Seite 1 von 5
Tutorial - Install openwb 1.9 in 2023
Verfasst: Do Sep 21, 2023 8:45 am
von courage2000
The official github page has old info, so the latest Rpi OS Buster installer does not work.
Install OpenWB on Rpi with Bullseye, step by step:
1. Write this official Bullseye image with BalenaEtcher on microSD
2. To activate ssh, Create an empty text file called ssh into the boot partition.
3. Insert the MicroSD card into Rpi and boot.
4. Login via SSH with Terminal or Putty
user: pi
password: raspberry
4.1 in ssh run raspi-config
sudo raspi-config
- set the hostname to openwb
- activate wait for network on boot
- extend the file system on microsd
- automatically boot on the desktop as pi user
5. Run those commands via ssh, logged as pi user (not root):
sudo apt update
suto apt upgrade -y -q
sudo apt-get autoremove -y
sudo apt-get autoclean -y
sudo restart
6. Create the script to install OpenWB (modified from the original)
sudo nano /home/pi/openwb-install.sh
Paste the content of the attached openwb-install.sh.txt
(4.85 KiB) 1723-mal heruntergeladen
Save with Ctrl+x
7. make it executable
sudo chmod +x /home/pi/openwb-install.sh
8. Run the installer (wait for about 10 minutes)
sudo bash /home/pi/openwb-install.sh
8.1 Add cronjobs to crontab as pi user (not root)
crontab -e
Paste this:
* * * * * /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
* * * * * sleep 10 && /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
* * * * * sleep 20 && /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
* * * * * sleep 30 && /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
* * * * * sleep 40 && /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
* * * * * sleep 50 && /var/www/html/openWB/regel.sh >> /var/log/openWB.log 2>&1
9. Reboot
sudo reboot
10. Access the openWB interface
http://openwb.local/openWB/web/index.php
11. Go to Stable of openWB, from Nightly
The default version will install the latest nightly build (now 1.9.304).
If you want to install the latest Stable version - 1.9.303, go to:
http://openwb.local/openWB/web/settings/settings.php
This will not activate the external LCD interface.
See here how to activate it.
If you have original hardware, but no settings backup, you can add the serial:
sudo nano /var/www/html/openWB/openwb.conf
add your serial, like this (use your sn and production date, from the sticker inside the box.
snnumber=owbg111333
pddate=21.03.23
Re: Tutorial - Install openwb 1.9 in 2023
Verfasst: Sa Sep 23, 2023 10:59 am
von kratan75
Hello
Unfortunatelly is the install not running.
Can you please give me a hint ?
What ist wrong ?
For me it seems there is a problem with generall installation of some parts.
Some directories are not generated ?
why ???
pi@openwb:~ $ sudo bash /home/pi/openwb-install.sh
apt update
OK:1 http://security.debian.org/debian-security bullseye-security InRelease
OK:2 http://deb.debian.org/debian bullseye InRelease
OK:3 http://deb.debian.org/debian bullseye-updates InRelease
OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
Paketlisten werden gelesen… Fertig
apt upgrade
Extrahiere Vorlagen aus Paketen: 100%
Vorkonfiguration der Pakete ...
(Lese Datenbank ... 96864 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../libsystemd0_247.3-7+deb11u4_arm64.deb ...
Entpacken von libsystemd0:arm64 (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
libsystemd0:arm64 (247.3-7+deb11u4) wird eingerichtet ...
Vorbereitung zum Entpacken von .../systemd-timesyncd_247.3-7+deb11u4_arm64.deb ...
Entpacken von systemd-timesyncd (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
Vorbereitung zum Entpacken von .../libpam-systemd_247.3-7+deb11u4_arm64.deb ...
Entpacken von libpam-systemd:arm64 (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
Vorbereitung zum Entpacken von .../systemd_247.3-7+deb11u4_arm64.deb ...
Entpacken von systemd (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
Vorbereitung zum Entpacken von .../udev_247.3-7+deb11u4_arm64.deb ...
Entpacken von udev (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
Vorbereitung zum Entpacken von .../libudev1_247.3-7+deb11u4_arm64.deb ...
Entpacken von libudev1:arm64 (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
libudev1:arm64 (247.3-7+deb11u4) wird eingerichtet ...
systemd (247.3-7+deb11u4) wird eingerichtet ...
Vorbereitung zum Entpacken von .../0-systemd-sysv_247.3-7+deb11u4_arm64.deb ...
Entpacken von systemd-sysv (247.3-7+deb11u4) über (247.3-7+deb11u2) ...
Vorbereitung zum Entpacken von .../1-chromium-browser-l10n_113.0.5672.95-rpt1_all.deb ...
Entpacken von chromium-browser-l10n (113.0.5672.95-rpt1) über (113.0.5672.59-rpt1) ...
Vorbereitung zum Entpacken von .../2-libx11-data_2%3a1.7.2-1+deb11u1_all.deb ...
Entpacken von libx11-data (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
Vorbereitung zum Entpacken von .../3-libx11-6_2%3a1.7.2-1+deb11u1_arm64.deb ...
Entpacken von libx11-6:arm64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
Vorbereitung zum Entpacken von .../4-libx11-xcb1_2%3a1.7.2-1+deb11u1_arm64.deb ...
Entpacken von libx11-xcb1:arm64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
Vorbereitung zum Entpacken von .../5-chromium-browser_113.0.5672.95-rpt1_arm64.deb ...
