habe eben festgestellt das meine SoC Wert auf "0" steht und dadurch mein Auto läd. Das ist nicht gut.
2023-11-24 18:18:51,642 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 43 counter 3149740
2023-11-24 18:18:51,652 - {control.process:111} - {INFO:MainThread} - LP2: set current 10 A, state CHARGING_ALLOWED
2023-11-24 18:18:51,654 - {modules.common.component_context:24} - {DEBUG:set current cp2} - Update Komponente ['Ladepunkt']
2023-11-24 18:18:51,661 - {urllib3.connectionpool:227} - {DEBUG:set current cp2} - Starting new HTTP connection (1): 192.168.5.111:80
2023-11-24 18:18:51,678 - {urllib3.connectionpool:452} - {DEBUG:set current cp2} - http://192.168.5.111:80 "POST /connect.php HTTP/1.1" 200 20
2023-11-24 18:18:51,682 - {modules.common.req:11} - {DEBUG:set current cp2} - Get-Response: OK Value:10 accepted
2023-11-24 18:18:51,689 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-11-24 18:18:51,908 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-11-24 18:18:55,932 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-11-24 18:19:00,945 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-11-24 18:19:00,946 - {root:74} - {INFO:MainThread} - # ***Start***
2023-11-24 18:19:01,009 - {modules.common.component_context:51} - {DEBUG:device0} - Update Komponenten ['SMA Home Manager Zähler']
2023-11-24 18:19:01,010 - {modules.devices.sma_sunny_boy.device:72} - {DEBUG:device1} - Start device reading {'component1': <modules.devices.sma_sunny_boy.inverter.SmaSunnyBoyInverter object at 0x715e3370>}
2023-11-24 18:19:01,012 - {modules.common.component_context:24} - {DEBUG:set values cp2} - Update Komponente ['Ladepunkt']
2023-11-24 18:19:01,020 - {urllib3.connectionpool:227} - {DEBUG:set values cp2} - Starting new HTTP connection (1): 192.168.5.111:80
2023-11-24 18:19:01,022 - {modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-11-24 18:19:01,053 - {urllib3.connectionpool:452} - {DEBUG:set values cp2} - http://192.168.5.111:80 "GET /connect.php HTTP/1.1" 200 497
2023-11-24 18:19:01,057 - {modules.common.req:11} - {DEBUG:set values cp2} - Get-Response: {"date":"2023:11:24-18:19:01","timestamp":1700846341,"powers":[1894.4,0,5.5],"power_all":1897,"currents":[9.304,0.035,0.04],"voltages":[224.5,229.49,229.63],"frequency":49.98,"imported":3149745,"exported":2659,"plug_state":true,"charge_state":true,"phases_actual":1,"phases_target":1,"phases_in_use":1,"offered_current":10,"evse_signaling":"unclear\n","v2g_ready":0,"soc_value":24,"soc_timestamp":1700827315,"vehicle_id":"E0:0E:E1:02:56:45","rfid_tag":null,"rfid_timestamp":null,"serial":"386723"}
2023-11-24 18:19:01,058 - {modules.common.store._api:26} - {DEBUG:set values cp2} - Raw data ChargepointState(currents=[9.304, 0.035, 0.04], powers=[1894.4, 0, 5.5], voltages=[224.5, 229.49, 229.63], frequency=49.98, imported=3149745, exported=2659, power=1897, phases_in_use=1, charge_state=True, plug_state=True, rfid=E0:0E:E1:02:56:45, power_factors=[0.0, 0.0, 0.0], soc=24, soc_timestamp=1700827315, evse_current=10)
2023-11-24 18:19:01,653 - {modules.devices.sma_sunny_boy.inverter:72} - {DEBUG:device1} - WR 192.168.5.130: InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=55960394, dc_power=4294967296)
