Rückmeldungen Nightly 1.9.296
LarsBr87
Has thanked: 5 times
Re: Rückmeldungen Nightly 1.9.296
Beitrag von LarsBr87 »
nach dem update auf die neuste Nightly läuft das Smarthome nicht mehr. Status (rot/grün) stimmen nicht mehr und auch die Leitung ist eingefroren bzw wird nicht mehr angezeigt. Hier de Logs, sollte was fehlen, gerne melden.
Gruß Lars
UnboundLocalError: local variable 'keyword' referenced before assignment
    elif (("/" in keyword) or (int(devicenumb) < 1) or
  File "/var/www/html/openWB/runs/smarthomemq.py", line 67, in on_message
    on_message(self, self._userdata, message)
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3570, in _handle_on_message
    self._handle_on_message(message)
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3327, in _handle_publish
    return self._handle_publish()
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3033, in _packet_handle
    rc = self._packet_handle()
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 2439, in _packet_read
    rc = self._packet_read()
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1556, in loop_read
    rc = self.loop_read()
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1164, in _loop
    return self._loop(timeout)
  File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1120, in loop
    client.loop()
  File "/var/www/html/openWB/runs/smarthomemq.py", line 400, in readmq
    readmq()
  File "/var/www/html/openWB/runs/smarthomemq.py", line 463, in <module>
  RequestsDependencyWarning)
/usr/lib/python3/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.15) or chardet (3.0.4) doesn't match a supported version!
2023-03-22 17:20:02,417 INFO (9) Key mode Value 0
2023-03-22 17:20:02,417 INFO (9) Key device_configured Value 0
2023-03-22 17:20:02,416 INFO (8) Key mode Value 0
2023-03-22 17:20:02,416 INFO (8) Key device_configured Value 0
2023-03-22 17:20:02,415 INFO (7) Key mode Value 0
2023-03-22 17:20:02,415 INFO (7) Key device_configured Value 0
2023-03-22 17:20:02,414 INFO (6) Key mode Value 0
2023-03-22 17:20:02,414 INFO (6) Key device_configured Value 0
2023-03-22 17:20:02,413 INFO (5) Key mode Value 0
2023-03-22 17:20:02,413 INFO (5) Key device_configured Value 0
2023-03-22 17:20:02,412 INFO (4) Key device_shauth Value 0
2023-03-22 17:20:02,412 INFO (4) Key device_manual_control Value 0
2023-03-22 17:20:02,412 INFO (4) Key device_differentMeasurement Value 0
2023-03-22 17:20:02,412 INFO (4) Key device_pbtype Value none
2023-03-22 17:20:02,411 INFO (4) Key device_homeConsumtion Value 0
2023-03-22 17:20:02,411 INFO (4) Key device_temperatur_configured Value 0
2023-03-22 17:20:02,411 INFO (4) Key device_speichersocbeforestop Value 100
2023-03-22 17:20:02,410 INFO (4) Key device_speichersocbeforestart Value 100
2023-03-22 17:20:02,410 INFO (4) Key device_ausschaltverzoegerung Value 1
2023-03-22 17:20:02,410 INFO (4) Key device_ausschaltschwelle Value -1000
2023-03-22 17:20:02,409 INFO (4) Key device_updatesec Value 0
2023-03-22 17:20:02,409 INFO (4) Key device_einschaltverzoegerung Value 2
2023-03-22 17:20:02,409 INFO (4) Key device_einschaltschwelle Value 3500
