1.9.266: Fronius: keine EVU/PV Daten mehr
Toboli
Beitrag von Toboli »
Da scheint etwas noch nicht zu passen.... Ich bekomme keine Daten mehr nach dem Update:
installierte Version: 1.9.266 (2022-05-18 09:09:33 +0200 [71a05411] )
2022-05-17 07:10:22: PID: 2381: legacy run server: Received command ["modules.fronius.device","inverter","192.168.200.252","0","0","none","1"]
2022-05-17 07:10:24: PID: 2381: root: Fronius IP-Adresse: 192.168.200.252
2022-05-17 07:10:24: PID: 2381: root: Komponente Fronius Wechselrichter auslesen.
2022-05-17 07:10:24: PID: 2381: root: Fronius Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr <class 'KeyError'> 'ip_address', Traceback:
File "/var/www/html/openWB/packages/modules/fronius/device.py", line 111, in read_legacy
total_power = inverter1.read_power()
File "/var/www/html/openWB/packages/modules/fronius/inverter.py", line 40, in read_power
'http://' + self.device_config["ip_address"] + '/solar_api/v1/GetPowerFlowRealtimeData.fcgi',
KeyError: 'ip_address'
2022-05-17 07:10:24: PID: 2381: legacy run server: Completed running command in 2.08s: ["modules.fronius.device","inverter","192.168.200.252","0","0","none","1"]
2022-05-17 07:10:28: PID: 2381: legacy run server: Received command ["modules.fronius.device","counter_s0","192.168.200.252","1","1","none"]
2022-05-17 07:10:28: PID: 2381: root: Fronius IP-Adresse: 192.168.200.252
2022-05-17 07:10:28: PID: 2381: legacy run server: Unhandled exception
File "/var/www/html/openWB/packages/legacy_run_server.py", line 48, in redirect_stdout_stderr_exceptions_to_log
yield
File "/var/www/html/openWB/packages/legacy_run_server.py", line 87, in handle_connection
self.__callback(read_all_bytes(connection))
File "/var/www/html/openWB/packages/legacy_run_server.py", line 109, in handle_message
importlib.import_module(parsed[0]).main(parsed[1:])
File "/var/www/html/openWB/packages/modules/fronius/device.py", line 120, in main
run_using_positional_cli_args(read_legacy, argv)
File "/var/www/html/openWB/packages/helpermodules/cli/_run_using_positional_cli_args.py", line 34, in run_using_positional_cli_args
args.RUN(args)
File "/var/www/html/openWB/packages/helpermodules/cli/_run_using_positional_cli_args.py", line 19, in
parser.set_defaults(RUN=lambda args: function(*[getattr(args, argument_name) for argument_name in arg_spec.args]))
File "/var/www/html/openWB/packages/modules/fronius/device.py", line 116, in read_legacy
raise Exception("illegal component num " + str(num) + ". Should be an int if it is an inverter.")
Exception: illegal component num None. Should be an int if it is an inverter.
2022-05-17 07:10:31: PID: 2381: legacy run server: Received command ["modules.fronius.device","inverter","192.168.200.252","0","0","none","1"]
2022-05-17 07:10:31: PID: 2381: root: Fronius IP-Adresse: 192.168.200.252
2022-05-17 07:10:31: PID: 2381: root: Komponente Fronius Wechselrichter auslesen.
2022-05-17 07:10:31: PID: 2381: root: Fronius Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr <class 'KeyError'> 'ip_address', Traceback:
vuffiraa
Has thanked: 6 times
Been thanked: 31 times
Re: 1.9.266: Fronius: keine EVU/PV Daten mehr
Beitrag von vuffiraa »
Ich glaube, es gab gestern Abend noch einen Fix im Git-Repository.
Mit der aktuellen Nightly werden bei mir Daten angezeigt.
Kannst du bei dir noch mal den aktuellen Stand abrufen und probieren.
Wenn es immer noch nicht klappt, schreib mal deine kompletten Einstellungen für EVU und WR.
openWB serie 2 custom 11kW
Skoda Enyaq iV80
Toboli
Ja, die Daten kommen wieder nach dem letzten update!
