Aus dem Debug-Log (SoC Log ist leer, wegen Reboot).
2024-04-29 17:35:03: PID: 8500: ##### cron5min.sh finished ##### (LV0)
2024-04-29 17:35:02: PID: 8799: Starting OpenWB services (LV0)
2024-04-29 17:35:01: PID: 8500: ##### cron5min.sh started ##### (LV0)
2024-04-29 17:31:09: PID: 10528: **** WARNING **** Regulation loop needs 8 seconds (LV0)
2024-04-29 17:30:03: PID: 4065: ##### cron5min.sh finished ##### (LV0)
2024-04-29 17:30:01: PID: 4267: Starting OpenWB services (LV0)
2024-04-29 17:30:01: PID: 2770: **** FATAL ********************************* (LV0)
2024-04-29 17:30:01: PID: 2770: **** FATAL Regulation loop needs 29 seconds (LV0)
2024-04-29 17:30:01: PID: 4065: ##### cron5min.sh started ##### (LV0)
2024-04-29 17:30:01: PID: 4051: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
2770
tail: '/var/www/html/openWB/ramdisk/soc1-live.graph' kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
2024-04-29 17:29:51: PID: 3663: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
2770
2024-04-29 17:29:51: PID: 3653: Pause nach Umschaltung: 2s (LV0)
2024-04-29 17:29:41: PID: 3249: Previous regulation loop still running. Skipping. (LV0) at 35 main /var/www/html/openWB/regel.sh
2770
loadvars.sh: Zeile 1872: ramdisk/mqttslavemode: Datei oder Verzeichnis nicht gefunden
Trying to read meter serial number once from meter at address /dev/ttyUSB0, ID 105
no response from id 201
no response from id 5
2024-04-29 17:29:22: at_reboot: 2024-04-29 17:29:22: boot done :-)
2024-04-29 17:29:22: at_reboot: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
2024-04-29 17:29:21: PID: 2707: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:29:21: at_reboot: fix upload limit...OS Stretch
2024-04-29 17:29:21: at_reboot: not activated, skipping
2024-04-29 17:29:21: at_reboot: etprovider...
2024-04-29 17:29:12: at_reboot: update broker...
2024-04-29 17:29:11: PID: 2592: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:29:10: PID: 2522: legacy run server: Changing log level DEBUG -> WARNING
2024-04-29 17:29:09: at_reboot: Starting legacy run server
2024-04-29 17:29:09: PID: 2461: legacy run server is not running. Restarting process (LV0)
2024-04-29 17:29:09: PID: 2461: smart home handler not running! restarting process (LV0)
2024-04-29 17:29:09: PID: 2461: mqtt handler not running! restarting process (LV0)
2024-04-29 17:29:09: PID: 2461: modbus tcp server not running! restarting process (LV0)
2024-04-29 17:29:09: PID: 2461: Starting OpenWB services (LV0)
2024-04-29 17:29:09: PID: 2461: OpenWB services stopped (LV0)
2024-04-29 17:29:09: PID: 2461: Stopping OpenWB services (LV0)
2024-04-29 17:29:09: at_reboot: clear warning...
2024-04-29 17:29:09: at_reboot: </body></html>
2024-04-29 17:29:09: at_reboot: <address>Apache Server at openwb.de Port 443</address>
2024-04-29 17:29:09: at_reboot: <hr>
2024-04-29 17:29:09: at_reboot: <p>The requested URL was not found on this server.</p>
2024-04-29 17:29:09: at_reboot: <h1>Not Found</h1>
2024-04-29 17:29:09: at_reboot: </head><body>
2024-04-29 17:29:09: at_reboot: <title>404 Not Found</title>
2024-04-29 17:29:09: at_reboot: <html><head>
2024-04-29 17:29:09: at_reboot: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 301 100 256 100 45 1267 222 --:--:-- --:--:-- --:--:-- 1273
2024-04-29 17:29:09: at_reboot: Dload Upload Total Spent Left Speed
2024-04-29 17:29:09: at_reboot: % Total % Received % Xferd Average Speed Time Time Time Current
2024-04-29 17:29:09: at_reboot: version...
