Seite 1 von 1
Neues Fahrzeug lädt trotz hohem PV nur mit 16 A 1-Phasig
Verfasst: Do Jun 05, 2025 9:46 am
von Daphne
ich habe ein neues Fz eingerichtet und es lädt - trotz höherem PV - nur mit 16 A und 1-Phasig.
In der Konfig unter FZ-Profil habe ich folgende Einstellungen:
2025-06-05 11_44_11-openWB _ Konfiguration - Fahrzeuge.jpg (81.68 KiB) 755 mal betrachtet
Woran liegt das?
2025-06-05 11_40_13-openWB.jpg (369.47 KiB) 755 mal betrachtet
2025-06-05 11:39:30,610 - {root:74} - {INFO:MainThread} - # ***Start***
2025-06-05 11:39:30,614 - {root:75} - {DEBUG:MainThread} - Threads: [<_MainThread(MainThread, started 1993283968)>, <Thread(Thread-1, started daemon 1968391232)>, <Thread(Internal RFID, started 1954260032)>, <Thread(Internal GPIO, started 1875133504)>, <Thread(Subdata, started 1865413696)>, <Thread(Setdata, started 1854927936)>, <Thread(Commands, started 1844442176)>, <Thread(SoC, started 1833956416)>, <Thread(Internal Chargepoint, started 1823470656)>, <Thread(Modbus Control Server, started 1815077952)>, <Thread(ChargepointStateUpdate cp 6, started 1806685248)>, <Thread(smarthome, started 1596154944)>]
2025-06-05 11:39:30,748 - {modules.common.component_context:66} - {DEBUG:device0} - Update Komponenten ['LG ESS V1.0 Zähler', 'LG ESS V1.0 Wechselrichter', 'LG ESS V1.0 Speicher']
2025-06-05 11:39:30,757 - {modules.common.component_context:31} - {DEBUG:set values cp6} - Update Komponente ['Ladepunkt']
2025-06-05 11:39:30,775 - {urllib3.connectionpool:973} - {DEBUG:device0} - Starting new HTTPS connection (1): 192.168.178.98:443
2025-06-05 11:39:30,839 - {modules.internal_chargepoint_handler.gpio:25} - {DEBUG:Internal GPIO} - {'io_states0': <control.io_device.IoStates object at 0x6acc6130>, 'internal_io_states': <control.io_device.IoStates object at 0x6acc69a0>}
2025-06-05 11:39:30,883 - {modules.common.component_context:31} - {DEBUG:Internal GPIO} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:30,890 - {modules.common.store._api:26} - {DEBUG:Internal GPIO} - Raw data IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:30,906 - {modules.common.store._api:31} - {INFO:Internal GPIO} - Saving IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:30,927 - {modules.common.component_context:31} - {DEBUG:Internal GPIO} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:31,054 - {urllib3.connectionpool:452} - {DEBUG:device0} - https://192.168.178.98:443 "POST /v1/user/essinfo/home HTTP/1.1" 200 None
2025-06-05 11:39:31,060 - {modules.common.req:53} - {DEBUG:device0} - Get-Response: {
    "statistics":
        "pcs_pv_total_power": "4505",
        "batconv_power": "357",
        "bat_use": "1",
        "bat_status": "1",
        "bat_user_soc": "51.1",
        "load_power": "4154",
        "ac_output_power": "10",
        "load_today": "0.0",
        "grid_power": "6",
        "current_day_self_consumption": "98.0",
        "current_pv_generation_sum": "12756",
        "current_grid_feed_in_energy": "259"
    "direction":
        "is_direct_consuming_": "1",
        "is_battery_charging_": "1",
        "is_battery_discharging_": "0",
        "is_grid_selling_": "0",
        "is_grid_buying_": "0",
        "is_charging_from_grid_": "0",
        "is_discharging_to_grid_": "0"
    "operation":
        "status": "start",
        "mode": "1",
        "pcs_standbymode": "false",
        "drm_mode0": "0",
        "remote_mode": "0",
        "drm_control": "0",
        "on_matching": "false",
        "match_complete": "false"
    "wintermode":
        "winter_status": "off",
        "backup_status": "off"
    "backupmode": "",
    "pcs_fault":
        "pcs_status": "pcs_ok",
        "pcs_op_status": "pcs_run"
    "heatpump":
        "heatpump_protocol": "2",
        "heatpump_activate": "off",
        "current_temp": "0",
        "heatpump_working": "off"
    "evcharger":
        "ev_activate": "off",
        "ev_power": "0",
        "auth_method": "off",
        "evcharger_detected": "off",
        "authentication": "false"
    "gridWaitingTime": "0"
2025-06-05 11:39:31,085 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1749116361.1845195, power=393.0, imported=3226839.5831256504, exported=5338773.771260044)
2025-06-05 11:39:31,091 - {modules.common.simcount._calculate:11} - {DEBUG:device0} - time passed: 0.00275038, power1: 393, power2: 6
