Seite 2 von 8
Re: Rückmeldungen 2.1.7 Release Candidate 1
Verfasst: Mo Feb 03, 2025 2:54 pm
von LenaK
Enyaq60 hat geschrieben: Fr Jan 31, 2025 10:23 am Ich versuche es hier auch nochmal. Trotz der Einstellung "Bezug" wird permanent ins Netz eingespeist.
Ist kein neues Thema, zieht sich seit Version 2.x durch. Habe ich hier ggf. einen Fehler in meiner Konfig?
2025-01-31 11:12:20,256 - {root:69} - {INFO:MainThread} - # ***Start***
2025-01-31 11:12:20,260 - {root:70} - {DEBUG:MainThread} - Threads: [<_MainThread(MainThread, started 1992874368)>, <Thread(Thread-1, started daemon 1967858752)>, <Thread(Internal Chargepoint, started 1953817664)>, <Thread(Subdata, started 1879749696)>, <Thread(Setdata, started 1869608000)>, <Thread(Commands, started 1859122240)>, <Thread(SoC, started 1848636480)>, <Thread(Internal Chargepoint, started 1838150720)>, <Thread(Modbus Control Server, started 1827664960)>, <Thread(ChargepointStateUpdate cp 0, started 1819272256)>, <Thread(smarthome, started 1810879552)>]
2025-01-31 11:12:20,291 - {modules.common.component_context:58} - {DEBUG:device0} - Update Komponenten ['Kostal Plenticore Wechselrichter', 'Kostal Plenticore Zähler']
2025-01-31 11:12:20,294 - {modules.common.component_context:26} - {DEBUG:device1} - Update Komponente ['Kostal Piko Wechselrichter']
2025-01-31 11:12:20,296 - {modules.common.component_context:26} - {DEBUG:set values cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:20,312 - {urllib3.connectionpool:227} - {DEBUG:device1} - Starting new HTTP connection (1): 192.168.12.45:80
2025-01-31 11:12:20,337 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2603, exported=47961780.0, dc_power=None)
2025-01-31 11:12:20,348 - {urllib3.connectionpool:452} - {DEBUG:device1} - http://192.168.12.45:80 "GET /api/dxs.json?dxsEntries=67109120&dxsEntries=251658753%29 HTTP/1.1" 200 None
2025-01-31 11:12:20,357 - {modules.common.req:32} - {DEBUG:device1} - Get-Response: {"dxsEntries":[{"dxsId":67109120,"value":904.785278},{"dxsId":251658753,"value":18872.375000}],"session":{"sessionId":0,"roleId":0},"status":{"code":0}}
2025-01-31 11:12:20,359 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-904.785278, exported=18872375.0, dc_power=None)
2025-01-31 11:12:20,427 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1738318330.3328047, power=-8.5, imported=1667717.2422773612, exported=4093308.3458864572)
2025-01-31 11:12:20,429 - {modules.common.simcount._calculate:11} - {DEBUG:device0} - time passed: 0.00280397, power1: -8.5, power2: -163.1
2025-01-31 11:12:20,434 - {modules.common.simcount._calculate:27} - {DEBUG:device0} - power did not change sign. Total energy: -0.240581
2025-01-31 11:12:20,439 - {modules.common.simcount._simcount:65} - {DEBUG:device0} - imported: 0 Wh, exported: 0.240581 Wh, new state: SimCounterState(timestamp=1738318340.427106, power=-163.10000610351562, imported=1667717.2422773612, exported=4093308.5864673117)
2025-01-31 11:12:20,442 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[8.112000465393066, -4.1570000648498535, -4.775000095367432], powers=[1811.300048828125, -942.6000366210938, -1078.0], voltages=[227.01600646972656, 229.97801208496094, 228.92501831054688], power_factors=[1.0, 1.0, 1.0], imported=1667717.2422773612, exported=4093308.5864673117, power=-163.10000610351562, frequency=49.974002838134766)
2025-01-31 11:12:20,455 - {modules.common.component_context:26} - {DEBUG:component2} - Update Komponente ['Kostal Plenticore Wechselrichter']
2025-01-31 11:12:20,459 - {modules.common.component_context:26} - {DEBUG:component3} - Update Komponente ['Kostal Piko Wechselrichter']
2025-01-31 11:12:20,462 - {modules.common.store._api:26} - {DEBUG:component2} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2603, exported=47961780.0, dc_power=None)
2025-01-31 11:12:20,466 - {modules.common.component_context:26} - {DEBUG:update values cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:20,470 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-904.785278, exported=18872375.0, dc_power=None)
2025-01-31 11:12:20,472 - {modules.common.store._api:31} - {INFO:component2} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-2603, exported=47961780.0, dc_power=None)
2025-01-31 11:12:20,486 - {modules.common.store._api:31} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-904.785278, exported=18872375.0, dc_power=None)
2025-01-31 11:12:20,539 - {modules.common.component_context:26} - {DEBUG:component9} - Update Komponente ['Kostal Plenticore Zähler']
2025-01-31 11:12:20,540 - {modules.common.store._api:31} - {INFO:component9} - Saving CounterState(currents=[8.112000465393066, -4.1570000648498535, -4.775000095367432], powers=[1811.300048828125, -942.6000366210938, -1078.0], voltages=[227.01600646972656, 229.97801208496094, 228.92501831054688], power_factors=[1.0, 1.0, 1.0], imported=1667717.2422773612, exported=4093308.5864673117, power=-163.10000610351562, frequency=49.974002838134766)
2025-01-31 11:12:20,704 - {control.counter:160} - {INFO:MainThread} - Verbleibende Ströme an Zähler 9: [39.51, 39.16, 39.78]A
2025-01-31 11:12:20,711 - {control.counter:187} - {INFO:MainThread} - Verbleibende Leistung an Zähler 9: 27002.910006103517W
2025-01-31 11:12:20,715 - {control.chargepoint.chargepoint:555} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2025-01-31 11:12:20,746 - {control.chargepoint.chargepoint:705} - {INFO:MainThread} - LP 0, EV: Standard-Fahrzeug (EV-Nr.0): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.INSTANT_CHARGING, Phasen: 1, Priorität: False, max. Ist-Strom: 12.62
2025-01-31 11:12:20,761 - {control.chargepoint.chargepoint:81} - {INFO:MainThread} - LP 0: Ladung evtl. auch ohne PV-Überschuss, da minimaler Dauerstrom aktiv ist.
