SOC BMW
Extrahirn
Has thanked: 3 times
Been thanked: 7 times
Re: SOC BMW
Beitrag von Extrahirn »
Seit heute Mittag funktioniert die SOC Abfrage nicht mehr. :(
Fehlermeldung : missing captcha.
Ich hatte keinen Neustart gemacht.Die installierte Version ist die Master 2.1.7 alpha
Nachdem ich den Fehler festgestellt habe, habe ich
Einen Neustart gemacht und ein neues captcha erzeugt
Und kopiert, aber das war erfolglos.
Hier der trace:
File "/usr/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
return future.result()
File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/api.py", line 112, in _fetch_soc
await account.get_vehicles()
File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/account.py", line 114, in get_vehicles
await self._init_vehicles()
File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/account.py", line 86, in _init_vehicles
vehicle_list_response = await client.post(
File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1892, in post
return await self.request(
File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1574, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1661, in send
response = await self._send_handling_auth(
File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1707, in _send_handling_auth
raise exc
File "/home/openwb/.local/lib/python3.9/site-packages/httpx/_client.py", line 1696, in _send_handling_auth
next_request = await auth_flow.asend(response)
File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 118, in async_auth_flow
await self.login()
File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 137, in login
token_data = await self._login_row_na()
File "/home/openwb/.local/lib/python3.9/site-packages/bimmer_connected/api/authentication.py", line 159, in _login_row_na
raise MyBMWCaptchaMissingError(
bimmer_connected.models.MyBMWCaptchaMissingError: Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io ... ptcha.html
OpenWB standard Series 2+ | MINI SE
Extrahirn
Re: SOC BMW
Hier der Anfang vom trace… 8-)
2024-12-15 14:41:07,811 - {bimmer_connected.api.authentication:86} - {ERROR:fetch soc_ev0} - MyBMWAuthError due to HTTPStatusError: invalid_request - The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed
2024-12-15 14:41:07,877 - {modules.vehicles.bmwbc.api:143} - {ERROR:fetch soc_ev0} - bmwbc.fetch_soc: requestData Error, vnum: 0 err=MyBMWCaptchaMissingError('Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io ... ptcha.html'), type(err)=<class 'bimmer_connected.models.MyBMWCaptchaMissingError'>
2024-12-15 14:41:07,879 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev0} - BMW (Bimmer): FaultState FaultStateLevel.ERROR, FaultStr <class 'bimmer_connected.models.MyBMWCaptchaMissingError'> ('Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io ... ptcha.html',), Traceback:
File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 66, in update
File "/var/www/html/openWB/packages/modules/common/configurable_vehicle.py", line 110, in _get_carstate_by_source
File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/soc.py", line 20, in updater
return api.fetch_soc(
File "/var/www/html/openWB/packages/modules/vehicles/bmwbc/api.py", line 156, in fetch_soc
soc, range = loop.run_until_complete(_fetch_soc(user_id, password, vin, captcha_token, vnum))
rleidner
Has thanked: 103 times
Been thanked: 202 times
Re: SOC BMW
Beitrag von rleidner »
Extrahirn hat geschrieben: So Dez 15, 2024 1:55 pm Hi,
Log-Auszüge bitte in einen code block (button (</>) ) posten, ist übersichtlicher und viel einfacher zu lesen.
Das Captcha-Verfahren sollte eigentlich nur einmal nötig sein.
Danach merkt sich das SOC-Modul die Token in einer Datei auf der SD-Karte, d.h. auch einen Neustart sollte das überleben.
Ich hoffe mal dass Deine SD-Karte noch richtig funktioniert.
Die Fehlermeldung sagt dass der Login mit einem leeren Captcha-Token versucht wird.
2 Fragen:
1) Wenn Du in die Fahrzeug-SoC-Modul-Einstellung schaust: wird das vorher erzeugte, eingefügte und gespeicherte Captcha-Token angezeigt?