2025-06-05 11:39:31,094 - {modules.common.simcount._calculate:27} - {DEBUG:device0} - power did not change sign. Total energy: 0.5487
2025-06-05 11:39:31,099 - {modules.common.simcount._simcount:65} - {DEBUG:device0} - imported: 0.5487 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1749116371.085875, power=6.0, imported=3226840.131825768, exported=5338773.771260044)
2025-06-05 11:39:31,105 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=3226840.131825768, exported=5338773.771260044, power=6.0, frequency=50)
2025-06-05 11:39:31,111 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1749116361.2182908, power=-4829.0, imported=0.0, exported=16071486.88627998)
2025-06-05 11:39:31,119 - {modules.common.simcount._calculate:11} - {DEBUG:device0} - time passed: 0.00274808, power1: -4829, power2: -4505
2025-06-05 11:39:31,123 - {modules.common.simcount._calculate:27} - {DEBUG:device0} - power did not change sign. Total energy: -12.8253
2025-06-05 11:39:31,128 - {modules.common.simcount._simcount:65} - {DEBUG:device0} - imported: 0 Wh, exported: 12.8253 Wh, new state: SimCounterState(timestamp=1749116371.111365, power=-4505.0, imported=0.0, exported=16071499.711551545)
2025-06-05 11:39:31,148 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-4505.0, exported=16071499.711551545, imported=0, dc_power=None)
2025-06-05 11:39:31,152 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1749116361.2434077, power=1038.0, imported=3101343.077377879, exported=2605469.2939128606)
2025-06-05 11:39:31,157 - {modules.common.simcount._calculate:11} - {DEBUG:device0} - time passed: 0.0027526, power1: 1038, power2: 357
2025-06-05 11:39:31,162 - {modules.common.simcount._calculate:27} - {DEBUG:device0} - power did not change sign. Total energy: 1.91994
2025-06-05 11:39:31,168 - {modules.common.simcount._simcount:65} - {DEBUG:device0} - imported: 1.91994 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1749116371.152769, power=357.0, imported=3101344.997316643, exported=2605469.2939128606)
2025-06-05 11:39:31,183 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=3101344.997316643, exported=2605469.2939128606, power=357.0, soc=51.1, currents=[0.0, 0.0, 0.0])
2025-06-05 11:39:32,373 - {modules.chargepoints.external_openwb.chargepoint_module:82} - {DEBUG:set values cp6} - Empfange MQTT Daten für Ladepunkt 6: {'openWB/internal_chargepoint/0/get/voltages': [232.97, 244.06, 243.96], 'openWB/internal_chargepoint/0/get/currents': [14.8, -0.03, 0.03], 'openWB/internal_chargepoint/0/get/frequency': 49.97, 'openWB/internal_chargepoint/0/get/power_factors': [1.0, -1.0, 1.0], 'openWB/internal_chargepoint/0/get/imported': 7760132.81, 'openWB/internal_chargepoint/0/get/exported': 0, 'openWB/internal_chargepoint/0/get/power': 3444.19, 'openWB/internal_chargepoint/0/get/powers': [3443.16, -5.84, 6.86], 'openWB/internal_chargepoint/0/get/phases_in_use': 1, 'openWB/internal_chargepoint/0/get/charge_state': True, 'openWB/internal_chargepoint/0/get/plug_state': True, 'openWB/internal_chargepoint/0/get/evse_current': 16.0, 'openWB/internal_chargepoint/0/get/serial_number': '21262168', 'openWB/internal_chargepoint/0/get/error_timestamp': None, 'openWB/internal_chargepoint/0/get/max_evse_current': 32, 'openWB/internal_chargepoint/0/get/version': '2.1.8-Alpha.2', 'openWB/internal_chargepoint/0/get/current_branch': 'master', 'openWB/internal_chargepoint/0/get/current_commit': '2025-06-04 13:00:47 +0200 [8ddb00dd6]', 'openWB/internal_chargepoint/0/get/rfid': None}
2025-06-05 11:39:32,382 - {modules.common.store._api:26} - {DEBUG:set values cp6} - Raw data ChargepointState(currents=[14.8, -0.03, 0.03], powers=[3443.16, -5.84, 6.86], voltages=[232.97, 244.06, 243.96], frequency=49.97, imported=7760132.81, exported=0, power=3444.19, serial_number=21262168, phases_in_use=1, charge_state=True, plug_state=True, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[1.0, -1.0, 1.0], soc=None, soc_timestamp=None, evse_current=16.0, max_evse_current=32, vehicle_id=None, current_branch=None, current_commit=None, version=None)
2025-06-05 11:39:32,390 - {modules.common.component_context:31} - {DEBUG:component3} - Update Komponente ['LG ESS V1.0 Wechselrichter']
2025-06-05 11:39:32,393 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-4505.0, exported=16071499.711551545, imported=0, dc_power=None)
