Hello!
I have a working installation of Simple EVSE DIN (Modbus active) + Simple EVSE WIfi (Node MCU esp8266) v1.1.1 and is working.
Now I want to install a PV system.
For this, I plan to mount inside the house, on the dedicated EVSE Circuit
- SDM630 Modbus V2
- OpenWB will run on an RPi 3 in a DIN case + USB Modbus adapter for SMD630v2 MB.
OpenWB will be on the same LAN with SimpleEVSE WIFI.
OpenWB is controlling the Simple EVSE Wifi via LAN API?
rPi Connection to SimpleEVSE WIFI
courage2000
- Has thanked: 269 times
- Been thanked: 287 times
Re: rPi Connection to SimpleEVSE WIFI
rightcourage2000 hat geschrieben: So Jul 25, 2021 2:46 pm OpenWB is controlling the Simple EVSE Wifi via LAN API?
