Ja habe ich auch gedacht.
Mit dem private mode des Browsers klappt es nicht.
Was mir aber aufgefallen ist, dass das Update-Script bei mir sehr (zu) schnell abgearbeitet wird:
Die Systemrückmeldungen, die Du nach dem atreboot.sh angeführt hast, werden bei mir nicht angezeigt.
also diese folgenden sind in meinen logs nicht vorhanden:
"atreboot.sh started
LAN/WLAN...
apache...
...changed
apt packages...
python packages...
Looking in indexes:
https://pypi.org/simple,
https://www.piwheels.org/simple
Requirement already satisfied: jq==1.1.3 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 1)) (1.1.3)
Requirement already satisfied: paho_mqtt==1.6.1 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 2)) (1.6.1)
Requirement already satisfied: pymodbus==2.5.2 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 3)) (2.5.2)
Requirement already satisfied: pytest==6.2.5 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 4)) (6.2.5)
Requirement already satisfied: requests_mock==1.9.3 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 5)) (1.9.3)
Requirement already satisfied: pyserial>=3.4 in /usr/local/lib/python3.9/dist-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (3.5)
Requirement already satisfied: six>=1.15.0 in /usr/lib/python3/dist-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (1.16.0)
Requirement already satisfied: attrs>=19.2.0 in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (21.4.0)
Requirement already satisfied: toml in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (0.10.2)
Requirement already satisfied: iniconfig in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.1.1)
Requirement already satisfied: pluggy<2.0,>=0.12 in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.0.0)
Requirement already satisfied: packaging in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (21.3)
Requirement already satisfied: py>=1.8.2 in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.11.0)
Requirement already satisfied: requests<3,>=2.3 in /usr/lib/python3/dist-packages (from requests_mock==1.9.3->-r /var/www/html/openWB/requirements.txt (line 5)) (2.25.1)
Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in /usr/local/lib/python3.9/dist-packages (from packaging->pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (3.0.6)
version...
load versions...
2022-01-14 16:04:06: boot done
pi@raspi3b:~ $"
Stimmt was mit dem atreboot.sh nicht?
PS:kann erst wieder zum Wochenende weiter schauen