2024-04-29 17:29:08: at_reboot: No matching distribution found for urllib3
2024-04-29 17:29:08: at_reboot: Could not find a version that satisfies the requirement urllib3 (from versions: )
2024-04-29 17:29:07: at_reboot: Collecting urllib3
2024-04-29 17:29:01: PID: 2419: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:29:01: PID: 2380: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:57: at_reboot: lxml installed...
2024-04-29 17:28:57: at_reboot: all required modules are installed
2024-04-29 17:28:57: at_reboot: python3 packages...
2024-04-29 17:28:57: at_reboot: updating mosquitto config file
2024-04-29 17:28:57: at_reboot: mosquitto...
2024-04-29 17:28:56: at_reboot: cp: '/usr/share/zoneinfo/Europe/Berlin' und '/etc/localtime' sind die gleiche Datei
2024-04-29 17:28:56: at_reboot: timezone...
2024-04-29 17:28:56: at_reboot: 2024-04-29 17:28:56: PID: 2321: upgradeChargeLogs: upgrading charge logs done
2024-04-29 17:28:56: at_reboot: 2024-04-29 17:28:56: PID: 2321: upgradeChargeLogs: upgrading charge logs with a price of 0.359 per kWh
2024-04-29 17:28:56: at_reboot: evdev for python2 installed...
2024-04-29 17:28:56: at_reboot: packages 1...
2024-04-29 17:28:55: at_reboot: crontab 2...
2024-04-29 17:28:55: at_reboot: ...changed
2024-04-29 17:28:55: at_reboot: apache...
2024-04-29 17:28:55: at_reboot: crontab 1...
2024-04-29 17:28:55: at_reboot: deleting browser cache
2024-04-29 17:28:55: at_reboot: already up to date
2024-04-29 17:28:55: at_reboot: display...
2024-04-29 17:28:51: PID: 2233: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:51: at_reboot: triginit...
2024-04-29 17:28:51: at_reboot: Ramdisk init done.
2024-04-29 17:28:51: at_reboot: Trigger update of logfiles...
2024-04-29 17:28:50: at_reboot: 'mqttwizzarddone' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttwattbezug' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttversion' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttverbraucher2_name' missing: Setting to provided default value 'notset'
2024-04-29 17:28:50: at_reboot: 'mqttverbraucher2_aktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttverbraucher1_name' missing: Setting to provided default value 'notset'
2024-04-29 17:28:50: at_reboot: 'mqttverbraucher1_aktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttupdateinprogress' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttu1p3pstandby' missing: Setting to provided default value '-1'
2024-04-29 17:28:50: at_reboot: 'mqttu1p3psofort' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttu1p3pnurpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttu1p3pnl' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttu1p3pminundpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttu1p3paktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttstopchargepvpercentagelp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttstopchargepvpercentagelp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttstopchargepvatpercentlp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttstopchargepvatpercentlp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeicherwattnurpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeichersocnurpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeichersocminpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeichersochystminpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeicherpvui' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeicherpveinbeziehen' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttspeichermaxwatt' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsofortsocstatlp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsofortsocstatlp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsofortsoclp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsofortsoclp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsocvorhanden' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsoc' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttsoc1vorhanden' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttrfidakt' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttrestzeitlp3' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttrestzeitlp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttrestzeitlp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttpvwatt' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttpvbezugeinspeisung' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttpreisjekwh' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttoffsetpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnurpv70dynw' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnurpv70dynact' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnlakt_standby' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnlakt_sofort' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnlakt_nurpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnlakt_minpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnachtladens1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttnachtladen' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminnurpvsoclp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminnurpvsocll' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminimalstromstaerke' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminimalapv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminimalampv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttminimalalp2pv' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttmindestuberschuss' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttmaxnurpvsoclp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttmaximalstromstaerke' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlastlademodus' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstats2' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstats1' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstatlp8' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstatlp7' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstatlp6' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstatlp5' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstatlp4' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademstat' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademkwhlp8' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademkwhlp7' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademkwhlp6' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademkwhlp5' missing: Setting to provided default value '-1'
