Rückmeldungen Nightly ab 1.9.231
Has thanked: 28 times
Been thanked: 202 times
Die Änderungen seit der letzten Beta 1.9.230 findet ihr dort: viewtopic.php?f=3&t=3128
sunnykleineichen
Been thanked: 8 times
Re: Rückmeldungen Nightly ab 1.9.231
Beitrag von sunnykleineichen »
Seit heute morgen habe ich Probleme mit der aktuellen Nightly.
Das Log ist voller Fehlermeldungen:
2021-04-24 08:01:25: Pause nach Umschaltung: 2s (LV0)
    voltage = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
  File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 93, in <module>
    print(rq.registers[0])
  File "runs/readmodbus.py", line 18, in <module>
2021-04-24 08:01:05: boot done :-)
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
fix upload limit...OS Stretch
not activated, skipping
etprovider...
2021-04-24 08:01:01: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
2021-04-24 08:00:59: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
update broker...
load versions...
display update...
clear warning...
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100    41    0     0  100    41      0    226 --:--:-- --:--:-- --:--:--   226
                                 Dload  Upload   Total   Spent    Left  Speed
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
version...
jq installed...
pymodbus installed...
aiohttp installed...
certifi installed...
docopt installed...
mqtt installed...
packages 2...
mosquitto...
cp: '/usr/share/zoneinfo/Europe/Berlin' und '/etc/localtime' sind die gleiche Datei
timezone...
evdev installed...
packages 1...
crontab 2...
...changed
apache...
LAN/WLAN...
crontab 1...
mqtt handler...
smarthome handler...
display...
2021-04-24 08:00:49: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
triginit...
Ramdisk init done.
Trigger update of logfiles...
'mqttwizzarddone' missing: Setting to provided default value '-1'
'mqttwattbezug' missing: Setting to provided default value '-1'
'mqttversion' missing: Setting to provided default value '-1'
'mqttverbraucher2_name' missing: Setting to provided default value 'notset'
'mqttverbraucher2_aktiv' missing: Setting to provided default value '-1'
'mqttverbraucher1_name' missing: Setting to provided default value 'notset'
'mqttverbraucher1_aktiv' missing: Setting to provided default value '-1'
'mqttupdateinprogress' missing: Setting to provided default value '-1'
'mqttu1p3pstandby' missing: Setting to provided default value '-1'
'mqttu1p3psofort' missing: Setting to provided default value '-1'
'mqttu1p3pnurpv' missing: Setting to provided default value '-1'
'mqttu1p3pnl' missing: Setting to provided default value '-1'
'mqttu1p3pminundpv' missing: Setting to provided default value '-1'
'mqttu1p3paktiv' missing: Setting to provided default value '-1'
'mqttstopchargepvpercentagelp2' missing: Setting to provided default value '-1'
'mqttstopchargepvpercentagelp1' missing: Setting to provided default value '-1'
'mqttstopchargepvatpercentlp2' missing: Setting to provided default value '-1'
'mqttstopchargepvatpercentlp1' missing: Setting to provided default value '-1'
'mqttspeicherwattnurpv' missing: Setting to provided default value '-1'
'mqttspeichersocnurpv' missing: Setting to provided default value '-1'
'mqttspeichersocminpv' missing: Setting to provided default value '-1'
'mqttspeichersochystminpv' missing: Setting to provided default value '-1'
'mqttspeicherpvui' missing: Setting to provided default value '-1'
'mqttspeicherpveinbeziehen' missing: Setting to provided default value '-1'
'mqttspeichermaxwatt' missing: Setting to provided default value '-1'
'mqttsofortsocstatlp2' missing: Setting to provided default value '-1'
'mqttsofortsocstatlp1' missing: Setting to provided default value '-1'
'mqttsofortsoclp2' missing: Setting to provided default value '-1'
'mqttsofortsoclp1' missing: Setting to provided default value '-1'
'mqttsocvorhanden' missing: Setting to provided default value '-1'
'mqttsoc' missing: Setting to provided default value '-1'
'mqttsoc1vorhanden' missing: Setting to provided default value '-1'
'mqttrfidakt' missing: Setting to provided default value '-1'
'mqttrestzeitlp3' missing: Setting to provided default value '-1'
'mqttrestzeitlp2' missing: Setting to provided default value '-1'
'mqttrestzeitlp1' missing: Setting to provided default value '-1'
'mqttpvwatt' missing: Setting to provided default value '-1'
'mqttpvbezugeinspeisung' missing: Setting to provided default value '-1'
'mqttpreisjekwh' missing: Setting to provided default value '-1'
'mqttoffsetpv' missing: Setting to provided default value '-1'
'mqttnurpv70dynw' missing: Setting to provided default value '-1'
'mqttnurpv70dynact' missing: Setting to provided default value '-1'
'mqttnlakt_standby' missing: Setting to provided default value '-1'
'mqttnlakt_sofort' missing: Setting to provided default value '-1'
'mqttnlakt_nurpv' missing: Setting to provided default value '-1'
'mqttnlakt_minpv' missing: Setting to provided default value '-1'
'mqttnachtladens1' missing: Setting to provided default value '-1'
'mqttnachtladen' missing: Setting to provided default value '-1'
'mqttminnurpvsoclp1' missing: Setting to provided default value '-1'
'mqttminnurpvsocll' missing: Setting to provided default value '-1'
