1.9.266: JSON: keine EVU/PV Daten mehr
Has thanked: 12 times
Been thanked: 50 times
Hallo Lena und Lutz,
habe heute Nachmittag auf meinem Spiel Raspi auch auf die aktuellste 266 aktualisiert und keine EVU und PV Daten mehr mit dem JSON Modul.
2022-05-18 16:08:12: PID: 29858: legacy run server: Received command ["modules.json.device","inverter","http://raspi3.fritz.box:8081",".data[]|select(.uuid==\"8ae19880-d
2022-05-18 16:08:12: PID: 29858: root: Fehler im Modul Json
File "/var/www/html/openWB/packages/modules/json/device.py", line 45, in __init__
":" + port if port else ""
TypeError: can only concatenate str (not "int") to str
2022-05-18 16:08:12: PID: 29858: root: Start device reading {'component1': <modules.json.inverter.JsonInverter object at 0xb5311790>}
2022-05-18 16:08:12: PID: 29858: root: Json Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> 'Device' object has no attribute 'domain', Traceback:
File "/var/www/html/openWB/packages/modules/json/device.py", line 64, in update
response = req.get_http_session().get(self.domain, timeout=5)
AttributeError: 'Device' object has no attribute 'domain'
2022-05-18 16:08:12: PID: 29858: legacy run server: Completed running command in 0.01s: ["modules.json.device","inverter","http://raspi3.fritz.box:8081",".data[]|select(.uuid==\"8ae19880-d
2022-05-18 16:08:17: PID: 3461: ungültiger Wert für lla2:  (LV0) at 590 loadvars loadvars.sh
2022-05-18 16:08:17: PID: 3674: EVU URL: http://raspi3.fritz.box:8081 (LV2) at 18 main modules/bezug_json/main.sh
2022-05-18 16:08:17: PID: 3674: Filter Watt : .data[] | select(.uuid=="0265cf40-d42b-11eb-b7e7-3ff66060fa6b")| .tuples[0][1] | if . == null then 0 else . end (LV2) at 19 main modules/bezug_json/main.sh
2022-05-18 16:08:17: PID: 3674: Filter Bezug: .data[] | select(.uuid=="e0f95960-d42a-11eb-bb4a-05a2a3f49d4f")| .tuples[0][1] (LV2) at 20 main modules/bezug_json/main.sh
2022-05-18 16:08:17: PID: 3674: Filter Einsp: .data[] | select(.uuid=="aa5aac00-d42a-11eb-b608-d568343b9bdc")| .tuples[0][1] (LV2) at 21 main modules/bezug_json/main.sh
2022-05-18 16:08:17: PID: 29858: legacy run server: Received command ["modules.json.device","counter","http://raspi3.fritz.box:8081",".data[] | select(.uuid==\"0265cf40-
2022-05-18 16:08:17: PID: 29858: root: Fehler im Modul Json
2022-05-18 16:08:17: PID: 29858: root: Start device reading {'componentNone': <modules.json.counter.JsonCounter object at 0xb5460c70>}
2022-05-18 16:08:17: PID: 29858: root: Json Zähler: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> 'Device' object has no attribute 'domain', Traceback:
2022-05-18 16:08:17: PID: 29858: legacy run server: Completed running command in 0.01s: ["modules.json.device","counter","http://raspi3.fritz.box:8081",".data[] | select(.uuid==\"0265cf40-
2022-05-18 16:08:17: PID: 3674: RET: 0 (LV2) at 26 main modules/bezug_json/main.sh
Der Port wird im read_legacy als INT definiert und im __init__ dann als String erwartet. Wurde erst gestern geändert.
Ich hab jetzt mal Zeile 42 in openWB/packages/modules/json/device.py
   port = self.device_config["configuration"]["port"]
in
   port = str(self.device_config["configuration"]["port"])
geändert. Damit funktioniert es bei mir wieder.
Has thanked: 24 times
Been thanked: 172 times
Re: 1.9.266: JSON: keine EVU/PV Daten mehr
Besser in Zeile 45 ergänzen, damit der Port intern ein Integer bleibt.
Hab ich versucht, bin ich zu blöd dafür
Oder ich hab nicht neu gestartet. Der Legacy Run Server bekommt leider nicht (immer) mit, wenn sich code ändert.
Ist im master.
Danke,
probiere ich nachher, muss jetzt Training geben.
Funktioniert wieder, Danke!
So hatte ich das eigentlich auch drin. Aber der Legacy_run Server bekommt das irgendwie nicht mit, dass sich der Code geändert hat.
Muss mal schauen, wie ich den killen und frisch starten kann, ohne den Raspi komplett zu Booten. Da laufen noch andere Sachen drauf.
Der server wird automatisch neu gestartet, wenn man das Shell-Skript erneut aufruft. Du mMusst mal in der atreboot.sh oder update.sh nachsehen. Komme gerade nicht dran.
Danke, habs gefunden. Teste ich mal.