2024-04-29 17:28:49: at_reboot: 'mqttlademkwhlp4' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlademkwh' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtthook3_aktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtthook2_aktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtthook1_aktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttheutegeladen' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtthausverbrauchstat' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtthausverbrauch' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttevuglaettungakt' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp8etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp7etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp6etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp5etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp4etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp3etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp2etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttlp1etbasedcharging' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttetprovider' missing: Setting to provided default value 'notset'
2024-04-29 17:28:48: at_reboot: 'mqttetprovideraktiv' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqtteinschaltverzoegerung' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdurchslp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdisplayspeichermax' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdisplaypvmax' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdisplayhausmax' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdisplayhausanzeigen' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdisplayevumax' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdatenschutzack' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdailychargelp3' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdailychargelp2' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttdailychargelp1' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttaktgeladens2' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttaktgeladens1' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttaktgeladen' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttadaptpv' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttadaptfaktor' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttabschaltverzoegerung' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttabschaltuberschuss' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttRandomSleepValue' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: 'mqttCp1Configured' missing: Setting to provided default value '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp8' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp8max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp8name' missing: no MQTT topic set: Setting to default of 'Lp8'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp8' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp8' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp8' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:48: at_reboot: '/var/www/html/openWB/ramdisk/lp8sofortll' missing: Setting from MQTT topic 'lp8sofortll' to value '10'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp8' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp8' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/lp8enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/lp8phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:47: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp8' missing: Setting from MQTT topic 'pluggedladungaktlp8' to value '0'
2024-04-29 17:28:46: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp8startkwh' missing: Setting from MQTT topic 'pluggedladunglp8startkwh' to value '0'
2024-04-29 17:28:45: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:45: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp7' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp7max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp7name' missing: no MQTT topic set: Setting to default of 'Lp7'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp7' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp7' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp7' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:44: at_reboot: '/var/www/html/openWB/ramdisk/lp7sofortll' missing: Setting from MQTT topic 'lp7sofortll' to value '10'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp7' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp7' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/lp7enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/lp7phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:43: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp7' missing: Setting from MQTT topic 'pluggedladungaktlp7' to value '0'
2024-04-29 17:28:42: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp7startkwh' missing: Setting from MQTT topic 'pluggedladunglp7startkwh' to value '0'
2024-04-29 17:28:41: PID: 2041: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp6' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp6max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp6name' missing: no MQTT topic set: Setting to default of 'Lp6'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp6' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp6' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp6' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:41: at_reboot: '/var/www/html/openWB/ramdisk/lp6sofortll' missing: Setting from MQTT topic 'lp6sofortll' to value '10'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp6' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp6' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/lp6enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/lp6phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:40: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp6' missing: Setting from MQTT topic 'pluggedladungaktlp6' to value '0'
2024-04-29 17:28:39: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp6startkwh' missing: Setting from MQTT topic 'pluggedladunglp6startkwh' to value '0'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp5' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp5max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp5name' missing: no MQTT topic set: Setting to default of 'Lp5'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp5' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp5' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp5' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:38: at_reboot: '/var/www/html/openWB/ramdisk/lp5sofortll' missing: Setting from MQTT topic 'lp5sofortll' to value '10'
2024-04-29 17:28:37: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:37: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp5' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:37: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp5' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:36: at_reboot: '/var/www/html/openWB/ramdisk/lp5enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:36: at_reboot: '/var/www/html/openWB/ramdisk/lp5phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:36: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp5' missing: Setting from MQTT topic 'pluggedladungaktlp5' to value '0'