2025-01-31 11:12:20,777 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1738318330.609526, power=470.5799999999999, imported=3435603.753513669, exported=0)
2025-01-31 11:12:20,796 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00282445, power1: 470.58, power2: 504.88
2025-01-31 11:12:20,798 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 1.37757
2025-01-31 11:12:20,805 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 1.37757 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1738318340.7775545, power=504.8799938964844, imported=3435605.1310838233, exported=0)
2025-01-31 11:12:20,821 - {control.data:238} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=False, power_limit_mode='no_limit'), get=Get(power_limit_controllable=False, soc=0, daily_exported=0.0, daily_imported=0.0, fault_str='Kein Fehler.', fault_state=0, imported=0, exported=0, power=0), set=Set(charging_power_left=0, power_limit=0, regulate_up=False))
2025-01-31 11:12:20,824 - {control.data:239} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=1033.0, daily_exported=0.0, power=2839.81, imported=1036364.01, exported=0))
2025-01-31 11:12:20,827 - {control.data:268} - {INFO:MainThread} - cp0
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, current_plan=None, failed_phase_switches=1, imported_at_plan_start=None, imported_instant_charging=1035214.97, limit=', da die maximale Leistung an Zähler {} erreicht ist.', min_current=6, phases=1, prio=False, required_current=6, required_currents=[6, 0.0, 0.0], state=4, submode=<Chargemode.INSTANT_CHARGING: 'instant_charging'>, timestamp_charge_start=1738317021.730833, timestamp_last_phase_switch=1738317005.082279, timestamp_switch_on_off=None), get=Get(charge_state=True, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[12.62, 0.0, 0.0], daily_imported=1033.0, daily_exported=0.0, error_timestamp=None, evse_current=13, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=1036364.01, max_evse_current=32, phases_in_use=1, plug_state=True, power=2839.81, rfid_timestamp=None, rfid=None, serial_number='230782745', soc=None, soc_timestamp=None, state_str='Ladung evtl. auch ohne PV-Überschuss, da minimaler Dauerstrom aktiv ist.', vehicle_id=None, voltages=[225.45, 230.38, 229.23]), set=Set(charging_ev=0, charging_ev_prev=0, current=13.86, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', costs=0.0395, imported_at_mode_switch=1035371.95, imported_at_plugtime=1035214.97, imported_since_mode_switch=984.0100000000093, imported_since_plugged=1140.9899999999907, range_charged=4.920050000000047, time_charged='0:22', timestamp_start_charging=1738317005.059394, ev=0, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time=1738316920.975898, required_power=1380.0, rfid=None, current_prev=13.86, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6eec7910>, ocpp_transaction_id=None), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=0, ocpp_chargebox_id=None))
2025-01-31 11:12:20,848 - {control.data:268} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), charging_type='AC', id=0, max_current_multi_phases=16, max_current_single_phase=32, dc_max_current=435, name='Standard Ladepunkt-Profil', disable_after_unplug=False, valid_tags=[])
2025-01-31 11:12:20,852 - {control.data:268} - {INFO:MainThread} - counter9
CounterData(config=Config(max_power_errorcase=16000, max_currents=[35, 35, 35], max_total_power=24000), get=Get(powers=[1811.3, -942.6, -1078.0], currents=[8.11, -4.16, -4.78], voltages=[227.02, 229.98, 228.93], power_factors=[1.0, 1.0, 1.0], frequency=49.974002838134766, daily_exported=3604.0, daily_imported=2618.0, imported=1667717.2422773612, exported=4093308.5864673117, fault_state=0, fault_str='Kein Fehler.', power=-163.10000610351562), set=Set(error_timer=None, reserved_surplus=0, released_surplus=0, raw_power_left=27002.910006103517, raw_currents_left=[39.51, 39.16, 39.78], surplus_power_left=0))
2025-01-31 11:12:20,862 - {control.data:243} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(home_consumption_source_id=None, consider_less_charging=False), get=Get(hierarchy=[{'id': 9, 'type': 'counter', 'children': [{'id': 2, 'type': 'inverter', 'children': []}, {'id': 3, 'type': 'inverter', 'children': []}, {'id': 0, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=504.8799938964844, smarthome_power_excluded_from_home_consumption=0, invalid_home_consumption=0, daily_yield_home_consumption=3534.0, imported_home_consumption=3435605.1310838233, disengageable_smarthome_power=0))
2025-01-31 11:12:20,866 - {control.data:268} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Lade-Profil', prio=False, load_default=False, et=Et(active=False, max_price=0.0002), time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, min_soc_current=6, min_current=6, feed_in_limit=False, min_soc=0, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=32, dc_current=145, limit=Limit(selected='none', amount=1000, soc=100))))
2025-01-31 11:12:20,871 - {control.data:268} - {INFO:MainThread} - ev0
EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=None, soc_request_timestamp=None, soc_timestamp=None, force_soc_update=True, range=None, fault_state=0, fault_str='Kein Fehler.'))