2023-03-22 17:20:02,408 INFO (4) Key device_deactivateper Value 0
2023-03-22 17:20:02,408 INFO (4) Key device_setauto Value 0
2023-03-22 17:20:02,408 INFO (4) Key device_deactivateWhileEvCharging Value 0
2023-03-22 17:20:02,408 INFO (4) Key device_startupDetection Value 0
2023-03-22 17:20:02,407 INFO (4) Key device_offTime Value 00:00
2023-03-22 17:20:02,407 INFO (4) Key device_onTime Value 00:00
2023-03-22 17:20:02,407 INFO (4) Key device_onuntilTime Value 00:00
2023-03-22 17:20:02,406 INFO (4) Key device_finishTime Value 00:00
2023-03-22 17:20:02,406 INFO (4) Key device_endTime Value 14:30
2023-03-22 17:20:02,406 INFO (4) Key device_startTime Value 09:15
2023-03-22 17:20:02,405 INFO (4) Key device_maxeinschaltdauer Value 2
2023-03-22 17:20:02,405 INFO (4) Key device_mineinschaltdauer Value 2
2023-03-22 17:20:02,405 INFO (4) Key device_canSwitch Value 1
2023-03-22 17:20:02,404 INFO (4) Key device_ip Value 192.168.200.166
2023-03-22 17:20:02,404 INFO (4) Key device_chan Value 0
2023-03-22 17:20:02,403 INFO (4) Key device_type Value shelly
2023-03-22 17:20:02,403 INFO (4) Key device_name Value WWZ
2023-03-22 17:20:02,402 INFO (4) Key mode Value 0
2023-03-22 17:20:02,402 INFO (4) Key device_configured Value 1
2023-03-22 17:20:02,401 INFO (3) Key device_measureshauth Value 0
2023-03-22 17:20:02,401 INFO (3) Key device_measchan Value 0
2023-03-22 17:20:02,400 INFO (3) Key device_measureip Value 192.168.200.197
2023-03-22 17:20:02,400 INFO (3) Key device_measureType Value shelly
2023-03-22 17:20:02,399 INFO (3) Key device_differentMeasurement Value 1
2023-03-22 17:20:02,399 INFO (3) Key device_pbtype Value none
2023-03-22 17:20:02,399 INFO (3) Key device_homeConsumtion Value 1
2023-03-22 17:20:02,398 INFO (3) Key device_nonewatt Value 5
2023-03-22 17:20:02,398 INFO (3) Key device_type Value none
2023-03-22 17:20:02,397 INFO (3) Key device_name Value WaMa
2023-03-22 17:20:02,397 INFO (3) Key mode Value 0
2023-03-22 17:20:02,396 INFO (3) Key device_configured Value 1
2023-03-22 17:20:02,396 INFO (2) Key device_shauth Value 0
2023-03-22 17:20:02,395 INFO (2) Key device_differentMeasurement Value 0
2023-03-22 17:20:02,395 INFO (2) Key device_pbtype Value none
2023-03-22 17:20:02,395 INFO (2) Key device_homeConsumtion Value 1
2023-03-22 17:20:02,394 INFO (2) Key device_temperatur_configured Value 0
2023-03-22 17:20:02,394 INFO (2) Key device_canSwitch Value 0
2023-03-22 17:20:02,394 INFO (2) Key device_ip Value 192.168.200.181
2023-03-22 17:20:02,393 INFO (2) Key device_chan Value 0
2023-03-22 17:20:02,393 INFO (2) Key device_type Value shelly
2023-03-22 17:20:02,392 INFO (2) Key device_name Value Luft
2023-03-22 17:20:02,392 INFO (2) Key mode Value 0
2023-03-22 17:20:02,391 INFO (2) Key device_configured Value 1
2023-03-22 17:20:02,390 INFO (1) Key device_measurePortSdm Value 8899
2023-03-22 17:20:02,388 INFO (1) Key device_measureid Value 117
2023-03-22 17:20:02,388 INFO (1) Key device_measureip Value 192.168.200.86
2023-03-22 17:20:02,387 INFO (1) Key device_measureType Value sdm630
2023-03-22 17:20:02,387 INFO (1) Key device_differentMeasurement Value 1
2023-03-22 17:20:02,387 INFO (1) Key device_pbtype Value none
