Anbindung FritzBox (FritzDect)
cpm
Re: Anbindung FritzBox (FritzDect)
Beitrag von cpm »
Ja, das glaube ich mittlerweile auch. Allerdings liegt es nicht am Passwort. Ich habe eben mal die zweite Fritz-Dect parametriert. Steht ja alles sauber im Log:
2021-01-17 19:22:44 Topic: openWB/config/set/SmartHome/Device2/device_manual_control Message: 1
2021-01-17 19:22:21 Topic: openWB/set/system/topicSender Message: local client uid: aijrn sent: openWB/config/set/SmartHome/Device2/device_manual_control
2021-01-17 19:22:21 Topic: openWB/config/set/SmartHome/Device2/device_manual_control Message: 0
2021-01-17 19:22:18 Topic: openWB/set/system/topicSender Message: local client uid: aijrn sent: openWB/config/set/SmartHome/Devices/2/mode
2021-01-17 19:22:18 Topic: openWB/config/set/SmartHome/Devices/2/mode Message: 1
2021-01-17 19:22:11 Topic: openWB/config/set/SmartHome/Devices/2/device_differentMeasurement Message: 0
2021-01-17 19:22:11 Topic: openWB/config/set/SmartHome/Devices/2/device_ausschaltverzoegerung Message: 0
2021-01-17 19:22:10 Topic: openWB/config/set/SmartHome/Devices/2/device_ausschaltschwelle Message: 1500
2021-01-17 19:22:10 Topic: openWB/config/set/SmartHome/Devices/2/device_einschaltverzoegerung Message: 0
2021-01-17 19:22:10 Topic: openWB/config/set/SmartHome/Devices/2/device_einschaltschwelle Message: 0
2021-01-17 19:22:10 Topic: openWB/config/set/SmartHome/Devices/2/device_deactivateWhileEvCharging Message: 0
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_maxeinschaltdauer Message: 1440
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_mineinschaltdauer Message: 0
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_canSwitch Message: 1
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_actor Message: F200-Medien
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_password Message: openwb20
2021-01-17 19:22:09 Topic: openWB/config/set/SmartHome/Devices/2/device_username Message: fbox
2021-01-17 19:22:08 Topic: openWB/config/set/SmartHome/Devices/2/device_ip Message: 192.168.2.1
2021-01-17 19:22:08 Topic: openWB/config/set/SmartHome/Devices/2/device_type Message: avm
2021-01-17 19:22:08 Topic: openWB/config/set/SmartHome/Devices/2/device_name Message: Office
2021-01-17 19:22:08 Topic: openWB/config/set/SmartHome/Devices/2/device_configured Message: 1
Schaltet nicht. Im Log sieht man ja das Passwort (Ist wieder geändert ;-) )
2021-01-17 19:23:57: Main routine Device: 2 Office'2relais'
2021-01-17 19:23:57: Main routine Device: 1 Ladedose'1relais'
2021-01-17 19:23:57: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-17 19:23:57: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-17 19:23:55: Device avm1Ladedose Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret1'
2021-01-17 19:23:54: Wattbezug: -541 Uberschuss: -541 Speicherleistung: 0 SpeicherSoC: 100
Weiterhin ratlos ....
Zuletzt geändert von cpm am Mo Jan 18, 2021 5:04 pm, insgesamt 1-mal geändert.
14,96 kWp PV / openWB / ID.3 GTX Performance / MG 4 Lux / 🌞
fawick
Been thanked: 3 times
Beitrag von fawick »
Ich habe das Logging des Modules aufgebohrt, so dass seine saemtliche Log-Meldungen ueber die Status-Page (Smarthome Log) erreichbar sein sollten. PR ist https://github.com/snaptec/openWB/pull/915. Falls und sobald der angenommen wurde, muesstest Du noch mal Nightly aktualisieren.
Falls es dringender ist: Alternativ koenntest Du die Datei https://raw.githubusercontent.com/fawic ... mcommon.py auch direkt auf deine SD-Karte laden. Das setzt Linuxkenntnisse und Root-Rechte voraus und im schlimmsten Fall machst Du Dir durch einen Fehler die Wallbox unbenutzbar. Der sichere Weg waere warten.
cpm
Beitrag von cpm »
Perfekt, Danke.
