Support: EVCC
Bubbagump
Has thanked: 3 times
Been thanked: 3 times
Re: Support: EVCC
Beitrag von Bubbagump »
Nissan hat die API geändert, siehe
https://github.com/evcc-io/evcc/issues/13941
9,86 kWp PV, SMA STP 10, SHM 2.0
Skoda Enyaq 85 (2024)
OpenWB Series2 Standard+
andig
Re: Support: EVCC
Beitrag von andig »
Nissan soeben behoben, in 10min sollte es wieder klappen.
Oeffly
Re: Support: EVCC
Beitrag von Oeffly »
leider auch bei Audi und VW bekome gerade auch keine SOC bei der OpenWB angezeigt.....
Version 2.1.4. Beta 2 und auch nun RC2
folgende Log-Eintrag:
2024-05-18 16:41:03,486 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev1} - EVCC: FaultState FaultStateLevel.ERROR, FaultStr <class 'grpc.RpcError'> (<_InactiveRpcError of RPC that terminated with:
	status = StatusCode.UNKNOWN
	details = "vehicle not available"
	debug_error_string = "UNKNOWN:Error received from peer  {created_time:"2024-05-18T16:41:03.482144813+02:00", grpc_status:2, grpc_message:"vehicle not available"}"
>,), Traceback:
  File "/var/www/html/openWB/packages/modules/vehicles/evcc/api.py", line 71, in fetch_soc
    response = stub.SoC(
  File "/home/openwb/.local/lib/python3.9/site-packages/grpc/_channel.py", line 1160, in __call__
    return _end_unary_response_blocking(state, call, False, None)
  File "/home/openwb/.local/lib/python3.9/site-packages/grpc/_channel.py", line 1003, in _end_unary_response_blocking
    raise _InactiveRpcError(state)  # pytype: disable=not-instantiable
grpc._channel._InactiveRpcError: <_InactiveRpcError of RPC that terminated with:
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 66, in update
  File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 110, in _get_carstate_by_source
  File "/var/www/html/openWB/packages/modules/vehicles/evcc/soc.py", line 16, in updater
    return fetch_soc(vehicle_config.configuration, vehicle_update_data, vehicle)
  File "/var/www/html/openWB/packages/modules/vehicles/evcc/api.py", line 86, in fetch_soc
    raise grpc.RpcError(rpc_error)
grpc.RpcError: <_InactiveRpcError of RPC that terminated with:
2024-05-18 16:41:04,802 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev2} - EVCC: FaultState FaultStateLevel.ERROR, FaultStr <class 'grpc.RpcError'> (<_InactiveRpcError of RPC that terminated with:
	debug_error_string = "UNKNOWN:Error received from peer  {created_time:"2024-05-18T16:41:04.796329376+02:00", grpc_status:2, grpc_message:"vehicle not available"}"
>,), Traceback:
PV 1: 13,4 kWp
PV 2: in Planung (16,4 kWp)
Hausakku: E3DC S10 Pro
WB 1: openWB series2 custom
WB 2: openWB series2 custom
BEV 1: Cupra Born
BEV 2: AUDI Q4
andig
Re: Support: EVCC
Beitrag von andig »
Mhhm. Bitte mal im Forum einen Thread eröffnen und mrhinas mit rein nehmen. Bei mir geht das mit der Cloud:
gor main.go vehicle --log trace,db:error --log-headers -c cfg/audi.yaml
[main  ] INFO 2024/05/19 11:03:21 evcc 0.0.0
[main  ] INFO 2024/05/19 11:03:21 using config file: cfg/audi.yaml
Soc:      30%
Capacity: 0.0kWh
Features: []
Bubbagump
Re: Support: EVCC
andig hat geschrieben: Sa Mai 18, 2024 10:36 am Nissan soeben behoben, in 10min sollte es wieder klappen.
kann ich bestätigen, allerdings erst nachdem ich zum zweiten Mal in einer Woche evcc erneut als SOC Modul gespeichert habe und zuvor ein anderes Modul kurz ausgewählt hatte.
Oeffly
SoC-modul "EVCC" Wert wird mit 0% angezeigt
hallo,
eit gestern Mittag ca. 12 Uhr wir der SOC von denn Autos was über Evcc ausgelesen wird nicht mehr angezeigt. Die Autos haben eine SoC von 0%.
in der App wird der richtige Wert angezeigt.
Log:
2024-05-19 14:55:05,846 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev2} - EVCC: FaultState FaultStateLevel.ERROR, FaultStr <class 'grpc.RpcError'> (<_InactiveRpcError of RPC that terminated with:
debug_error_string = "UNKNOWN:Error received from peer {created_time:"2024-05-19T14:55:05.839882092+02:00", grpc_status:2, grpc_message:"vehicle not available"}"
>,), Traceback:
2024-05-19 15:03:23,663 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev1} - EVCC: FaultState FaultStateLevel.ERROR, FaultStr <class 'grpc._channel._InactiveRpcError'> (<grpc._channel._RPCState object at 0x6ec4ee50>,), Traceback:
File "/var/www/html/openWB/packages/modules/vehicles/evcc/api.py", line 57, in fetch_soc
vehicle_to_fetch = create_vehicle(evcc_config, stub)
File "/var/www/html/openWB/packages/modules/vehicles/evcc/api.py", line 33, in create_vehicle
response = stub.New(
details = "token is malformed: token contains an invalid number of segments"
debug_error_string = "UNKNOWN:Error received from peer {created_time:"2024-05-19T15:03:23.654680059+02:00", grpc_status:2, grpc_message:"token is malformed: token contains an invalid number of segments"}"
2024-05-19 15:03:24,942 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev2} - EVCC: FaultState FaultStateLevel.ERROR, FaultStr <class 'grpc.RpcError'> (<_InactiveRpcError of RPC that terminated with:
debug_error_string = "UNKNOWN:Error received from peer {grpc_message:"vehicle not available", grpc_status:2, created_time:"2024-05-19T15:03:24.937276108+02:00"}"
>,), Traceback:
PV 1: 13,4 kWp
BEV 1: Cupra Born
BEV 2: AUDI Q4
Oeffly
Re: Support: EVCC
andig hat geschrieben: So Mai 19, 2024 9:04 am Mhhm. Bitte mal im Forum einen Thread eröffnen und mrhinas mit rein nehmen. Bei mir geht das mit der Cloud:
Soc:      30%
Capacity: 0.0kWh
Features: []
okay... hab mal ein Software 2.0 einen Thread erstellt. Wie nehme ich jemanden dazu?
PV 1: 13,4 kWp
BEV 1: Cupra Born
BEV 2: AUDI Q4
andig
Re: Support: EVCC
Beitrag von andig »
ping @mrhinas
ruffieuxh
Has thanked: 4 times
Re: Support: EVCC
Beitrag von ruffieuxh »
In welchem Logfile stehen eigentlich die Meldungen vom EVCC? Auch im openwb.log file?
Ich habe derzeit mit meinem Mustang Mach-e das gleiche Problem (0% SoC) aber mit der 1.9er SW.
Schöne Grüsse
Heinz
rleidner
Has thanked: 110 times
Been thanked: 236 times
Re: Support: EVCC
Beitrag von rleidner »
ruffieuxh hat geschrieben: Mo Mai 20, 2024 8:41 am Hallo zusammen,
Schöne Grüsse
Heinz
sollte im "EV SoC-Log" sein.