'mqttminimalstromstaerke' missing: Setting to provided default value '-1'
'mqttminimalapv' missing: Setting to provided default value '-1'
'mqttminimalampv' missing: Setting to provided default value '-1'
'mqttminimalalp2pv' missing: Setting to provided default value '-1'
'mqttmindestuberschuss' missing: Setting to provided default value '-1'
'mqttmaxnurpvsoclp1' missing: Setting to provided default value '-1'
'mqttmaximalstromstaerke' missing: Setting to provided default value '-1'
'mqttlastlademodus' missing: Setting to provided default value '-1'
'mqttlademstats2' missing: Setting to provided default value '-1'
'mqttlademstats1' missing: Setting to provided default value '-1'
'mqttlademstatlp8' missing: Setting to provided default value '-1'
'mqttlademstatlp7' missing: Setting to provided default value '-1'
'mqttlademstatlp6' missing: Setting to provided default value '-1'
'mqttlademstatlp5' missing: Setting to provided default value '-1'
'mqttlademstatlp4' missing: Setting to provided default value '-1'
'mqttlademstat' missing: Setting to provided default value '-1'
'mqttlademkwhlp8' missing: Setting to provided default value '-1'
'mqttlademkwhlp7' missing: Setting to provided default value '-1'
'mqttlademkwhlp6' missing: Setting to provided default value '-1'
'mqttlademkwhlp5' missing: Setting to provided default value '-1'
'mqttlademkwhlp4' missing: Setting to provided default value '-1'
'mqttlademkwh' missing: Setting to provided default value '-1'
'mqtthook3_aktiv' missing: Setting to provided default value '-1'
'mqtthook2_aktiv' missing: Setting to provided default value '-1'
'mqtthook1_aktiv' missing: Setting to provided default value '-1'
'mqttheutegeladen' missing: Setting to provided default value '-1'
'mqtthausverbrauchstat' missing: Setting to provided default value '-1'
'mqtthausverbrauch' missing: Setting to provided default value '-1'
'mqttevuglaettungakt' missing: Setting to provided default value '-1'
'mqttetprovider' missing: Setting to provided default value 'notset'
'mqttetprovideraktiv' missing: Setting to provided default value '-1'
'mqtteinschaltverzoegerung' missing: Setting to provided default value '-1'
'mqttdurchslp1' missing: Setting to provided default value '-1'
'mqttdisplayspeichermax' missing: Setting to provided default value '-1'
'mqttdisplaypvmax' missing: Setting to provided default value '-1'
'mqttdisplayhausmax' missing: Setting to provided default value '-1'
'mqttdisplayhausanzeigen' missing: Setting to provided default value '-1'
'mqttdisplayevumax' missing: Setting to provided default value '-1'
'mqttdatenschutzack' missing: Setting to provided default value '-1'
'mqttdailychargelp3' missing: Setting to provided default value '-1'
'mqttdailychargelp2' missing: Setting to provided default value '-1'
'mqttdailychargelp1' missing: Setting to provided default value '-1'
'mqttaktgeladens2' missing: Setting to provided default value '-1'
'mqttaktgeladens1' missing: Setting to provided default value '-1'
'mqttaktgeladen' missing: Setting to provided default value '-1'
'mqttadaptpv' missing: Setting to provided default value '-1'
'mqttadaptfaktor' missing: Setting to provided default value '-1'
'mqttabschaltverzoegerung' missing: Setting to provided default value '-1'
'mqttabschaltuberschuss' missing: Setting to provided default value '-1'
'mqttRandomSleepValue' missing: Setting to provided default value '-1'
'mqttCp1Configured' missing: Setting to provided default value '-1'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp8max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp8name' missing: no MQTT topic set: Setting to default of 'Lp8'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp8' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp8sofortll' missing: Setting from MQTT topic 'lp8sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp8' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp8enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp8phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp8' missing: Setting from MQTT topic 'pluggedladungaktlp8' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp8startkwh' missing: Setting from MQTT topic 'pluggedladunglp8startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp7max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp7name' missing: no MQTT topic set: Setting to default of 'Lp7'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp7' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp7sofortll' missing: Setting from MQTT topic 'lp7sofortll' to value '10'
2021-04-24 08:00:39: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
