Auch ein paar weitere Fehlermeldungen, u.a. zu einem meiner HTTP Zähler, muss da gleich nochmal die Konfiguration überprüfen - wenngleich sich da nix geändert hat und das bisher stets funktioniert hat.
Update: Hatte den Pfad für den Erzeugungszähler mit 'none' angegeben da es diesen nicht gibt. Das klappt nun wohl nicht mehr, ein leeres Feld scheint nun keine Fehler mehr zu generieren.
atreboot.sh started
apt configuration already up to date
install required packages with 'apt-get'...
Err:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Temporary failure resolving 'raspbian.raspberrypi.org'
Err:2 https://deb.nodesource.com/node_14.x bullseye InRelease
Temporary failure resolving 'deb.nodesource.com'
Err:3 http://archive.raspberrypi.org/debian bullseye InRelease
Temporary failure resolving 'archive.raspberrypi.org'
Reading package lists...
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/bullseye/InRelease Temporary failure resolving 'raspbian.raspberrypi.org'
W: Failed to fetch https://deb.nodesource.com/node_14.x/dists/bullseye/InRelease Temporary failure resolving 'deb.nodesource.com'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease Temporary failure resolving 'archive.raspberrypi.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
apache2 is already the newest version (2.4.54-1~deb11u1).
bc is already the newest version (1.07.1-2+b1).
git is already the newest version (1:2.30.2-1).
jq is already the newest version (1.6-2.1).
libapache2-mod-php is already the newest version (2:7.4+76).
mosquitto is already the newest version (2.0.11-1).
mosquitto-clients is already the newest version (2.0.11-1).
php-curl is already the newest version (2:7.4+76).
php-gd is already the newest version (2:7.4+76).
php-json is already the newest version (2:7.4+76).
php-xml is already the newest version (2:7.4+76).
socat is already the newest version (1.7.4.1-3).
sshpass is already the newest version (1.09-1).
ssl-cert is already the newest version (1.1.0+nmu1).
sudo is already the newest version (1.9.5p2-3).
vim is already the newest version (2:8.2.2434-3+deb11u1).
python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
done
openwb.cron already up to date
openwb2.service already up to date
no restore pending, normal startup
cleaning obsolete python cache folders...
python cache cleanup done
LAN/WLAN...
apache default site...
...ok
checking required apache modules...
headers (enabled by site administrator)
headers already enabled
ssl (enabled by site administrator)
ssl already enabled
proxy_wstunnel (enabled by site administrator)
proxy_wstunnel already enabled
check mosquitto installation...
mosquitto.conf already up to date
mosquitto openwb.conf already up to date
mosquitto_local.conf already up to date
mosquitto openwb_local.conf already up to date
mosquitto done
install required python packages with 'pip3'...
Requirement already satisfied: jq==1.1.3 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 1)) (1.1.3)
Requirement already satisfied: paho_mqtt==1.6.1 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 2)) (1.6.1)
Requirement already satisfied: pymodbus==2.5.2 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 3)) (2.5.2)
Requirement already satisfied: pytest==6.2.5 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 4)) (6.2.5)
Requirement already satisfied: requests_mock==1.9.3 in /usr/local/lib/python3.9/dist-packages (from -r /var/www/html/openWB/requirements.txt (line 5)) (1.9.3)
Requirement already satisfied: lxml==4.7.1 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 6)) (4.7.1)
Requirement already satisfied: aiohttp==3.7.2 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 7)) (3.7.2)
Requirement already satisfied: schedule==1.1.0 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 8)) (1.1.0)
Requirement already satisfied: PyJWT==2.6.0 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 9)) (2.6.0)
Requirement already satisfied: ipparser==0.3.8 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 10)) (0.3.8)
Requirement already satisfied: bs4==0.0.1 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 11)) (0.0.1)
Requirement already satisfied: pkce==1.0.3 in /home/openwb/.local/lib/python3.9/site-packages (from -r /var/www/html/openWB/requirements.txt (line 12)) (1.0.3)
Requirement already satisfied: multidict<7.0,>=4.5 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (6.0.2)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (3.0.1)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.9/dist-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (21.2.0)
Requirement already satisfied: chardet<4.0,>=2.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (3.0.4)
Requirement already satisfied: typing-extensions>=3.6.5 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (4.4.0)