2023-03-22 17:20:02,386 INFO (1) Key device_homeConsumtion Value 1
2023-03-22 17:20:02,386 INFO (1) Key device_nonewatt Value 0
2023-03-22 17:20:02,385 INFO (1) Key device_type Value none
2023-03-22 17:20:02,385 INFO (1) Key device_name Value SWWP
2023-03-22 17:20:02,384 INFO (1) Key mode Value 0
2023-03-22 17:20:02,384 INFO (1) Key device_configured Value 1
2023-03-22 17:20:02,379 INFO Config reRead start / Parameter check
2023-03-22 17:20:02,379 INFO *** Smarthome mq Start ***
    client.loop()
    readmq()
2023-03-22 17:16:25,753 INFO (9) Key mode Value 0
2023-03-22 17:16:25,753 INFO (9) Key device_configured Value 0
2023-03-22 17:16:25,752 INFO (8) Key mode Value 0
2023-03-22 17:16:25,751 INFO (8) Key device_configured Value 0
2023-03-22 17:16:25,750 INFO (7) Key mode Value 0
2023-03-22 17:16:25,749 INFO (7) Key device_configured Value 0
2023-03-22 17:16:25,748 INFO (6) Key mode Value 0
2023-03-22 17:16:25,748 INFO (6) Key device_configured Value 0
2023-03-22 17:16:25,747 INFO (5) Key mode Value 0
2023-03-22 17:16:25,746 INFO (5) Key device_configured Value 0
2023-03-22 17:16:25,745 INFO (4) Key device_shauth Value 0
2023-03-22 17:16:25,745 INFO (4) Key device_manual_control Value 0
2023-03-22 17:16:25,744 INFO (4) Key device_differentMeasurement Value 0
2023-03-22 17:16:25,744 INFO (4) Key device_pbtype Value none
2023-03-22 17:16:25,743 INFO (4) Key device_homeConsumtion Value 0
2023-03-22 17:16:25,743 INFO (4) Key device_temperatur_configured Value 0
2023-03-22 17:16:25,742 INFO (4) Key device_speichersocbeforestop Value 100
2023-03-22 17:16:25,742 INFO (4) Key device_speichersocbeforestart Value 100
2023-03-22 17:16:25,741 INFO (4) Key device_ausschaltverzoegerung Value 1
2023-03-22 17:16:25,741 INFO (4) Key device_ausschaltschwelle Value -1000
2023-03-22 17:16:25,740 INFO (4) Key device_updatesec Value 0
2023-03-22 17:16:25,739 INFO (4) Key device_einschaltverzoegerung Value 2
2023-03-22 17:16:25,739 INFO (4) Key device_einschaltschwelle Value 3500
2023-03-22 17:16:25,738 INFO (4) Key device_deactivateper Value 0
2023-03-22 17:16:25,738 INFO (4) Key device_setauto Value 0
2023-03-22 17:16:25,737 INFO (4) Key device_deactivateWhileEvCharging Value 0
2023-03-22 17:16:25,736 INFO (4) Key device_startupDetection Value 0
2023-03-22 17:16:25,736 INFO (4) Key device_offTime Value 00:00
2023-03-22 17:16:25,735 INFO (4) Key device_onTime Value 00:00
2023-03-22 17:16:25,735 INFO (4) Key device_onuntilTime Value 00:00
2023-03-22 17:16:25,734 INFO (4) Key device_finishTime Value 00:00
2023-03-22 17:16:25,734 INFO (4) Key device_endTime Value 14:30
2023-03-22 17:16:25,733 INFO (4) Key device_startTime Value 09:15
2023-03-22 17:16:25,733 INFO (4) Key device_maxeinschaltdauer Value 2
2023-03-22 17:16:25,732 INFO (4) Key device_mineinschaltdauer Value 2
2023-03-22 17:16:25,732 INFO (4) Key device_canSwitch Value 1
2023-03-22 17:16:25,731 INFO (4) Key device_ip Value 192.168.200.166
2023-03-22 17:16:25,731 INFO (4) Key device_chan Value 0
2023-03-22 17:16:25,730 INFO (4) Key device_type Value shelly
2023-03-22 17:16:25,730 INFO (4) Key device_name Value WWZ
2023-03-22 17:16:25,729 INFO (4) Key mode Value 0