E_Esteban
Has thanked: 5 times
Been thanked: 5 times
Beitrag von E_Esteban »
muss mich auch nochmal dranhängen.
Vom Gen24 kommen die Daten wohl wieder... aber von meinem Symo mit Datamanger 2.0 nicht mehr.
In der Version: openWB Version: 1.9.266 (2022-05-25 07:34:33 +0200 [23d5a1d6] ) habe ich somit immer mehr Einspeisung am NVP als Erzeugung, somit immer Hausverbauch = 0 ....
Bis zur Version: openWB Version: 1.9.265 (2022-04-25 13:36:02 +0200 [0243e53f] ) läuft alles super.
Die Systeme laufen parallel...
Habe die obere Version immer als Testversion auf einem RasPi als Testdummy laufen, um genau diesem "blöden" Fall vorzubeugen.
Habe alles abgeglichen, aber die Einstellungen sind identisch... daher meine Vermutung, dass sich beim Auslesen des Sekundären WR etwas getan hat. (Fronius Symo mit Datamanger 2.0 unter der zweiten IP im PV-Modul.
VG Stephan
3 x openWB series2 custom je 22kW
Tesla Model Y LR + Model 3 Perf.
58,86 kWp PV (Ost-West + Fassade) mit 1x Fronius Verto Plus 20.0 + 1 x Fronius Gen24 10.0 + 2x Symo 15k + 1x Symo 6k
2x 22,08 kWh stationärer Speicher BYD HVM
Been thanked: 172 times
Beitrag von LenaK »
E_Esteban hat geschrieben: Mi Mai 25, 2022 7:11 am Hi,
VG Stephan
Bitte das Debuglevel auf 2 stellen und einen Auszug aus dem Debuglog posten. Es gab eine Änderung an der Verarbeitung des zweiten WR.
E_Esteban
Hi LenaK,
IP: 10.0.0.3 ist der Symo mit Datamanager 2.0 + ein weiterer Slave WR (2 x Symo 15.0 Master/Slave)
IP: 10.0.0.22 ist der Gen24 (10.0 Plus)
Vielleicht wird auch nur der sekundäre WR am Datamanager nicht einbezogen?
2022-05-25 12:07:02: PID: 2169: soc.modules.common.component_context: Update Komponente ['Fronius Wechselrichter']
2022-05-25 12:07:02: PID: 2169: modules.fronius.device: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:07:02: PID: 2169: legacy run server: Received command ["modules.fronius.device","inverter","10.0.0.22","0","0","10.0.0.3","1"]
2022-05-25 12:06:53: PID: 2169: legacy run server: Completed running command in 0.09s: ["modules.fronius.device","counter_sm","10.0.0.22","1","1","10.0.0.3"]
2022-05-25 12:06:53: PID: 2169: soc.modules.common.store._api: Saving CounterState(imported=478997.8238888889, power_factors=[1.0, -0.999, -0.999], powers=[-12901.2, -12872.6, -12381.6], currents=[-55.13333333333334, -54.66072186836518, -52.687659574468086], power=-38456.4, exported=413461.5013351103, voltages=[234.0, 235.5, 235.0], frequency=49.9)
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 1724392166 Export: 1488461404.806397 Leistung: -38456.4
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 478997.8238888889, Einspeisung[Wh]: 413461.5013351103
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 1724392166, Einspeisung[Ws]: 1488461404.806397
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: -380103.806396985
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]9.936912775039673, vorherige Leistung[W]: -38047, aktuelle Leistung[W]: -38456.4
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 1724392166 Export: 1488081301 Leistung: -38047
2022-05-25 12:06:53: PID: 2169: modules.fronius.counter_sm: Einbauort: MeterLocation.grid
"Timestamp" : "2022-05-25T10:06:53+00:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Scope" : "Device"
"DeviceId" : "1",
"RequestArguments" : {
"Head" : {
"Voltage_AC_Phase_3" : 235.0
"Voltage_AC_Phase_2" : 235.5,
"Voltage_AC_Phase_1" : 234.0,
"Voltage_AC_PhaseToPhase_31" : 406.10000000000002,
"Voltage_AC_PhaseToPhase_23" : 409.5,
"Voltage_AC_PhaseToPhase_12" : 404.5,
"Visible" : 1,
"TimeStamp" : 1653473213,
"PowerReal_P_Sum" : -38456.400000000001,
"PowerReal_P_Phase_3" : -12381.6,
"PowerReal_P_Phase_2" : -12872.6,
"PowerReal_P_Phase_1" : -12901.200000000001,