Hat keine Eile. Ich warte bis es in der Nightly ist.
cpm
Beitrag von cpm »
Hallo fawick
Ich habe jetzt die Nightly mit dem pull request #915 installiert. Wie soll ich vorgehen um Dir das ideale Log zu generieren ;-) Alles wegparametrieren und von vorne beginnen? Ein Einfacher Klick auf das Gerät (im manuell modus) scheint mir nicht viel mehr zu loggen:
2021-01-20 10:07:07: Main routine Device: 2 Office'2relais'
2021-01-20 10:07:07: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 10:07:07: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 10:07:07 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 10:07:07: Wattbezug: 592 Uberschuss: 592 Speicherleistung: 0 SpeicherSoC: 100
2021-01-20 10:07:02: Main routine Device: 2 Office'2relais'
2021-01-20 10:07:02: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 10:07:02: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 10:07:01 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 10:07:01: Wattbezug: 605 Uberschuss: 605 Speicherleistung: 0 SpeicherSoC: 100
Ich habe hier das zweite Gerät genommen, das ist in meinem HomeOffice Büro, da höre ich es wenigstens schalten.
Danke, CPM
fawick
Dreh mal das Smarthome-Loglevel auf maximale Verbosity. Das duerfte der Wert 0 sein (ganz unten auf der SmartHome 2.0 Einstellungsseite)
cpm
Beitrag von cpm »
Jeweils: Einstellungen -> Loglevel ändern; speichern -> 1 Zyklus auf der Hauptseite abgewartet, Graph zuckt. -> Singleklick Gerät
SmartHome Loglevel: 0
SmartHome Log:
2021-01-20 18:05:22: Main routine Device: 2 Office'2relais'
2021-01-20 18:05:22: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:05:22: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 18:05:22 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 18:05:21: Wattbezug: -724 Uberschuss: -724 Speicherleistung: 0 SpeicherSoC: 100
2021-01-20 18:05:16: Main routine Device: 2 Office'2relais'
2021-01-20 18:05:16: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:05:16: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 18:05:16 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 18:05:15: Wattbezug: -724 Uberschuss: -724 Speicherleistung: 0 SpeicherSoC: 100
2021-01-20 18:05:10: Main routine Device: 2 Office'2relais'
2021-01-20 18:05:10: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:05:10: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 18:05:10 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 18:05:09: Wattbezug: -683 Uberschuss: -683 Speicherleistung: 0 SpeicherSoC: 100
2021-01-20 18:05:04: Main routine Device: 2 Office'2relais'
2021-01-20 18:05:04: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:05:04: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 18:05:04 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 18:05:03: Wattbezug: -728 Uberschuss: -728 Speicherleistung: 0 SpeicherSoC: 100
Mqtt Log:
2021-01-20 18:05:17 Topic: openWB/set/system/topicSender Message: local client uid: dodur sent: openWB/config/set/SmartHome/Device2/device_manual_control
2021-01-20 18:05:17 Topic: openWB/config/set/SmartHome/Device2/device_manual_control Message: 0
--------------------- 8< ---------------------
SmartHome Loglevel 1:
SmartHome Log:
2021-01-20 18:07:34: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:34: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:07:29: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:29: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:07:23: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:23: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:07:17: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:17: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:07:10: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:10: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:07:10: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:07:09: Wattbezug: -721 Uberschuss: -721 Speicherleistung: 0 SpeicherSoC: 100
2021-01-20 18:07:04: Main routine Device: 2 Office'2relais'
2021-01-20 18:07:04: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 18:07:04: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 18:07:04 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20 18:07:03: Wattbezug: -734 Uberschuss: -734 Speicherleistung: 0 SpeicherSoC: 100