2023-03-22 17:16:25,729 INFO (4) Key device_configured Value 1
2023-03-22 17:16:25,728 INFO (3) Key device_measureshauth Value 0
2023-03-22 17:16:25,727 INFO (3) Key device_measchan Value 0
2023-03-22 17:16:25,726 INFO (3) Key device_measureip Value 192.168.200.197
2023-03-22 17:16:25,725 INFO (3) Key device_measureType Value shelly
2023-03-22 17:16:25,725 INFO (3) Key device_differentMeasurement Value 1
2023-03-22 17:16:25,724 INFO (3) Key device_pbtype Value none
2023-03-22 17:16:25,723 INFO (3) Key device_homeConsumtion Value 1
2023-03-22 17:16:25,722 INFO (3) Key device_nonewatt Value 5
2023-03-22 17:16:25,722 INFO (3) Key device_type Value none
2023-03-22 17:16:25,721 INFO (3) Key device_name Value WaMa
2023-03-22 17:16:25,720 INFO (3) Key mode Value 0
2023-03-22 17:16:25,719 INFO (3) Key device_configured Value 1
2023-03-22 17:16:25,718 INFO (2) Key device_shauth Value 0
2023-03-22 17:16:25,717 INFO (2) Key device_differentMeasurement Value 0
2023-03-22 17:16:25,716 INFO (2) Key device_pbtype Value none
2023-03-22 17:16:25,716 INFO (2) Key device_homeConsumtion Value 1
2023-03-22 17:16:25,715 INFO (2) Key device_temperatur_configured Value 0
2023-03-22 17:16:25,714 INFO (2) Key device_canSwitch Value 0
2023-03-22 17:16:25,713 INFO (2) Key device_ip Value 192.168.200.181
2023-03-22 17:16:25,712 INFO (2) Key device_chan Value 0
2023-03-22 17:16:25,712 INFO (2) Key device_type Value shelly
2023-03-22 17:16:25,711 INFO (2) Key device_name Value Luft
2023-03-22 17:16:25,710 INFO (2) Key mode Value 0
2023-03-22 17:16:25,709 INFO (2) Key device_configured Value 1
2023-03-22 17:16:25,707 INFO (1) Key device_measurePortSdm Value 8899
2023-03-22 17:16:25,707 INFO (1) Key device_measureid Value 117
2023-03-22 17:16:25,706 INFO (1) Key device_measureip Value 192.168.200.86
2023-03-22 17:16:25,705 INFO (1) Key device_measureType Value sdm630
2023-03-22 17:16:25,704 INFO (1) Key device_differentMeasurement Value 1
2023-03-22 17:16:25,704 INFO (1) Key device_pbtype Value none
2023-03-22 17:16:25,703 INFO (1) Key device_homeConsumtion Value 1
2023-03-22 17:16:25,702 INFO (1) Key device_nonewatt Value 0
2023-03-22 17:16:25,701 INFO (1) Key device_type Value none
2023-03-22 17:16:25,701 INFO (1) Key device_name Value SWWP
2023-03-22 17:16:25,700 INFO (1) Key mode Value 0
2023-03-22 17:16:25,699 INFO (1) Key device_configured Value 1
2023-03-22 17:16:25,689 INFO Config reRead start / Parameter check
2023-03-22 17:15:38,781 WARNING Ramdisk not set up. Maybe we are still booting (updateinprogress).[Errno 2] No such file or directory: '/var/www/html/openWB/ramdisk/updateinprogress'
2023-03-22 17:15:38,780 INFO *** Smarthome mq Start ***
**** REBOOT ****
Der ist in der neuesten nightly gefixt.
Been thanked: 44 times
Hast du eine Eigeninstallation unter Buster?
Dann such mal hier nach urllib3.
LarsBr87
Ja, ist eine eigene Installation, weil ich aktuell immer beim Solax Modul 3 Dateien ersetzen muss, damit die richtigen Werte kommen.
ich habe jetzt
sudo pip3 install --upgrade requests
ausgeführt, aber es ist immer noch unverändert.
Mach das mal ohne sudo und teste dann noch mal.