"PowerReactive_Q_Sum" : -1202.2,
"PowerReactive_Q_Phase_3" : -484.19999999999999,
"PowerReactive_Q_Phase_2" : -443.30000000000001,
"PowerReactive_Q_Phase_1" : -291.60000000000002,
"PowerFactor_Sum" : 1.0,
"PowerFactor_Phase_3" : -0.999,
"PowerFactor_Phase_2" : -0.999,
"PowerFactor_Phase_1" : 1.0,
"PowerApparent_S_Sum" : 38476.199999999997,
"PowerApparent_S_Phase_3" : 12391.1,
"PowerApparent_S_Phase_2" : 12880.200000000001,
"PowerApparent_S_Phase_1" : 12904.5,
"Meter_Location_Current" : 0.0,
"Frequency_Phase_Average" : 49.899999999999999,
"EnergyReal_WAC_Sum_Produced" : 39454703.0,
"EnergyReal_WAC_Sum_Consumed" : 4981566.0,
"EnergyReal_WAC_Plus_Absolute" : 4981566.0,
"EnergyReal_WAC_Minus_Absolute" : 39454703.0,
"EnergyReactive_VArAC_Sum_Produced" : 14055632.0,
"EnergyReactive_VArAC_Sum_Consumed" : 117327.0,
"Enable" : 1,
"Serial" : "342295005"
"Model" : "Smart Meter TS 65A-3",
"Manufacturer" : "Fronius",
"Details" : {
"Current_AC_Sum" : -162.65100000000001,
"Current_AC_Phase_3" : -52.762,
"Current_AC_Phase_2" : -54.716999999999999,
"Current_AC_Phase_1" : -55.171999999999997,
"Data" : {
"Body" : {
2022-05-25 12:06:53: PID: 2169: soc.modules.common.req: Get-Response: {
2022-05-25 12:06:53: PID: 2169: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MeterRealtimeData HTTP/1.1" 200 2203
2022-05-25 12:06:53: PID: 2169: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:06:53: PID: 2169: soc.modules.common.component_context: Update Komponenten ['Fronius SM Zähler']
2022-05-25 12:06:53: PID: 2169: modules.fronius.device: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x74e27450>}
2022-05-25 12:06:53: PID: 2169: modules.fronius.device: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:06:53: PID: 2169: legacy run server: Received command ["modules.fronius.device","counter_sm","10.0.0.22","1","1","10.0.0.3"]
2022-05-25 12:06:53: PID: 2169: legacy run server: Completed running command in 0.07s: ["modules.fronius.device","bat","10.0.0.22","1","0","10.0.0.3"]
2022-05-25 12:06:53: PID: 2169: soc.modules.common.store._api: Saving BatState(imported=1009279.0751937352, soc=100.0, power=24, exported=947863.3397222222)
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 3633404670.697447 Export: 3412308023 Leistung: 24
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 1009279.0751937352, Einspeisung[Wh]: 947863.3397222222
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 3633404670.697447, Einspeisung[Ws]: 3412308023
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: 239.69744682312012
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]9.987393617630005, vorherige Leistung[W]: 24, aktuelle Leistung[W]: 24
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 3633404431 Export: 3412308023 Leistung: 24
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"RequestArguments" : {},
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"rel_SelfConsumption" : 0.0
"rel_Autonomy" : 100.0,
"P_PV" : 9746.1650390625,
"P_Load" : 29129.6396484375,
"P_Grid" : -38599.0,
"P_Akku" : -24.698078155517578,
"Mode" : "bidirectional",
"Meter_Location" : "grid",
"E_Year" : null,
"E_Total" : 15184986.363055555,
"E_Day" : null,
"BatteryStandby" : true,
"BackupMode" : false,
"Site" : {
"SOC" : 100.0
"P" : 9386.2177734375,
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"Battery_Mode" : "normal",
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:06:53: PID: 2169: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1169
2022-05-25 12:06:53: PID: 2169: soc.modules.common.component_context: Update Komponenten ['Fronius Speicher']
2022-05-25 12:06:53: PID: 2169: modules.fronius.device: Start device reading {'componentNone': <modules.fronius.bat.FroniusBat object at 0x74e19050>}