2025-06-05 11:39:32,397 - {modules.common.store._api:31} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-4505.0, exported=16071499.711551545, imported=0, dc_power=None)
2025-06-05 11:39:32,403 - {modules.common.component_context:31} - {DEBUG:component5} - Update Komponente ['LG ESS V1.0 Speicher']
2025-06-05 11:39:32,408 - {modules.common.store._api:31} - {INFO:component5} - Saving BatState(imported=3101344.997316643, exported=2605469.2939128606, power=357.0, soc=51.1, currents=[0.0, 0.0, 0.0])
2025-06-05 11:39:32,410 - {modules.common.component_context:31} - {DEBUG:update values cp6} - Update Komponente ['Ladepunkt']
2025-06-05 11:39:32,428 - {modules.common.store._api:31} - {INFO:update values cp6} - Saving ChargepointState(currents=[14.8, -0.03, 0.03], powers=[3443.16, -5.84, 6.86], voltages=[232.97, 244.06, 243.96], frequency=49.97, imported=7760132.81, exported=0, power=3444.19, serial_number=21262168, phases_in_use=1, charge_state=True, plug_state=True, rfid=None, rfid_timestamp=None, charging_current=0, charging_power=0, charging_voltage=0, power_factors=[1.0, -1.0, 1.0], soc=None, soc_timestamp=None, evse_current=16.0, max_evse_current=32, vehicle_id=None, current_branch=None, current_commit=None, version=None)
2025-06-05 11:39:32,687 - {modules.common.component_context:31} - {DEBUG:component1} - Update Komponente ['LG ESS V1.0 Zähler']
2025-06-05 11:39:32,690 - {modules.common.store._api:31} - {INFO:component1} - Saving CounterState(currents=[0.0, 0.0, 0.0], powers=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], imported=3226840.131825768, exported=5338773.771260044, power=6.0, frequency=50)
2025-06-05 11:39:32,780 - {modules.common.component_context:31} - {DEBUG:get io state} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:32,786 - {modules.common.store._api:26} - {DEBUG:get io state} - Raw data IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:32,789 - {modules.common.component_context:31} - {DEBUG:get io state} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:33,873 - {modules.common.store._api:26} - {DEBUG:get io state} - Raw data IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:33,881 - {modules.common.component_context:31} - {DEBUG:publish io state} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:33,885 - {modules.common.store._api:31} - {INFO:publish io state} - Saving IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:33,888 - {modules.common.component_context:31} - {DEBUG:publish io state} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:33,904 - {modules.common.store._api:31} - {INFO:publish io state} - Saving IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:33,987 - {modules.internal_chargepoint_handler.gpio:25} - {DEBUG:Internal GPIO} - {'io_states0': <control.io_device.IoStates object at 0x6ae56880>, 'internal_io_states': <control.io_device.IoStates object at 0x6ae56160>}
2025-06-05 11:39:33,995 - {modules.common.component_context:31} - {DEBUG:Internal GPIO} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:34,014 - {modules.common.store._api:26} - {DEBUG:Internal GPIO} - Raw data IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:34,052 - {modules.common.store._api:31} - {INFO:Internal GPIO} - Saving IoState(analog_input=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False})
2025-06-05 11:39:34,084 - {modules.common.component_context:31} - {DEBUG:Internal GPIO} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:34,188 - {control.counter:161} - {INFO:MainThread} - Verbleibende Ströme an Zähler 1: [49.93, 34.97, 35.03]A
2025-06-05 11:39:34,197 - {control.counter:188} - {INFO:MainThread} - Verbleibende Leistung an Zähler 1: 27471.33W
2025-06-05 11:39:34,203 - {control.chargepoint.chargepoint:537} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2025-06-05 11:39:34,207 - {control.chargepoint.chargepoint:523} - {DEBUG:MainThread} - Phasenzahl Lademodus: 1
2025-06-05 11:39:34,216 - {control.chargepoint.chargepoint:704} - {INFO:MainThread} - LP 6, EV: TAVASCAN (EV-Nr.3): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.PV_CHARGING, Phasen: 1, Priorität: False, mittlerer Ist-Strom: 14.93
2025-06-05 11:39:34,221 - {control.bat_all:320} - {DEBUG:MainThread} - Speicher-Leistung nicht begrenzen, da keine Ladepunkte in einem Lademodus mit Netzbezug sind.
