Re: Fronius PV-Modul WR2 wird nicht mehr erfasst
Verfasst: Do Dez 30, 2021 9:40 am
Jetzt noch das debuglog:
AttributeError: 'NoneType' object has no attribute 'interCharTimeout'
self.socket.interCharTimeout = self.inter_char_timeout
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 476, in connect
if not self.connect():
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 106, in execute
return self.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 114, in read_holding_registers
request = client.read_holding_registers(readreg,reganzahl,unit=modbusid)
File "runs/readmodbus.py", line 17, in <module>
2021-12-30 10:39:11: **** Regulation loop needs 0 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:39:11: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:39:11: Timing Umschaltung: 720 / 240 (LV1) at 15 u1p3pswitch u1p3p.sh
2021-12-30 10:39:11: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2021-12-30 10:39:10: chargestatlp1 chargestatlp2 0 chargestatlp3 0 (LV1) at 1284 loadvars loadvars.sh
2021-12-30 10:39:10: plugstatlp1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1283 loadvars loadvars.sh
2021-12-30 10:39:10: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1282 loadvars loadvars.sh
2021-12-30 10:39:10: EVU 1:V/0A 2: V/0A 3: V/0A (LV1) at 1281 loadvars loadvars.sh
2021-12-30 10:39:10: lla3 0 llv3 0 llas13 llas23 soclp1 0 soclp2 (LV1) at 1280 loadvars loadvars.sh
2021-12-30 10:39:10: lla2 0 llv2 0 llas12 llas22 sofortll 32 hausverbrauch 374 wattbezug 232 uberschuss -232 (LV1) at 1279 loadvars loadvars.sh
2021-12-30 10:39:10: lla1 0 llv1 0 llas11 llas21 mindestuberschuss 1700 abschaltuberschuss -100 lademodus 2 (LV1) at 1278 loadvars loadvars.sh
2021-12-30 10:39:10: pv1watt -69 pv2watt -73 pvwatt -142 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1277 loadvars loadvars.sh
2021-12-30 10:39:10: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-12-30 10:39:10: PID: 2951: root: EVU Einspeisung: 31153167
2021-12-30 10:39:10: PID: 2951: root: EVU Bezug: 5006846
2021-12-30 10:39:10: PID: 2951: root: EVU Watt: 232.37
2021-12-30 10:39:10: PID: 2951: root: Fronius SM Leistung[W]: 232.37
2021-12-30 10:39:10: PID: 2951: root: Einbauort: MeterLocation.grid
2021-12-30 10:39:10: PID: 2951: requests.packages.urllib3.connectionpool: http://192.168.2.180:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0 HTTP/1.1" 200 2209
2021-12-30 10:39:09: PID: 2951: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 192.168.2.180
2021-12-30 10:39:09: PID: 2951: root: Komponente Fronius SM Zähler auslesen.
2021-12-30 10:39:09: PID: 2951: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75b8ced0>}
2021-12-30 10:39:09: PID: 2951: root: Fronius IP-Adresse: 192.168.2.180
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 125, in read_input_registers
resp = client.read_input_registers(0x00,2, unit=sdmid)
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 93, in <module>
loadvars.sh: Zeile 126: [: : Ganzzahliger Ausdruck erwartet.