'/var/www/html/openWB/ramdisk/autolockconfiguredlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp7' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp7enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp7phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp7' missing: Setting from MQTT topic 'pluggedladungaktlp7' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp7startkwh' missing: Setting from MQTT topic 'pluggedladunglp7startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp6max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp6name' missing: no MQTT topic set: Setting to default of 'Lp6'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp6' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp6sofortll' missing: Setting from MQTT topic 'lp6sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp6' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp6enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp6phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp6' missing: Setting from MQTT topic 'pluggedladungaktlp6' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp6startkwh' missing: Setting from MQTT topic 'pluggedladunglp6startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp5max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp5name' missing: no MQTT topic set: Setting to default of 'Lp5'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp5' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp5sofortll' missing: Setting from MQTT topic 'lp5sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp5' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp5enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp5phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp5' missing: Setting from MQTT topic 'pluggedladungaktlp5' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp5startkwh' missing: Setting from MQTT topic 'pluggedladunglp5startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp4max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp4name' missing: no MQTT topic set: Setting to default of 'Lp4'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp4' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp4sofortll' missing: Setting from MQTT topic 'lp4sofortll' to value '10'
2021-04-24 08:00:21: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
'/var/www/html/openWB/ramdisk/autolockconfiguredlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp4' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp4enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp4phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp4' missing: Setting from MQTT topic 'pluggedladungaktlp4' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp4startkwh' missing: Setting from MQTT topic 'pluggedladunglp4startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp3max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp3name' missing: no MQTT topic set: Setting to default of 'Lp3'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp3' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/rfidlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp3sofortll' missing: Setting from MQTT topic 'lp3sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp3' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp3enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp3phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp3' missing: Setting from MQTT topic 'pluggedladungaktlp3' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp3startkwh' missing: Setting from MQTT topic 'pluggedladunglp3startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp2max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp2name' missing: no MQTT topic set: Setting to default of 'Lp2'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp2' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp2sofortll' missing: Setting from MQTT topic 'lp2sofortll' to value '10'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp2' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp2enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp2phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp2' missing: Setting from MQTT topic 'pluggedladungaktlp2' to value '0'
'/var/www/html/openWB/ramdisk/pluggedladunglp2startkwh' missing: Setting from MQTT topic 'pluggedladunglp2startkwh' to value '0'
'/var/www/html/openWB/ramdisk/mqttautolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttautolockstatuslp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttdisplaylp1max' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttlp1name' missing: no MQTT topic set: Setting to default of 'Lp1'
'/var/www/html/openWB/ramdisk/mqttmsmoduslp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/mqttzielladenaktivlp1' missing: no MQTT topic set: Setting to default of '-1'
'/var/www/html/openWB/ramdisk/boolstopchargeafterdisclp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp1sofortll' missing: Setting from MQTT topic 'lp1sofortll' to value '32'
'/var/www/html/openWB/ramdisk/autolockconfiguredlp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/autolockstatuslp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/restzeitlp1' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/lp1enabled' missing: no MQTT topic set: Setting to default of '1'
'/var/www/html/openWB/ramdisk/lp1phasen' missing: no MQTT topic set: Setting to default of '0'
'/var/www/html/openWB/ramdisk/pluggedladungaktlp1' missing: Setting from MQTT topic 'pluggedladungaktlp1' to value '0'
2021-04-24 08:00:11: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
'/var/www/html/openWB/ramdisk/pluggedladunglp1startkwh' missing: Setting from MQTT topic 'pluggedladunglp1startkwh' to value '134.708'
Initializing Ramdisk /var/www/html/openWB/ramdisk
Config file Update done.