Entpacken von chromium-browser (113.0.5672.95-rpt1) über (113.0.5672.59-rpt1) ...
Vorbereitung zum Entpacken von .../6-chromium-codecs-ffmpeg-extra_113.0.5672.95-rpt1_arm64.deb ...
Entpacken von chromium-codecs-ffmpeg-extra (113.0.5672.95-rpt1) über (113.0.5672.59-rpt1) ...
Vorbereitung zum Entpacken von .../7-libcupsfilters1_1.28.7-1+deb11u2_arm64.deb ...
Entpacken von libcupsfilters1:arm64 (1.28.7-1+deb11u2) über (1.28.7-1+deb11u1) ...
Vorbereitung zum Entpacken von .../8-cups-browsed_1.28.7-1+deb11u2_arm64.deb ...
Entpacken von cups-browsed (1.28.7-1+deb11u2) über (1.28.7-1+deb11u1) ...
Vorbereitung zum Entpacken von .../9-libssl1.1_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
Entpacken von libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) über (1.1.1n-0+deb11u4+rpt1) ...
libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) wird eingerichtet ...
Vorbereitung zum Entpacken von .../00-libjson-c5_0.15-2+deb11u1_arm64.deb ...
Entpacken von libjson-c5:arm64 (0.15-2+deb11u1) über (0.15-2) ...
Vorbereitung zum Entpacken von .../01-bind9-libs_1%3a9.16.44-1~deb11u1_arm64.deb ...
Entpacken von bind9-libs:arm64 (1:9.16.44-1~deb11u1) über (1:9.16.37-1~deb11u1) ...
Vorbereitung zum Entpacken von .../02-bind9-host_1%3a9.16.44-1~deb11u1_arm64.deb ...
Entpacken von bind9-host (1:9.16.44-1~deb11u1) über (1:9.16.37-1~deb11u1) ...
Vorbereitung zum Entpacken von .../03-file_1%3a5.39-3+deb11u1_arm64.deb ...
Entpacken von file (1:5.39-3+deb11u1) über (1:5.39-3) ...
Vorbereitung zum Entpacken von .../04-libmagic1_1%3a5.39-3+deb11u1_arm64.deb ...
Entpacken von libmagic1:arm64 (1:5.39-3+deb11u1) über (1:5.39-3) ...
Vorbereitung zum Entpacken von .../05-libmagic-mgc_1%3a5.39-3+deb11u1_arm64.deb ...
Entpacken von libmagic-mgc (1:5.39-3+deb11u1) über (1:5.39-3) ...
Vorbereitung zum Entpacken von .../06-cups-filters-core-drivers_1.28.7-1+deb11u2_arm64.deb ...
Entpacken von cups-filters-core-drivers (1.28.7-1+deb11u2) über (1.28.7-1+deb11u1) ...
Vorbereitung zum Entpacken von .../07-libfontembed1_1.28.7-1+deb11u2_arm64.deb ...
Entpacken von libfontembed1:arm64 (1.28.7-1+deb11u2) über (1.28.7-1+deb11u1) ...
Vorbereitung zum Entpacken von .../08-ghostscript_9.53.3~dfsg-7+deb11u5_arm64.deb ...
Entpacken von ghostscript (9.53.3~dfsg-7+deb11u5) über (9.53.3~dfsg-7+deb11u4) ...
Vorbereitung zum Entpacken von .../09-libgs9_9.53.3~dfsg-7+deb11u5_arm64.deb ...
Entpacken von libgs9:arm64 (9.53.3~dfsg-7+deb11u5) über (9.53.3~dfsg-7+deb11u4) ...
Vorbereitung zum Entpacken von .../10-libgs9-common_9.53.3~dfsg-7+deb11u5_all.deb ...
Entpacken von libgs9-common (9.53.3~dfsg-7+deb11u5) über (9.53.3~dfsg-7+deb11u4) ...
Vorbereitung zum Entpacken von .../11-cups-filters_1.28.7-1+deb11u2_arm64.deb ...
Entpacken von cups-filters (1.28.7-1+deb11u2) über (1.28.7-1+deb11u1) ...
Vorbereitung zum Entpacken von .../12-ffmpeg_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von ffmpeg (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../13-libavdevice58_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavdevice58:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../14-libavfilter7_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavfilter7:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../15-libswscale5_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libswscale5:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../16-libavformat58_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavformat58:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../17-libavcodec58_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavcodec58:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../18-libswresample3_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libswresample3:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../19-libpostproc55_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libpostproc55:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../20-libavresample4_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavresample4:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../21-libavutil56_8%3a4.3.6-0+deb11u1+rpt5_arm64.deb ...
Entpacken von libavutil56:arm64 (8:4.3.6-0+deb11u1+rpt5) über (7:4.3.6-0+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../22-libssh-gcrypt-4_0.9.7-0+deb11u1_arm64.deb ...
Entpacken von libssh-gcrypt-4:arm64 (0.9.7-0+deb11u1) über (0.9.5-1+deb11u1) ...
Vorbereitung zum Entpacken von .../23-libaom0_1.0.0.errata1-3+deb11u1_arm64.deb ...
Entpacken von libaom0:arm64 (1.0.0.errata1-3+deb11u1) über (1.0.0.errata1-3) ...