2023-11-24 18:19:01,654 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=55960394, dc_power=4294967296)
2023-11-24 18:19:01,949 - {modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SMA Home Manager Zähler']
2023-11-24 18:19:01,950 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[2.233, 1.054, 10.35], powers=[340.7, 172.1, 2097.5], voltages=[229.314, 228.224, 226.881], power_factors=[0.764, 0.753, 0.905], imported=57381658.8, exported=30363077.2, power=2610.3, frequency=50)
2023-11-24 18:19:01,953 - {modules.devices.sma_shm.device:29} - {DEBUG:device0} - All components updated
2023-11-24 18:19:01,962 - {modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2023-11-24 18:19:01,964 - {modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=55960394, dc_power=None)
2023-11-24 18:19:01,966 - {modules.common.component_context:24} - {DEBUG:update values cp2} - Update Komponente ['Ladepunkt']
2023-11-24 18:19:01,967 - {modules.common.store._api:30} - {INFO:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=0, exported=55960394, dc_power=None)
2023-11-24 18:19:01,969 - {modules.common.store._api:30} - {INFO:update values cp2} - Saving ChargepointState(currents=[9.304, 0.035, 0.04], powers=[1894.4, 0, 5.5], voltages=[224.5, 229.49, 229.63], frequency=49.98, imported=3149745, exported=2659, power=1897, phases_in_use=1, charge_state=True, plug_state=True, rfid=E0:0E:E1:02:56:45, power_factors=[0.0, 0.0, 0.0], soc=24, soc_timestamp=1700827315, evse_current=10)
2023-11-24 18:19:02,096 - {modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SMA Home Manager Zähler']
2023-11-24 18:19:02,097 - {modules.common.store._api:30} - {INFO:component0} - Saving CounterState(currents=[2.233, 1.054, 10.35], powers=[340.7, 172.1, 2097.5], voltages=[229.314, 228.224, 226.881], power_factors=[0.764, 0.753, 0.905], imported=57381658.8, exported=30363077.2, power=2610.3, frequency=50)
2023-11-24 18:19:02,240 - {modules.ripple_control_receiver:30} - {DEBUG:MainThread} - RSE1-Status: False, RSE2-Status: False
2023-11-24 18:19:02,243 - {control.counter:138} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [42.07, 33.99, 24.689999999999998]A
2023-11-24 18:19:02,243 - {control.counter:161} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 23286.7W
2023-11-24 18:19:02,246 - {modules.common.component_context:24} - {DEBUG:MainThread} - Update Komponente ['Ladepunkt']
2023-11-24 18:19:02,246 - {modules.chargepoints.openwb_pro.chargepoint_module:88} - {DEBUG:MainThread} - Die openWB-Pro unterstützt keine RFID-Tags.
2023-11-24 18:19:02,247 - {control.chargepoint.chargepoint:277} - {INFO:MainThread} - LP 2: Nach Ladestart wird kein anderer RFID-Tag akzeptiert.
2023-11-24 18:19:02,250 - {control.chargepoint.chargepoint:699} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-11-24 18:19:02,250 - {control.chargepoint.chargepoint:682} - {DEBUG:MainThread} - Phasenzahl Lademodus: 1
2023-11-24 18:19:02,252 - {control.ev:580} - {DEBUG:MainThread} - Keine Ladung, da kein Zeitfenster für Zeitladen aktiv ist.