2025-06-05 11:39:34,226 - {control.bat_all:200} - {INFO:MainThread} - 357.0W verbleibende Speicher-Leistung
2025-06-05 11:39:34,233 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1749116364.4254863, power=735.6799999999998, imported=10332694.222417362, exported=406.03196724355223)
2025-06-05 11:39:34,256 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00272432, power1: 735.68, power2: 676.67
2025-06-05 11:39:34,259 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 1.92384
2025-06-05 11:39:34,265 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 1.92384 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1749116374.233021, power=676.6700000000001, imported=10332696.146260643, exported=406.03196724355223)
2025-06-05 11:39:34,277 - {control.data:295} - {INFO:MainThread} - bat5
BatData(get=Get(currents=[0.0, 0.0, 0.0], soc=51, daily_exported=1249.0, daily_imported=4076.0, imported=3101345.0, exported=2605469.29, fault_state=0, fault_str='Kein Fehler.', power=357.0, power_limit_controllable=False), set=Set(power_limit=0))
2025-06-05 11:39:34,283 - {control.data:262} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True, power_limit_mode='no_limit'), get=Get(power_limit_controllable=False, soc=51, daily_exported=1249.0, daily_imported=4076.0, fault_str='Kein Fehler.', fault_state=0, imported=3101345.0, exported=2605469.29, power=357.0), set=Set(charging_power_left=357.0, power_limit=None, regulate_up=False))
2025-06-05 11:39:34,288 - {control.data:263} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=5304.0, daily_exported=0.0, power=3477.33, imported=7760136.23, exported=0))
2025-06-05 11:39:34,293 - {control.data:295} - {INFO:MainThread} - cp6
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, current_plan=None, failed_phase_switches=0, limit=LoadmanagementLimit(message=None, limiting_value=None), min_current=6, phases=1, prio=False, required_current=6, required_currents=[6, 0.0, 0.0], state=4, submode=<Chargemode.PV_CHARGING: 'pv_charging'>, timestamp_charge_start=1749110934.905536, timestamp_chargemode_changed=1749109033.348891, timestamp_last_phase_switch=0, timestamp_phase_switch_buffer_start=None, timestamp_switch_on_off=None), get=Get(charge_state=True, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=46), current_branch='master', current_commit='2025-06-04 13:00:47 +0200 [8ddb00dd6]', currents=[14.93, -0.03, 0.03], daily_imported=5304.0, daily_exported=0.0, error_timestamp=None, evse_current=16.0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=7760136.23, max_evse_current=32, phases_in_use=1, plug_state=True, power=3477.33, powers=[3476.48, -5.92, 6.77], rfid_timestamp=None, rfid=None, serial_number='21262168', soc=None, soc_timestamp=None, state_str=None, vehicle_id=None, version='2.1.8-Alpha.2', voltages=[233.05, 244.14, 244.04]), set=Set(charging_ev=3, charging_ev_prev=3, charge_template=ChargeTemplate(data=ChargeTemplateData(id=2, name='Tavascan Ladeprofil', prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={'1': TimeChargingPlan(active=False, frequency=Frequency(selected='once', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], current=16, dc_current=145, id=1, limit=Limit(selected='none', amount=1000, soc=50), name='Zeitladen-Standard', phases_to_use=1)}), chargemode=Chargemode(selected='pv_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='soc', amount=1000, soc=80), min_current=0, min_soc_current=6, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans={'1': ScheduledChargingPlan(active=True, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[True, True, True, True, True, True, True]), current=12, dc_current=145, et_active=False, id=1, name='Zielladen Tavascan 40% bis 05:00 Uhr', limit=ScheduledLimit(selected='soc', amount=1000, soc_limit=80, soc_scheduled=40), phases_to_use=0, phases_to_use_pv=0, time='05:00')}), instant_charging=InstantCharging(current=12, dc_current=145, limit=Limit(selected='soc', amount=1000, soc=40), phases_to_use=3)))), current=16, energy_to_charge=0, ev_prev=3, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', costs=0.24280000000000002, imported_at_mode_switch=7754560.06, imported_at_plugtime=7754560.06, imported_since_mode_switch=5563.959999999963, imported_since_plugged=5563.959999999963, range_charged=29.283999999999804, time_charged='1:53', timestamp_start_charging=1749109584.569688, ev=3, prio=False, rfid=None, serial_number=None, soc_at_start=43, soc_at_end=None, range_at_start=194, range_at_end=None), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time=1749108684.547346, required_power=1398.3000000000002, rfid=None, current_prev=16, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6d6b2700>, ocpp_transaction_id=None, charge_state_prev=True), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=3, name='Garage', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=False, id=6, ocpp_chargebox_id=None))