2024-04-29 17:28:25: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp5startkwh' missing: Setting from MQTT topic 'pluggedladunglp5startkwh' to value '0'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp4' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp4max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp4name' missing: no MQTT topic set: Setting to default of 'Lp4'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp4' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp4' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp4' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:24: at_reboot: '/var/www/html/openWB/ramdisk/lp4sofortll' missing: Setting from MQTT topic 'lp4sofortll' to value '10'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp4' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp4' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/lp4enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/lp4phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:23: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp4' missing: Setting from MQTT topic 'pluggedladungaktlp4' to value '0'
2024-04-29 17:28:22: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp4startkwh' missing: Setting from MQTT topic 'pluggedladunglp4startkwh' to value '0'
2024-04-29 17:28:21: PID: 1958: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp3' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp3max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp3name' missing: no MQTT topic set: Setting to default of 'Lp3'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp3' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp3' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/rfidlp3' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:21: at_reboot: '/var/www/html/openWB/ramdisk/lp3sofortll' missing: Setting from MQTT topic 'lp3sofortll' to value '10'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp3' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp3' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/lp3enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/lp3phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:19: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp3' missing: Setting from MQTT topic 'pluggedladungaktlp3' to value '0'
2024-04-29 17:28:18: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp3startkwh' missing: Setting from MQTT topic 'pluggedladunglp3startkwh' to value '0'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp2' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp2max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp2name' missing: no MQTT topic set: Setting to default of 'Lp2'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp2' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp2' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:17: at_reboot: '/var/www/html/openWB/ramdisk/lp2sofortll' missing: Setting from MQTT topic 'lp2sofortll' to value '10'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp2' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp2' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/lp2enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/lp2phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:16: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp2' missing: Setting from MQTT topic 'pluggedladungaktlp2' to value '0'
2024-04-29 17:28:15: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp2startkwh' missing: Setting from MQTT topic 'pluggedladunglp2startkwh' to value '0'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttautolockstatuslp1' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttdisplaylp1max' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttlp1name' missing: no MQTT topic set: Setting to default of 'Lp1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttmsmoduslp1' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttzielladenaktivlp1' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/mqttstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '-1'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:14: at_reboot: '/var/www/html/openWB/ramdisk/lp1sofortll' missing: Setting from MQTT topic 'lp1sofortll' to value '6'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/autolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/autolockstatuslp1' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/restzeitlp1' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/lp1enabled' missing: no MQTT topic set: Setting to default of '1'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/lp1phasen' missing: no MQTT topic set: Setting to default of '0'
2024-04-29 17:28:13: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladungaktlp1' missing: Setting from MQTT topic 'pluggedladungaktlp1' to value '0'
2024-04-29 17:28:12: at_reboot: '/var/www/html/openWB/ramdisk/pluggedladunglp1startkwh' missing: Setting from MQTT topic 'pluggedladunglp1startkwh' to value '4542.944'
2024-04-29 17:28:11: PID: 1875: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:10: at_reboot: Initializing Ramdisk /var/www/html/openWB/ramdisk
2024-04-29 17:28:10: at_reboot: Config file Update done.
2024-04-29 17:28:01: PID: 897: Ramdisk not set up. Maybe we are still booting. (LV0) at 50 main /var/www/html/openWB/regel.sh
2024-04-29 17:28:01: at_reboot: Updating /var/www/html/openWB/openwb.conf...
2024-04-29 17:27:56: at_reboot: openwbRemoteSupport.service already up to date
2024-04-29 17:27:56: at_reboot: checking openwb remote support service
2024-04-29 17:27:56: at_reboot: already up to date
2024-04-29 17:27:56: at_reboot: checking init in /boot/config.txt...
2024-04-29 17:27:55: at_reboot: loading config
2024-04-29 17:27:55: at_reboot: atreboot.sh started
helperFunctions.sh: Zeile 62: 4441 Beendet timeout 10 "modules/$ladeleistungmodul/main.sh"
ConnectionRefusedError: [Errno 111] Connection refused
sock.connect(sa)
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 3522, in _create_socket_connection
sock = self._create_socket_connection()
File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 1071, in reconnect
return self.reconnect()
File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 937, in connect
client.connect(hostname, port, keepalive)
File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/publish.py", line 163, in multiple
protocol, transport, proxy_args)
File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/publish.py", line 228, in single
publish.single(topic, json.dumps(payload), hostname=hostname, retain=True)
File "/var/www/html/openWB/packages/helpermodules/pub.py", line 60, in pub_single
2024-04-29 17:27:53: PID: 2721: helpermodules.pub: Fehler im pub-Modul
sock.connect(sa)
raise err