Vorbereitung zum Entpacken von .../24-librsvg2-common_2.50.3+dfsg-1+deb11u1_arm64.deb ...
Entpacken von librsvg2-common:arm64 (2.50.3+dfsg-1+deb11u1) über (2.50.3+dfsg-1) ...
Vorbereitung zum Entpacken von .../25-librsvg2-2_2.50.3+dfsg-1+deb11u1_arm64.deb ...
Entpacken von librsvg2-2:arm64 (2.50.3+dfsg-1+deb11u1) über (2.50.3+dfsg-1) ...
Vorbereitung zum Entpacken von .../26-libwebp6_0.6.1-2.1+deb11u2_arm64.deb ...
Entpacken von libwebp6:arm64 (0.6.1-2.1+deb11u2) über (0.6.1-2.1) ...
Vorbereitung zum Entpacken von .../27-libwebpmux3_0.6.1-2.1+deb11u2_arm64.deb ...
Entpacken von libwebpmux3:arm64 (0.6.1-2.1+deb11u2) über (0.6.1-2.1) ...
Vorbereitung zum Entpacken von .../28-firmware-atheros_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
Entpacken von firmware-atheros (1:20230210-5~bpo11+1+rpt1) über (1:20221012-1~bpo11+1+rpt1) ...
Vorbereitung zum Entpacken von .../29-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
Entpacken von firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) über (1:20221012-1~bpo11+1+rpt1) ...
Vorbereitung zum Entpacken von .../30-firmware-libertas_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
Entpacken von firmware-libertas (1:20230210-5~bpo11+1+rpt1) über (1:20221012-1~bpo11+1+rpt1) ...
Vorbereitung zum Entpacken von .../31-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
Entpacken von firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) über (1:20221012-1~bpo11+1+rpt1) ...
Vorbereitung zum Entpacken von .../32-firmware-realtek_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
Entpacken von firmware-realtek (1:20230210-5~bpo11+1+rpt1) über (1:20221012-1~bpo11+1+rpt1) ...
Vorbereitung zum Entpacken von .../33-libgstreamer-plugins-base1.0-0_1.18.4-2+deb11u1_arm64.deb ...
Entpacken von libgstreamer-plugins-base1.0-0:arm64 (1.18.4-2+deb11u1) über (1.18.4-2) ...
Vorbereitung zum Entpacken von .../34-gstreamer1.0-alsa_1.18.4-2+deb11u1_arm64.deb ...
Entpacken von gstreamer1.0-alsa:arm64 (1.18.4-2+deb11u1) über (1.18.4-2) ...
Vorbereitung zum Entpacken von .../35-libflac8_1.3.3-2+deb11u2_arm64.deb ...
Entpacken von libflac8:arm64 (1.3.3-2+deb11u2) über (1.3.3-2+deb11u1) ...
Vorbereitung zum Entpacken von .../36-gstreamer1.0-plugins-good_1.18.4-2+deb11u2+rpt1_arm64.deb ...
Entpacken von gstreamer1.0-plugins-good:arm64 (1.18.4-2+deb11u2+rpt1) über (1.18.4-2+deb11u1+rpt1) ...
Vorbereitung zum Entpacken von .../37-gstreamer1.0-plugins-bad_1.18.4-3+deb11u1_arm64.deb ...
Entpacken von gstreamer1.0-plugins-bad:arm64 (1.18.4-3+deb11u1) über (1.18.4-3) ...
Vorbereitung zum Entpacken von .../38-gstreamer1.0-plugins-base_1.18.4-2+deb11u1_arm64.deb ...
Entpacken von gstreamer1.0-plugins-base:arm64 (1.18.4-2+deb11u1) über (1.18.4-2) ...
Vorbereitung zum Entpacken von .../39-libgstreamer-gl1.0-0_1.18.4-2+deb11u1_arm64.deb ...
Entpacken von libgstreamer-gl1.0-0:arm64 (1.18.4-2+deb11u1) über (1.18.4-2) ...
Vorbereitung zum Entpacken von .../40-libgstreamer-plugins-bad1.0-0_1.18.4-3+deb11u1_arm64.deb ...
Entpacken von libgstreamer-plugins-bad1.0-0:arm64 (1.18.4-3+deb11u1) über (1.18.4-3) ...
Vorbereitung zum Entpacken von .../41-gstreamer1.0-x_1.18.4-2+deb11u1_arm64.deb ...
Entpacken von gstreamer1.0-x:arm64 (1.18.4-2+deb11u1) über (1.18.4-2) ...
Vorbereitung zum Entpacken von .../42-libcamera0_0~git20230720+bde9b04f-1_arm64.deb ...
Entpacken von libcamera0:arm64 (0~git20230720+bde9b04f-1) über (0~git20230302+923f5d70-1) ...
Vorbereitung zum Entpacken von .../43-libcamera-apps_1.2.1-1_arm64.deb ...
Entpacken von libcamera-apps (1.2.1-1) über (0~git20230301+54a781d-1) ...
Vorbereitung zum Entpacken von .../44-libcamera-tools_0~git20230720+bde9b04f-1_arm64.deb ...
Entpacken von libcamera-tools (0~git20230720+bde9b04f-1) über (0~git20230302+923f5d70-1) ...
Vorbereitung zum Entpacken von .../45-libwebpdemux2_0.6.1-2.1+deb11u2_arm64.deb ...