2) Falls Du MQTT-Explorer zur Verfügung hast und damit umgehen kannst:
Die Login - Information des SoC-Adapters wird in mosquitto gespeichert; mit dem mosquitto der openwb verbinden und unter topic
openWB/vehicle/fahrzeug-nummer/soc_module/config
nachsehen, ob die in den Einstellungen eingegebene Information dort steht; fahrzeug-nummer entsprechend ersetzen.
Das sollte ungefähr so aussehen:
  "name": "BMW-bimmer_connected",
  "type": "bmwbc",
  "configuration": {
    "user_id": "xxxx@yyyy.zz",
    "password": "xxxxxxxxxxxxxxxxxx",
    "vin": "Wxxxxxxxxxxxxxxx",
    "calculate_soc": true,
    "captcha_token": "P1_eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.hadwYXNza2V5xQP0w9FLY29MyWz80uiuEklZiy-5o34S_d0MgFviArFumeXqJqlSqX6vPo_8DoEhKIbN6fbPC01K8NTmFu5hhLxqLencdr57pTfomTVwT8SV-855c9aJxs860U4WoC4wMQ5_HE5RzudRXrAe9RfBA942sXf2K1Iq_sN6UPbMpHc25_ST9NQvVgLckqeOt-yhFtVyLHw_2GUWstnDWG6r8BxVs6diRj-yKzljLqRVKTup-eEx5PbxEizI9tgwvRN-B5b36cA7ZMwTQTtzgc9xCjaQGuUHBOhhki5omQHAsblJWDBnW25BCTq_35cZFXUFwI7Bw8hQsTtlGZrfAhRXcAyfDECBlIqwoBjYxfslf9v82pMk3Mu24JoRkC7Yl3F2gxK1b-kb6-ih6W0Au47QKOX51YmOC8VTuTbQjaE26Ejyh58Y_FVPGS9VALQlhxzrJ3uWKNK9SDaPOd8a1XJEcY1yq5RXY-SR7ZvnJnYOFlBvdQLUXQm3WP_Y5O-3VmmPILgs_xVaASglHUtoJBgOVnbYxFFqeWofAdOH3xEy-jdv9PZ1X0-ItADcy4nRdpz4eZJF89LnSH6RoyQdJD1sxW7qJrI9wsdBhe9hW4saVpDktAZpl2hgQSLw-4AAigg5Lu_vrjKNXthLSJYDPelFmpJ_i6sz4QNbaumGzHDr5ocoe-xa_QkC-iEo9NUbs3sGDu4RM0N84b7Guqfbw3h3wpIujYuyWcd3thnsXflRnrmZBUYQ0IfeppGft9vlAnOhtuO1zJo8bQNTPWOhc_hrkkU0gajkak_PTexqJXKmza1yL0742oSUQaQkZwBQ7M7lU8NFpUyDSlTNY5wxX1NQgyalpbeDe74Op10hJfERipdhH1e9o12nSzSLWsIr237evACCnCaN0_HkrARCQgYohZ9H7_AVZuRx1HAx-WtRYZZWheOYxFuxCZWlZQrEJ4VFntjxcrWkrMXnq_uuXHBda9i65ccawqO_MX7V5aq_uAHDDqAHxorWgCTxXj2xpdx4bMLyDH95ApG8Y05nDMS2ffsiW_85la1KdFsafALPbNeE_VKg2tn1MzthK2Z7-zkihZOgP5M1w4WHWrZAbcNtVSkNPO2W5HILvSqPDGjR2Vz8ANesYV7NnoEV5wOY8SVlO-ZbD1s9q0OUnCnFzIWUO-uCfhDsRv01gfjbZLBSJ45pwn7nJsLsMmOkTmO6nQRY-Zil15wd9KolzYF6P12SDlyru8oEC6FAgBuy4Nt9bL_cIqb9zXk-FuVKuHBoPs2LiHMCDzbj_r7LrXemUIWwP5qfFyAnu5yM0GgKHBKAi5rKlZ0pXh64hn_T2yPNYNDQrk-UqMrtHqNleHDOZ1weq6hzaGFyZF9pZM4UPIQfomtypzg0OGY2MjaicGQA.16Rqmz0b_EVCPXdvMYiuYFT0jGd5DDQbMKa11iCzPTo"
Wie sieht das bei Dir aus?
openWB-2 Standard+ | openWB EVU Kit v2 MID| 9,9kWp mit Kostal Plenticore 8.5 plus | Zendure Solarflow 2400 AC+ 8,2kWh | VW ID.3, Kia EV6, Smart EQ forfour
Extrahirn
Re: SOC BMW
Ok, den Button kannte ich bisher nicht.
