Mercedes SoC
Has thanked: 12 times
Been thanked: 52 times
Re: Mercedes SoC
2021-01-14 10:31:22: Lp1: SOC: 100 RANGE: 47
2021-01-14 11:30:56: Lp1: Acc Token Expired
2021-01-14 11:31:51: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 11:31:51: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 12:32:01: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 12:32:01: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 13:31:15: Lp1: Acc Token Expired
2021-01-14 13:32:11: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 13:32:11: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 14:32:21: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 14:32:21: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 15:31:36: Lp1: Acc Token Expired
2021-01-14 15:32:32: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 15:32:32: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 16:32:41: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 16:32:41: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 17:31:56: Lp1: Acc Token Expired
2021-01-14 17:32:51: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 17:32:51: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
2021-01-14 18:18:21: Lp1: SoC Request fehlgeschlagen unbekannter Code: 504
2021-01-14 18:18:21: Lp1: {"fault":{"faultstring":"Gateway Timeout","detail":{"errorcode":"messaging.adaptors.http.flow.GatewayTimeout"}}}
Laut meiner openWB auf dem Raspi seit ca.11:30 Uhr.
Re: Mercedes SoC
2021-01-14 23:21:40: Lp1: SOC: 86 RANGE: 38
2021-01-15 00:21:16: Lp1: Acc Token Expired
2021-01-15 00:21:20: Lp1: SOC: 86 RANGE: 38
2021-01-15 01:21:34: Lp1: SOC: 86 RANGE: 38
Die Server sind wieder erreichbar.
Crazyrider
Re: Mercedes SoC
Beitrag von Crazyrider »
Erstmal: Herzlichen Dank für das Modul. Ich hab einen Smart EQ2020 und GLC300e.
Für den Smart habe ich verstanden wird dies mit dem Modul nicht gehen, der Abfrage Service ist aktiviert, Auto auch die MB ID zugeordnet bekomme da die Meldung, sollte aber so sein und eh nicht klappen korrekt?
2021-01-16 15:19:08: Lp1: {"exVeErrorId":"2","exVeErrorMsg":"The Extended Vehicle Service for this vehicle is not activated.","exVeErrorRef":"8790fb81-1d33-4bdb-829c-be51e06bab24"} 2021-01-16 15:19:08: Lp1: SoC Request fehlgeschlagen Code: 403 (Forbidden)
Für den GLC bekomme ich die Meldung:
2021-01-16 15:25:53: Lp2: 2021-01-16 15:25:53: Lp2: SoC Request Code: 204 (no data is available for the resource)
Würde das interpretieren als: Mit der Verbindung klappt eigentlich alles (Errors sind alle Weg) aber lieber User ich habe keine Daten für Dich? Woran könnte das liegen? Update auch ohne Laden aktiv - Dienste sind aktiviert, VIN ist korrekt, den Link hab ich geklickt. :-))
LG Ingo
Crazyrider
Re: Mercedes SoC
Ok kurze Ergänzung: Der GLC war seit 4h geparkt und aus als ich den Post oben gemacht habe. Habe Ihn grad mal kurz gestartet und wieder ausgemacht und prompt:
2021-01-16 15:40:33: Lp2: SOC: 33 RANGE: 11
Frage: gibt es eine „einschlafzeit“ nach der das Auto den Wert nicht mehr übermittelt an die Schnittstelle?
Re: Mercedes SoC
Hallo Ingo,
Für den Smart geht es nicht, scheint als ob sich Mercedes nicht zu Smart bekennt ;) und denen daher den Zugriff auf die API verweigert.
Das mit Status 204 ist in meinem GLA soweit ich sehen kann noch nicht vorgekommen, allerdings beobachte ich das auch nicht dauernd und das SoC Log wird regelmäßig gekürzt.
Ich hab den Verdacht oder die Vermutung, dass wenn das Fahrzeug regelmäßig abgefragt wird, dass es dann auch nicht vorkommt. Aber genau sagen kann ich dir das leider auch nicht. Es kann genauso daran liegen, dass die Steuergeräte in einem GLA anders laufen als in einem GLC, der vom Grundmodell schon älter ist.
Crazyrider
Re: Mercedes SoC
Hi Det, alles klar danke dir für die Info - jetzt grade kommt der Fehler auch nicht mehr, ich verfolg das mal ein bisschen. Zum Thema Smart: ich stehe grade ohnehin mit den Entwicklern der Smart eq App im Kontakt (auf kurzem Dienstweg) und werd da mal nachfragen ob man da was tun kann bzgl API. LG Ingo
aling
Re: Mercedes SoC
Beitrag von aling »
Der 204 kommt nach der Beschreibung wenn das Auto länger als 12h keine Daten übermittelt hat. Ich hatte den auch schon mal aber das mit den 12h stimmt wohl nicht. In den letzten 2 Wochen habe ich den 204 gar nicht gesehen obwohl mein EQC zwischendurch 4 Tage in der Tiefgarage (kein Mobilfunk) gestanden hat.
Sieht also mit dem 204 mehr so aus: kann vorkommen, muss aber nicht.
Das Auto wird übrigens durch die Abfrage des SoC nicht kontaktiert oder geweckt, das passiert nur wenn aktiv Daten ans Auto geschickt werden (Vorklima, Temperatur, max Ladestand umstellen oder so etwas)
Gruss Achim
Ihaglc
Has thanked: 37 times
Been thanked: 23 times
Re: Mercedes SoC
Beitrag von Ihaglc »
Hallo Zusammen!
Habe gerade versucht, mich für die Abfrage des Mercdes SOC vorzubereiten.
Scheitert leider schon bei der Anmeldung bei MercedesDeveloper Seite mit dem ME-Account.
Rückmeldung:Seite noch mal Aufrufen oder an den Support wenden"
Gibt es zur Zeit Probleme auf der Mercedes Developer Seite?
Anzeige über die Mercedes App klappt aber.
Danke Euch
Thomas
PV Modul JaSolar
WR Solaredge SE7K Hybrid
Speicher LG Resu13
EV Ford Mustang Mach E
Re: Mercedes SoC
Ich konnte mich gerade anmelden. Also einfach noch mal probieren.
Ihaglc
Re: Mercedes SoC
Danke Det ,
komisch, ich erhalte folgende Rückmeldung:
"Sorry something went wrong
When loading User Information, there was a technical error.
Please reload this page or contact our support"
werde mal schauen, wie gut dere Mercedes Support ist
Thomas
PV Modul JaSolar
Speicher LG Resu13
