Fehler nach Evse Update
Verfasst: Do Jun 15, 2023 5:46 pm
ich habe meine beiden Evse von openWB ja updaten lassen und diese heute wieder verbaut bekommen nun aber fehler angezeigt
nutze die aktuell version 2.0 (master 2023-06-15 16:37:17 +0200 [f0467a3e9])
und habe meine openWB als DUO
vielleicht weiß ja jemand bescheid
LG
Florian
2023-06-15 19:38:49,311 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as duo
2023-06-15 19:38:49,312 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 1']
2023-06-15 19:38:49,314 - {modules.internal_chargepoint_handler.clients:98} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0')]
2023-06-15 19:38:49,315 - {modules.internal_chargepoint_handler.clients:100} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-15 19:38:49,316 - {modules.internal_chargepoint_handler.clients:104} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-06-15 19:38:49,370 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:38:49,371 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7240f5b0>
2023-06-15 19:38:49,372 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-06-15 19:38:50,383 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7240f5b0>
2023-06-15 19:38:50,384 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-06-15 19:38:50,429 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-06-15 19:38:50,584 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:38:55,160 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Interner Ladepunkt 1: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
modules.common.fault_state.FaultState: ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 139, in __init__
self.cp0 = HandlerChargepoint(self.cp0_serial_client, 0, mode, global_data, parent_cp0)
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 201, in __init__
self.module = chargepoint_module.ChargepointModule(ClientConfig(
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/chargepoint_module.py", line 38, in __init__
if self.__client.evse_client.is_precise_current_active() is False:
File "/var/www/html/openWB/packages/modules/common/evse.py", line 57, in is_precise_current_active
value = self.client.read_holding_registers(2005, ModbusDataType.UINT_16, unit=self.id)
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 118, in read_holding_registers
return self.__read_registers(
File "/var/www/html/openWB/packages/modules/common/modbus.py", line 100, in __read_registers
modules.common.fault_state.FaultState: ("modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>)", <FaultStateLevel.ERROR: 2>)
2023-06-15 19:38:55,205 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:268} - {ERROR:Internal Chargepoint} - Fehler im internem Ladepunkt
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 264, in handler
self.internal_chargepoint_handler.loop()
File "/var/www/html/openWB/packages/modules/internal_chargepoint_handler/internal_chargepoint_handler.py", line 177, in loop
with SingleComponentUpdateContext(self.cp0.module.component_info):
AttributeError: 'InternalChargepointHandler' object has no attribute 'cp0'
2023-06-15 19:38:57,213 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as duo
2023-06-15 19:38:57,214 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 1']
2023-06-15 19:38:57,215 - {modules.internal_chargepoint_handler.clients:98} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0')]
2023-06-15 19:38:57,217 - {modules.internal_chargepoint_handler.clients:100} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-15 19:38:57,217 - {modules.internal_chargepoint_handler.clients:104} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-06-15 19:38:57,271 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:38:57,272 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7241c8b0>
2023-06-15 19:38:57,272 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-06-15 19:38:58,284 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7241c8b0>
2023-06-15 19:38:58,285 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-06-15 19:38:58,331 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-06-15 19:38:58,486 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:38:59,496 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Interner Ladepunkt 1: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
2023-06-15 19:38:59,520 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:268} - {ERROR:Internal Chargepoint} - Fehler im internem Ladepunkt
2023-06-15 19:40:06,517 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:131} - {DEBUG:Internal Chargepoint} - Init internal chargepoint as duo
2023-06-15 19:40:06,518 - {modules.common.component_context:24} - {DEBUG:Internal Chargepoint} - Update Komponente ['Interner Ladepunkt 1']
2023-06-15 19:40:06,520 - {modules.internal_chargepoint_handler.clients:98} - {DEBUG:Internal Chargepoint} - tty_devices[PosixPath('/dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0')]
2023-06-15 19:40:06,521 - {modules.internal_chargepoint_handler.clients:100} - {DEBUG:Internal Chargepoint} - resolved_devices['/dev/ttyUSB0']
2023-06-15 19:40:06,521 - {modules.internal_chargepoint_handler.clients:104} - {ERROR:Internal Chargepoint} - LP0 Device: /dev/ttyUSB0
2023-06-15 19:40:06,570 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:40:06,570 - {modules.internal_chargepoint_handler.clients:48} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7240f6b8>
2023-06-15 19:40:06,571 - {modules.internal_chargepoint_handler.clients:49} - {ERROR:Internal Chargepoint} - Modbus-ID der EVSE an LP0: 1
2023-06-15 19:40:07,583 - {modules.internal_chargepoint_handler.clients:66} - {DEBUG:Internal Chargepoint} - <modules.common.modbus.ModbusSerialClient_ object at 0x7240f6b8>
2023-06-15 19:40:07,583 - {modules.internal_chargepoint_handler.clients:67} - {DEBUG:Internal Chargepoint} - Zähler <class 'modules.common.mpm3pm.Mpm3pm'> mit Modbus-ID:5 antwortet nicht.
2023-06-15 19:40:07,629 - {modules.internal_chargepoint_handler.clients:63} - {ERROR:Internal Chargepoint} - Verbauter Zähler: <class 'modules.common.sdm.Sdm630'> mit Modbus-ID: 105
2023-06-15 19:40:07,787 - {modules.common.evse:53} - {DEBUG:Internal Chargepoint} - FW-Version: 18
2023-06-15 19:40:08,797 - {modules.common.fault_state:52} - {ERROR:Internal Chargepoint} - Interner Ladepunkt 1: FaultState FaultStateLevel.ERROR, FaultStr modules.common.modbus <class 'modules.common.fault_state.FaultState'> ('modules.common.modbus Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 2 bytes (0 received)', <FaultStateLevel.ERROR: 2>), Traceback:
2023-06-15 19:40:08,831 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:268} - {ERROR:Internal Chargepoint} - Fehler im internem Ladepunkt
AttributeError: 'InternalChargepointHandler' object has no attribute 'cp0'nutze die aktuell version 2.0 (master 2023-06-15 16:37:17 +0200 [f0467a3e9])
LG
Florian