Die SD Karte ist ca. 6 Monate alt. Die habe ich bei OpenWB für die Umstellung auf die Version 2 gekauft.
Zur Frage 1: ja. ich hatte dann einen Neustart durchgeführt, das „alte“ captcha gelöscht und
Ein Neues eingefügt und dann die SOC Abfrage ausgeführt.
Zur Frage 2: nein, da kenne ich mich nicht aus.
Die einzigen Änderungen, die ich gemacht habe, waren im Bereich der Ladeprofile,
Um von Energie wieder auf SOC umzustellen.
rleidner
Re: SOC BMW
Extrahirn hat geschrieben: So Dez 15, 2024 7:42 pm Die SD Karte ist ca. 6 Monate alt. Die habe ich bei OpenWB für die Umstellung auf die Version 2 gekauft.
Das beantwortet die Frage 1 leider nicht:
1) Wenn Du (nochmal) in die Fahrzeug-SoC-Modul-Einstellung schaust (ohne etwas zu ändern): wird das vorher erzeugte, eingefügte und gespeicherte Captcha-Token angezeigt?
Extrahirn
Re: SOC BMW
Ja, ich habe soeben nochmal einen Neustart gemacht und der Token ist noch da.
Das Abfrageintervall ist auf 60 min eingestellt.
rleidner
Re: SOC BMW
OK, es scheint also das Captcha-Token vorhanden zu sein, kommt aber im Modul nicht an.
Dann benötige ich mehr Information - bitte Folgendes machen:
1) In Einstellungen - System - Fehlersucher auf Details umstellen und speichern:
2) Im Hauptbildschirm den SoC für das Fahrzeug abrufen (Kreispfeil).
Standard Theme:
oder im Colors Theme:
3) den SoC-Log dieses Abrufs komplett hier als code block (</>) posten - Passwort bzw. VIN bitte vorher unkenntlich machen.
Danach den Debug Level wieder auf Warnungen und Fehler oder Info umstellen und speichern.
Extrahirn
Re: SOC BMW
2024-12-15 22:45:37,066 - {modules.common.configurable_vehicle:56} - {DEBUG:fetch soc_ev0} - Vehicle Instance <class 'modules.vehicles.bmwbc.config.BMWbc'>
2024-12-15 22:45:37,069 - {modules.common.configurable_vehicle:57} - {DEBUG:fetch soc_ev0} - Calculated SoC-State CalculatedSocState(imported_start=5247404.79, manual_soc=None, soc_start=50)
2024-12-15 22:45:37,072 - {modules.common.configurable_vehicle:58} - {DEBUG:fetch soc_ev0} - Vehicle Update Data VehicleUpdateData(plug_state=False, charge_state=False, imported=None, battery_capacity=30000, efficiency=96, soc_from_cp=None, timestamp_soc_from_cp=None)
2024-12-15 22:45:37,076 - {modules.common.configurable_vehicle:59} - {DEBUG:fetch soc_ev0} - General Config GeneralVehicleConfig(use_soc_from_cp=False, request_interval_charging=300, request_interval_not_charging=3600, request_only_plugged=False)
2024-12-15 22:45:37,078 - {modules.common.component_context:26} - {DEBUG:fetch soc_ev0} - Update Komponente ['BMW (Bimmer)']
2024-12-15 22:45:37,081 - {asyncio:59} - {DEBUG:fetch soc_ev0} - Using selector: EpollSelector
2024-12-15 22:45:37,088 - {modules.vehicles.bmwbc.api:77} - {DEBUG:fetch soc_ev0} - dataPath=/var/www/html/openWB/data/modules/bmwbc