2025-06-05 11:39:34,319 - {control.data:295} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={'0': AutolockPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], name='Standard Autolock-Plan')}, wait_for_charging_end=False), charging_type='AC', id=0, max_current_multi_phases=32, max_current_single_phase=16, dc_max_current=435, name='Standard Ladepunkt-Profil', disable_after_unplug=False, valid_tags=[])
2025-06-05 11:39:34,326 - {control.data:295} - {INFO:MainThread} - counter1
CounterData(config=Config(max_power_errorcase=7000, max_currents=[35, 35, 35], max_total_power=24000), get=Get(powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], voltages=[230.0, 230.0, 230.0], power_factors=[0.0, 0.0, 0.0], frequency=50, daily_exported=175.0, daily_imported=3218.0, imported=3226840.131825768, exported=5338773.771260044, fault_state=0, fault_str='Kein Fehler.', power=6.0), set=Set(error_timer=None, reserved_surplus=0, released_surplus=0, raw_power_left=27471.33, raw_currents_left=[49.93, 34.97, 35.03], surplus_power_left=0))
2025-06-05 11:39:34,333 - {control.data:267} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(home_consumption_source_id=None, consider_less_charging=False), get=Get(hierarchy=[{'id': 1, 'type': 'counter', 'children': [{'id': 3, 'type': 'inverter', 'children': []}, {'id': 5, 'type': 'bat', 'children': []}, {'id': 6, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=676.6700000000001, smarthome_power_excluded_from_home_consumption=0, invalid_home_consumption=0, daily_yield_home_consumption=8307.0, imported_home_consumption=10332696.146260643, disengageable_smarthome_power=0))
2025-06-05 11:39:34,343 - {control.data:295} - {INFO:MainThread} - ct0
ChargeTemplateData(id=0, name='Standard-Lade-Profil', prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={'0': TimeChargingPlan(active=False, frequency=Frequency(selected='once', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], current=16, dc_current=145, id=0, limit=Limit(selected='none', amount=1000, soc=50), name='Zeitladen-Standard', phases_to_use=1)}), chargemode=Chargemode(selected='stop', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='none', amount=1000, soc=50), min_current=0, min_soc_current=6, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=6, dc_current=145, limit=Limit(selected='soc', amount=1000, soc=5), phases_to_use=1)))
2025-06-05 11:39:34,360 - {control.data:295} - {INFO:MainThread} - ct2
2025-06-05 11:39:34,379 - {control.data:295} - {INFO:MainThread} - ct3
ChargeTemplateData(id=3, name='Born Lade-Profil', prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={'2': TimeChargingPlan(active=False, frequency=Frequency(selected='once', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], current=16, dc_current=145, id=2, limit=Limit(selected='none', amount=1000, soc=50), name='Zeitladen-Standard', phases_to_use=1)}), chargemode=Chargemode(selected='pv_charging', eco_charging=EcoCharging(current=6, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50), max_price=0.0002, phases_to_use=3), pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, feed_in_limit=False, limit=Limit(selected='soc', amount=1000, soc=50), min_current=0, min_soc_current=6, min_soc=0, phases_to_use=0, phases_to_use_min_soc=3), scheduled_charging=ScheduledCharging(plans={'2': ScheduledChargingPlan(active=True, frequency=Frequency(selected='weekly', once=['2021-11-01', '2021-11-05'], weekly=[True, True, True, True, True, False, False]), current=12, dc_current=145, et_active=False, id=2, name='Zielladen Born 50% bis 04:00 Uhr', limit=ScheduledLimit(selected='soc', amount=1000, soc_limit=80, soc_scheduled=50), phases_to_use=0, phases_to_use_pv=0, time='04:00')}), instant_charging=InstantCharging(current=12, dc_current=145, limit=Limit(selected='soc', amount=1000, soc=50), phases_to_use=3)))
2025-06-05 11:39:34,395 - {control.data:295} - {INFO:MainThread} - ev0
EvData(set=Set(soc_error_counter=1), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=None, soc_request_timestamp=None, soc_timestamp=None, force_soc_update=True, range=None, fault_state=0, fault_str='Kein Fehler.'))
2025-06-05 11:39:34,400 - {control.data:295} - {INFO:MainThread} - ev1
EvData(set=Set(soc_error_counter=0), charge_template=3, ev_template=2, name='BORN', tag_id=[], get=Get(soc=52, soc_request_timestamp=1749116160.310561, soc_timestamp=1749115219.601, force_soc_update=False, range=192, fault_state=0, fault_str='Kein Fehler.'))
2025-06-05 11:39:34,406 - {control.data:295} - {INFO:MainThread} - ev2
EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='neues Fahrzeug', tag_id=[], get=Get(soc=None, soc_request_timestamp=None, soc_timestamp=None, force_soc_update=True, range=None, fault_state=0, fault_str='Kein Fehler.'))
2025-06-05 11:39:34,411 - {control.data:295} - {INFO:MainThread} - ev3
EvData(set=Set(soc_error_counter=0), charge_template=2, ev_template=1, name='TAVASCAN', tag_id=[], get=Get(soc=46, soc_request_timestamp=1749116243.285333, soc_timestamp=1749115004.425, force_soc_update=False, range=205, fault_state=0, fault_str='Kein Fehler.'))