2022-05-25 12:06:53: PID: 2169: legacy run server: Received command ["modules.fronius.device","bat","10.0.0.22","1","0","10.0.0.3"]
2022-05-25 12:06:53: PID: 2169: legacy run server: Completed running command in 0.12s: ["modules.fronius.device","inverter","10.0.0.22","0","0","10.0.0.3","1"]
2022-05-25 12:06:53: PID: 2169: soc.modules.common.store._api: Saving InverterState(counter=10329805.725747164, currents=[0.0, 0.0, 0.0], power=-19492.330078125)
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 0 Export: 37187300612.68979 Leistung: -19492.330078125
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 0.0, Einspeisung[Wh]: 10329805.725747164
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 0, Einspeisung[Ws]: 37187300612.68979
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: -193418.68978954246
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]9.990033626556396, vorherige Leistung[W]: -19230, aktuelle Leistung[W]: -19492.330078125
2022-05-25 12:06:53: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 0 Export: 37187107194 Leistung: -19230
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"Timestamp" : "2022-05-25T10:06:52+00:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:06:52: PID: 2169: soc.modules.common.req: Get-Response: {
2022-05-25 12:06:52: PID: 2169: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1169
2022-05-25 12:06:52: PID: 2169: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:06:52: PID: 2169: soc.modules.common.component_context: Update Komponente ['Fronius Wechselrichter']
2022-05-25 12:06:52: PID: 2169: modules.fronius.device: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:06:52: PID: 2169: legacy run server: Received command ["modules.fronius.device","inverter","10.0.0.22","0","0","10.0.0.3","1"]
2022-05-25 12:06:43: PID: 2169: legacy run server: Completed running command in 0.20s: ["modules.fronius.device","counter_sm","10.0.0.22","1","1","10.0.0.3"]
2022-05-25 12:06:43: PID: 2169: soc.modules.common.store._api: Saving CounterState(imported=478997.8238888889, power_factors=[1.0, -0.999, -0.999], powers=[-12845.0, -12844.3, -12358.0], currents=[-54.84628522630231, -54.49427238014425, -52.52018699532511], power=-38047.5, exported=413355.9169693838, voltages=[234.2, 235.7, 235.3], frequency=49.9)
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 1724392166 Export: 1488081301.0897815 Leistung: -38047.5
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 478997.8238888889, Einspeisung[Wh]: 413355.9169693838
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 1724392166, Einspeisung[Ws]: 1488081301.0897815
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: -383850.08978158236
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]10.055999994277954, vorherige Leistung[W]: -38295, aktuelle Leistung[W]: -38047.5
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 1724392166 Export: 1487697451 Leistung: -38295
2022-05-25 12:06:43: PID: 2169: modules.fronius.counter_sm: Einbauort: MeterLocation.grid
"Timestamp" : "2022-05-25T10:06:43+00:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Scope" : "Device"
"DeviceId" : "1",
"Head" : {
"Voltage_AC_Phase_3" : 235.30000000000001
"Voltage_AC_Phase_2" : 235.69999999999999,
"Voltage_AC_Phase_1" : 234.19999999999999,
"Voltage_AC_PhaseToPhase_31" : 406.5,
"Voltage_AC_PhaseToPhase_23" : 409.89999999999998,
"Voltage_AC_PhaseToPhase_12" : 404.80000000000001,
"Visible" : 1,
"TimeStamp" : 1653473203,
"PowerReal_P_Sum" : -38047.5,
"PowerReal_P_Phase_3" : -12358.0,
"PowerReal_P_Phase_2" : -12844.299999999999,
"PowerReal_P_Phase_1" : -12845.0,
"PowerReactive_Q_Sum" : -1211.9000000000001,