2024-12-15 22:45:37,098 - {bimmer_connected.account:111} - {DEBUG:fetch soc_ev0} - Getting vehicle list
2024-12-15 22:45:37,100 - {bimmer_connected.account:79} - {DEBUG:fetch soc_ev0} - Getting vehicle list
2024-12-15 22:45:37,226 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.started host='cocoapi.bmwgroup.com' port=443 local_address=None timeout=30.0 socket_options=None
2024-12-15 22:45:37,273 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x756db1d8>
2024-12-15 22:45:37,274 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.started ssl_context=<ssl.SSLContext object at 0x75674c40> server_hostname='cocoapi.bmwgroup.com' timeout=30.0
2024-12-15 22:45:37,328 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x756e2d00>
2024-12-15 22:45:37,329 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.started request=<Request [b'POST']>
2024-12-15 22:45:37,332 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.complete
2024-12-15 22:45:37,333 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.started request=<Request [b'POST']>
2024-12-15 22:45:37,333 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.complete
2024-12-15 22:45:37,334 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.started request=<Request [b'POST']>
2024-12-15 22:45:37,390 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.complete return_value=(b'HTTP/1.1', 401, b'Unauthorized', [(b'Date', b'Sun, 15 Dec 2024 21:45:37 GMT'), (b'Content-Length', b'0'), (b'Connection', b'keep-alive'), (b'Request-Context', b'appId=cid-v1:24f34ad2-7e62-4399-93db-3071c599c619'), (b'set-cookie', b'ASLBSA=00030ba4bee0ac881fe811bc41e69bd98c56b9cd9a538acfae5da96e9319d4ddde6e; Path=/; Secure; HttpOnly;'), (b'set-cookie', b'ASLBSACORS=00030ba4bee0ac881fe811bc41e69bd98c56b9cd9a538acfae5da96e9319d4ddde6e; SameSite=none; Path=/; Secure; HttpOnly;'), (b'x-azure-ref', b'20241215T214537Z-17964fc66b77krzqhC1DUShdyn0000000en0000000006tca'), (b'X-Cache', b'CONFIG_NOCACHE')])
2024-12-15 22:45:37,395 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.started request=<Request [b'POST']>
2024-12-15 22:45:37,396 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.complete
2024-12-15 22:45:37,396 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.started
2024-12-15 22:45:37,397 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.complete
2024-12-15 22:45:37,398 - {bimmer_connected.api.authentication:117} - {DEBUG:fetch soc_ev0} - Received unauthorized response, refreshing token.
2024-12-15 22:45:37,443 - {bimmer_connected.api.authentication:257} - {DEBUG:fetch soc_ev0} - Authenticating with refresh token for North America & Rest of World.