2025-01-31 11:12:20,873 - {control.data:268} - {INFO:MainThread} - et0
EvTemplateData(dc_min_current=0, dc_max_current=0, name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=20000, min_current=6, max_current_single_phase=32, battery_capacity=58000, efficiency=95, nominal_difference=2, keep_charge_active_duration=10)
2025-01-31 11:12:20,881 - {control.data:247} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), phase_switch_delay=5, pv_charging=PvCharging(bat_power_reserve=0, bat_power_reserve_active=False, control_range=[0, 230], feed_in_yield=0, phase_switch_delay=7, phases_to_use=1, bat_power_discharge=0, bat_power_discharge_active=False, min_bat_soc=50, bat_mode='ev_mode', switch_off_delay=60, switch_off_threshold=350, switch_on_delay=15, switch_on_threshold=1450), retry_failed_phase_switches=True, scheduled_charging=ScheduledCharging(phases_to_use=0, phases_to_use_pv=0), time_charging=TimeCharging(phases_to_use=3), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp=None, http_api=False, mqtt_bridge=False, prices=Prices(bat=0.0002, cp=0, grid=0.0002807, pv=7.98e-05), range_unit='km', ripple_control_receiver=RippleControlReceiver(get=RippleControlReceiverGet(fault_state=0, fault_str='Kein Fehler.', override_value=100), module=None, override_reference=<OverrideReference.CHARGEPOINT: 'chargepoint'>))
2025-01-31 11:12:20,888 - {control.data:248} - {INFO:MainThread} - general_data-display
local
2025-01-31 11:12:20,891 - {control.data:249} - {INFO:MainThread} - graph_data
2025-01-31 11:12:20,895 - {control.data:250} - {INFO:MainThread} - optional_data
OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=120, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6ee5ea90>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, url=None, version='ocpp1.6'))
2025-01-31 11:12:20,900 - {control.data:268} - {INFO:MainThread} - pv2
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=4280.0, monthly_exported=193984.0, yearly_exported=193984.0, exported=47961780.0, fault_state=0, fault_str='Kein Fehler.', power=-2603))
2025-01-31 11:12:20,908 - {control.data:268} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=1159.0, monthly_exported=92503.90600000322, yearly_exported=92503.90600000322, exported=18872375.0, fault_state=0, fault_str='Kein Fehler.', power=-904.79))
2025-01-31 11:12:20,913 - {control.data:252} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=5439.0, fault_str='Kein Fehler.', fault_state=0, monthly_exported=286487.9060000032, yearly_exported=286487.9060000032, exported=66834155.0, power=-3507.79))
2025-01-31 11:12:20,918 - {control.data:268} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '192.168.12.43', 'current_commit': '2025-01-30 12:29:13 +0100 [1d26a8434]', 'current_branch': 'master', 'current_branch_commit': '2025-01-30 12:29:13 +0100 [1d26a8434]', 'current_missing_commits': [], 'datastore_version': 75, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.7-RC.1', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1738318330, 'time': '11:12:10', 'grid': -0.009, 'house-power': 0.471, 'charging-all': 3.064, 'pv-all': 3.543, 'cp0-power': 3.064}, 'installAssistantDone': True, 'serial_number': '', 'module_update_completed': True, 'mac_address': 'b8:27:eb:33:18:bb'}
2025-01-31 11:12:20,925 - {control.data:281} - {INFO:MainThread} - device0
{'name': 'Kostal Plenticore', 'type': 'kostal_plenticore', 'vendor': 'kostal', 'id': 0, 'configuration': {'modbus_id': 71, 'ip_address': '192.168.12.41', 'port': 1502}}
2025-01-31 11:12:20,930 - {control.data:283} - {INFO:MainThread} - component2
{'name': 'Kostal Plenticore Wechselrichter', 'info': {'manufacturer': None, 'model': None}, 'type': 'inverter', 'id': 2, 'configuration': {}}
2025-01-31 11:12:20,936 - {control.data:283} - {INFO:MainThread} - component9
{'name': 'Kostal Plenticore Zähler', 'info': {'manufacturer': None, 'model': None}, 'type': 'counter', 'id': 9, 'configuration': {}}
2025-01-31 11:12:20,941 - {control.data:281} - {INFO:MainThread} - device1
{'name': 'Kostal Piko', 'vendor': 'kostal', 'type': 'kostal_piko', 'id': 1, 'configuration': {'ip_address': '192.168.12.45'}}
2025-01-31 11:12:20,944 - {control.data:283} - {INFO:MainThread} - component3
{'name': 'Kostal Piko Wechselrichter', 'info': {'manufacturer': None, 'model': None}, 'type': 'inverter', 'id': 3, 'configuration': {'bat_configured': False}}
2025-01-31 11:12:20,950 - {control.data:255} - {INFO:MainThread} -
2025-01-31 11:12:20,952 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2025-01-31 11:12:20,953 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2025-01-31 11:12:20,956 - {control.algorithm.min_current:21} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:20,959 - {control.counter:198} - {DEBUG:MainThread} - Zähler 9: [33.51, 39.16, 39.78]A verbleibende Ströme, 25622.910006103517W verbleibende Leistung
2025-01-31 11:12:20,962 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 6A
2025-01-31 11:12:20,965 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Soll-Strom setzen**
2025-01-31 11:12:20,990 - {control.algorithm.filter_chargepoints:102} - {DEBUG:MainThread} - Geordnete Ladepunkte [0]
2025-01-31 11:12:20,992 - {control.algorithm.additional_current:27} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:20,996 - {control.algorithm.additional_current:32} - {DEBUG:MainThread} - cp 0 available currents [0.0, 0.0, 0.0] missing currents [0.0, 0.0, 0.0] limit None
2025-01-31 11:12:20,999 - {control.algorithm.additional_current:55} - {DEBUG:MainThread} - current 6 target 6 set current None required currents [6, 0.0, 0.0]
2025-01-31 11:12:21,003 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 6A
2025-01-31 11:12:21,005 - {control.counter:248} - {DEBUG:MainThread} - Anpassen des Regelbereichs 115.0W
2025-01-31 11:12:21,008 - {control.counter:514} - {DEBUG:MainThread} - Zähler 9: Begrenzung der verbleibenden Leistung auf 1737.910006103517W
2025-01-31 11:12:21,011 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2025-01-31 11:12:21,016 - {control.algorithm.filter_chargepoints:102} - {DEBUG:MainThread} - Geordnete Ladepunkte [0]
2025-01-31 11:12:21,020 - {control.algorithm.surplus_controlled:49} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:21,025 - {control.loadmanagement:82} - {DEBUG:MainThread} - Leistungsüberschreitung auf 1737.910006103517W korrigieren: [26.0, 0.0, 0.0]
2025-01-31 11:12:21,032 - {control.counter:205} - {DEBUG:MainThread} - Zähler 9: [25.953869538680358, 39.16, 39.78]A verbleibende Ströme, -2.2737367544323206e-13W verbleibender Überschuss
2025-01-31 11:12:21,048 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 13.55613046131964A
2025-01-31 11:12:21,051 - {control.process:26} - {INFO:MainThread} - # Ladung starten.