2023-11-24 18:19:02,255 - {control.chargepoint.chargepoint:898} - {INFO:MainThread} - LP 2, EV: Kona (EV-Nr.1): Theoretisch benötigter Strom 10A, Lademodus pv_charging, Submodus: Chargemode.INSTANT_CHARGING, Phasen: 1, Priorität: False, max. Ist-Strom: 9.3
2023-11-24 18:19:02,258 - {modules.common.simcount._simcount:38} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1700846331.5807896, power=726.3999999999999, imported=1952144.1278138855, exported=0)
2023-11-24 18:19:02,259 - {modules.common.simcount._calculate:13} - {DEBUG:MainThread} - time passed: 0.00296594, power1: 726.4, power2: 713.3
2023-11-24 18:19:02,260 - {modules.common.simcount._calculate:29} - {DEBUG:MainThread} - power did not change sign. Total energy: 2.13503
2023-11-24 18:19:02,261 - {modules.common.simcount._simcount:47} - {DEBUG:MainThread} - imported: 2.13503 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1700846342.258157, power=713.3000000000002, imported=1952146.262842485, exported=0)
2023-11-24 18:19:02,264 - {control.data:236} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=False), get=Get(soc=0, daily_exported=0, daily_imported=0, fault_str='Kein Fehler.', fault_state=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, switch_on_soc_reached=False))
2023-11-24 18:19:02,265 - {control.data:237} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=2784, daily_exported=5, power=1897, imported=3149745, exported=2659))
2023-11-24 18:19:02,266 - {control.data:266} - {INFO:MainThread} - cp2
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, current_plan=None, imported_at_plan_start=3149697, imported_instant_charging=None, limit=None, phases=1, prio=False, required_current=10, required_currents=[10, 0.0, 0.0], state=4, submode=<Chargemode.INSTANT_CHARGING: 'instant_charging'>, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[9.3, 0.04, 0.04], daily_imported=2784, daily_exported=5, evse_current=10, exported=2659, fault_str='Kein Fehler.', fault_state=0, imported=3149745, phases_in_use=1, plug_state=True, power=1897, rfid_timestamp=None, rfid=None, soc=24, soc_timestamp=1700827315, state_str='Nach Ladestart wird kein anderer RFID-Tag akzeptiert.', voltages=[224.5, 229.49, 229.63]), set=Set(change_ev_permitted=[True, ''], charging_ev=1, charging_ev_prev=1, current=10, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', imported_at_mode_switch=3149697, imported_at_plugtime=3149697, imported_since_mode_switch=43, imported_since_plugged=43, range_charged=0.27741935483870966, time_charged='0:01', timestamp_start_charging='11/24/2023, 18:17:21'), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time='11/24/2023, 16:44:51', required_power=2300.0, rfid='E0:0E:E1:02:56:45', target_current=0, charging_ev_data=<control.ev.Ev object at 0x7575abb0>), config=Config(configuration={'ip_address': '192.168.5.111', 'duo_num': 0}, ev=1, name='Garage', type='openwb_pro', template=1, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=2))
2023-11-24 18:19:02,267 - {control.data:266} - {INFO:MainThread} - cpt0
2023-11-24 18:19:02,268 - {control.data:266} - {INFO:MainThread} - cpt1
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), id=1, max_current_multi_phases=16, max_current_single_phase=16, name='openWB Pro', rfid_enabling=True, valid_tags=['E0:0E:E1:02:56:45'])
2023-11-24 18:19:02,269 - {control.data:266} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[35, 35, 35], max_total_power=24000), get=Get(powers=[340.7, 172.1, 2097.5], currents=[2.23, 1.05, 10.35], voltages=[229.31, 228.22, 226.88], power_factors=[0.76, 0.75, 0.91], unbalanced_load=0, frequency=50, daily_exported=0.0, daily_imported=31765.199999996, imported=57381658.8, exported=30363077.2, fault_state=0, fault_str='Kein Fehler.', power=2610.3), set=Set(error_counter=0, reserved_surplus=0, released_surplus=0, raw_power_left=23286.7, raw_currents_left=[42.07, 33.99, 24.689999999999998], surplus_power_left=0, state_str=''))
2023-11-24 18:19:02,270 - {control.data:241} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(reserve_for_not_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': []}, {'id': 2, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=713.3000000000002, invalid_home_consumption=0, daily_yield_home_consumption=29684.1428060276, imported_home_consumption=1952146.262842485, disengageable_smarthome_power=0))
2023-11-24 18:19:02,271 - {control.data:266} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=8, min_current=0, feed_in_limit=False, min_soc=0, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2023-11-24 18:19:02,273 - {control.data:266} - {INFO:MainThread} - ct1
ChargeTemplateData(name='Kona-Lade-Profil', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=True, plans={'0': TimeChargingPlan(active=True, frequency=Frequency(selected='weekly', once=['2021-11-01', '2021-11-05'], weekly=[True, True, False, False, False, False, False]), time=['06:45', '07:15'], name='Vorklimatisierung Mo-Di 6:45-7:15', current=7, limit=Limit(selected='none', amount=1000, soc=55))}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=25, max_soc=101), scheduled_charging=ScheduledCharging(plans={'0': ScheduledChargingPlan(active=True, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), current=10, name='Zielladen morgens 6:30', limit=ScheduledLimit(selected='soc', amount=1000, soc_limit=55, soc_scheduled=50), time='06:30')}), instant_charging=InstantCharging(current=11, limit=Limit(selected='soc', amount=1000, soc=60))))
2023-11-24 18:19:02,280 - {control.data:266} - {INFO:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=16, battery_capacity=82000, efficiency=90, nominal_difference=2, keep_charge_active_duration=40), et_num=0), soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp=None, force_soc_update=True, range=0, fault_state=0, fault_str='Kein Fehler.'))