2024-12-15 22:45:37,446 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.started host='cocoapi.bmwgroup.com' port=443 local_address=None timeout=30.0 socket_options=None
2024-12-15 22:45:37,483 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x75664fe8>
2024-12-15 22:45:37,483 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.started ssl_context=<ssl.SSLContext object at 0x756a2cd0> server_hostname='cocoapi.bmwgroup.com' timeout=30.0
2024-12-15 22:45:37,803 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x756674c0>
2024-12-15 22:45:37,805 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.started request=<Request [b'GET']>
2024-12-15 22:45:37,807 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.complete
2024-12-15 22:45:37,807 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.started request=<Request [b'GET']>
2024-12-15 22:45:37,808 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.complete
2024-12-15 22:45:37,808 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.started request=<Request [b'GET']>
2024-12-15 22:45:37,844 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.complete return_value=(b'HTTP/1.1', 200, b'OK', [(b'Date', b'Sun, 15 Dec 2024 21:45:37 GMT'), (b'Content-Type', b'application/json; charset=utf-8'), (b'Content-Length', b'580'), (b'Connection', b'keep-alive'), (b'x-correlation-id', b'1b8182cf-7033-48cb-9514-04b6b1cf982c'), (b'bmw-correlation-id', b'1b8182cf-7033-48cb-9514-04b6b1cf982c'), (b'x-cluster-mock-used', b'false'), (b'Strict-Transport-Security', b'max-age=31536000; includeSubDomains'), (b'X-Content-Type-Options', b'nosniff'), (b'Content-Security-Policy', b"default-src 'self'"), (b'Request-Context', b'appId=cid-v1:24f34ad2-7e62-4399-93db-3071c599c619'), (b'x-azure-ref', b'20241215T214537Z-16fcb4bb965ww6wmhC1FRA856c00000009n0000000007uw5'), (b'X-Cache', b'CONFIG_NOCACHE'), (b'Accept-Ranges', b'bytes')])
2024-12-15 22:45:37,846 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.started request=<Request [b'GET']>
2024-12-15 22:45:37,847 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.complete
2024-12-15 22:45:37,848 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.started
2024-12-15 22:45:37,848 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.complete
2024-12-15 22:45:37,852 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.started host='customer.bmwgroup.com' port=443 local_address=None timeout=30.0 socket_options=None
2024-12-15 22:45:37,892 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - connect_tcp.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x7566d418>
2024-12-15 22:45:37,893 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.started ssl_context=<ssl.SSLContext object at 0x756a2cd0> server_hostname='customer.bmwgroup.com' timeout=30.0
2024-12-15 22:45:37,923 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - start_tls.complete return_value=<httpcore._backends.anyio.AnyIOStream object at 0x7566df88>
2024-12-15 22:45:37,926 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.started request=<Request [b'POST']>
2024-12-15 22:45:37,928 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_headers.complete
2024-12-15 22:45:37,929 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.started request=<Request [b'POST']>
2024-12-15 22:45:37,931 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - send_request_body.complete
2024-12-15 22:45:37,932 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.started request=<Request [b'POST']>
2024-12-15 22:45:37,972 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_headers.complete return_value=(b'HTTP/1.1', 400, b'Bad Request', [(b'date', b'Sun, 15 Dec 2024 21:45:37 GMT'), (b'content-type', b'application/json'), (b'Content-Length', b'304'), (b'x-frame-options', b'SAMEORIGIN'), (b'x-content-type-options', b'nosniff'), (b'cache-control', b'no-store'), (b'pragma', b'no-cache'), (b'strict-transport-security', b'max-age=31536000; includeSubDomains'), (b'access-control-allow-headers', b'Authorization, Origin, X-c2b-Authorization, X-c2b-mTAN, X-Requested-With, X-c2b-Sender-Id, X-c2b-External-Id, Content-Type, Accept, Cache-Control, KeyId, x-dtc, deviceName, loginId, clientId, X-C2b-Api-Key, hcaptchatoken'), (b'access-control-max-age', b'3628800'), (b'access-control-allow-credentials', b'true'), (b'access-control-allow-methods', b'POST, GET, OPTIONS, PUT, DELETE, HEAD'), (b'referrer-policy', b'same-origin'), (b'x-xss-protection', b'0'), (b'x-c2b-request-id', b'f23c3766-427d-4556-86bd-39e40a732d9940262798'), (b'x-request-id', b'05a0ed64-1b62-4f3b-9534-28a430b78c65'), (b'via', b'1.1 google'), (b'Alt-Svc', b'h3=":443"; ma=2592000,h3-29=":443"; ma=2592000')])
2024-12-15 22:45:37,976 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.started request=<Request [b'POST']>
2024-12-15 22:45:37,977 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - receive_response_body.complete
2024-12-15 22:45:37,978 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.started
2024-12-15 22:45:37,980 - {httpcore.http11:85} - {DEBUG:fetch soc_ev0} - response_closed.complete
2024-12-15 22:45:37,983 - {bimmer_connected.api.authentication:86} - {ERROR:fetch soc_ev0} - MyBMWAuthError due to HTTPStatusError: invalid_request - The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed
2024-12-15 22:45:37,985 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.started
2024-12-15 22:45:37,986 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.complete
2024-12-15 22:45:37,987 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.started
2024-12-15 22:45:37,988 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.complete
2024-12-15 22:45:37,989 - {bimmer_connected.api.authentication:288} - {DEBUG:fetch soc_ev0} - Unable to get access token using refresh token, falling back to username/password.