LarsBr87
Danke für deine Hilfe, aber so recht komme ich so nicht weiter. Habe es mal ohne sudo probiert und folgende Meldung wurde angezeigt, bringt aber keine Verbesserung.
pi@raspberrypi:~ $ pip3 install --upgrade requests
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: requests in /usr/local/lib/python3.7/dist-packages (2.28.2)
Requirement already satisfied, skipping upgrade: urllib3<1.27,>=1.21.1 in ./.local/lib/python3.7/site-packages (from requests) (1.26.15)
Requirement already satisfied, skipping upgrade: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests) (2018.8.24)
Requirement already satisfied, skipping upgrade: idna<4,>=2.5 in /usr/lib/python3/dist-packages (from requests) (2.6)
Requirement already satisfied, skipping upgrade: charset-normalizer<4,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (3.1.0)
Gruß Lars
Hmm, gestern wurde eine größere Anpassung des Smarthome gemerged. Evtl. Ist da dann doch noch was anderes schief.
Zuletzt geändert von derNeueDet am Mi Mär 22, 2023 7:13 pm, insgesamt 1-mal geändert.
LarsBr87
Wir warten mal ab und gucken, wie es bei den anderen läuft. Wird schon wieder 👍
Trotzdem vielen Dank 🤗
Kitmgue
Has thanked: 4 times
Beitrag von Kitmgue »
Mir ist da etwas merkwürdiges aufgefallen:
im Debug Log:
2023-03-23 07:47:54: PID: 28932: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:47:44: PID: 27638: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:47:34: PID: 26330: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:47:24: PID: 25034: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:47:14: PID: 23731: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:47:04: PID: 22432: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:55: PID: 21102: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:45: PID: 19807: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:34: PID: 18513: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:25: PID: 17218: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:14: PID: 15917: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:46:04: PID: 14609: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:55: PID: 13289: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:44: PID: 11996: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:35: PID: 10693: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:25: PID: 9390: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:15: PID: 8092: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:05: PID: 6496: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:45:03: PID: 6504: ##### cron5min.sh finished ##### (LV0)
2023-03-23 07:45:02: PID: 6736: Starting OpenWB services (LV0)
2023-03-23 07:45:02: PID: 6504: ##### cron5min.sh started ##### (LV0)
2023-03-23 07:44:54: PID: 5169: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:44:44: PID: 3872: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:44:35: PID: 2568: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:44:25: PID: 1180: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:44:15: PID: 32312: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:44:04: PID: 31012: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:55: PID: 29684: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:45: PID: 28380: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:35: PID: 27086: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:24: PID: 25790: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:15: PID: 24493: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:43:04: PID: 23176: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:54: PID: 21842: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:44: PID: 20539: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:34: PID: 19245: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:24: PID: 17942: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:14: PID: 16645: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:42:04: PID: 15342: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:54: PID: 14017: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:44: PID: 12722: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:34: PID: 11427: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:24: PID: 10131: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:14: PID: 8835: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:41:04: PID: 7526: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:54: PID: 6205: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:45: PID: 4910: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:34: PID: 3613: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:25: PID: 2289: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:15: PID: 919: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:05: PID: 31747: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:40:03: PID: 31762: ##### cron5min.sh finished ##### (LV0)
2023-03-23 07:40:02: PID: 32002: Starting OpenWB services (LV0)
2023-03-23 07:40:02: PID: 31762: ##### cron5min.sh started ##### (LV0)
