OpenWB 1.9.304 loopt - gelöst HW Problem des Steckers
Ren001
Beitrag von Ren001 »
OpenWB Series 1 am LAN Kabel
FW 1.9.304
EVU Fronius Gen10 mit Fronius Smartmeter TS65A-3 FW 1.32.51-1 am LAN Kabel
Kompatibilitätsmodus Variante 1
Es scheint, als ob Fronius mit dem letzten FW Update die API Parameter geändert hat. Ich bekomme laufend folgende Meldungen und die OpenWB lädt das Tesla Model 3 nicht mehr.
2023-10-06 15:50:12: PID: 2667: **** FATAL ********************************* (LV0)
2023-10-06 15:50:12: PID: 2667: **** FATAL Regulation loop needs 11 seconds (LV0)
2023-10-06 15:50:11: PID: 4449: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
2667
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.59', port=80): Max retries exceeded with url: /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0&DataCollection=MeterRealtimeData (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x74d20f10>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
raise ConnectionError(e, request=request)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 487, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 609, in send
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 488, in request
return self.request('GET', url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 501, in get
timeout=5)
File "/var/www/html/openWB/packages/modules/devices/fronius/counter_sm.py", line 63, in __update_variant_0_1
counter_state = self.__update_variant_0_1(session)
File "/var/www/html/openWB/packages/modules/devices/fronius/counter_sm.py", line 36, in update
self.components[component].update()
File "/var/www/html/openWB/packages/modules/devices/fronius/device.py", line 63, in update
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.59', port=80): Max retries exceeded with url: /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0&DataCollection=MeterRealtimeData (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x74d20f10>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
raise MaxRetryError(_pool, url, error or ResponseError(cause))
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/retry.py", line 592, in increment
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 786, in urlopen
timeout=timeout
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 423, in send
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x74d20f10>: Failed to establish a new connection: [Errno 101] Network is unreachable
self, "Failed to establish a new connection: %s" % e
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 187, in _new_conn
conn = self._new_conn()
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 205, in connect
self.connect()
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 239, in request
conn.request(method, url, **httplib_request_kw)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 398, in _make_request
chunked=chunked,
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 710, in urlopen
OSError: [Errno 101] Network is unreachable
sock.connect(sa)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/connection.py", line 85, in create_connection
raise err
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/connection.py", line 95, in create_connection
(self._dns_host, self.port), self.timeout, **extra_kw
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 175, in _new_conn
2023-10-06 15:50:04: PID: 3746: modules.common.fault_state: Fronius SM Zähler: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Server http://192.168.1.59/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0&DataCollection=MeterRealtimeData ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
2023-10-06 15:50:03: PID: 2668: ##### cron5min.sh finished ##### (LV0)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.59', port=80): Max retries exceeded with url: /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x74d20570>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
timeout=5).json()
File "/var/www/html/openWB/packages/modules/devices/fronius/bat.py", line 33, in update
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.59', port=80): Max retries exceeded with url: /solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x74d20570>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
timeout=timeout
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x74d20570>: Failed to establish a new connection: [Errno 101] Network is unreachable
self.connect()
self.send(msg)
chunked=chunked,
sock.connect(sa)
raise err
2023-10-06 15:50:03: PID: 3746: modules.common.fault_state: Fronius Speicher: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Server http://192.168.1.59/solar_api/v1/GetPowerFlowRealtimeData.fcgi?Scope=System ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
2023-10-06 15:50:01: PID: 2921: Starting OpenWB services (LV0)
RTNETLINK answers: Network is unreachable
2023-10-06 15:50:01: PID: 2668: ##### cron5min.sh started ##### (LV0)
2023-10-06 15:49:52: PID: 760: **** FATAL ********************************* (LV0)
2023-10-06 15:49:52: PID: 760: **** FATAL Regulation loop needs 11 seconds (LV0)
2023-10-06 15:49:51: PID: 2293: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
760
2023-10-06 15:49:33: PID: 31503: **** FATAL ********************************* (LV0)
2023-10-06 15:49:33: PID: 31503: **** FATAL Regulation loop needs 12 seconds (LV0)
2023-10-06 15:49:31: PID: 483: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
Die direkte Abfrage über http (Adresse 192.168.1.59) funktioniert aber und das API ist enabled.