Entpacken von libwebpdemux2:arm64 (0.6.1-2.1+deb11u2) über (0.6.1-2.1) ...
Vorbereitung zum Entpacken von .../46-libwebkit2gtk-4.0-37_2.40.5-1~deb11u1_arm64.deb ...
Entpacken von libwebkit2gtk-4.0-37:arm64 (2.40.5-1~deb11u1) über (2.38.5-1~deb11u1) ...
Vorbereitung zum Entpacken von .../47-libjavascriptcoregtk-4.0-18_2.40.5-1~deb11u1_arm64.deb ...
Entpacken von libjavascriptcoregtk-4.0-18:arm64 (2.40.5-1~deb11u1) über (2.38.5-1~deb11u1) ...
Vorbereitung zum Entpacken von .../48-libsynctex2_2020.20200327.54578-7+deb11u1_arm64.deb ...
Entpacken von libsynctex2:arm64 (2020.20200327.54578-7+deb11u1) über (2020.20200327.54578-7) ...
Vorbereitung zum Entpacken von .../49-vlc_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../50-vlc-plugin-base_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-base:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../51-vlc-data_1%3a3.0.18-0+rpt7+deb11u1_all.deb ...
Entpacken von vlc-data (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../52-libvlccore9_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von libvlccore9:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../53-vlc-plugin-skins2_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-skins2:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../54-vlc-plugin-qt_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-qt:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../55-vlc-plugin-video-output_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-video-output:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../56-libvlc5_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von libvlc5:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../57-vlc-bin_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-bin (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../58-libvlc-bin_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von libvlc-bin:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../59-lxplug-bluetooth_0.33_arm64.deb ...
Entpacken von lxplug-bluetooth (0.33) über (0.32) ...
Vorbereitung zum Entpacken von .../60-lxplug-cputemp_0.12_arm64.deb ...
Entpacken von lxplug-cputemp (0.12) über (0.10) ...
Vorbereitung zum Entpacken von .../61-lxplug-menu_0.4_arm64.deb ...
Entpacken von lxplug-menu (0.4) über (0.3) ...
Vorbereitung zum Entpacken von .../62-lxplug-network_0.33_arm64.deb ...
Entpacken von lxplug-network (0.33) über (0.32) ...
Vorbereitung zum Entpacken von .../63-lxplug-ptbatt_0.22_arm64.deb ...
Entpacken von lxplug-ptbatt (0.22) über (0.20) ...
Vorbereitung zum Entpacken von .../64-lxplug-updater_0.14_arm64.deb ...
Entpacken von lxplug-updater (0.14) über (0.13) ...
Vorbereitung zum Entpacken von .../65-openssl_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
Entpacken von openssl (1.1.1n-0+deb11u5+rpt1) über (1.1.1n-0+deb11u4+rpt1) ...
Vorbereitung zum Entpacken von .../66-python3-werkzeug_1.0.1+dfsg1-2+deb11u1_all.deb ...
Entpacken von python3-werkzeug (1.0.1+dfsg1-2+deb11u1) über (1.0.1+dfsg1-2) ...
Vorbereitung zum Entpacken von .../67-python3-flask_1.1.2-2+deb11u1_all.deb ...
Entpacken von python3-flask (1.1.2-2+deb11u1) über (1.1.2-2) ...
Vorbereitung zum Entpacken von .../68-python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb ...
Entpacken von python3-libcamera (0~git20230720+bde9b04f-1) über (0~git20230302+923f5d70-1) ...
Vorbereitung zum Entpacken von .../69-python3-picamera2_0.3.12-2_all.deb ...
Entpacken von python3-picamera2 (0.3.12-2) über (0.3.9-1) ...
Vorbereitung zum Entpacken von .../70-raspberrypi-sys-mods_20230510~bullseye_arm64.deb ...
Entpacken von raspberrypi-sys-mods (20230510~bullseye) über (20230329) ...
Vorbereitung zum Entpacken von .../71-realvnc-vnc-server_7.5.1.50075_arm64.deb ...
Entpacken von realvnc-vnc-server (7.5.1.50075) über (7.0.1.49073) ...
Vorbereitung zum Entpacken von .../72-rp-prefapps_0.47_arm64.deb ...
Entpacken von rp-prefapps (0.47) über (0.46) ...
Vorbereitung zum Entpacken von .../73-rpi-eeprom_16.1-1_arm64.deb ...
Entpacken von rpi-eeprom (16.1-1) über (16.0-1) ...
Vorbereitung zum Entpacken von .../74-rpi-imager_1.7.5+rpt1_arm64.deb ...
Entpacken von rpi-imager (1.7.5+rpt1) über (1.7.4+rpt1) ...
Vorbereitung zum Entpacken von .../75-vlc-l10n_1%3a3.0.18-0+rpt7+deb11u1_all.deb ...
Entpacken von vlc-l10n (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../76-vlc-plugin-access-extra_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-access-extra:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../77-vlc-plugin-notify_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-notify:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../78-vlc-plugin-samba_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-samba:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../79-vlc-plugin-video-splitter_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-video-splitter:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
Vorbereitung zum Entpacken von .../80-vlc-plugin-visualization_1%3a3.0.18-0+rpt7+deb11u1_arm64.deb ...