2023-03-23 07:39:54: PID: 30428: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:39:44: PID: 29134: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:39:34: PID: 27840: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:39:24: PID: 26546: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:39:14: PID: 25245: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:39:04: PID: 23873: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:54: PID: 22552: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:44: PID: 21258: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:34: PID: 19954: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:24: PID: 18660: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:14: PID: 17361: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:38:04: PID: 16060: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:54: PID: 14734: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:44: PID: 13419: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:34: PID: 12121: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:23: PID: 10834: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:14: PID: 9541: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:37:04: PID: 8235: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:54: PID: 6922: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:44: PID: 5633: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:34: PID: 4343: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:24: PID: 3054: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:14: PID: 1682: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:36:04: PID: 331: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:54: PID: 31474: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:43: PID: 30187: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:34: PID: 28899: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:24: PID: 27611: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:14: PID: 26321: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:04: PID: 24724: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:35:02: PID: 24737: ##### cron5min.sh finished ##### (LV0)
2023-03-23 07:35:01: PID: 24969: Starting OpenWB services (LV0)
2023-03-23 07:35:01: PID: 24737: ##### cron5min.sh started ##### (LV0)
2023-03-23 07:34:54: PID: 23403: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:34:44: PID: 22114: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:34:34: PID: 20810: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:34:24: PID: 19514: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:34:14: PID: 18216: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:34:04: PID: 16908: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:54: PID: 15597: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:44: PID: 14309: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:34: PID: 13020: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:24: PID: 11721: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:14: PID: 10430: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:33:04: PID: 9131: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:54: PID: 7811: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:44: PID: 6521: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:34: PID: 5234: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:24: PID: 3944: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:14: PID: 2644: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:32:04: PID: 1254: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:54: PID: 32361: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:44: PID: 31073: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:34: PID: 29785: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:24: PID: 28497: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:14: PID: 27206: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:31:04: PID: 25906: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:30:54: PID: 24589: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:30:44: PID: 23295: ungültiger Wert für soc1:  (LV0)
2023-03-23 07:30:02: PID: 17818: ##### cron5min.sh finished ##### (LV0)
2023-03-23 07:30:01: PID: 18060: Starting OpenWB services (LV0)
2023-03-23 07:30:01: PID: 17818: ##### cron5min.sh started ##### (LV0)
Das EV SoC Log sagt:
2023-03-23 07:47:40: PID: 26629: Lp1: Fetched from Citroen: 76% but skipping as not different from last fetched SoC and car is plugged in. (LV0)
2023-03-23 07:47:35: PID: 26629: Lp1: Fetching SoC from Citroen (LV0)
2023-03-23 07:37:41: PID: 12417: Lp1: Fetched from Citroen: 76% and using it. (LV0)
2023-03-23 07:37:35: PID: 12417: Lp1: Fetching SoC from Citroen (LV0)
2023-03-23 07:30:39 ERROR:libvwid:Lp2 Get status failed
2023-03-23 07:30:31: PID: 20987: Lp1: Fetched from Citroen: 78% and using it. (LV0)
2023-03-23 07:30:25: PID: 20987: Lp1: Fetching SoC from Citroen (LV0)
Warum ist mir das aufgefallen?
weil ich eigentlich die EV SoC Begrenzung auf 80% gestellt habe und daher der Lp1 automatisch freigegeben werden müsste, was er aber nicht wird.
Nach einem Reboot funktioniert es wieder wie gewünscht.
installierte Version: 1.9.296 (2023-03-22 11:57:42 +0100 [f834633c] )
openWB series2 standard+
LP1 : intern
LP2: smartWB
(manueller SoC für beide LP)
EVU: Sunny Home Manager 2.0
kein Speicher
philipp123
Beitrag von philipp123 »
LutzB hat geschrieben: Mo Mär 20, 2023 9:29 am Das manuelle Ein-/Ausschalten wurde gerade behoben.
Kann es sein, dass das jetzt im der Cloud nicht mehr funktioniert? Lokal hat es nach Update und Cash-leeren wieder getan.
LP2: go-e V2
Kostal Plenticore Plus
e-up BJ 2021, SOC mit OVMS
9 x Smarthome mit Shellys
Been thanked: 33 times
Beitrag von okaegi »
LarsBr87 hat geschrieben: Mi Mär 22, 2023 4:27 pm nach dem update auf die neuste Nightly läuft das Smarthome nicht mehr. Status (rot/grün) stimmen nicht mehr und auch die Leitung ist eingefroren bzw wird nicht mehr angezeigt. Hier de Logs, sollte was fehlen, gerne melden.
Gruß Lars
    client.loop()
    readmq()
    client.loop()
    readmq()
**** REBOOT ****
Sorry habe den original Beitrag von Lars geändert, wollte ihn nur zitieren. Das obige Problem ist im neusten Nightly behoben.