2021-12-30 10:39:02: Modbus EVSE read CP1 issue - using previous state '' (LV0) at 121 loadvars loadvars.sh
loadvars.sh: Zeile 120: /var/www/html/openWB/ramdisk/evseplugstate: Datei oder Verzeichnis nicht gefunden
2021-12-30 10:39:01: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: **** FATAL ********************************* (LV0) at 61 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: **** FATAL Regulation loop needs 11 seconds (LV0) at 60 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: **** FATAL ********************************* (LV0) at 59 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: **** Regulation loop needs 1 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: Überschuss -179; mindestens 1700 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-30 10:38:52: uberschuss -179 wattbezug 179 ladestatus 0 llsoll 0 pvwatt -161 mindestuberschussphasen 1700 wattkombiniert -179 schaltschwelle 230 (LV2) at 578 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:52: anzahlphasen 1 (LV1) at 577 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:51: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:51: Timing Umschaltung: 720 / 240 (LV1) at 15 u1p3pswitch u1p3p.sh
2021-12-30 10:38:51: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2021-12-30 10:38:50: chargestatlp1 chargestatlp2 0 chargestatlp3 0 (LV1) at 1284 loadvars loadvars.sh
2021-12-30 10:38:50: plugstatlp1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1283 loadvars loadvars.sh
2021-12-30 10:38:50: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1282 loadvars loadvars.sh
2021-12-30 10:38:50: EVU 1:V/0A 2: V/0A 3: V/-0A (LV1) at 1281 loadvars loadvars.sh
2021-12-30 10:38:50: lla3 0 llv3 0 llas13 llas23 soclp1 0 soclp2 (LV1) at 1280 loadvars loadvars.sh
2021-12-30 10:38:50: lla2 0 llv2 0 llas12 llas22 sofortll 32 hausverbrauch 340 wattbezug 179 uberschuss -179 (LV1) at 1279 loadvars loadvars.sh
2021-12-30 10:38:50: lla1 0 llv1 0 llas11 llas21 mindestuberschuss 1700 abschaltuberschuss -100 lademodus 2 (LV1) at 1278 loadvars loadvars.sh
2021-12-30 10:38:50: pv1watt -79 pv2watt -82 pvwatt -161 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1277 loadvars loadvars.sh
2021-12-30 10:38:50: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-12-30 10:38:50: PID: 1592: root: EVU Einspeisung: 31153167
2021-12-30 10:38:50: PID: 1592: root: EVU Bezug: 5006845
2021-12-30 10:38:50: PID: 1592: root: EVU Watt: 179.89
2021-12-30 10:38:50: PID: 1592: root: Fronius SM Leistung[W]: 179.89
2021-12-30 10:38:50: PID: 1592: root: Einbauort: MeterLocation.grid
2021-12-30 10:38:50: PID: 1592: requests.packages.urllib3.connectionpool: http://192.168.2.180:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0 HTTP/1.1" 200 2254
2021-12-30 10:38:50: PID: 1592: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 192.168.2.180
2021-12-30 10:38:50: PID: 1592: root: Komponente Fronius SM Zähler auslesen.
2021-12-30 10:38:50: PID: 1592: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75ba5ed0>}
2021-12-30 10:38:50: PID: 1592: root: Fronius IP-Adresse: 192.168.2.180
2021-12-30 10:38:42: Modbus EVSE read CP1 issue - using previous state '' (LV0) at 121 loadvars loadvars.sh
2021-12-30 10:38:41: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: **** FATAL ********************************* (LV0) at 61 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: **** FATAL Regulation loop needs 11 seconds (LV0) at 60 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: **** FATAL ********************************* (LV0) at 59 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: Überschuss -236; mindestens 1700 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-30 10:38:32: uberschuss -236 wattbezug 236 ladestatus 0 llsoll 0 pvwatt -177 mindestuberschussphasen 1700 wattkombiniert -236 schaltschwelle 230 (LV2) at 578 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: anzahlphasen 1 (LV1) at 577 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:32: **** Regulation loop needs 1 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:31: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:31: Timing Umschaltung: 720 / 240 (LV1) at 15 u1p3pswitch u1p3p.sh
2021-12-30 10:38:31: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2021-12-30 10:38:30: chargestatlp1 chargestatlp2 0 chargestatlp3 0 (LV1) at 1284 loadvars loadvars.sh
2021-12-30 10:38:30: plugstatlp1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1283 loadvars loadvars.sh
2021-12-30 10:38:30: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1282 loadvars loadvars.sh
2021-12-30 10:38:30: EVU 1:V/0A 2: V/0A 3: V/-0A (LV1) at 1281 loadvars loadvars.sh
2021-12-30 10:38:30: lla3 0 llv3 0 llas13 llas23 soclp1 0 soclp2 (LV1) at 1280 loadvars loadvars.sh
2021-12-30 10:38:30: lla2 0 llv2 0 llas12 llas22 sofortll 32 hausverbrauch 413 wattbezug 236 uberschuss -236 (LV1) at 1279 loadvars loadvars.sh
2021-12-30 10:38:30: lla1 0 llv1 0 llas11 llas21 mindestuberschuss 1700 abschaltuberschuss -100 lademodus 2 (LV1) at 1278 loadvars loadvars.sh
2021-12-30 10:38:30: pv1watt -86 pv2watt -91 pvwatt -177 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1277 loadvars loadvars.sh
2021-12-30 10:38:30: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-12-30 10:38:30: PID: 32738: root: EVU Einspeisung: 31153167
2021-12-30 10:38:30: PID: 32738: root: EVU Bezug: 5006844
2021-12-30 10:38:30: PID: 32738: root: EVU Watt: 236.45
2021-12-30 10:38:30: PID: 32738: root: Fronius SM Leistung[W]: 236.45
2021-12-30 10:38:30: PID: 32738: root: Einbauort: MeterLocation.grid
2021-12-30 10:38:30: PID: 32738: requests.packages.urllib3.connectionpool: http://192.168.2.180:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0 HTTP/1.1" 200 2251
2021-12-30 10:38:30: PID: 32738: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 192.168.2.180
2021-12-30 10:38:30: PID: 32738: root: Komponente Fronius SM Zähler auslesen.