Entpacken von vlc-plugin-visualization:arm64 (1:3.0.18-0+rpt7+deb11u1) über (3.0.18-0+rpt3+deb11u1) ...
libssh-gcrypt-4:arm64 (0.9.7-0+deb11u1) wird eingerichtet ...
libgs9-common (9.53.3~dfsg-7+deb11u5) wird eingerichtet ...
rp-prefapps (0.47) wird eingerichtet ...
systemd-sysv (247.3-7+deb11u4) wird eingerichtet ...
chromium-codecs-ffmpeg-extra (113.0.5672.95-rpt1) wird eingerichtet ...
libgs9:arm64 (9.53.3~dfsg-7+deb11u5) wird eingerichtet ...
libfontembed1:arm64 (1.28.7-1+deb11u2) wird eingerichtet ...
libmagic-mgc (1:5.39-3+deb11u1) wird eingerichtet ...
libaom0:arm64 (1.0.0.errata1-3+deb11u1) wird eingerichtet ...
lxplug-ptbatt (0.22) wird eingerichtet ...
firmware-atheros (1:20230210-5~bpo11+1+rpt1) wird eingerichtet ...
firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) wird eingerichtet ...
libmagic1:arm64 (1:5.39-3+deb11u1) wird eingerichtet ...
libjavascriptcoregtk-4.0-18:arm64 (2.40.5-1~deb11u1) wird eingerichtet ...
libgstreamer-plugins-base1.0-0:arm64 (1.18.4-2+deb11u1) wird eingerichtet ...
vlc-l10n (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
file (1:5.39-3+deb11u1) wird eingerichtet ...
ghostscript (9.53.3~dfsg-7+deb11u5) wird eingerichtet ...
raspberrypi-sys-mods (20230510~bullseye) wird eingerichtet ...
lxplug-menu (0.4) wird eingerichtet ...
libflac8:arm64 (1.3.3-2+deb11u2) wird eingerichtet ...
librsvg2-2:arm64 (2.50.3+dfsg-1+deb11u1) wird eingerichtet ...
libgstreamer-plugins-bad1.0-0:arm64 (1.18.4-3+deb11u1) wird eingerichtet ...
lxplug-bluetooth (0.33) wird eingerichtet ...
gstreamer1.0-plugins-base:arm64 (1.18.4-2+deb11u1) wird eingerichtet ...
firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) wird eingerichtet ...
libx11-data (2:1.7.2-1+deb11u1) wird eingerichtet ...
python3-werkzeug (1.0.1+dfsg1-2+deb11u1) wird eingerichtet ...
firmware-realtek (1:20230210-5~bpo11+1+rpt1) wird eingerichtet ...
systemd-timesyncd (247.3-7+deb11u4) wird eingerichtet ...
udev (247.3-7+deb11u4) wird eingerichtet ...
libwebp6:arm64 (0.6.1-2.1+deb11u2) wird eingerichtet ...
librsvg2-common:arm64 (2.50.3+dfsg-1+deb11u1) wird eingerichtet ...
libvlccore9:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
lxplug-network (0.33) wird eingerichtet ...
firmware-libertas (1:20230210-5~bpo11+1+rpt1) wird eingerichtet ...
libpam-systemd:arm64 (247.3-7+deb11u4) wird eingerichtet ...
libx11-6:arm64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
rpi-eeprom (16.1-1) wird eingerichtet ...
rpi-imager (1.7.5+rpt1) wird eingerichtet ...
lxplug-cputemp (0.12) wird eingerichtet ...
realvnc-vnc-server (7.5.1.50075) wird eingerichtet ...
Updating /etc/pam.d/vncserver
Updating /etc/pam.conf... done
Looking for font path... not found.
Original config file "/etc/vnc/pulse/daemon.conf.old" preserved
Privater Schlüssel wird generiert... fertig
Installed systemd unit for VNC Server in Service Mode daemon
Start or stop the service with:
  systemctl (start|stop) vncserver-x11-serviced.service
Mark or unmark the service to be started at boot time with:
  systemctl (enable|disable) vncserver-x11-serviced.service
Installed systemd unit for VNC Server in Virtual Mode daemon
  systemctl (start|stop) vncserver-virtuald.service
  systemctl (enable|disable) vncserver-virtuald.service
libcamera0:arm64 (0~git20230720+bde9b04f-1) wird eingerichtet ...
openssl (1.1.1n-0+deb11u5+rpt1) wird eingerichtet ...
libwebpmux3:arm64 (0.6.1-2.1+deb11u2) wird eingerichtet ...
libjson-c5:arm64 (0.15-2+deb11u1) wird eingerichtet ...
vlc-data (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libcupsfilters1:arm64 (1.28.7-1+deb11u2) wird eingerichtet ...
lxplug-updater (0.14) wird eingerichtet ...
vlc-plugin-notify:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libsynctex2:arm64 (2020.20200327.54578-7+deb11u1) wird eingerichtet ...
vlc-plugin-video-output:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
vlc-plugin-samba:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libcamera-tools (0~git20230720+bde9b04f-1) wird eingerichtet ...
cups-browsed (1.28.7-1+deb11u2) wird eingerichtet ...
libx11-xcb1:arm64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
gstreamer1.0-x:arm64 (1.18.4-2+deb11u1) wird eingerichtet ...
gstreamer1.0-alsa:arm64 (1.18.4-2+deb11u1) wird eingerichtet ...
bind9-libs:arm64 (1:9.16.44-1~deb11u1) wird eingerichtet ...
python3-flask (1.1.2-2+deb11u1) wird eingerichtet ...