2024-12-15 22:45:38,049 - {bimmer_connected.api.authentication:156} - {DEBUG:fetch soc_ev0} - Authenticating with MyBMW flow for North America & Rest of World.
2024-12-15 22:45:38,051 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.started
2024-12-15 22:45:38,054 - {httpcore.connection:85} - {DEBUG:fetch soc_ev0} - close.complete
2024-12-15 22:45:38,055 - {modules.vehicles.bmwbc.api:143} - {ERROR:fetch soc_ev0} - bmwbc.fetch_soc: requestData Error, vnum: 0 err=MyBMWCaptchaMissingError('Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io/en/stable/captcha.html'), type(err)=<class 'bimmer_connected.models.MyBMWCaptchaMissingError'>
2024-12-15 22:45:38,129 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev0} - BMW (Bimmer): FaultState FaultStateLevel.ERROR, FaultStr <class 'bimmer_connected.models.MyBMWCaptchaMissingError'> ('Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io/en/stable/captcha.html',), Traceback:
    raise exc
    await self.login()
bimmer_connected.models.MyBMWCaptchaMissingError: Missing hCaptcha token for login. See https://bimmer-connected.readthedocs.io/en/stable/captcha.html
ich kann weder Passwort noch VIN im Trace finden.
rleidner
Re: SOC BMW
Extrahirn hat geschrieben: So Dez 15, 2024 10:13 pm ich kann weder Passwort noch VIN im Trace finden.
OK, die Datei mit access- und refresh-token ist vorhanden, das Captcha-Verfahren wird nicht benutzt und es passiert Folgendes:
Es wird versucht unter Nutzung der vorhandenen access- und refresh-token:
- die Liste der Fahrzeuge des Accounts abzurufen,
- dabei kommt ein authentication Fehler zurück - das ist OK
- darauf wird ein token refresh versucht, das ohne captcha-token funktioniert.
EDIT - jetzt erst gesehen:
- der refresh_token geht schief mit Meldung:
"Unable to get access token using refresh token, falling back to username/password."
In dieser Situation ist normalerweise kein gültiger captcha-token vorhanden.
Ich habe dieses Verhalten noch nicht gesehen und kann es auch nicht reproduzieren.
Möglicherweise hängt es mit Deinem BMW/Mini-Account zusammen.
Du könntest Dich in Deinem BMW/Mini-Account per Browser einloggen und prüfen
- ob der Account noch gültig ist und
- ob evtl. neue Geschäftsbedingungen zu akzeptieren sind.
Die BMW/Mini-App funktioniert möglicherweise trotzdem!
Ich werde in die nächste Version des SOC-Moduls einbauen, dass bei Vorliegen eines neuen captcha-token in der Konfiguration die gespeicherten refresh- und access-token verworfen werden und damit eine komplette Neuanmeldung mit captcha-token erzwungen werden kann.
Zuletzt geändert von rleidner am Mo Dez 16, 2024 9:27 am, insgesamt 1-mal geändert.
Has thanked: 252 times
Been thanked: 273 times
Re: SOC BMW
Genau - bei so etwas zuerst direkt auf "Connected Drive" gehen und eine saubere Anmeldung sicherstellen (An-,Ab-,Anmelden).
Ich hatte das im Laufe der Jahre ein paar Mal, dass es schon dort nicht funktionierte. Erst kürzlich wieder, wo auf CD ständig ein Systemfehler gemeldet wurde, obwohl die credentials korrekt waren.
Die BMW-Hotline ist da recht schnell (Problembehebung dauerte max. 2 Tage).