2023-11-24 18:19:02,284 - {control.data:266} - {INFO:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Kona-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=15500, min_current=6, max_current_single_phase=16, battery_capacity=39000, efficiency=85, nominal_difference=3, keep_charge_active_duration=40), et_num=0), soc_error_counter=3), charge_template=1, ev_template=1, name='Kona', tag_id=['E0:0E:E1:02:56:45'], get=Get(soc=0, soc_timestamp='11/24/2023, 18:17:03', force_soc_update=False, range=0, fault_state=2, fault_str="<class 'TypeError'> unsupported operand type(s) for -: 'int' and 'NoneType'"))
2023-11-24 18:19:02,285 - {control.data:266} - {INFO:MainThread} - et0
2023-11-24 18:19:02,288 - {control.data:266} - {INFO:MainThread} - et1
2023-11-24 18:19:02,291 - {control.data:245} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=False, charging_power_reserve=0, control_range=[0, 230], feed_in_yield=3000, phase_switch_delay=1, phases_to_use=0, rundown_power=0, rundown_soc=100, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1350), scheduled_charging=ScheduledCharging(phases_to_use=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.305, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=True, r1_active=False, r2_active=False))
2023-11-24 18:19:02,292 - {control.data:246} - {INFO:MainThread} - general_data-display
local
2023-11-24 18:19:02,296 - {control.data:247} - {INFO:MainThread} - graph_data
2023-11-24 18:19:02,296 - {control.data:248} - {INFO:MainThread} - optional_data
OptionalData(et=Et(active=False, config=EtConfig(max_price=0, provider={}), get=EtGet(price=0, price_list=[])), int_display=InternalDisplay(active=False, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=60, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x75772d18>), led=Led(active=False), rfid=Rfid(active=True))
2023-11-24 18:19:02,298 - {control.data:266} - {INFO:MainThread} - pv1
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=675, monthly_exported=0, yearly_exported=0, exported=55960394, fault_state=0, fault_str='Kein Fehler.', power=0))
2023-11-24 18:19:02,300 - {control.data:250} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=675, monthly_exported=0, yearly_exported=0, exported=55960394, power=0))
2023-11-24 18:19:02,302 - {control.data:266} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.5.110', 'current_commit': '2023-11-22 13:01:10 +0100 [a327c63a4]', 'current_branch': 'master', 'current_branch_commit': '2023-11-22 13:01:10 +0100 [a327c63a4]', 'current_missing_commits': [], 'boot_done': True, 'datastore_version': 29, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'release_train': 'master', 'version': '2.1.2-Beta.4', 'lastlivevaluesJson': {'timestamp': 1700846331, 'time': '18:18:51', 'grid': 2.622, 'house-power': 0.726, 'charging-all': 1.895, 'pv-all': -0.0, 'cp2-power': 1.895, 'ev1-soc': 0}, 'debug_level': 10, 'module_update_completed': True}
2023-11-24 18:19:02,303 - {control.data:279} - {INFO:MainThread} - device0
{'name': 'SMA Home Manager', 'type': 'sma_shm', 'id': 0, 'configuration': {}}
2023-11-24 18:19:02,303 - {control.data:281} - {INFO:MainThread} - component0
{'name': 'SMA Home Manager Zähler', 'type': 'counter', 'id': 0, 'configuration': {'serials': None}}
2023-11-24 18:19:02,304 - {control.data:279} - {INFO:MainThread} - device1
{'name': 'SMA Sunny Boy', 'type': 'sma_sunny_boy', 'id': 1, 'configuration': {'ip_address': '192.168.5.130'}}
2023-11-24 18:19:02,304 - {control.data:281} - {INFO:MainThread} - component1
{'name': 'Sma Sunny Boy/Tripower Wechselrichter', 'type': 'inverter', 'id': 1, 'configuration': {'hybrid': False, 'version': 0}}
2023-11-24 18:19:02,304 - {control.data:253} - {INFO:MainThread} -
2023-11-24 18:19:02,305 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2023-11-24 18:19:02,305 - {control.algorithm.algorithm:63} - {DEBUG:MainThread} - Ladepunkt 2: Prüfen, ob Phasenumschaltung durchgeführt werden soll.