gstreamer1.0-plugins-good:arm64 (1.18.4-2+deb11u2+rpt1) wird eingerichtet ...
libwebpdemux2:arm64 (0.6.1-2.1+deb11u2) wird eingerichtet ...
vlc-plugin-video-splitter:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libvlc5:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
cups-filters-core-drivers (1.28.7-1+deb11u2) wird eingerichtet ...
libavutil56:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
vlc-plugin-visualization:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
vlc-plugin-access-extra:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libgstreamer-gl1.0-0:arm64 (1.18.4-2+deb11u1) wird eingerichtet ...
gstreamer1.0-plugins-bad:arm64 (1.18.4-3+deb11u1) wird eingerichtet ...
libpostproc55:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
python3-libcamera (0~git20230720+bde9b04f-1) wird eingerichtet ...
libwebkit2gtk-4.0-37:arm64 (2.40.5-1~deb11u1) wird eingerichtet ...
vlc-plugin-qt:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libvlc-bin:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
chromium-browser (113.0.5672.95-rpt1) wird eingerichtet ...
chromium-browser-l10n (113.0.5672.95-rpt1) wird eingerichtet ...
libswscale5:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
cups-filters (1.28.7-1+deb11u2) wird eingerichtet ...
bind9-host (1:9.16.44-1~deb11u1) wird eingerichtet ...
vlc-plugin-skins2:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
vlc-bin (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libswresample3:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
libavresample4:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
python3-picamera2 (0.3.12-2) wird eingerichtet ...
libavcodec58:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
libavformat58:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
libavfilter7:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
vlc-plugin-base:arm64 (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
vlc (1:3.0.18-0+rpt7+deb11u1) wird eingerichtet ...
libavdevice58:arm64 (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
ffmpeg (8:4.3.6-0+deb11u1+rpt5) wird eingerichtet ...
libcamera-apps (1.2.1-1) wird eingerichtet ...
Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
Trigger für cups (2.3.3op2-3+deb11u2) werden verarbeitet ...
Updating PPD files for cups-filters ...
Updating PPD files for escpr ...
Updating PPD files for hpcups ...
Updating PPD files for postscript-hp ...
Trigger für gnome-menus (3.36.0-1) werden verarbeitet ...
Trigger für libc-bin (2.31-13+rpt2+rpi1+deb11u5) werden verarbeitet ...
Trigger für man-db (2.9.4-2) werden verarbeitet ...
Trigger für dbus (1.12.24-0+deb11u1) werden verarbeitet ...
Trigger für libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u1) werden verarbeitet ...
Trigger für mailcap (3.69) werden verarbeitet ...
Trigger für desktop-file-utils (0.26-1) werden verarbeitet ...
Trigger für initramfs-tools (0.140) werden verarbeitet ...
Trigger für libvlc-bin:arm64 (1:3.0.18-0+rpt7+deb11u1) werden verarbeitet ...
remove firefox and libpam-chksshpwd
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Paket »firefox-esr« ist nicht installiert, wird also auch nicht entfernt.
Die folgenden Pakete werden ENTFERNT:
  libpam-chksshpwd* pprompt*
0 aktualisiert, 0 neu installiert, 2 zu entfernen und 0 nicht aktualisiert.
Nach dieser Operation werden 145 kB Plattenplatz freigegeben.
(Lese Datenbank ... 96925 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von pprompt (0.20) ...
Entfernen von libpam-chksshpwd:arm64 (1.4.0-9+deb11u1+rpt2) ...
(Lese Datenbank ... 96909 Dateien und Verzeichnisse sind derzeit installiert.)
Löschen der Konfigurationsdateien von pprompt (0.20) ...
Löschen der Konfigurationsdateien von libpam-chksshpwd:arm64 (1.4.0-9+deb11u1+rpt2) ...
install required packages. It will take a while, please wait
E: Für Paket »python-pip« existiert kein Installationskandidat.
install required packages. It will take a while, please wait for second bach
E: Paket libssl1.0.2 kann nicht gefunden werden.
E: Mittels des Musters »libssl1.0.2« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »libssl1.0.2« konnte kein Paket gefunden werden.
E: Paket php7.3-cli kann nicht gefunden werden.
E: Mittels des Musters »php7.3-cli« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-cli« konnte kein Paket gefunden werden.
E: Paket php7.3-gd kann nicht gefunden werden.
E: Mittels des Musters »php7.3-gd« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-gd« konnte kein Paket gefunden werden.
E: Paket php7.3-opcache kann nicht gefunden werden.
E: Mittels des Musters »php7.3-opcache« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-opcache« konnte kein Paket gefunden werden.
E: Für Paket »php7.3-common« existiert kein Installationskandidat.
E: Paket php7.3-json kann nicht gefunden werden.
E: Mittels des Musters »php7.3-json« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-json« konnte kein Paket gefunden werden.
E: Paket php7.3-readline kann nicht gefunden werden.
E: Mittels des Musters »php7.3-readline« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-readline« konnte kein Paket gefunden werden.
E: Paket php7.3-xml kann nicht gefunden werden.
E: Mittels des Musters »php7.3-xml« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-xml« konnte kein Paket gefunden werden.
E: Paket php7.3-curl kann nicht gefunden werden.
E: Mittels des Musters »php7.3-curl« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »php7.3-curl« konnte kein Paket gefunden werden.