2025-01-31 11:12:21,054 - {control.process:109} - {INFO:MainThread} - LP0: set current 13.56 A, state CHARGING_ALLOWED
2025-01-31 11:12:21,060 - {modules.common.component_context:26} - {DEBUG:set current cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:21,451 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/power, Payload 2839.81, vorherige Payload: 3063.96
2025-01-31 11:12:21,458 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/imported, Payload 1036364.01, vorherige Payload: 1036355.96
2025-01-31 11:12:21,460 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/home_consumption, Payload 504.8799938964844, vorherige Payload: 470.5799999999999
2025-01-31 11:12:21,463 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/imported_home_consumption, Payload 3435605.1310838233, vorherige Payload: 3435603.753513669
2025-01-31 11:12:25,480 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2025-01-31 11:12:30,495 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2025-01-31 11:12:30,499 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2025-01-31 11:12:30,503 - {root:69} - {INFO:MainThread} - # ***Start***
2025-01-31 11:12:30,507 - {root:70} - {DEBUG:MainThread} - Threads: [<_MainThread(MainThread, started 1992874368)>, <Thread(Thread-1, started daemon 1967858752)>, <Thread(Internal Chargepoint, started 1953817664)>, <Thread(Subdata, started 1879749696)>, <Thread(Setdata, started 1869608000)>, <Thread(Commands, started 1859122240)>, <Thread(SoC, started 1848636480)>, <Thread(Internal Chargepoint, started 1838150720)>, <Thread(Modbus Control Server, started 1827664960)>, <Thread(ChargepointStateUpdate cp 0, started 1819272256)>, <Thread(smarthome, started 1794094144)>]
2025-01-31 11:12:30,540 - {modules.common.component_context:58} - {DEBUG:device0} - Update Komponenten ['Kostal Plenticore Wechselrichter', 'Kostal Plenticore Zähler']
2025-01-31 11:12:30,543 - {modules.common.component_context:26} - {DEBUG:device1} - Update Komponente ['Kostal Piko Wechselrichter']
2025-01-31 11:12:30,550 - {modules.common.component_context:26} - {DEBUG:set values cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:30,552 - {urllib3.connectionpool:227} - {DEBUG:device1} - Starting new HTTP connection (1): 192.168.12.45:80
2025-01-31 11:12:30,571 - {urllib3.connectionpool:452} - {DEBUG:device1} - http://192.168.12.45:80 "GET /api/dxs.json?dxsEntries=67109120&dxsEntries=251658753%29 HTTP/1.1" 200 None
2025-01-31 11:12:30,593 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2563, exported=47961780.0, dc_power=None)
2025-01-31 11:12:30,605 - {modules.common.req:32} - {DEBUG:device1} - Get-Response: {"dxsEntries":[{"dxsId":67109120,"value":889.687378},{"dxsId":251658753,"value":18872.375000}],"session":{"sessionId":0,"roleId":0},"status":{"code":0}}
2025-01-31 11:12:30,608 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-889.687378, exported=18872375.0, dc_power=None)
2025-01-31 11:12:30,692 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1738318340.427106, power=-163.10000610351562, imported=1667717.2422773612, exported=4093308.5864673117)
2025-01-31 11:12:30,694 - {modules.common.simcount._calculate:11} - {DEBUG:device0} - time passed: 0.00285144, power1: -163.1, power2: -146.5
2025-01-31 11:12:30,695 - {modules.common.simcount._calculate:27} - {DEBUG:device0} - power did not change sign. Total energy: -0.441403
2025-01-31 11:12:30,696 - {modules.common.simcount._simcount:65} - {DEBUG:device0} - imported: 0 Wh, exported: 0.441403 Wh, new state: SimCounterState(timestamp=1738318350.692288, power=-146.5, imported=1667717.2422773612, exported=4093309.027870147)
2025-01-31 11:12:30,699 - {modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(currents=[8.181000709533691, -4.095000267028809, -4.677000045776367], powers=[1830.4000244140625, -926.4000244140625, -1057.5999755859375], voltages=[226.843017578125, 229.79800415039062, 228.79600524902344], power_factors=[1.0, 1.0, 1.0], imported=1667717.2422773612, exported=4093309.027870147, power=-146.5, frequency=49.970001220703125)
2025-01-31 11:12:30,719 - {modules.common.component_context:26} - {DEBUG:component2} - Update Komponente ['Kostal Plenticore Wechselrichter']
2025-01-31 11:12:30,721 - {modules.common.store._api:26} - {DEBUG:component2} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-2563, exported=47961780.0, dc_power=None)
2025-01-31 11:12:30,723 - {modules.common.component_context:26} - {DEBUG:component3} - Update Komponente ['Kostal Piko Wechselrichter']
2025-01-31 11:12:30,725 - {modules.common.store._api:31} - {INFO:component2} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-2563, exported=47961780.0, dc_power=None)
2025-01-31 11:12:30,727 - {modules.common.component_context:26} - {DEBUG:update values cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:30,730 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-889.687378, exported=18872375.0, dc_power=None)
2025-01-31 11:12:30,743 - {modules.common.store._api:31} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-889.687378, exported=18872375.0, dc_power=None)
2025-01-31 11:12:30,793 - {modules.common.component_context:26} - {DEBUG:component9} - Update Komponente ['Kostal Plenticore Zähler']
2025-01-31 11:12:30,794 - {modules.common.store._api:31} - {INFO:component9} - Saving CounterState(currents=[8.181000709533691, -4.095000267028809, -4.677000045776367], powers=[1830.4000244140625, -926.4000244140625, -1057.5999755859375], voltages=[226.843017578125, 229.79800415039062, 228.79600524902344], power_factors=[1.0, 1.0, 1.0], imported=1667717.2422773612, exported=4093309.027870147, power=-146.5, frequency=49.970001220703125)
2025-01-31 11:12:30,959 - {control.counter:160} - {INFO:MainThread} - Verbleibende Ströme an Zähler 9: [39.46, 39.1, 39.68]A
2025-01-31 11:12:30,961 - {control.counter:187} - {INFO:MainThread} - Verbleibende Leistung an Zähler 9: 26984.989999999998W
2025-01-31 11:12:30,967 - {control.chargepoint.chargepoint:555} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2025-01-31 11:12:30,971 - {control.chargepoint.chargepoint:705} - {INFO:MainThread} - LP 0, EV: Standard-Fahrzeug (EV-Nr.0): Theoretisch benötigter Strom 6A, Lademodus pv_charging, Submodus: Chargemode.INSTANT_CHARGING, Phasen: 1, Priorität: False, max. Ist-Strom: 12.64
2025-01-31 11:12:30,973 - {control.chargepoint.chargepoint:81} - {INFO:MainThread} - LP 0: Ladung evtl. auch ohne PV-Überschuss, da minimaler Dauerstrom aktiv ist.