2023-11-24 18:19:02,306 - {control.chargepoint.chargepoint:699} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2023-11-24 18:19:02,306 - {control.counter:198} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 2725.3W
2023-11-24 18:19:02,308 - {control.ev:449} - {DEBUG:MainThread} - Genutzter Strom: 9.3A, Überschuss: -2725.3W, benötigte neue Leistung: -460W
2023-11-24 18:19:02,309 - {control.counter:198} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 2725.3W
2023-11-24 18:19:02,310 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2023-11-24 18:19:02,313 - {control.algorithm.min_current:18} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 0
2023-11-24 18:19:02,314 - {control.counter:169} - {DEBUG:MainThread} - Zähler 0: [36.07, 33.99, 24.689999999999998]A verbleibende Ströme, 21906.7W verbleibende Leistung
2023-11-24 18:19:02,316 - {control.algorithm.common:95} - {INFO:MainThread} - LP2: Stromstärke 6A
2023-11-24 18:19:02,318 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Sollstrom setzen**
2023-11-24 18:19:02,323 - {control.algorithm.filter_chargepoints:117} - {DEBUG:MainThread} - Geordnete Ladepunkte [2]
2023-11-24 18:19:02,326 - {control.algorithm.additional_current:26} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 0
2023-11-24 18:19:02,327 - {control.counter:169} - {DEBUG:MainThread} - Zähler 0: [32.07, 33.99, 24.689999999999998]A verbleibende Ströme, 20986.7W verbleibende Leistung
2023-11-24 18:19:02,330 - {control.algorithm.common:95} - {INFO:MainThread} - LP2: Stromstärke 10A
2023-11-24 18:19:02,331 - {control.counter:211} - {INFO:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-11-24 18:19:02,332 - {control.counter:457} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-11-24 18:19:02,333 - {control.algorithm.algorithm:43} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-11-24 18:19:02,334 - {control.process:23} - {INFO:MainThread} - # Ladung starten.
2023-11-24 18:19:02,335 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 48 counter 3149745
2023-11-24 18:19:02,337 - {control.process:111} - {INFO:MainThread} - LP2: set current 10 A, state CHARGING_ALLOWED
2023-11-24 18:19:02,339 - {modules.common.component_context:24} - {DEBUG:set current cp2} - Update Komponente ['Ladepunkt']
2023-11-24 18:19:02,344 - {urllib3.connectionpool:227} - {DEBUG:set current cp2} - Starting new HTTP connection (1): 192.168.5.111:80
2023-11-24 18:19:02,363 - {urllib3.connectionpool:452} - {DEBUG:set current cp2} - http://192.168.5.111:80 "POST /connect.php HTTP/1.1" 200 20
2023-11-24 18:19:02,367 - {modules.common.req:11} - {DEBUG:set current cp2} - Get-Response: OK Value:10 accepted
2023-11-24 18:19:02,369 - {control.counter:186} - {INFO:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-11-24 18:19:02,581 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-11-24 18:19:05,619 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2023-11-24 18:19:10,631 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-11-24 18:19:10,633 - {root:74} - {INFO:MainThread} - # ***Start***