Aufruf:
http://192.168.1.199/openWB/modules/bez ... 2.168.1.59
Antwort:
   "Body" : {
      "Data" : {
         "0" : {
            "Current_AC_Phase_1" : -1.3700000000000001,
            "Current_AC_Phase_2" : 4.343,
            "Current_AC_Phase_3" : -2.4409999999999998,
            "Current_AC_Sum" : 0.53200000000000003,
            "Details" : {
               "Manufacturer" : "Fronius",
               "Model" : "Smart Meter TS 65A-3",
               "Serial" : "2979136943"
            "Enable" : 1,
            "EnergyReactive_VArAC_Sum_Consumed" : 39137.0,
            "EnergyReactive_VArAC_Sum_Produced" : 1565231.0,
            "EnergyReal_WAC_Minus_Absolute" : 716051.0,
            "EnergyReal_WAC_Plus_Absolute" : 2094650.9999999998,
            "EnergyReal_WAC_Sum_Consumed" : 2094650.9999999998,
            "EnergyReal_WAC_Sum_Produced" : 716051.0,
            "Frequency_Phase_Average" : 50.0,
            "Meter_Location_Current" : 0.0,
            "PowerApparent_S_Phase_1" : 280.80000000000001,
            "PowerApparent_S_Phase_2" : 836.29999999999995,
            "PowerApparent_S_Phase_3" : 572.60000000000002,
            "PowerApparent_S_Sum" : 1689.9000000000001,
            "PowerFactor_Phase_1" : -0.76400000000000001,
            "PowerFactor_Phase_2" : 0.81200000000000006,
            "PowerFactor_Phase_3" : -0.98299999999999998,
            "PowerFactor_Sum" : 0.0,
            "PowerReactive_Q_Phase_1" : -139.0,
            "PowerReactive_Q_Phase_2" : -218.30000000000001,
            "PowerReactive_Q_Phase_3" : -85.5,
            "PowerReactive_Q_Sum" : -442.89999999999998,
            "PowerReal_P_Phase_1" : -244.0,
            "PowerReal_P_Phase_2" : 807.29999999999995,
            "PowerReal_P_Phase_3" : -566.20000000000005,
            "PowerReal_P_Sum" : -2.8999999999999999,
            "TimeStamp" : 1723994901,
            "Visible" : 1,
            "Voltage_AC_PhaseToPhase_12" : 403.19999999999999,
            "Voltage_AC_PhaseToPhase_23" : 402.60000000000002,
            "Voltage_AC_PhaseToPhase_31" : 403.89999999999998,
            "Voltage_AC_Phase_1" : 233.59999999999999,
            "Voltage_AC_Phase_2" : 229.69999999999999,
            "Voltage_AC_Phase_3" : 235.19999999999999
   "Head" : {
      "RequestArguments" : {
         "Scope" : "System"
      "Status" : {
         "Code" : 0,
         "Reason" : "",
         "UserMessage" : ""
      "Timestamp" : "2024-08-18T15:28:22+00:00"
Gibt es da einen Tipp?
P.S.:
Ein Ticket habe ich heute eröffnet
Herzlichen Dank!
Zuletzt geändert von Ren001 am Fr Sep 06, 2024 9:35 am, insgesamt 1-mal geändert.
Has thanked: 20 times
Been thanked: 140 times
Re: Änderung in Fronius GEN24 FW? - OpenWB 1.9.304 loopt
Hast Du mittlerweile meine Hinweise mal geprüft?
https://forum.openwb.de/viewtopic.php?p=114809#p114809
Been thanked: 46 times
Im Log wird die IP 192.168.1.59 abgefragt, in deinem Beispiel fragst du dann aber die IP mit 192.168.1.199 ab. Ist das Absicht?
Welche IP hat die openWB? Wird WLAN oder LAN verwendet?
Ren001
Die OpenWB hat IP 192.168.1.199, der Fronius WR hat 192.168.1.59. Beide sind über LAN verkabelt.
Ich habe die Beispielabfrage hier aus dem Forum genommen und die IPs auf meine adaptiert - es soll zeigen, dass die OpenWB Verbindung zum WR hat.
Ren001
@LutzB
Danke für die Hinweise, die habe ich überprüft.
Probeweise habe ich auch eine Imagesicherung von 11/2023 mit 1.9.303 zurückgespielt - auch damit kommt jetzt derselbe Fehler. Der Fehler tritt seit 8.8.2024 auf, meiner Vermutung nach nach dem Update der Fronius FW auf 1.32.51-1.
Die Frage ist, ob das Problem andere User auf openWB 2.0 auch haben?
Ren001
Re: OpenWB 1.9.304 loopt - gelöst HW Problem des Steckers
Das Problem war der blaue EV Chargeking Stecker, der plötzlich nicht mehr mit dem Chargeport des Tesla Model 3 2019 zusammenarbeiten wollte.
An einem 2024 Highland funktioniert der Stecker und damit OpenWB jedoch.
So wird nun der 2019er am TWC (Port 2) geladen und der 2024er am EV Chargeking Stecker und alles ist gut.