"PowerReactive_Q_Phase_3" : -490.69999999999999,
"PowerReactive_Q_Phase_2" : -448.0,
"PowerReactive_Q_Phase_1" : -273.10000000000002,
"PowerFactor_Sum" : -0.999,
"PowerApparent_S_Sum" : 38067.900000000001,
"PowerApparent_S_Phase_3" : 12367.799999999999,
"PowerApparent_S_Phase_2" : 12852.1,
"PowerApparent_S_Phase_1" : 12847.9,
"EnergyReal_WAC_Sum_Produced" : 39454607.0,
"EnergyReal_WAC_Minus_Absolute" : 39454607.0,
"EnergyReactive_VArAC_Sum_Produced" : 14055629.0,
"Enable" : 1,
"Details" : {
"Current_AC_Sum" : -162.029,
"Current_AC_Phase_3" : -52.612000000000002,
"Current_AC_Phase_2" : -54.536000000000001,
"Current_AC_Phase_1" : -54.881,
"Data" : {
"Body" : {
2022-05-25 12:06:43: PID: 2169: soc.modules.common.req: Get-Response: {
2022-05-25 12:06:43: PID: 2169: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MeterRealtimeData HTTP/1.1" 200 2235
2022-05-25 12:06:43: PID: 2169: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:06:43: PID: 2169: soc.modules.common.component_context: Update Komponenten ['Fronius SM Zähler']
2022-05-25 12:06:43: PID: 2169: modules.fronius.device: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75090070>}
2022-05-25 12:06:43: PID: 2169: modules.fronius.device: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:06:43: PID: 2169: legacy run server: Received command ["modules.fronius.device","counter_sm","10.0.0.22","1","1","10.0.0.3"]
2022-05-25 12:06:43: PID: 2169: legacy run server: Completed running command in 0.07s: ["modules.fronius.device","bat","10.0.0.22","1","0","10.0.0.3"]
2022-05-25 12:06:43: PID: 2169: soc.modules.common.store._api: Saving BatState(imported=1009279.0086575057, soc=100.0, power=24, exported=947863.3397222222)
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 3633404431.167021 Export: 3412308023 Leistung: 24
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 1009279.0086575057, Einspeisung[Wh]: 947863.3397222222
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 3633404431.167021, Einspeisung[Ws]: 3412308023
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: 234.1670206785202
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]9.964554071426392, vorherige Leistung[W]: 23, aktuelle Leistung[W]: 24
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 3633404197 Export: 3412308023 Leistung: 23
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"P_PV" : 9615.010498046875,
"P_Load" : 28536.090624999997,
"P_Grid" : -37880.199999999997,
"P_Akku" : -24.811651229858398,
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"P" : 9412.2353515625,
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:06:43: PID: 2169: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1184
2022-05-25 12:06:43: PID: 2169: soc.modules.common.component_context: Update Komponenten ['Fronius Speicher']
2022-05-25 12:06:43: PID: 2169: modules.fronius.device: Start device reading {'componentNone': <modules.fronius.bat.FroniusBat object at 0x7689cad0>}
2022-05-25 12:06:43: PID: 2169: legacy run server: Received command ["modules.fronius.device","bat","10.0.0.22","1","0","10.0.0.3"]
2022-05-25 12:06:43: PID: 2169: legacy run server: Completed running command in 0.11s: ["modules.fronius.device","inverter","10.0.0.22","0","0","10.0.0.3","1"]
2022-05-25 12:06:43: PID: 2169: soc.modules.common.store._api: Saving InverterState(counter=10329751.99860278, currents=[0.0, 0.0, 0.0], power=-19230.02099609375)
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse aktuelle Berechnung: Import: 0 Export: 37187107194.97001 Leistung: -19230.02099609375
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Ergebnis: Bezug[Wh]: 0.0, Einspeisung[Wh]: 10329751.99860278