E: Paket libapache2-mod-php7.3 kann nicht gefunden werden.
E: Mittels des Musters »libapache2-mod-php7.3« konnte kein Paket gefunden werden.
E: Mittels regulärem Ausdruck »libapache2-mod-php7.3« konnte kein Paket gefunden werden.
Removing junk
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Install pip requests paho-mqtt
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.25.1)
Collecting paho-mqtt
  Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
     |████████████████████████████████| 75 kB 347 kB/s
Collecting docopt
  Downloading https://www.piwheels.org/simple/docopt/docopt-0.6.2-py2.py3-none-any.whl (13 kB)
Requirement already satisfied: certifi in /usr/lib/python3/dist-packages (2020.6.20)
Collecting aiohttp
  Downloading aiohttp-3.8.5-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.1 MB)
     |████████████████████████████████| 1.1 MB 85 kB/s
Collecting pymodbus
  Downloading pymodbus-3.5.2-py3-none-any.whl (203 kB)
     |████████████████████████████████| 203 kB 1.2 MB/s
Collecting jq
  Downloading jq-1.6.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (646 kB)
     |████████████████████████████████| 646 kB 1.2 MB/s
Collecting pparser
  Downloading https://www.piwheels.org/simple/pparser/pparser-2.0.2-py3-none-any.whl (29 kB)
Collecting bs4
  Downloading https://www.piwheels.org/simple/bs4/bs4-0.0.1-py3-none-any.whl (2.2 kB)
Collecting pkce
  Downloading https://www.piwheels.org/simple/pkce/pkce-1.0.3-py3-none-any.whl (3.2 kB)
Collecting charset-normalizer<4.0,>=2.0
  Downloading charset_normalizer-3.2.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (198 kB)
     |████████████████████████████████| 198 kB 1.2 MB/s
Collecting attrs>=17.3.0
  Downloading https://www.piwheels.org/simple/attrs/attrs-23.1.0-py3-none-any.whl (61 kB)
     |████████████████████████████████| 61 kB 671 kB/s
Collecting multidict<7.0,>=4.5
  Downloading multidict-6.0.4-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (116 kB)
     |████████████████████████████████| 116 kB 1.2 MB/s
Collecting frozenlist>=1.1.1
  Downloading frozenlist-1.4.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (228 kB)
     |████████████████████████████████| 228 kB 1.2 MB/s
Collecting async-timeout<5.0,>=4.0.0a3
  Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Collecting aiosignal>=1.1.2
  Downloading https://www.piwheels.org/simple/aiosignal/aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
Collecting yarl<2.0,>=1.0
  Downloading yarl-1.9.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (265 kB)
     |████████████████████████████████| 265 kB 43 kB/s
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp) (2.10)
Requirement already satisfied: beautifulsoup4 in /usr/lib/python3/dist-packages (from bs4) (4.9.3)
Collecting packaging>=20.4
  Downloading https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
     |████████████████████████████████| 48 kB 504 kB/s
Requirement already satisfied: colorama>=0.4.3 in /usr/lib/python3/dist-packages (from pparser) (0.4.4)
Requirement already satisfied: soupsieve>1.2 in /usr/lib/python3/dist-packages (from beautifulsoup4->bs4) (2.2.1)
Installing collected packages: multidict, frozenlist, yarl, packaging, charset-normalizer, attrs, async-timeout, aiosignal, pymodbus, pparser, pkce, paho-mqtt, jq, docopt, bs4, aiohttp
Successfully installed aiohttp-3.8.5 aiosignal-1.3.1 async-timeout-4.0.3 attrs-23.1.0 bs4-0.0.1 charset-normalizer-3.2.0 docopt-0.6.2 frozenlist-1.4.0 jq-1.6.0 multidict-6.0.4 packaging-23.1 paho-mqtt-1.6.1 pkce-1.0.3 pparser-2.0.2 pymodbus-3.5.2 yarl-1.9.2
Install pip requests Adafruit_MCP4725 evdev 1.6.0 pyserial sysv_ipc 1.0.1
Collecting Adafruit_MCP4725
  Downloading https://www.piwheels.org/simple/adafruit-mcp4725/Adafruit_MCP4725-1.0.4-py3-none-any.whl (3.9 kB)
Requirement already satisfied: pyserial in /usr/lib/python3/dist-packages (3.5b0)
Collecting sysv_ipc==1.0.1
  Downloading sysv_ipc-1.0.1.tar.gz (102 kB)
     |████████████████████████████████| 102 kB 783 kB/s
Collecting evdev==1.6.0
  Downloading evdev-1.6.0.tar.gz (26 kB)
Requirement already satisfied: urllib3 in /usr/lib/python3/dist-packages (1.26.5)
Collecting Adafruit-GPIO>=0.6.5
  Downloading https://www.piwheels.org/simple/adafruit-gpio/Adafruit_GPIO-1.0.3-py3-none-any.whl (38 kB)
Collecting adafruit-pureio
  Downloading https://www.piwheels.org/simple/adafruit-pureio/Adafruit_PureIO-1.1.11-py3-none-any.whl (10 kB)
Requirement already satisfied: spidev in /usr/lib/python3/dist-packages (from Adafruit-GPIO>=0.6.5->Adafruit_MCP4725) (3.5)
Building wheels for collected packages: evdev, sysv-ipc
  Building wheel for evdev (setup.py) ... done
  Created wheel for evdev: filename=evdev-1.6.0-cp39-cp39-linux_aarch64.whl size=84232 sha256=faacf262322bf17ab9fbddc72da132913c08cc69f3a6e92d87a617f3be48cd22
  Stored in directory: /root/.cache/pip/wheels/a0/06/04/6b78264b54f05314363fa0b6d7cbfa26f0a80999e63cc181e8
  Building wheel for sysv-ipc (setup.py) ... done
  Created wheel for sysv-ipc: filename=sysv_ipc-1.0.1-cp39-cp39-linux_aarch64.whl size=65898 sha256=21efd8accd4608165c3af3b801ab24cd89e4fbcf10172710113e96c4d2917163
  Stored in directory: /root/.cache/pip/wheels/10/12/1f/c41cf705510daffafb87aae3778da01c29c3c8423be753ee37
Successfully built evdev sysv-ipc
Installing collected packages: adafruit-pureio, Adafruit-GPIO, sysv-ipc, evdev, Adafruit-MCP4725
Successfully installed Adafruit-GPIO-1.0.3 Adafruit-MCP4725-1.0.4 adafruit-pureio-1.1.11 evdev-1.6.0 sysv-ipc-1.0.1
...done
check for timezone
...ok
check for i2c bus
check for initial git clone
/home/pi/openwb-install.sh: Zeile 60: cd: /var/www/html/: Datei oder Verzeichnis nicht gefunden
Klone nach 'openWB' ...