Updating /var/www/html/openWB/openwb.conf...
touch: '/var/www/html/openWB/web/backup/.donotdelete' kann nicht berührt werden: Keine Berechtigung
RTNETLINK answers: Network is unreachable
/var/www/html/openWB/runs/cron5min.sh: Zeile 80: /var/www/html/openWB/ramdisk/netzschutz: Datei oder Verzeichnis nicht gefunden
(standard_in) 1: syntax error
/var/www/html/openWB/runs/cron5min.sh: Zeile 78: /var/www/html/openWB/ramdisk/llhz: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 69: /var/www/html/openWB/ramdisk/device9_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 68: /var/www/html/openWB/ramdisk/device8_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 67: /var/www/html/openWB/ramdisk/device7_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 66: /var/www/html/openWB/ramdisk/device6_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 65: /var/www/html/openWB/ramdisk/device5_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 64: /var/www/html/openWB/ramdisk/device4_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 63: /var/www/html/openWB/ramdisk/device3_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 62: /var/www/html/openWB/ramdisk/device2_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 61: /var/www/html/openWB/ramdisk/device1_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 60: /var/www/html/openWB/ramdisk/device2_temp2: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 59: /var/www/html/openWB/ramdisk/device2_temp1: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 58: /var/www/html/openWB/ramdisk/device2_temp0: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 57: /var/www/html/openWB/ramdisk/device1_temp2: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 56: /var/www/html/openWB/ramdisk/device1_temp1: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 55: /var/www/html/openWB/ramdisk/device1_temp0: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 54: /var/www/html/openWB/ramdisk/verbraucher2_whe: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 53: /var/www/html/openWB/ramdisk/verbraucher1_whe: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 52: /var/www/html/openWB/ramdisk/verbraucher3_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 51: /var/www/html/openWB/ramdisk/verbraucher2_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 50: /var/www/html/openWB/ramdisk/verbraucher1_wh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 49: /var/www/html/openWB/ramdisk/speichersoc: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 48: /var/www/html/openWB/ramdisk/speicherekwh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 47: /var/www/html/openWB/ramdisk/speicherikwh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 46: /var/www/html/openWB/ramdisk/soc1: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 45: /var/www/html/openWB/ramdisk/soc: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 43: /var/www/html/openWB/ramdisk/pvkwh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 39: /var/www/html/openWB/ramdisk/einspeisungkwh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 38: /var/www/html/openWB/ramdisk/bezugkwh: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 24: /var/www/html/openWB/ramdisk/llkwhges: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 23: /var/www/html/openWB/ramdisk/llkwhlp8: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 22: /var/www/html/openWB/ramdisk/llkwhlp7: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 21: /var/www/html/openWB/ramdisk/llkwhlp6: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 20: /var/www/html/openWB/ramdisk/llkwhlp5: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 19: /var/www/html/openWB/ramdisk/llkwhlp4: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 18: /var/www/html/openWB/ramdisk/llkwhs2: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 17: /var/www/html/openWB/ramdisk/llkwhs1: Datei oder Verzeichnis nicht gefunden
/var/www/html/openWB/runs/cron5min.sh: Zeile 16: /var/www/html/openWB/ramdisk/llkwh: Datei oder Verzeichnis nicht gefunden
2021-04-24 08:00:01: Ramdisk not set up. Maybe we are still booting. (LV0) at 43 main /var/www/html/openWB/regel.sh
loading config
atreboot.sh started
runs/pubmqtt.sh: Zeile 282: ramdisk/mqttdaily_verbraucher1ekwh: Keine Berechtigung
ConnectionRefusedError: [Errno 111] Connection refused
    sock.connect(sa)
  File "/usr/lib/python3.5/socket.py", line 703, in create_connection
    raise err
  File "/usr/lib/python3.5/socket.py", line 712, in create_connection
    return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
  File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 3522, in _create_socket_connection
    sock = self._create_socket_connection()
  File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 1071, in reconnect
    return self.reconnect()
  File "/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py", line 937, in connect
    client.connect("localhost")
  File "runs/mqttpub.py", line 19, in main
    main()
  File "runs/mqttpub.py", line 31, in <module>
Error: Connection refused
Debug-Log (vor einem Neustart) habe ich schon verschickt.