2025-06-05 11:39:34,417 - {control.data:295} - {INFO:MainThread} - et0
EvTemplateData(dc_min_current=0, dc_max_current=0, id='0', name='Standard-Fahrzeug-Profil', max_current_multi_phases=6, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=1000, min_current=6, max_current_single_phase=6, battery_capacity=1000, efficiency=90, nominal_difference=1, keep_charge_active_duration=30)
2025-06-05 11:39:34,423 - {control.data:295} - {INFO:MainThread} - et1
EvTemplateData(dc_min_current=0, dc_max_current=0, id='1', name='Tavascan Fahrzeug-Profil', max_current_multi_phases=32, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=19000, min_current=6, max_current_single_phase=16, battery_capacity=77000, efficiency=90, nominal_difference=1, keep_charge_active_duration=40)
2025-06-05 11:39:34,428 - {control.data:295} - {INFO:MainThread} - et2
EvTemplateData(dc_min_current=0, dc_max_current=0, id='0', name='Born Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=19000, min_current=6, max_current_single_phase=32, battery_capacity=58000, efficiency=90, nominal_difference=1, keep_charge_active_duration=30)
2025-06-05 11:39:34,434 - {control.data:271} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(phase_switch_delay=6, pv_charging=PvCharging(bat_power_reserve=1000, bat_power_reserve_active=True, control_range=[-115, 115], feed_in_yield=0, phase_switch_delay=7, bat_power_discharge=100, bat_power_discharge_active=False, min_bat_soc=50, bat_mode='ev_mode', switch_off_delay=30, switch_off_threshold=0, switch_on_delay=30, switch_on_threshold=1400), retry_failed_phase_switches=True, unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='primary', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp=None, http_api=False, mqtt_bridge=False, prices=Prices(bat=0, cp=0, grid=0.000287, pv=7e-05), range_unit='km')
2025-06-05 11:39:34,443 - {control.data:272} - {INFO:MainThread} - general_data-display
primary
2025-06-05 11:39:34,448 - {control.data:273} - {INFO:MainThread} - graph_data
2025-06-05 11:39:34,454 - {control.data:325} - {INFO:MainThread} - io_action0
{'name': 'RSE-Kontakt', 'id': 0, 'configuration': {'io_device': 0, 'input_pattern': [{'value': 1, 'input_matrix': {'RSE1': False, 'RSE2': False}}, {'value': 0, 'input_matrix': {'RSE1': False, 'RSE2': True}}, {'value': 0, 'input_matrix': {'RSE1': True, 'RSE2': False}}, {'value': 0, 'input_matrix': {'RSE1': True, 'RSE2': True}}], 'devices': [['cp6']]}, 'type': 'ripple_control_receiver', 'group': 'controllable_consumers'}
2025-06-05 11:39:34,459 - {control.data:295} - {INFO:MainThread} - io_states0
IoDeviceData(get=Get(analog_input=None, analog_output=None, digital_input={'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}, digital_output={'LED1': False, 'LED2': False, 'LED3': False}, fault_str='Kein Fehler.', fault_state=0), set=Set(analog_output=None, digital_output={'LED1': False, 'LED2': False, 'LED3': False}))
2025-06-05 11:39:34,464 - {control.data:295} - {INFO:MainThread} - internal_io_states
2025-06-05 11:39:34,469 - {control.data:276} - {INFO:MainThread} - optional_data
OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=180, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x69950ee0>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, url=None, version='ocpp1.6'))
2025-06-05 11:39:34,474 - {control.data:295} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=10000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=13318.0, monthly_exported=140003.01799999923, yearly_exported=5935286.044, exported=16071499.712, fault_state=0, fault_str='Kein Fehler.', power=-4505.0))
2025-06-05 11:39:34,478 - {control.data:278} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=13318.0, fault_str='Kein Fehler.', fault_state=0, monthly_exported=140003.01799999923, yearly_exported=5935286.044, exported=16071499.712, power=-4505.0))
2025-06-05 11:39:34,482 - {control.data:295} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '192.168.178.71', 'current_commit': '2025-06-04 13:00:47 +0200 [8ddb00dd6]', 'current_branch': 'master', 'current_branch_commit': '2025-06-04 13:00:47 +0200 [8ddb00dd6]', 'current_missing_commits': [], 'datastore_version': 83, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.8-Alpha.2', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1749116364, 'time': '11:39:24', 'grid': 0.393, 'house-power': 0.736, 'charging-all': 3.448, 'pv-all': 4.829, 'cp6-power': 3.448, 'ev1-soc': 52, 'ev3-soc': 46, 'bat-all-power': 1.038, 'bat-all-soc': 51}, 'installAssistantDone': True, 'serial_number': 'owbl11111503', 'secondary_auto_update': True, 'module_update_completed': True, 'mac_address': 'b8:27:eb:37:01:53'}
2025-06-05 11:39:34,489 - {control.data:308} - {INFO:MainThread} - device0
{'name': 'LG ESS V1.0', 'type': 'lg', 'vendor': 'lg', 'id': 0, 'configuration': {'ip_address': '192.168.178.98', 'password': '***REDACTED***'}}
2025-06-05 11:39:34,492 - {control.data:310} - {INFO:MainThread} - component1
{'name': 'LG ESS V1.0 Zähler', 'info': {'manufacturer': None, 'model': None}, 'type': 'counter', 'id': 1, 'configuration': {}}
2025-06-05 11:39:34,496 - {control.data:310} - {INFO:MainThread} - component3
{'name': 'LG ESS V1.0 Wechselrichter', 'info': {'manufacturer': None, 'model': None}, 'type': 'inverter', 'id': 3, 'configuration': {}}
2025-06-05 11:39:34,499 - {control.data:310} - {INFO:MainThread} - component5
{'name': 'LG ESS V1.0 Speicher', 'info': {'manufacturer': None, 'model': None}, 'type': 'bat', 'id': 5, 'configuration': {}}
2025-06-05 11:39:34,503 - {control.data:318} - {INFO:MainThread} - iolocal
{'name': 'Kontakte der AddOn-Platine', 'type': 'add_on', 'id': 0, 'configuration': {'host': 'localhost'}, 'input': {'analog': {}, 'digital': {'RSE1': False, 'RSE2': False, 'nurPV': False, 'SofortLa': False, 'Stop': False, 'MinPV': False, 'Standby': False}}, 'output': {'analog': {}, 'digital': {'LED1': False, 'LED2': False, 'LED3': False}}}
2025-06-05 11:39:34,507 - {control.data:318} - {INFO:MainThread} - io0
2025-06-05 11:39:34,512 - {control.data:282} - {INFO:MainThread} -
2025-06-05 11:39:34,514 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2025-06-05 11:39:34,517 - {control.algorithm.algorithm:63} - {DEBUG:MainThread} - Ladepunkt 6: Prüfen, ob Phasenumschaltung durchgeführt werden soll.