2025-01-31 11:12:30,976 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1738318340.7775545, power=504.8799938964844, imported=3435605.1310838233, exported=0)
2025-01-31 11:12:30,980 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00283303, power1: 504.88, power2: 467.7
2025-01-31 11:12:30,982 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 1.37767
2025-01-31 11:12:30,988 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 1.37767 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1738318350.9764528, power=467.7000000000003, imported=3435606.508756665, exported=0)
2025-01-31 11:12:30,996 - {control.data:238} - {INFO:MainThread} - bat_all_data
2025-01-31 11:12:30,999 - {control.data:239} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=1033.0, daily_exported=0.0, power=2838.49, imported=1036373.05, exported=0))
2025-01-31 11:12:31,005 - {control.data:268} - {INFO:MainThread} - cp0
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.PV_CHARGING: 'pv_charging'>, current_plan=None, failed_phase_switches=1, imported_at_plan_start=None, imported_instant_charging=1035214.97, limit=', da die maximale Leistung an Zähler {} erreicht ist.', min_current=6, phases=1, prio=False, required_current=6, required_currents=[6, 0.0, 0.0], state=4, submode=<Chargemode.INSTANT_CHARGING: 'instant_charging'>, timestamp_charge_start=1738317021.730833, timestamp_last_phase_switch=1738317005.082279, timestamp_switch_on_off=None), get=Get(charge_state=True, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[12.64, 0.0, 0.0], daily_imported=1033.0, daily_exported=0.0, error_timestamp=None, evse_current=13, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=1036373.05, max_evse_current=32, phases_in_use=1, plug_state=True, power=2838.49, rfid_timestamp=None, rfid=None, serial_number='230782745', soc=None, soc_timestamp=None, state_str='Ladung evtl. auch ohne PV-Überschuss, da minimaler Dauerstrom aktiv ist.', vehicle_id=None, voltages=[225.22, 230.17, 228.96]), set=Set(charging_ev=0, charging_ev_prev=0, current=13.56, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='pv_charging', costs=0.0395, imported_at_mode_switch=1035371.95, imported_at_plugtime=1035214.97, imported_since_mode_switch=992.0600000000559, imported_since_plugged=1149.0400000000373, range_charged=4.960300000000279, time_charged='0:22', timestamp_start_charging=1738317005.059394, ev=0, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time=1738316920.975898, required_power=1380.0, rfid=None, current_prev=13.56, target_current=0, charging_ev_data=<control.ev.ev.Ev object at 0x6eec6ac0>, ocpp_transaction_id=None), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=0, name='openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=0, ocpp_chargebox_id=None))
2025-01-31 11:12:31,015 - {control.data:268} - {INFO:MainThread} - cpt0
2025-01-31 11:12:31,019 - {control.data:268} - {INFO:MainThread} - counter9
CounterData(config=Config(max_power_errorcase=16000, max_currents=[35, 35, 35], max_total_power=24000), get=Get(powers=[1830.4, -926.4, -1057.6], currents=[8.18, -4.1, -4.68], voltages=[226.84, 229.8, 228.8], power_factors=[1.0, 1.0, 1.0], frequency=49.970001220703125, daily_exported=3604.0, daily_imported=2618.0, imported=1667717.2422773612, exported=4093309.027870147, fault_state=0, fault_str='Kein Fehler.', power=-146.5), set=Set(error_timer=None, reserved_surplus=0, released_surplus=0, raw_power_left=26984.989999999998, raw_currents_left=[39.46, 39.1, 39.68], surplus_power_left=0))
2025-01-31 11:12:31,025 - {control.data:243} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(home_consumption_source_id=None, consider_less_charging=False), get=Get(hierarchy=[{'id': 9, 'type': 'counter', 'children': [{'id': 2, 'type': 'inverter', 'children': []}, {'id': 3, 'type': 'inverter', 'children': []}, {'id': 0, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=467.7000000000003, smarthome_power_excluded_from_home_consumption=0, invalid_home_consumption=0, daily_yield_home_consumption=3534.0, imported_home_consumption=3435606.508756665, disengageable_smarthome_power=0))
2025-01-31 11:12:31,030 - {control.data:268} - {INFO:MainThread} - ct0
2025-01-31 11:12:31,049 - {control.data:268} - {INFO:MainThread} - ev0
2025-01-31 11:12:31,051 - {control.data:268} - {INFO:MainThread} - et0
2025-01-31 11:12:31,058 - {control.data:247} - {INFO:MainThread} - general_data
2025-01-31 11:12:31,076 - {control.data:248} - {INFO:MainThread} - general_data-display
local
2025-01-31 11:12:31,084 - {control.data:249} - {INFO:MainThread} - graph_data
2025-01-31 11:12:31,089 - {control.data:250} - {INFO:MainThread} - optional_data
OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=120, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6eec6c88>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False, ocpp=Ocpp(active=False, boot_notification_sent=False, url=None, version='ocpp1.6'))
2025-01-31 11:12:31,094 - {control.data:268} - {INFO:MainThread} - pv2
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=4280.0, monthly_exported=193984.0, yearly_exported=193984.0, exported=47961780.0, fault_state=0, fault_str='Kein Fehler.', power=-2563))
2025-01-31 11:12:31,096 - {control.data:268} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=0), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=1159.0, monthly_exported=92503.90600000322, yearly_exported=92503.90600000322, exported=18872375.0, fault_state=0, fault_str='Kein Fehler.', power=-889.69))
