Bei der Verarbeitung des Befehls 'getDailyLog' mit den Parametern '[object Object]' ist ein Fehler aufgetreten:
Es ist ein interner Fehler aufgetreten: Traceback (most recent call last):
  File "/var/www/html/openWB/packages/helpermodules/command.py", line 127, in on_message
    func(connection_id, payload)
  File "/var/www/html/openWB/packages/helpermodules/command.py", line 561, in getDailyLog
    get_daily_log(payload["data"]["day"]))
  File "/var/www/html/openWB/packages/helpermodules/measurement_logging/process_log.py", line 140, in get_daily_log
    data = _collect_daily_log_data(date)
  File "/var/www/html/openWB/packages/helpermodules/measurement_logging/process_log.py", line 154, in _collect_daily_log_data
    log_data["entries"].append(create_entry(
  File "/var/www/html/openWB/packages/helpermodules/measurement_logging/write_log.py", line 253, in create_entry
    return fix_values(new_entry, previous_entry)
  File "/var/www/html/openWB/packages/helpermodules/measurement_logging/write_log.py", line 265, in fix_values
    find_and_fix_value("exported")
  File "/var/www/html/openWB/packages/helpermodules/measurement_logging/write_log.py", line 260, in find_and_fix_value
    value[value_name] = previous_entry[group][component][value_name]
KeyError: 'cp3'