2021-12-30 10:38:30: PID: 32738: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75b9bed0>}
2021-12-30 10:38:30: PID: 32738: root: Fronius IP-Adresse: 192.168.2.180
2021-12-30 10:38:22: Modbus EVSE read CP1 issue - using previous state '' (LV0) at 121 loadvars loadvars.sh
2021-12-30 10:38:21: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: **** FATAL ********************************* (LV0) at 61 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: **** FATAL Regulation loop needs 11 seconds (LV0) at 60 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: **** FATAL ********************************* (LV0) at 59 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: Überschuss -213; mindestens 1700 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-30 10:38:12: uberschuss -213 wattbezug 213 ladestatus 0 llsoll 0 pvwatt -191 mindestuberschussphasen 1700 wattkombiniert -213 schaltschwelle 230 (LV2) at 578 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: anzahlphasen 1 (LV1) at 577 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:12: **** Regulation loop needs 1 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:38:11: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:38:11: Timing Umschaltung: 720 / 240 (LV1) at 15 u1p3pswitch u1p3p.sh
2021-12-30 10:38:11: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2021-12-30 10:38:10: chargestatlp1 chargestatlp2 0 chargestatlp3 0 (LV1) at 1284 loadvars loadvars.sh
2021-12-30 10:38:10: plugstatlp1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1283 loadvars loadvars.sh
2021-12-30 10:38:10: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1282 loadvars loadvars.sh
2021-12-30 10:38:10: EVU 1:V/0A 2: V/0A 3: V/-0A (LV1) at 1281 loadvars loadvars.sh
2021-12-30 10:38:10: lla3 0 llv3 0 llas13 llas23 soclp1 0 soclp2 (LV1) at 1280 loadvars loadvars.sh
2021-12-30 10:38:10: lla2 0 llv2 0 llas12 llas22 sofortll 32 hausverbrauch 404 wattbezug 213 uberschuss -213 (LV1) at 1279 loadvars loadvars.sh
2021-12-30 10:38:10: lla1 0 llv1 0 llas11 llas21 mindestuberschuss 1700 abschaltuberschuss -100 lademodus 2 (LV1) at 1278 loadvars loadvars.sh
2021-12-30 10:38:10: pv1watt -94 pv2watt -97 pvwatt -191 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1277 loadvars loadvars.sh
2021-12-30 10:38:10: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-12-30 10:38:10: PID: 31489: root: EVU Einspeisung: 31153167
2021-12-30 10:38:10: PID: 31489: root: EVU Bezug: 5006843
2021-12-30 10:38:10: PID: 31489: root: EVU Watt: 213.5
2021-12-30 10:38:10: PID: 31489: root: Fronius SM Leistung[W]: 213.5
2021-12-30 10:38:10: PID: 31489: root: Einbauort: MeterLocation.grid
2021-12-30 10:38:10: PID: 31489: requests.packages.urllib3.connectionpool: http://192.168.2.180:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0 HTTP/1.1" 200 2264
2021-12-30 10:38:10: PID: 31489: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 192.168.2.180
2021-12-30 10:38:10: PID: 31489: root: Komponente Fronius SM Zähler auslesen.