2025-01-31 11:12:31,101 - {control.data:252} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=5439.0, fault_str='Kein Fehler.', fault_state=0, monthly_exported=286487.9060000032, yearly_exported=286487.9060000032, exported=66834155.0, power=-3452.69))
2025-01-31 11:12:31,107 - {control.data:268} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'ip_address': '192.168.12.43', 'current_commit': '2025-01-30 12:29:13 +0100 [1d26a8434]', 'current_branch': 'master', 'current_branch_commit': '2025-01-30 12:29:13 +0100 [1d26a8434]', 'current_missing_commits': [], 'datastore_version': 75, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'release_train': 'master', 'version': '2.1.7-RC.1', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1738318341, 'time': '11:12:21', 'grid': -0.163, 'house-power': 0.505, 'charging-all': 2.84, 'pv-all': 3.508, 'cp0-power': 2.84}, 'installAssistantDone': True, 'serial_number': '', 'module_update_completed': True, 'mac_address': 'b8:27:eb:33:18:bb'}
2025-01-31 11:12:31,115 - {control.data:281} - {INFO:MainThread} - device0
2025-01-31 11:12:31,117 - {control.data:283} - {INFO:MainThread} - component2
2025-01-31 11:12:31,119 - {control.data:283} - {INFO:MainThread} - component9
2025-01-31 11:12:31,122 - {control.data:281} - {INFO:MainThread} - device1
2025-01-31 11:12:31,129 - {control.data:283} - {INFO:MainThread} - component3
2025-01-31 11:12:31,133 - {control.data:255} - {INFO:MainThread} -
2025-01-31 11:12:31,135 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2025-01-31 11:12:31,137 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2025-01-31 11:12:31,140 - {control.algorithm.min_current:21} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:31,142 - {control.counter:198} - {DEBUG:MainThread} - Zähler 9: [33.46, 39.1, 39.68]A verbleibende Ströme, 25604.989999999998W verbleibende Leistung
2025-01-31 11:12:31,144 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 6A
2025-01-31 11:12:31,146 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Soll-Strom setzen**
2025-01-31 11:12:31,149 - {control.algorithm.filter_chargepoints:102} - {DEBUG:MainThread} - Geordnete Ladepunkte [0]
2025-01-31 11:12:31,152 - {control.algorithm.additional_current:27} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:31,153 - {control.algorithm.additional_current:32} - {DEBUG:MainThread} - cp 0 available currents [0.0, 0.0, 0.0] missing currents [0.0, 0.0, 0.0] limit None
2025-01-31 11:12:31,155 - {control.algorithm.additional_current:55} - {DEBUG:MainThread} - current 6 target 6 set current None required currents [6, 0.0, 0.0]
2025-01-31 11:12:31,156 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 6A
2025-01-31 11:12:31,158 - {control.counter:248} - {DEBUG:MainThread} - Anpassen des Regelbereichs 115.0W
2025-01-31 11:12:31,159 - {control.counter:514} - {DEBUG:MainThread} - Zähler 9: Begrenzung der verbleibenden Leistung auf 1719.989999999998W
2025-01-31 11:12:31,161 - {control.algorithm.algorithm:38} - {INFO:MainThread} - **PV-geführten Strom setzen**
2025-01-31 11:12:31,163 - {control.algorithm.filter_chargepoints:102} - {DEBUG:MainThread} - Geordnete Ladepunkte [0]
2025-01-31 11:12:31,164 - {control.algorithm.surplus_controlled:49} - {INFO:MainThread} - Mode-Tuple Chargemode.PV_CHARGING - Chargemode.INSTANT_CHARGING - False, Zähler 9
2025-01-31 11:12:31,166 - {control.loadmanagement:82} - {DEBUG:MainThread} - Leistungsüberschreitung auf 1719.989999999998W korrigieren: [26.0, 0.0, 0.0]
2025-01-31 11:12:31,168 - {control.counter:205} - {DEBUG:MainThread} - Zähler 9: [25.98178260869566, 39.1, 39.68]A verbleibende Ströme, 0.0W verbleibender Überschuss
2025-01-31 11:12:31,169 - {control.algorithm.common:80} - {INFO:MainThread} - LP0: Stromstärke 13.478217391304339A
2025-01-31 11:12:31,172 - {control.process:26} - {INFO:MainThread} - # Ladung starten.
2025-01-31 11:12:31,180 - {control.process:109} - {INFO:MainThread} - LP0: set current 13.48 A, state CHARGING_ALLOWED
2025-01-31 11:12:31,198 - {modules.common.component_context:26} - {DEBUG:set current cp0} - Update Komponente ['Ladepunkt']
2025-01-31 11:12:31,523 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/power, Payload 2838.49, vorherige Payload: 2839.81
2025-01-31 11:12:31,527 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/chargepoint/get/imported, Payload 1036373.05, vorherige Payload: 1036364.01
2025-01-31 11:12:31,534 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/home_consumption, Payload 467.7000000000003, vorherige Payload: 504.8799938964844
2025-01-31 11:12:31,539 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/imported_home_consumption, Payload 3435606.508756665, vorherige Payload: 3435605.1310838233
2025-01-31 11:12:35,553 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2025-01-31 11:12:40,567 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2025-01-31 11:12:40,572 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2025-01-31 11:12:40,575 - {root:69} - {INFO:MainThread} - # ***Start***
Es ist ein Fix im Master.
Verfasst: Mo Feb 03, 2025 6:30 pm
von raffix
Bug: PV-Laden mit Mindest-SoC lädt bei automatischer Phasenumschaltung nicht mehr mit 3 Phasen wie früher
Detail: Wenn in den Ladeeinstellungen - PV-Laden die Phasenumschaltung auf Automatik steht, wurde früher wenn der Mindest-SoC noch nicht erreicht war mit der eingestellten Phasenzahl 3-phasig geladen. Jetzt wird nur noch mit einer Phase geladen.