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount aufsummierte Energie: Bezug[Ws]: 0, Einspeisung[Ws]: 37187107194.97001
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Gesamtenergie im Zeitintervall: -192621.97000560275
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Berechnungsgrundlage: vergangene Zeit [s]9.970075845718384, vorherige Leistung[W]: -19410, aktuelle Leistung[W]: -19230.02099609375
2022-05-25 12:06:43: PID: 2169: modules.common.simcount: simcount Zwischenergebnisse letzte Berechnung: Import: 0 Export: 37186914573 Leistung: -19410
Hier das Debug-Log der "operativen" - funktionierenden Version 1.9.265:
2022-05-25 12:12:25: PID: 16575: root: Get-Response: {
2022-05-25 12:12:25: PID: 16575: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MeterRealtimeData HTTP/1.1" 200 2300
2022-05-25 12:12:25: PID: 16575: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:12:25: PID: 16575: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x730544f0>}
2022-05-25 12:12:25: PID: 16575: root: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:12:25: PID: 16575: legacy run server: Received command ["modules.fronius.device","counter_sm","10.0.0.22","1","1","0","10.0.0.3","speicher_fronius"]
2022-05-25 12:12:25: PID: 2888: WR Speicher: speicher_fronius (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:25: PID: 2888: WR IP2: 10.0.0.3 (LV2) at 26 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:25: PID: 2888: WR MeterLocation: 0 (LV2) at 25 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:25: PID: 2888: WR Var2: 1 (LV2) at 24 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:25: PID: 2888: WR Erzeugung: 1 (LV2) at 23 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:25: PID: 2888: WR IP: 10.0.0.22 (LV2) at 22 main modules/bezug_fronius_sm/main.sh
2022-05-25 12:12:23: PID: 2757: BattLeistung: 0 (LV1) at 28 main modules/speicher_fronius/main.sh
2022-05-25 12:12:23: PID: 2757: RET: 0 (LV2) at 24 main modules/speicher_fronius/main.sh
2022-05-25 12:12:23: PID: 16575: legacy run server: Completed running command in 0.11s: ["modules.fronius.device","bat","10.0.0.22","1","0","0","none",""]
2022-05-25 12:12:23: PID: 16575: ValueStore: Saving BatState(exported=2605952.491388889, power=0, imported=1582569.094754023, soc=100.0)
2022-05-25 12:12:23: PID: 16575: root: simcount Zwischenergebnisse aktuelle Berechnung: Import: 5697248741.114483 Export: 9381428969 Leistung: 0
2022-05-25 12:12:23: PID: 16575: root: simcount Ergebnis: Bezug[Wh]: 1582569.094754023, Einspeisung[Wh]: 2605952.491388889
2022-05-25 12:12:23: PID: 16575: root: simcount aufsummierte Energie: Bezug[Ws]: 5697248741.114483, Einspeisung[Ws]: 9381428969
2022-05-25 12:12:23: PID: 16575: root: simcount Gesamtenergie im Zeitintervall: 10.114482402801514
2022-05-25 12:12:23: PID: 16575: root: simcount Berechnungsgrundlage: vergangene Zeit [s]10.114482402801514, vorherige Leistung[W]: 2, aktuelle Leistung[W]: 0
2022-05-25 12:12:23: PID: 16575: root: simcount Zwischenergebnisse letzte Berechnung: Import: 5697248731 Export: 9381428969 Leistung: 2
"Timestamp" : "2022-05-25T10:12:23+00:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"P_PV" : 2485.756591796875,
"P_Load" : 6928.559326171875,
"P_Grid" : -9340.5,
"P_Akku" : -0.55929094552993774,
"E_Year" : null,
"E_Total" : 15185619.635555556,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"P" : 2409.71435546875,
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:12:23: PID: 16575: root: Get-Response: {
2022-05-25 12:12:23: PID: 16575: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1173
2022-05-25 12:12:23: PID: 16575: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:12:23: PID: 16575: root: Komponente Fronius Speicher auslesen.
