' missing: MQTT topic 'lp1sofortll' can also not provide any value: Setting to default of '10'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp1' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp1' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp1enabled' missing: no MQTT topic set: Setting to default of '1'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/lp1phasen' missing: no MQTT topic set: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp1' missing: MQTT topic 'pluggedladungaktlp1' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:55: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp1startkwh' missing: MQTT topic 'pluggedladunglp1startkwh' can also not provide any value: Setting to default of '0'
2022-12-06 07:18:54: at_reboot: Error: Connection refused
2022-12-06 07:18:54: at_reboot: Initializing Ramdisk /var/www/html/openWB/ramdisk
2022-12-06 07:18:54: at_reboot: Config file Update done.
2022-12-06 07:18:50: at_reboot: Updating /var/www/html/openWB/openwb.conf...
2022-12-06 07:18:41: at_reboot: loading config
2022-12-06 07:18:41: at_reboot: atreboot.sh started[/code]
Ich hoffe, das ist so ausreichend.
Wegen zu vielen Zeichen für das Einstellen habe ich den neuesten Teil gekürzt.