Im angehängten Detail-Log sieht man diesen Effekt. Das Laden startet um 18:29 mit einer Phase. Ich hab dann um 18:33 Uhr manuell auf 3-phasiges Laden (Ladeinstellungen - PV-Laden - Phaenumschaltung - Anzahl Phasen - Maximum) umgestellt, damit das Laden nicht so lange dauert.
main.log.2.gz
(892.83 KiB) 106-mal heruntergeladen
main.log.1.gz
(988.43 KiB) 103-mal heruntergeladen
Verfasst: Di Feb 04, 2025 10:36 am
von raffix
Bug: Nach Ende von Zielladen (3-phasig) wird nicht direkt abgeschaltet.
Detail: Wenn der SoC mit Zielladen (3-phasig) erreicht ist, wird das Laden nicht direkt beendet, sondern zunächst auf 1-phasig umgeschaltet, kurz weitergeladen und dann erst abgeschaltet.
Erwartetes Verhalten: Zielladen stoppt direkt, also schaltet nicht um auf 1 Phase. Generell wäre meine Erwartung, dass _immer_ bei der aktuellen Phasenzahl geblieben wird bis eine Umschaltung erforderlich ist.
Im angehängten Detail-Log sieht man diesen Effekt. Das Laden startet um 11:11 Uhr direkt mit drei Phasen. Um 11:26 Uhr war der Zielwert erreicht, es folgte das Umschalten auf 1 Phase, dann kurzes Weiterladen, dann Abbruch.
main.log.gz
(516.96 KiB) 87-mal heruntergeladen
main.log.1.gz
(1009.8 KiB) 84-mal heruntergeladen
Verfasst: Mi Feb 05, 2025 3:58 pm
von raudi
Vorhin habe ich wieder gesteckt, aber irgendwas wurde nicht erkannt.
Muss so gegen 16:15 gewesen sein, als ich nach hause kam und den Stecker gesteckt habe, im Display vom PKW wurde der Akku-Stand angezeigt, also Stecker wurde eigentlich korrekt gesteckt.
Als ich dann ca. 30 Minuten Später auf die Web-GUI geschaut habe, war der Stecker nur gelb und er hat nicht geladen, der SoC war auf irgendwas um die 95%, da wo er zuletzt aufgehört hat. Am PKW hat nichts geleuchtet, kein Licht am Stecker. Ich konnte den Stecker so ziehen, er war nicht verriegelt.
Eben gegen 16:40 habe ich dann erneut angesteckt und dieses mal wurde der SoC erkannt und er hat begonnen zu laden.
Logs folgen, ich bin hier am Firmen PC angemeldet, da scheint die Paste-Seite irgendwie nicht zu funktionieren, ich kann einfügen, speichern, aber der Link landet nicht in der Zwischenablage, da ist dann nach wie vor das Log. Ich habe die Logs gespeichert und werde gleich einen anderen PC testen.
Nachtrag:
An meinem anderen PC funktioniert das auch nicht. irgendwie scheint die "paste.openwb.de" defekt zu sein. Ich war auch der Meinung, dass beim Speichern früher immer der URL oben in der Adresszeile stand und man dieses auch manuell kopieren konnte, aber das ist nun auch nicht der Fall.
Nachtrag 2: :)
Da auch nur das Main-Log gezippt über 3 MB ist, habe ich einen Systembericht erstellen lassen, dieser hat das Ticket #34471840 bekommen.
Verfasst: Do Feb 06, 2025 6:12 am
von Bogie
ich lade in der Nacht meinen Speicher (mit 5kW= 8A/Ph.) und wollte paralell mein Fzg. mit 12A laden.
Also zusammen 20A + Haus (3A) = 23A
Das Lastmanagement ist auf 30A eingestellt.
Trotzdem bekamm ich die Meldung, dass der maximale Strom im Solaredge-Zähler zu hoch ist und der Ladestrom reduziert wurde.
Der angezeigte Strom im Zähler lag aber weit unter dem max. Strom. Das Lastmanagement hätte nicht eingreifen müssen.
Es wurde auch nur mit 1P anstatt 3P geladen.
Mit 2.1.6 hat das noch funktioniert. (meine ich)
Hier mal ein Auszug aus dem Log:
Es wird ein ungültiger Hausverbrauch (Minus) gemeldet.
Kommt das Lastmanagement evt. nicht damit klar, dass der Speicher aus dem Netz geladen wird?
2025-02-06 00:01:00,322 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 00:01:01,041 - {control.counter_all:107} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -2731.09W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2025-02-06 00:01:10,483 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 00:02:45,091 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 00:05:00,595 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 366 gefunden.
2025-02-06 00:05:01,878 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 366 gefunden.
2025-02-06 00:10:00,852 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 194 gefunden.
2025-02-06 00:10:02,079 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 194 gefunden.
2025-02-06 00:40:00,694 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 198 gefunden.
2025-02-06 00:40:01,959 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 198 gefunden.
2025-02-06 00:45:00,706 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 35 gefunden.
2025-02-06 00:45:01,955 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 35 gefunden.
2025-02-06 00:48:41,624 - {control.counter_all:107} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -954.4700000000003W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2025-02-06 00:55:00,850 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 00:55:02,136 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 01:05:00,506 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 198 gefunden.
2025-02-06 01:05:01,773 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 198 gefunden.
2025-02-06 01:12:21,776 - {control.counter_all:107} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -1174.8199999999997W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2025-02-06 01:15:00,569 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 199 gefunden.
2025-02-06 01:15:01,886 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 199 gefunden.
2025-02-06 01:17:54,251 - {helpermodules.setdata:379} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/optional/dc_charging, False
2025-02-06 01:19:20,738 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 01:20:00,793 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 199 gefunden.
2025-02-06 01:20:02,106 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 199 gefunden.