Mqtt Log:
2021-01-20 18:07:27 Topic: openWB/set/system/topicSender Message: local client uid: bldpn sent: openWB/config/set/SmartHome/Device2/device_manual_control
2021-01-20 18:07:27 Topic: openWB/config/set/SmartHome/Device2/device_manual_control Message: 0
2021-01-20 18:07:10 Topic: openWB/config/set/SmartHome/logLevel Message: 1
SmartHome Loglevel 2:
SmartHome Log:
2021-01-20 18:03:39: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:39: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:33: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:33: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:27: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:27: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:21: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:21: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:15: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:15: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:09: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:09: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20 18:03:03: Main routine Device: 2 Office'2relais'
2021-01-20 18:03:03: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
Mqtt Log:
2021-01-20 18:03:33 Topic: openWB/set/system/topicSender Message: local client uid: tckas sent: openWB/config/set/SmartHome/Device2/device_manual_control
2021-01-20 18:03:33 Topic: openWB/config/set/SmartHome/Device2/device_manual_control Message: 0
2021-01-20 18:03:14 Topic: openWB/config/set/SmartHome/logLevel Message: 2
fawick
Hmm... Ich vermisse bei Dir Meldungen wie diese hier
2021-01-20, 19:20:59 Device 1: AVMHomeAutomation (actor name:Garage) (re-)authenticate at fritzbox
oder
2021-01-20, 19:10:58 Device 1 AVMHomeAutomation (actor name:Garage) setswitchon
2021-01-20, 19:18:33 Device 1: AVMHomeAutomation (actor name:Garage) setswitchoff
Ich muss wohl noch mehr Debugging-Strings hinzufuegen.
PS: Die Reauthentifizierung wird nur alle 5 Minuten angestossen. Schau doch mal bitte, ob sich die erste Meldung nicht doch irgendwo im Log finden laesst.
cpm
Beitrag von cpm »
So, Habe den Loglevel jetzt wieder auf 0 gesetzt. (Ich habe nicht so viel Unterschied zwischen den Leveln gesehen und war daher unsicher, welcher jetzt der mit "maximale Verbosity" ist.)
Ein wenig gewartet und dann gesucht:
2021-01-20 19:44:22: Main routine Device: 2 Office'2relais'
2021-01-20 19:44:22: Total Watt alle abschaltbarer smarthomedevices: 0
2021-01-20 19:44:22: Device avm2Office Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret2'
2021-01-20, 19:44:21 Device 2: AVMHomeAutomation (actor name:F200-Medien) fetch power
2021-01-20, 19:44:21 Device 2: AVMHomeAutomation (actor name:F200-Medien) (re-)authenticate at fritzbox
2021-01-20 19:44:20: Wattbezug: -910 Uberschuss: -910 Speicherleistung: 0 SpeicherSoC: 100
Hilft Dir das weiter?
fawick
Ja der LogLevel muss auf 0 stehen, dann gibt's die meisten Ausgaben.
Ich habe bei mir zwecks Fehlersuche mal ein paar absichtliche Fehlkonfigurationen eingetragen. Wenn ich die IP der Fritzbox bei mir verstelle, dann kriege ich aehnliche Fehlermeldungen wie Du. Das entspricht quasi dem Szenario, wenn Deine OpenWB die Fritzbox im Netzwerk nicht per HTTP erreicht.
2021-01-20 19:50:27: Main routine Device: 1 Garage'1relais'
2021-01-20 19:50:27: Device avm1Garage Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret1'
2021-01-20 19:50:18: Main routine Device: 1 Garage'1relais'
2021-01-20 19:50:18: Device avm1Garage Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret1'
2021-01-20 19:50:09: Main routine Device: 1 Garage'1relais'
2021-01-20 19:50:09: Device avm1Garage Fehlermeldung: [Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/smarthome_device_ret1'
2021-01-20 19:50:06: Config reRead
Kann es sein, dass Du die OpenWB in der Fritzbox in ihrem LAN-Zugriff eingeschraenkt hast (Internet gesperrt, Kindersicherung, Zugangsprofil)?
fawick
Ich habe mehr Logging messages hinzugefuegt und @LutzB hat es schon gemerged. @cpm: Bitte update noch ma Deine Nightly.