Neustart hat auch nicht geholfen :-(
Das Dashboard ist dementsprechend leer (keine Werte bei "Aktuelle Leistung", "Energie heute", "Ladepunkte").
Was kann ich tun?
Kann ich einfach auf die letzte Stable zurück (1.9.220) oder macht das Probleme?
OpenWB standard+, 3,9 kWp PV mit SMA WR, 4,12 kWp PV mit 2xVictron MPPT, Victron Multiplus 2 5000 mit Cerbo GX und 14,4 kWh Pylontech, smart #1 Brabus und Opel Corsa-e Ultimate
sunnykleineichen
Okay, ich antworte mir mal selbst ...
Problem scheint gelöst - aber so ganz sicher bin ich nicht woran es nun gelegen hat.
Ich habe nochmal die Verbindung zum Netz getrennt (am Switch) und OpenWB nochmal neu gestartet (indem ich den Host-Namen nochmal bestätigt, aber nicht geändert habe).
Auf meinem Mac zeigte sich dann aber das gleiche Bild.
Dann musste ich zusätzlich noch den Cache im Chrome löschen. Ansonsten sah es weiterhin genau so aus wie vorher.
Nun läuft aber wieder alles - sehr sehr seltsam.
Mafaldo
Has thanked: 8 times
Beitrag von Mafaldo »
Auch ich kann von einem seltsamen Verhalten seit dem letzten update
berichten.
Sobald ein Leistungseinbruch wegen Wolken zu sehen ist steigt
der Hausverbrauch an. Das bleibt eine Weile so stehen und dann
werden wieder die richtigen Werte angezeigt.
Das Log habe ich schon gesendet.
Hier nochmal kurz hintereinander,
nach Wolken zu hoch:
dann ca 10 sek später wieder normal:
Thomas aus W
Has thanked: 156 times
Been thanked: 68 times
Re: Rückmeldungen Nightly ab 1.9.231 - Lücke im Graph
Beitrag von Thomas aus W »
installierte Version: 1.9.231 (2021-04-23 16:08:24 +0200 [f0a6be47] )
Die Lücken im Graphen der Hauptansicht erscheinen immer noch.
Probiere mal bitte unter Einstellungen/Erscheinungsbild/Graph de- und reaktivieren.
Ich hatte in der 230 da Probleme mit der Legende und konnte sie darüber lösen.
hominidae
Has thanked: 46 times
Been thanked: 32 times
Beitrag von hominidae »
....ich habe nur 1 PV-Modul und einen SMA WR konfiguriert.
Die aktuelle Leistung (openWB/pv/W) und die aktuelle Tagessume (openWB/pv/DailyYieldKwh) sind im MQTT und natürlich auch im WebUI.
Allerdings ist openWB/pv/1/DailyYieldKwh, also der Wert am Modul 1 für die Tagessumme immer "0"...anders als zB die aktuelle Leistung am Modul 1.
Thomas aus W
HSC hat geschrieben: So Apr 25, 2021 12:03 pm Probiere mal bitte unter Einstellungen/Erscheinungsbild/Graph de- und reaktivieren.
Hab ich gemacht.
Da das Problem gerade nicht auftrat gab es auch keine Änderung. Ich beobachte das also weiter.
bye
TW
Thomas aus W
Re: Rückmeldungen Nightly ab 1.9.231 - Ladeleistung nicht aktualisiert
Nach dem die Ladung beendet wurde bleibt die Anzeige des (Messs-?)Wertes auf dem letzten Wert vor dem Abschalten, auch auf dem Handy.
Welche Hardware hängt am Ladepunkt 2?