2025-02-06 01:22:03,814 - {helpermodules.utils._thread_handler:33} - {ERROR:MainThread} - device0 konnte nicht innerhalb des Timeouts abgearbeitet werden.
2025-02-06 01:22:03,816 - {modules.common.utils.component_parser:25} - {ERROR:MainThread} - Keine aktuellen Werte für Gerät SolarEdge
2025-02-06 01:22:03,826 - {modules.common.utils.component_parser:25} - {ERROR:MainThread} - Keine aktuellen Werte für Gerät SolarEdge
2025-02-06 01:22:03,838 - {modules.common.utils.component_parser:25} - {ERROR:MainThread} - Keine aktuellen Werte für Gerät SolarEdge
2025-02-06 01:24:40,934 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 01:24:40,937 - {helpermodules.utils._thread_handler:40} - {ERROR:MainThread} - Thread smarthome ist bereits aktiv und wird nicht erneut gestartet.
2025-02-06 01:25:00,625 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 01:25:01,972 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 01:29:32,026 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:29:41,262 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:30:00,707 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 01:30:01,984 - {helpermodules.setdata:389} - {WARNING:Setdata} - Keine ID  mit gültiger Konfiguration für Topic openWB/set/counter/set/smarthome_power_excluded_from_home_consumption mit Payload 197 gefunden.
2025-02-06 01:30:31,513 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:30:41,779 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:30:52,093 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:31:01,496 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:31:11,676 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:31:22,014 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:31:31,261 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:31:41,479 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:32:11,009 - {control.counter_all:107} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -62.659999999999854W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2025-02-06 01:32:21,877 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:32:32,238 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:32:41,558 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:32:51,889 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:33:02,192 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:33:11,491 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:33:21,713 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:33:29,916 - {helpermodules.setdata:379} - {ERROR:Setdata} - Unbekanntes set-Topic: openWB/set/optional/dc_charging, False
2025-02-06 01:33:32,272 - {helpermodules.setdata:338} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/chargepoint/3/control_parameter/failed_phase_switches, Payload 5 liegt in keinem der angegebenen Wertebereiche.
2025-02-06 01:33:41,500 - {helper
Verfasst: Fr Feb 07, 2025 1:42 pm
von mrinas
Aktuell laden beide Fahrzeuge, eins an der Series 2, das andere an der Pro. PV Produktion schwankt ein wenig durch den Hochnebel.
Derzeit gibts starke Schwingungen im Ladestrom der Pro, was zu deutlicher Speicherentnahme während des Ladevorgangs führt. Das ist m.w. kein neues Verhalten mit dieser speziellen Version, es kommt lediglich wieder mehr Ertrag vom Dach.
Ich vermute dass die Messwerte der Pro etwas verzögert ankommen (ein Regelzyklus?) - konnte das an anderer Stelle schon beobachten. Z.b. bei Ladestopp sehe ich 0A Ladestromvorgabe, Ladeleistung wird für den Ladepunkt aber noch für 1-2 Regelzyklen angezeigt wenngleich defakto nicht mehr geladen wird, was ich z.b. am EVU Zähler in der openWB so auch sehe.
Kann das hier auch die Ursache für das Schwingen sein? Und gibts eine Idee was man dagegen tun könnte? Wie gesagt nix was jetzt erst neu aufgetreten wäre, und daher auch nicht ultra dringend. Aber es wäre gut wenn man hier perspektivisch etwas machen könnte. Hab' die weiteren Logs (main log 1-4) auch noch gesichert, kann die auch gern noch teilen falls notwendig.
Verfasst: Fr Feb 07, 2025 2:28 pm
von mrinas
zwei weitere Beobachtungen.
1) Ladung an der Series2 beendet, Ladestrom an der Pro ist nun stabiler und schwingt nicht mehr so stark.
2) Während des Ladevorgangs an beiden Ladepunkten wird der Hausverbrauch als stark fluktuierend berechnet, dem ist nicht der Fall. Hausverbrauch ist tagsüber relativ stetig irgendwo zwischen 400W und 500W. Könnte auf meine These mit Datenlatenz der openWB Pro einzahlen.
Screenshot 2025-02-07 152605.png (35.45 KiB) 2937 mal betrachtet
noch ein weitere Screenshot, man sieht dass der Hausverbrauch ohne Ladevorgang sehr konstant ist. Während des Ladevorgangs ist der unruhig, und zwar immer wenn sich die Ladeleistung verändert.
Screenshot 2025-02-07 155541.png (164.28 KiB) 2917 mal betrachtet
Verfasst: Sa Feb 08, 2025 9:19 am
von _daniel
raffix hat geschrieben: Mo Feb 03, 2025 6:30 pm Bug: PV-Laden mit Mindest-SoC lädt bei automatischer Phasenumschaltung nicht mehr mit 3 Phasen wie früher
Irgendwo in den tiefen des Forums hatte ich gelesen, dass das ein Feature ist.
Für mich auch schade, den mindestens SoC erreich ich oft nicht mit einphasig.
Lösung dürfte Ziel- oder Zeitladen sein. Das kommt für mich aber nicht in Frage.
Nix gegen die Konzepte, das Team hat bestimmt mehr Usecases im Blick als ich und muss entsprechend Entscheidungen treffen.
Hoffe, das 3phasiges Laden auch wieder kommt.
Oder beim Sofortladen halt ein Überschuss-SoC-Schieber ähnlich Zielladen ergänzt wird.
Verfasst: Sa Feb 08, 2025 9:27 am
von openWB
Wenn das dein Problem löst, was spricht dagegen?
Verfasst: Sa Feb 08, 2025 9:53 am
von Gero
_daniel hat geschrieben: Sa Feb 08, 2025 9:19 am
Wohl eher ein unerwünschtes Feature, welches demnächst korrigiert werden soll. Ich hatte das schon ein paar Mal gemeldet und auf eine Neumeldung - in der ich auch meint, dass das schon mal korrigiert wurde - die Antwort erhalten, dass das noch gar nicht gefixt wurde.
aktueller Stand ist: Mindst-SoC wird aktuell einphasig geladen. Dreiphasig irgendwann demnächst.