2022-05-25 12:12:23: PID: 16575: root: Start device reading {'componentNone': <modules.fronius.bat.FroniusBat object at 0x74d94630>}
2022-05-25 12:12:23: PID: 16575: root: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:12:23: PID: 16575: legacy run server: Received command ["modules.fronius.device","bat","10.0.0.22","1","0","0","none",""]
2022-05-25 12:12:23: PID: 2757: Speicher IP: 10.0.0.22 (LV2) at 19 main modules/speicher_fronius/main.sh
2022-05-25 12:12:22: PID: 16575: legacy run server: Completed running command in 0.18s: ["modules.fronius.device","inverter","10.0.0.22","0","0","0","10.0.0.3","speicher_fronius","1"]
2022-05-25 12:12:22: PID: 16575: ValueStore: Saving InverterState(counter=15491595.553331545, power=-10271.756591796875, currents=[0, 0, 0])
2022-05-25 12:12:22: PID: 16575: root: simcount Zwischenergebnisse aktuelle Berechnung: Import: 0 Export: 55769743991.99356 Leistung: -10271.756591796875
2022-05-25 12:12:22: PID: 16575: root: simcount Ergebnis: Bezug[Wh]: 0.0, Einspeisung[Wh]: 15491595.553331545
2022-05-25 12:12:22: PID: 16575: root: simcount aufsummierte Energie: Bezug[Ws]: 0, Einspeisung[Ws]: 55769743991.99356
2022-05-25 12:12:22: PID: 16575: root: simcount Gesamtenergie im Zeitintervall: -104847.99356172836
2022-05-25 12:12:22: PID: 16575: root: simcount Berechnungsgrundlage: vergangene Zeit [s]10.097190141677856, vorherige Leistung[W]: -10496, aktuelle Leistung[W]: -10271.756591796875
2022-05-25 12:12:22: PID: 16575: root: simcount Zwischenergebnisse letzte Berechnung: Import: 0 Export: 55769639144 Leistung: -10496
"Timestamp" : "2022-05-25T12:12:22+02:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"rel_SelfConsumption" : null
"rel_Autonomy" : null,
"P_PV" : 7786,
"P_Load" : null,
"P_Grid" : null,
"P_Akku" : null,
"Mode" : "produce-only",
"Meter_Location" : "unknown",
"E_Year" : 11533285.5,
"E_Total" : 141781400,
"E_Day" : 75930,
"Site" : {
"P" : 3912
"E_Year" : 5797648,
"E_Total" : 71528600,
"E_Day" : 38200,
"DT" : 115,
"2" : {
"P" : 3874
"E_Year" : 5735637.5,
"E_Total" : 70252800,
"E_Day" : 37730,
"DT" : 115,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:12:22: PID: 16575: root: Get-Response: {
2022-05-25 12:12:22: PID: 16575: requests.packages.urllib3.connectionpool: http://10.0.0.3:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1096
2022-05-25 12:12:22: PID: 16575: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.3:80
"Timestamp" : "2022-05-25T10:12:22+00:00"
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"P_Grid" : -9340.5,
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
2022-05-25 12:12:22: PID: 16575: requests.packages.urllib3.connectionpool: http://10.0.0.22:80 "GET /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System HTTP/1.1" 200 1173
2022-05-25 12:12:22: PID: 16575: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.22:80
2022-05-25 12:12:22: PID: 16575: root: Komponente Fronius Wechselrichter auslesen.
2022-05-25 12:12:22: PID: 16575: root: Start device reading {'component1': <modules.fronius.inverter.FroniusInverter object at 0x74cef890>}
2022-05-25 12:12:22: PID: 16575: root: Fronius IP-Adresse: 10.0.0.22
2022-05-25 12:12:22: PID: 16575: legacy run server: Received command ["modules.fronius.device","inverter","10.0.0.22","0","0","0","10.0.0.3","speicher_fronius","1"]
2022-05-25 12:12:22: PID: 2737: WR Speicher: speicher_fronius (LV2) at 24 main modules/wr_fronius/main.sh
2022-05-25 12:12:22: PID: 2737: WR IP2: 10.0.0.3 (LV2) at 23 main modules/wr_fronius/main.sh
2022-05-25 12:12:22: PID: 2737: WR IP: 10.0.0.22 (LV2) at 22 main modules/wr_fronius/main.sh
2022-05-25 12:12:21: PID: 2601: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-05-25 12:12:17: PID: 1061: **** Regulation loop needs 6 seconds (LV2) at 55 cleanup /var/www/html/openWB/regel.sh