2025-06-05 11:39:34,519 - {control.chargepoint.chargepoint:537} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2025-06-05 11:39:34,522 - {control.ev.ev:346} - {DEBUG:MainThread} - Genutzter Strom: 14.93A, Überschuss: 351.0W, benötigte neue Leistung: 460W
2025-06-05 11:39:34,525 - {control.ev.ev:370} - {DEBUG:MainThread} - Keine Phasenumschaltung, da nicht ausreichend Überschuss für mehrphasiges Laden zur Verfügung steht.
2025-06-05 11:39:34,529 - {control.counter:404} - {DEBUG:MainThread} - LP6 Switch-Off-Threshold prüfen: -351.0W, Schwelle: 0W, freigegebener Überschuss 0W, Einspeisegrenze 0W
2025-06-05 11:39:34,532 - {control.counter:249} - {DEBUG:MainThread} - Anpassen des Regelbereichs 0.0W
2025-06-05 11:39:34,535 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2025-06-05 11:39:34,539 - {control.algorithm.min_current:20} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 1
2025-06-05 11:39:34,543 - {control.counter:199} - {DEBUG:MainThread} - Zähler 1: [43.93, 34.97, 35.03]A verbleibende Ströme, 26073.030000000002W verbleibende Leistung
2025-06-05 11:39:34,546 - {control.algorithm.common:83} - {INFO:MainThread} - LP6: Stromstärke 6A
2025-06-05 11:39:34,549 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Soll-Strom setzen**
2025-06-05 11:39:34,553 - {control.counter:249} - {DEBUG:MainThread} - Anpassen des Regelbereichs 0.0W
2025-06-05 11:39:34,555 - {control.counter:516} - {DEBUG:MainThread} - Zähler 1: Begrenzung der verbleibenden Leistung auf 2430.0300000000025W
2025-06-05 11:39:34,558 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2025-06-05 11:39:34,563 - {control.algorithm.filter_chargepoints:102} - {DEBUG:MainThread} - Geordnete Ladepunkte [6]
2025-06-05 11:39:34,566 - {control.algorithm.surplus_controlled:50} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.PV_CHARGING - False, Zähler 1
2025-06-05 11:39:34,569 - {control.algorithm.common:162} - {DEBUG:MainThread} - LP 6 lädt deutlich unter dem Sollstrom und wird nur mit [14.93, -0.03, 0.03]A berücksichtigt.
2025-06-05 11:39:34,573 - {control.counter:206} - {DEBUG:MainThread} - Zähler 1: [35.0, 34.97, 35.03]A verbleibende Ströme, 348.8935000000024W verbleibender Überschuss
2025-06-05 11:39:34,576 - {control.algorithm.common:83} - {INFO:MainThread} - LP6: Stromstärke 16A
2025-06-05 11:39:34,578 - {control.process:29} - {INFO:MainThread} - # Ladung starten.
2025-06-05 11:39:34,582 - {control.process:133} - {INFO:MainThread} - LP6: set current 16 A, state CHARGING_ALLOWED
2025-06-05 11:39:34,598 - {modules.common.component_context:31} - {DEBUG:set current cp6} - Update Komponente ['Ladepunkt']
2025-06-05 11:39:34,601 - {modules.common.component_context:31} - {DEBUG:set output io0} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:34,618 - {modules.common.component_context:31} - {DEBUG:set output io0} - Update Komponente ['Kontakte der AddOn-Platine']
2025-06-05 11:39:35,148 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/bat/get/imported, Payload 3101345.0, vorherige Payload: 3101343.08
2025-06-05 11:39:35,161 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/bat/get/power, Payload 357.0, vorherige Payload: 1038.0
2025-06-05 11:39:35,181 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/bat/set/charging_power_left, Payload 357.0, vorherige Payload: 1038.0
2025-06-05 11:39:35,185 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/power, Payload 3477.33, vorherige Payload: 3448.32
2025-06-05 11:39:35,190 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/imported, Payload 7760136.23, vorherige Payload: 7760124.02
2025-06-05 11:39:35,195 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/counter/set/home_consumption, Payload 676.6700000000001, vorherige Payload: 735.6799999999998
2025-06-05 11:39:35,202 - {helpermodules.changed_values_handler:127} - {DEBUG:MainThread} - Topic openWB/set/counter/set/imported_home_consumption, Payload 10332696.146260643, vorherige Payload: 10332694.222417362
Log des internen Ladepunktes
MQTT-Log
SoC-Log
Protokoll des letzten Updates
Protokoll des Remote-Dienstes
Protokoll des SmartHome Dienstes
Protokoll der Datenmigration
Protokoll über die Schaltvorgänge von steuerbaren Verbrauchseinrichtungen
Re: Neues Fahrzeug lädt trotz hohem PV nur mit 16 A 1-Phasig
Verfasst: Do Jun 05, 2025 10:10 am
von Gero
Da gibt es ganz viele Möglichkeiten, die einfachste wäre, Du hättest den Tavascan als einphasig ladendes Fahrzeug konfiguriert. ;)
Wenn Du den Ladepunkt aufklappst, oder auf der Status-Seite nachschaust, kommt da noch ein erklärender Text in blau.
und auf der Status-Seite steht, wieviele Phasen vorgegeben sind. Die eingekreiste Zahl sagt nur, auf wievielen Strom fließt.