2021-12-30 10:38:10: PID: 31489: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75bd8ed0>}
2021-12-30 10:38:10: PID: 31489: root: Fronius IP-Adresse: 192.168.2.180
2021-12-30 10:38:02: Modbus EVSE read CP1 issue - using previous state '' (LV0) at 121 loadvars loadvars.sh
2021-12-30 10:38:01: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: **** FATAL ********************************* (LV0) at 61 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: **** FATAL Regulation loop needs 11 seconds (LV0) at 60 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: **** FATAL ********************************* (LV0) at 59 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: Überschuss -190; mindestens 1700 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-30 10:37:52: uberschuss -190 wattbezug 190 ladestatus 0 llsoll 0 pvwatt -198 mindestuberschussphasen 1700 wattkombiniert -190 schaltschwelle 230 (LV2) at 578 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: anzahlphasen 1 (LV1) at 577 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: **** Regulation loop needs 1 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:52: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:51: Timing Umschaltung: 720 / 240 (LV1) at 15 u1p3pswitch u1p3p.sh
2021-12-30 10:37:51: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2021-12-30 10:37:51: chargestatlp1 chargestatlp2 0 chargestatlp3 0 (LV1) at 1284 loadvars loadvars.sh
2021-12-30 10:37:51: plugstatlp1 plugstatlp2 0 plugstatlp3 0 (LV1) at 1283 loadvars loadvars.sh
2021-12-30 10:37:51: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1282 loadvars loadvars.sh
2021-12-30 10:37:51: EVU 1:V/0A 2: V/0A 3: V/-0A (LV1) at 1281 loadvars loadvars.sh
2021-12-30 10:37:51: lla3 0 llv3 0 llas13 llas23 soclp1 0 soclp2 (LV1) at 1280 loadvars loadvars.sh
2021-12-30 10:37:51: lla2 0 llv2 0 llas12 llas22 sofortll 32 hausverbrauch 388 wattbezug 190 uberschuss -190 (LV1) at 1279 loadvars loadvars.sh
2021-12-30 10:37:51: lla1 0 llv1 0 llas11 llas21 mindestuberschuss 1700 abschaltuberschuss -100 lademodus 2 (LV1) at 1278 loadvars loadvars.sh
2021-12-30 10:37:51: pv1watt -100 pv2watt -98 pvwatt -198 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1277 loadvars loadvars.sh
2021-12-30 10:37:51: RET: 0 (LV2) at 27 main modules/bezug_fronius_sm/main.sh
2021-12-30 10:37:50: PID: 30204: root: EVU Einspeisung: 31153167
2021-12-30 10:37:50: PID: 30204: root: EVU Bezug: 5006842
2021-12-30 10:37:50: PID: 30204: root: EVU Watt: 190.11
2021-12-30 10:37:50: PID: 30204: root: Fronius SM Leistung[W]: 190.11
2021-12-30 10:37:50: PID: 30204: root: Einbauort: MeterLocation.grid
2021-12-30 10:37:50: PID: 30204: requests.packages.urllib3.connectionpool: http://192.168.2.180:80 "GET /solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0 HTTP/1.1" 200 2262
2021-12-30 10:37:50: PID: 30204: requests.packages.urllib3.connectionpool: Starting new HTTP connection (1): 192.168.2.180
2021-12-30 10:37:50: PID: 30204: root: Komponente Fronius SM Zähler auslesen.
2021-12-30 10:37:50: PID: 30204: root: Start device reading {'componentNone': <modules.fronius.counter_sm.FroniusSmCounter object at 0x75bbded0>}
2021-12-30 10:37:50: PID: 30204: root: Fronius IP-Adresse: 192.168.2.180
2021-12-30 10:37:42: Modbus EVSE read CP1 issue - using previous state '' (LV0) at 121 loadvars loadvars.sh
2021-12-30 10:37:42: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: **** FATAL ********************************* (LV0) at 61 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: **** FATAL Regulation loop needs 11 seconds (LV0) at 60 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: **** FATAL ********************************* (LV0) at 59 cleanup /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: Überschuss -174; mindestens 1700 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-30 10:37:32: uberschuss -174 wattbezug 174 ladestatus 0 llsoll 0 pvwatt -209 mindestuberschussphasen 1700 wattkombiniert -174 schaltschwelle 230 (LV2) at 578 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: anzahlphasen 1 (LV1) at 577 main /var/www/html/openWB/regel.sh
2021-12-30 10:37:32: **** Regulation loop needs 1 seconds (LV0) at 55 cleanup /var/www/html/openWB/regel.sh
