SMA Energy Meter install script
Re: SMA Energy Meter install script
die sma Auslesung läuft nicht, daher die ganzen Fehler.
Was gibt denn:
ls -lah /run/shm/
ls -lah /opt/smaemd/
cat /etc/smaemd/config
aus?
Was gibt denn:
ls -lah /run/shm/
aus?
pi@raspberrypi:/run/shm $ ls -lah /run/shm/
total 4.0K
drwxrwxrwt 2 root root 60 Apr 14 12:57 .
drwxr-xr-x 14 root root 3.3K Apr 14 13:31 ..
-rw-rw-rw- 1 root root 24 Apr 14 12:57 em-status
pi@raspberrypi:/run/shm $ ls -lah /opt/smaemd
total 96K
drwxr-xr-x 5 root root 4.0K Apr 14 12:53 .
drwxr-xr-x 4 root root 4.0K Apr 14 12:53 ..
-rw-r--r-- 1 root root 910 Apr 14 12:53 changelog
-rw-r--r-- 1 root root 3.7K Apr 14 12:53 config.sample
-rw-r--r-- 1 root root 1012 Apr 14 12:53 contributors.md
-rw-r--r-- 1 root root 2.8K Apr 14 12:53 daemon3x.py
drwxr-xr-x 3 root root 4.0K Apr 14 12:53 features
drwxr-xr-x 8 root root 4.0K Apr 14 12:53 .git
-rw-r--r-- 1 root root 702 Apr 14 12:53 .gitignore
-rw-r--r-- 1 root root 665 Apr 14 12:53 knownProblems.md
-rw-r--r-- 1 root root 18K Apr 14 12:53 LICENSE
drwxr-xr-x 2 root root 4.0K Apr 14 12:53 __pycache__
-rw-r--r-- 1 root root 2.0K Apr 14 12:53 README.md
-rwxr-xr-x 1 root root 4.6K Apr 14 12:53 sma-daemon.py
-rwxr-xr-x 1 root root 5.1K Apr 14 12:53 sma-em-measurement.py
-rw-r--r-- 1 root root 6.3K Apr 14 12:53 smaem.py
-rw-r--r-- 1 root root 443 Apr 14 12:53 systemd-settings
pi@raspberrypi:/run/shm $ cat /etc/smaemd/config
[SMA-EM]
# serials of sma-ems the daemon should take notice
# seperated by space
serials=157044575
# features could filter serials to, but wouldn't see serials if these serials was not defines in SMA-EM serials
# list of features to load/run
features=simplefswriter sample
[DAEMON]
pidfile=/run/smaemd.pid
# listen on an interface with the given ip
# use 0.0.0.0 for any interface
ipbind=0.0.0.0
# multicast ip and port of sma-datagrams
# defaults
mcastgrp=239.12.255.254
mcastport=9522
# each feature/plugin has its own section
# called FEATURE-[featurename]
# the feature section is required if a feature is listed in [SMA-EM]features
[FEATURE-simplefswriter]
# list serials simplefswriter notice
serials=157044575
# measurement vars simplefswriter should write to filesystem (only from smas with serial in serials)
values=pregard pregardcounter psurplus psurplus psurpluscounter p1regard p1surplus p2regard p2surplus p3regard p3surplus
[FEATURE-sample]
nothing=here
Version 1.9.101 - DIY
Raspberry pi 3, OS Stretch, 2 Ladepunkte, Sunny Home Manager + SMA WR
2x USB-RS485 mit je 1x EVSE DIN Modbus + SDM120
Sind EnergyMeter und Raspberry den im selben Layer2 Netz ohne Firewalls dazwischen? keine VLANs?
Ist die Seriennummer korrekt?
Der Daemon findet anscheinend den EM nicht.
Ja, alles im gleichen Netz.
Der Raspberry der Wallbox hängt im Wlan, der zweite Raspi zum testen hängt direkt über Kabel im Lan an der Fritzbox.
Mit einem Tool vom Smartphone aus kann ich das Energymeter abfragen.
Werden den der Home Manager und/oder das Energymeter gleich angesprochen? Macht es einen Unterschied ob ich den Homemanager oder das Energymeter verwende? Natürlich mit der dazu passenden Seriennummer.
Ich hatte ja Energymeter auch ausprobiert, ging ja auch nicht.
Home Manager und EnergyMeter werden gleich angesprochen.
Hast du beides bei dir verbaut?
Das einzige was mir auffällt, zum testen waren die EM bzw. SHM Nummern 10-stellig. Deine ist 9-stellig.
Sicher das das die richtige ist?
Was steht in deiner App für eine Nummer?
Habe zwei Energymeter und einen Homemanager, ist der Homemanager ohne Energymeter nicht nutzlos?
Dabei kommt mir der Gedanke: ich habe den ersten Homemanager, ist das Programm evtl. nur für den HomeManager2? Dieser hat meines Wissens ein Energameter integriert.
Ah der 1er... Stimmt der hat das nicht.
Der SHM2 hat den EM integriert.
Der EM ist aber aaslesbar mit dem SHM Modul. Die Auslesung ist da nämlich gleich.
Deine EM sind ja wie gehabt per Multicast auslesbar, oder?
ja
Eine Idee noch:
sudo ip route add 224.0.0.0/4 dev wlan0
gehts dann?
gehts dann?
probier ich gleich...
kann ich auch als Modul den Home Manager auswählen und als Seriennummer die vom Energymeter mitgeben?