remote: Enumerating objects: 46070, done.
remote: Counting objects: 100% (1363/1363), done.
remote: Compressing objects: 100% (588/588), done.
remote: Total 46070 (delta 861), reused 1129 (delta 729), pack-reused 44707
Empfange Objekte: 100% (46070/46070), 100.58 MiB | 928.00 KiB/s, fertig.
Löse Unterschiede auf: 100% (31673/31673), fertig.
Aktualisiere Dateien: 100% (1410/1410), fertig.
... git cloned
grep: /var/www/html/openWB/openwb.conf: Datei oder Verzeichnis nicht gefunden
/home/pi/openwb-install.sh: Zeile 70: /var/www/html/openWB/openwb.conf: Datei oder Verzeichnis nicht gefunden
check for ramdisk
...created
Failed to start mosquitto.service: Unit mosquitto.service not found.
updating mosquitto config file
cp: der Aufruf von stat für '/var/www/html/openWB/web/files/mosquitto.conf' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
mosquitto: unrecognized service
disable cronjob logging
fix upload limit...installing pymodbus
Requirement already satisfied: pymodbus in /usr/local/lib/python3.9/dist-packages (3.5.2)
Collecting pymodbus
  Using cached pymodbus-3.5.2-py3-none-any.whl (203 kB)
  Downloading pymodbus-3.5.1-py3-none-any.whl (203 kB)
check for paho-mqtt
mqtt installed...
check for MCP4725
Adafruit_MCP4725 installed...
www-data ALL=(ALL) NOPASSWD: ALL
ServerName 127.0.0.1
restarting apache2.service
Failed to reload apache2.service: Unit apache2.service not found.
done restarting apache2.service
chmod: Zugriff auf '/var/www/html/openWB/openwb.conf' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Zugriff auf '/var/www/html/openWB/modules/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Zugriff auf '/var/www/html/openWB/runs/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Zugriff auf '/var/www/html/openWB/*.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
running atreboot script. It will take a while...
sudo: /var/www/html/openWB/runs/atreboot.sh: Befehl nicht gefunden
adding cron jobs to crontab
no crontab for root
all done! Don't forget to create the corong jobs and after that, to reboot
Hopefully you can help
Regards
Andreas
Verfasst: Sa Sep 23, 2023 11:13 am
von derNeueDet
Du musst BUSTER verwenden nicht Bullseye.
Verfasst: Sa Sep 23, 2023 12:16 pm
von courage2000
1. Use buster image, there is a link in the first post.
2. Check under pi user if the lines are added to crontab
crontab -e
The last lines should be:
sudo reboot
Verfasst: Sa Sep 23, 2023 1:15 pm
von openWB
Software2 gibt es sonst auch direkt als Image.
viewtopic.php?t=7317
Verfasst: Sa Sep 23, 2023 1:19 pm
von kratan75
Das läuft aber nicht.
Normal muß das doch immer so groß sein als die original SD Karte. Also 16 GB.
Dieses ist nur 1,7 GB groß.
Oder mach ich was falsch ?
Fakt ist der Raspi in der Wallbox mach exakt gar nichts wenn ich da dieses image drauf jage.
Verfasst: Sa Sep 23, 2023 1:21 pm
von openWB
Mit balenaetcher flashen. Das ist komprimiert.
Verfasst: Sa Sep 23, 2023 1:24 pm
von kratan75
okay ich probier das dann nochmal.
Weißt du zufällig was für ein Raspi da drinnen werkelt ?
Ich möchte da mal selber was probieren aber nicht auf dem Hauptsystem.
Verfasst: Sa Sep 23, 2023 1:52 pm
von openWB
Das Image lauft auf 3 & 4
Verfasst: Mo Sep 25, 2023 5:50 am
von hopper
kratan75 hat geschrieben: Sa Sep 23, 2023 1:24 pm okay ich probier das dann nochmal.
In der Box ist ein 3b+ verbaut.