Requirement already satisfied: yarl<2.0,>=1.0 in /home/openwb/.local/lib/python3.9/site-packages (from aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (1.8.1)
Requirement already satisfied: beautifulsoup4 in /home/openwb/.local/lib/python3.9/site-packages (from bs4==0.0.1->-r /var/www/html/openWB/requirements.txt (line 11)) (4.11.1)
Requirement already satisfied: dnspython in /home/openwb/.local/lib/python3.9/site-packages (from ipparser==0.3.8->-r /var/www/html/openWB/requirements.txt (line 10)) (2.2.1)
Requirement already satisfied: six>=1.15.0 in /usr/lib/python3/dist-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (1.16.0)
Requirement already satisfied: pyserial>=3.4 in /usr/local/lib/python3.9/dist-packages (from pymodbus==2.5.2->-r /var/www/html/openWB/requirements.txt (line 3)) (3.5)
Requirement already satisfied: iniconfig in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.1.1)
Requirement already satisfied: toml in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (0.10.2)
Requirement already satisfied: py>=1.8.2 in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.11.0)
Requirement already satisfied: pluggy<2.0,>=0.12 in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (1.0.0)
Requirement already satisfied: packaging in /usr/local/lib/python3.9/dist-packages (from pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (21.3)
Requirement already satisfied: requests<3,>=2.3 in /usr/lib/python3/dist-packages (from requests_mock==1.9.3->-r /var/www/html/openWB/requirements.txt (line 5)) (2.25.1)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp==3.7.2->-r /var/www/html/openWB/requirements.txt (line 7)) (2.10)
Requirement already satisfied: soupsieve>1.2 in /home/openwb/.local/lib/python3.9/site-packages (from beautifulsoup4->bs4==0.0.1->-r /var/www/html/openWB/requirements.txt (line 11)) (2.3.2.post1)
Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in /usr/local/lib/python3.9/dist-packages (from packaging->pytest==6.2.5->-r /var/www/html/openWB/requirements.txt (line 4)) (3.0.6)
done
my IP: "192.168.178.99"
load versions...
chgrp: cannot access '/var/www/html/openWB/data/restore/*': No such file or directory
chmod: cannot access '/var/www/html/openWB/data/restore/*': No such file or directory
2023-01-03 16:46:07: boot done :-)
2023-01-03 16:46:15,553 - {root:123} - {DEBUG:MainThread} - Start openWB2.service
2023-01-03 16:46:15,554 - {helpermodules.update_config:320} - {DEBUG:MainThread} - Broker-Konfiguration aktualisieren
2023-01-03 16:46:17,140 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/pv/set/reserved_evu_overhang
2023-01-03 16:46:17,143 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/pv/set/released_evu_overhang
2023-01-03 16:46:17,145 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/pv/set/available_power
2023-01-03 16:46:17,148 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/pv/set/overhang_power_left
2023-01-03 16:46:17,156 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/13/set/plug_state_prev
2023-01-03 16:46:17,158 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/chargepoint/13/set/required_power
2023-01-03 16:46:17,329 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/command_completed
2023-01-03 16:46:17,332 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_0d3e438d/messages/1672696343595
2023-01-03 16:46:17,335 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_b085f115/messages/1672760582891
2023-01-03 16:46:17,338 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_b085f115/messages/1672760595170
2023-01-03 16:46:17,341 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_b085f115/messages/1672760673764
2023-01-03 16:46:17,345 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/command/mqttjs_b085f115/messages/1672760707135
2023-01-03 16:46:17,348 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/chargepoint/0/get/voltages
2023-01-03 16:46:17,350 - {helpermodules.update_config:348} - {DEBUG:MainThread} - Ungültiges Topic zum Startzeitpunkt: openWB/set/chargepoint/13/get/voltages
2023-01-03 16:46:31,755 - {helpermodules.subdata:243} - {ERROR:Thread-5} - Fehler im subdata-Modul
File "/var/www/html/openWB/packages/helpermodules/subdata.py", line 232, in process_vehicle_topic
if config["type"] is None:
TypeError: string indices must be integers
2023-01-03 16:46:31,789 - {helpermodules.subdata:243} - {ERROR:Thread-5} - Fehler im subdata-Modul
2023-01-03 16:46:31,792 - {helpermodules.subdata:243} - {ERROR:Thread-5} - Fehler im subdata-Modul
2023-01-03 16:46:32,002 - {helpermodules.setdata:37} - {DEBUG:Thread-6} - Subdata initialisation completed. Starting setdata loop to broker.
2023-01-03 16:46:32,027 - {modules.devices.sma_shm.utils:17} - {ERROR:Thread-5} - Serial <1900210416> must bei an int or None, but is <<class 'str'>>. Assuming None.
2023-01-03 16:46:40,740 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-03 16:46:40,741 - {root:62} - {INFO:MainThread} - # ***Start***