2022-05-25 12:12:16: PID: 1061: Timing Umschaltung: 240 / 720 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-05-25 12:12:16: PID: 1061: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-05-25 12:12:16: PID: 1061: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-05-25 12:12:15: PID: 1061: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1302 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: plugstatlp1 0	plugstatlp2 0	plugstatlp3 0 (LV1) at 1301 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1300 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: EVU 1:V/-14A 2: V/-13A 3: V/-13A (LV1) at 1299 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: lla3 0	llv3 230.8	llas13 0 llas23  soclp1 74 soclp2 0 (LV1) at 1298 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: lla2 0	llv2 232.1	llas12 0 llas22  sofortll 32 hausverbrauch 1045 wattbezug -9449 uberschuss 9449 (LV1) at 1297 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: lla1 0	llv1 232.3	llas11 0 llas21  mindestuberschuss 1500 abschaltuberschuss 5 lademodus 3 (LV1) at 1296 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: pv1watt -10496 pv2watt  pvwatt -10496 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 10 maximalA 16 (LV1) at 1295 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 1061: speicherleistung 2 speichersoc 100 (LV1) at 1290 loadvars loadvars.sh
2022-05-25 12:12:15: PID: 16575: legacy run server: Completed running command in 0.08s: ["modules.fronius.device","counter_sm","10.0.0.22","1","1","0","10.0.0.3","speicher_fronius"]
2022-05-25 12:12:15: PID: 16575: ValueStore: Saving CounterState(frequency=50.0, imported=1078585.3169444446, exported=11371204.35456959, powers=[-3256.9, -3107.3, -3047.2], power_factors=[-0.995, -0.992, -0.988], voltages=[230.7, 232.5, 232.4], currents=[-14.117468573905507, -13.3647311827957, -13.111876075731496], power=-9449.6)
2022-05-25 12:12:15: PID: 16575: root: Fronius SM Leistung[W]: -9449.6
2022-05-25 12:12:15: PID: 16575: root: simcount Zwischenergebnisse aktuelle Berechnung: Import: 3882907141 Export: 40936335676.45052 Leistung: -9449.6
2022-05-25 12:12:15: PID: 16575: root: simcount Ergebnis: Bezug[Wh]: 1078585.3169444446, Einspeisung[Wh]: 11371204.35456959
2022-05-25 12:12:15: PID: 16575: root: simcount aufsummierte Energie: Bezug[Ws]: 3882907141, Einspeisung[Ws]: 40936335676.45052
2022-05-25 12:12:15: PID: 16575: root: simcount Gesamtenergie im Zeitintervall: -95523.45052084923
2022-05-25 12:12:15: PID: 16575: root: simcount Berechnungsgrundlage: vergangene Zeit [s]9.932460308074951, vorherige Leistung[W]: -9785, aktuelle Leistung[W]: -9449.6
2022-05-25 12:12:15: PID: 16575: root: simcount Zwischenergebnisse letzte Berechnung: Import: 3882907141 Export: 40936240153 Leistung: -9785
2022-05-25 12:12:15: PID: 16575: root: Einbauort: MeterLocation.grid
Beitrag von LenaK »
E_Esteban hat geschrieben: Mi Mai 25, 2022 10:15 am Hi LenaK,
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Scope" : "Device"
"DeviceId" : "1",
"Head" : {
"Visible" : 1,
"Enable" : 1,
"Details" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Scope" : "Device"
"DeviceId" : "1",
"Head" : {
"Visible" : 1,
"Enable" : 1,
"Details" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"P_Grid" : -9340.5,
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"P_PV" : 7786,
"P_Load" : null,
"P_Grid" : null,
"P_Akku" : null,
"E_Day" : 75930,
"Site" : {
"P" : 3912
"E_Year" : 5797648,
"E_Day" : 38200,
"DT" : 115,
"2" : {
"P" : 3874
"E_Day" : 37730,
"DT" : 115,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
"UserMessage" : ""
"Reason" : "",
"Code" : 0,
"Status" : {
"Head" : {
"Version" : "12"
"Ohmpilots" : {}
"Smartloads" : {
"P_Grid" : -9340.5,
"E_Year" : null,
"E_Day" : null,
"Site" : {
"SOC" : 100.0
"E_Year" : null,
"E_Day" : null,
"DT" : 1,
"1" : {
"Inverters" : {
"Data" : {
"Body" : {
Das Problem wurde in der Nightly gefixt. Bitte nochmal testen.
E_Esteban
Schaut gut aus !! - Passt wieder :-)
Danke !!
VG St.
