Release: {"1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0","2.1.0":"2.1.0: 2.1.0 Release","2.1.1":"2.1.1: 2.1.1 Release","2.1.1-Beta.1":"2.1.1-Beta.1: 2.1.1 Beta 1","2.1.1-Beta.2":"2.1.1-Beta.2: 2.1.1 Beta 2","2.1.1-Beta.3":"2.1.1-Beta.3: 2.1.1 Beta 3"}
checking commit for origin/aiohttp-3.8.5...fatal: ambiguous argument 'origin/aiohttp-3.8.5': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
tags in branch:
fatal: malformed object name origin/aiohttp-3.8.5
2023-11-14 16:37:20,517 - {modules.common.fault_state:55} - {ERROR:set current cp4} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr <class 'ValueError'> Invalid host., Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 35, in set_current
    pub.pub_single("openWB/set/isss/Lp2Current", current,
  File "/var/www/html/openWB/packages/helpermodules/utils/error_counter.py", line 22, in __exit__
    raise exception
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 28, in set_current
    pub.pub_single("openWB/set/internal_chargepoint/0/data/set_current", current,
  File "/var/www/html/openWB/packages/helpermodules/pub.py", line 51, in pub_single
    publish.single(topic, json.dumps(payload), hostname=hostname, port=port, retain=retain)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 240, in single
    multiple([msg], hostname, port, client_id, keepalive, will, auth, tls,
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 176, in multiple
    client.connect(hostname, port, keepalive)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 912, in connect
    self.connect_async(host, port, keepalive,
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 978, in connect_async
    raise ValueError('Invalid host.')
ValueError: Invalid host.
kill: (462): No such process
seems like atreboot.sh finished normally