Verfasst: Do Jun 05, 2025 11:13 am
von Daphne
Vielen Dank.
Wenn ich den Ladepunkt auf der GUI aufklappe kommt nichts weiteres als "Lädt ..." kann ich aber auch nichts öffnen.
Unter Status steht unter "Vorgabe" 1 Phase:
2025-06-05 13_08_17-openWB _ Status.jpg (69.74 KiB) 737 mal betrachtet
Nur wo kann ich einstellen, das er auch bei höherem PV 3-Phasig lädt?
In dem Ladeprofil steht z.B. bei [Anzahl Phasen] automatisch ...
Verfasst: Do Jun 05, 2025 12:06 pm
von aiole
1. Test: Sofortladen -> Geht dann 3p?
2. bei v2.1.7:
Einstell. -> Ladeeinstell. -> PV-Laden -> Phasenumschaltung -> Anzahl Phasen -> Automatik
3. Wie ist die Speicherbeachtung konfiguriert (Einstell. -> Ladeeinstell. -> PV-Laden)? Lt. Diagramm geht die Rest-PV in den Speicher und steht damit nicht dem EV zur Verfügung.
Verfasst: Do Jun 05, 2025 12:14 pm
von Daphne
zu 1: Bei Sofortladen gehen auch 3p
zu 2: ich habe Version 2.1.8
zu 3. Vorrang Auto eingestellt
Verfasst: Do Jun 05, 2025 12:22 pm
von aiole
Oh - mit ner Alpha unterwegs - hoffentlich als Testinstallation.
In 2.1.8 werden etliche Änderungen im Vergleich zur 2.1.7 vorgenommen. Für produktiven Betrieb sind nur die Release-Versionen zu verwenden.
Als alpha-Tester immer die brandaktuelle Version nehmen und im passenden 2.1.8-alpha-Chat die Bugs kommunizieren.
Du kannst noch mit der Speicherbeachtung probieren. -> Speicher Mindest-SoC
Ev. klemmt was bei Fahrzeugvorrang.
Verfasst: Do Jun 05, 2025 12:49 pm
von Gero
Ich hab' mir noch mal deinen Graphen angezeigt. Da ist doch gar kein Überschuss, der noch ins Auto könnte - der Überschuss geht ja in den Speicher. Lädst Du da mit Prio Speicher? Auch gibt es da immer wieder Einbrüche in der PV-Leistung. Wenn diese Einbrüche unter 3,4kW gehen, wird der Zähler zur Phasenumschaltung wieder auf Null gesetzt. (Das ist aktuell sehr versionsabhängig, die 2.1.7 ist da ein bisschen anders als die 2.1.8)
Von daher ist der beste Hinweis schon der blau hinterlegte. Da steht auch, dass bald die Phasen umgeschaltet werden. Oder aber das schon zu oft versucht wurde, und es nicht geklappt hat. (ab der 2.1.8 alpha2)
Ob ich mir das mit den vielen Änderungen aktuell antuen wollte, möchte ich bezweifeln. Ich kenne die Software eigentlich schon ganz gut, bin gerade im Bereich Phasenumschaltung ein bisschen lost. Ich würde das als Einsteiger erst mal mit dem letzten Release versuchen.
Verfasst: Do Jun 05, 2025 1:55 pm
von Daphne
Gero hat geschrieben: Do Jun 05, 2025 12:49 pm Ich hab' mir noch mal deinen Graphen angezeigt. Da ist doch gar kein Überschuss, der noch ins Auto könnte - der Überschuss geht ja in den Speicher. Lädst Du da mit Prio Speicher? Auch gibt es da immer wieder Einbrüche in der PV-Leistung. Wenn diese Einbrüche unter 3,4kW gehen, wird der Zähler zur Phasenumschaltung wieder auf Null gesetzt. (Das ist aktuell sehr versionsabhängig, die 2.1.7 ist da ein bisschen anders als die 2.1.8)
Wie komme ich auf das letzte Release zurück?
Verfasst: Do Jun 05, 2025 3:54 pm
von aiole
auf Release switchen (autom. Reboot) und dein 2.1.7-Backup einspielen
Zwischenzeitliche Daten sind dann natürlich weg.
ohne Backup -> Werkseinstellung + Neukonfig (alle Logs weg)
Alternativ bis 2.1.8-release gedulden.
Oder den bug in der alpha mitsuchen, um das Release schneller fertig zu bekommen. Erfordert aktive Mitarbeit.
