Der Debug ist voll:
Debug Log:
Not deleting randomSleepValue
/var/www/html/openWB/runs/cronnightly.sh: Zeile 95: ramdisk/randomSleepValue: Datei oder Verzeichnis nicht gefunden
Start cron nightly @ Fr 19. Feb 00:01:01 CET 2021
voltage = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 93, in
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
'device reports readiness to read but returned no data '
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 501, in read
result = self.socket.read(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 555, in _recv
return self._recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 88, in recv
result = self.client.recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/framer/rtu_framer.py", line 286, in recvPacket
read_min = self.client.framer.recvPacket(min_size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 241, in _recv
result = self._recv(response_length, full)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 212, in _transact
full=full
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 140, in execute
return self.transaction.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 108, in execute
return self.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 125, in read_input_registers
resp = client.read_input_registers(0x06,2, unit=sdmid)
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 98, in
result = self.client.framer.recvPacket(expected_response_length)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 276, in _recv
full=full
resp = client.read_input_registers(0x00,2, unit=sdmid)
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 92, in
llkwh = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 120, in
full=full
lla2 = float(struct.unpack('>f',struct.pack('>HH',*resp.registers))[0])
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 105, in
full=full
full=full
resp = client.read_input_registers(0x08,2, unit=sdmid)
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 104, in
full=full
full=full
lla3 = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 111, in
full=full
lla1 = float(struct.unpack('>f',struct.pack('>HH',*resp.registers))[0])
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 99, in
full=full
hz = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 151, in
full=full
full=full
full=full
resp = client.read_input_registers(0x0A,2, unit=sdmid)
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 110, in
full=full
full=full
full=full
full=full
full=full
full=full
full=full
llw3 = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 129, in
full=full
full=full
uvmHeute läuft alles (PV1+PV2+Speicher+Home Manager).
Kann man die Meldungen löschen oder löschen die sich selbst nach gewisser Zeit ?
Die Frequenz wird nicht angezeigt: Ist das richtig ?
