Seite 1 von 1
Pausenlos DNS Queries
Verfasst: Di Mai 06, 2025 6:11 am
von sonnenanbeter
Ich bin durch Zufall darauf aufmerksam geworden, dass meine OpenWB (2.1.7-Patch.1) pausenlos auf meinem DNS Server herum hämmert:
Tue May 6 08:04:10 2025 daemon.info dnsmasq[1]: 3485 192.168.1.100/40128 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:10 2025 daemon.info dnsmasq[1]: 3486 192.168.1.100/45296 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:10 2025 daemon.info dnsmasq[1]: 3486 192.168.1.100/45296 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:12 2025 daemon.info dnsmasq[1]: 3487 192.168.1.100/54469 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:12 2025 daemon.info dnsmasq[1]: 3487 192.168.1.100/54469 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:12 2025 daemon.info dnsmasq[1]: 3488 192.168.1.100/46924 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:12 2025 daemon.info dnsmasq[1]: 3488 192.168.1.100/46924 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:15 2025 daemon.info dnsmasq[1]: 3489 192.168.1.100/43219 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:15 2025 daemon.info dnsmasq[1]: 3489 192.168.1.100/43219 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:15 2025 daemon.info dnsmasq[1]: 3490 192.168.1.100/49676 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:15 2025 daemon.info dnsmasq[1]: 3490 192.168.1.100/49676 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:17 2025 daemon.info dnsmasq[1]: 3491 192.168.1.100/57021 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:17 2025 daemon.info dnsmasq[1]: 3491 192.168.1.100/57021 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:17 2025 daemon.info dnsmasq[1]: 3492 192.168.1.100/60946 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:17 2025 daemon.info dnsmasq[1]: 3492 192.168.1.100/60946 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:20 2025 daemon.info dnsmasq[1]: 3493 192.168.1.100/43454 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:20 2025 daemon.info dnsmasq[1]: 3493 192.168.1.100/43454 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:20 2025 daemon.info dnsmasq[1]: 3494 192.168.1.100/50729 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:20 2025 daemon.info dnsmasq[1]: 3494 192.168.1.100/50729 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:22 2025 daemon.info dnsmasq[1]: 3495 192.168.1.100/38743 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:22 2025 daemon.info dnsmasq[1]: 3495 192.168.1.100/38743 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:22 2025 daemon.info dnsmasq[1]: 3496 192.168.1.100/56257 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:22 2025 daemon.info dnsmasq[1]: 3496 192.168.1.100/56257 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:25 2025 daemon.info dnsmasq[1]: 3497 192.168.1.100/48765 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:25 2025 daemon.info dnsmasq[1]: 3497 192.168.1.100/48765 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:25 2025 daemon.info dnsmasq[1]: 3498 192.168.1.100/40922 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:25 2025 daemon.info dnsmasq[1]: 3498 192.168.1.100/40922 cached monitoring.wb-solution.de is NODATA-IPv6
Tue May 6 08:04:27 2025 daemon.info dnsmasq[1]: 3499 192.168.1.100/44827 query[A] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:27 2025 daemon.info dnsmasq[1]: 3499 192.168.1.100/44827 cached monitoring.wb-solution.de is 142.132.169.106
Tue May 6 08:04:27 2025 daemon.info dnsmasq[1]: 3500 192.168.1.100/45607 query[AAAA] monitoring.wb-solution.de from 192.168.1.100
Tue May 6 08:04:27 2025 daemon.info dnsmasq[1]: 3500 192.168.1.100/45607 cached monitoring.wb-solution.de is NODATA-IPv6
# grep -e "src=192\.168\.1\.100.*dport=53" /proc/net/nf_conntrack | wc -l
51
Das muss doch nicht sein! Ich würde es gerne verstehen und abstellen.
Re: Pausenlos DNS Queries
Verfasst: Di Mai 06, 2025 6:54 am
von openWB
Was hast du denn unter Einstellungen -> System -> Datenverwaltung -> Monitoring konfiguriert?
Verfasst: Di Mai 06, 2025 7:01 am
von sonnenanbeter
Ich habe dort nichts verändert. Es steht auf "Anbieter: - kein Monitoring".
Allerdings hatte ich mich letztes Jahr als Betatester für's Monitoring gemeldet und da wurde von euch auch irgendwas aktiviert. Ich muss gestehen, dass ich da aber schon länger nicht mehr drauf geschaut habe.
Verfasst: Di Mai 06, 2025 7:11 am
von openWB
Das Monitoring …
Verfasst: Di Mai 06, 2025 9:48 am
von sonnenanbeter
Sollte ich lieber ein Support Ticket eröffnen?
Verfasst: Di Mai 06, 2025 4:02 pm
von sonnenanbeter
Monitoring aus, Problem gelöst, vielen Dank
