Rückmeldungen 2.1.2 Beta 2
Has thanked: 43 times
Been thanked: 257 times
Re: Rückmeldungen 2.1.2 Beta 2
Ich hätte ja das update.log vermutet, das hatte ich ja schon damals gepostet. Hier aber nochmal die verdächtige Fehlermeldung (ich meine die hatte ich schon mal in dem Alpha-Thread gepostet):
Release: {"1.99.002":"1.99.002: Alpha 2","1.99.003":"1.99.003: Alpha 3","1.99.004":"1.99.004: Alpha 4","1.99.100":"1.99.100: Beta 1","1.99.100.1":"1.99.100.1: Beta.2-RC1","1.99.101.0":"1.99.101.0: Beta 2","1.99.102.0":"1.99.102.0: Beta 3","1.99.103.0":"1.99.103.0: Beta 4","1.99.RC1.0":"1.99.RC1.0: Release Candidate 1","1.99.RC2.0":"1.99.RC2.0: Release Candidate 2","2.0.0":"2.0.0: Release 2.0.0","2.1.0":"2.1.0: 2.1.0 Release","2.1.1":"2.1.1: 2.1.1 Release","2.1.1-Beta.1":"2.1.1-Beta.1: 2.1.1 Beta 1","2.1.1-Beta.2":"2.1.1-Beta.2: 2.1.1 Beta 2","2.1.1-Beta.3":"2.1.1-Beta.3: 2.1.1 Beta 3"}
checking commit for origin/aiohttp-3.8.5...fatal: ambiguous argument 'origin/aiohttp-3.8.5': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
tags in branch:
fatal: malformed object name origin/aiohttp-3.8.5
Und dann findet sich im Main.log wiederkehrend das hier.
2023-11-14 16:37:20,517 - {modules.common.fault_state:55} - {ERROR:set current cp4} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr <class 'ValueError'> Invalid host., Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 35, in set_current
    pub.pub_single("openWB/set/isss/Lp2Current", current,
  File "/var/www/html/openWB/packages/helpermodules/utils/error_counter.py", line 22, in __exit__
    raise exception
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 28, in set_current
    pub.pub_single("openWB/set/internal_chargepoint/0/data/set_current", current,
  File "/var/www/html/openWB/packages/helpermodules/pub.py", line 51, in pub_single
    publish.single(topic, json.dumps(payload), hostname=hostname, port=port, retain=retain)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 240, in single
    multiple([msg], hostname, port, client_id, keepalive, will, auth, tls,
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 176, in multiple
    client.connect(hostname, port, keepalive)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 912, in connect
    self.connect_async(host, port, keepalive,
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 978, in connect_async
    raise ValueError('Invalid host.')
ValueError: Invalid host.
kill: (462): No such process
seems like atreboot.sh finished normally
Der invalid host kommt wohl vom Setzen des Ladestroms. Erstaunlicherweise lud gestern ein angestecktes Auto mit 10,4kW. Und es kommen seit einer knappen Stunde keine weiteren Einträge ins log.
Klausiy123
Has thanked: 6 times
Beitrag von Klausiy123 »
Hallo, ich hab das "Problem" es wird im Ladeprotokoll der falsche Preis für meinen Tibber Tarif angezeigt, statt 13,xx € sehe ich z.B. 89,xx€. Ein Luxusproblem, aber wäre schön wenn das wieder passt, ich kann den auch nicht ändern. Der Tibber Tarif ist hinterlegt.
Has thanked: 19 times
Been thanked: 136 times
@Gero
Das hat alles nichts mir der Meldung zu den Python Paketen zu tun. Die müsste reproduzierbar nach dem Booten kommen und dann auch am Anfang des Main Log zu sehen sein.
LutzB hat geschrieben: Di Nov 14, 2023 6:16 pm @Gero
Na dann ist es wohl das hier:
mosquitto done
install required python packages with 'pip3'...
  File "/usr/bin/pip3", line 33, in <module>
    sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
  File "/usr/bin/pip3", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 790, in exec_module
  File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
    from pip._internal.cli.autocompletion import autocomplete
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
    from pip._internal.cli.main_parser import create_main_parser
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
    from pip._internal.cli import cmdoptions
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
    from pip._vendor.packaging.utils import canonicalize_name
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
    vendored("requests.packages.urllib3.contrib.pyopenssl")
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
    __import__(modulename, globals(), locals(), level=0)
  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
  File "<frozen zipimport>", line 259, in load_module
  File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
  File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
    class X509StoreFlags(object):
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1577, in X509StoreFlags
    CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
failed!
load versions...
chgrp: cannot access '/var/www/html/openWB/data/restore/*': No such file or directory
chgrp: cannot access '/var/www/html/openWB/data/data_migration/*': No such file or directory
chmod: cannot access '/var/www/html/openWB/data/restore/*': No such file or directory
chmod: cannot access '/var/www/html/openWB/data/data_migration/*': No such file or directory
2023-11-14 19:22:44: boot done :-)
Das muss ja aus dem aktuellen Repository kommen, denn auf meiner anderen Installation hatte ich die Fehlermeldung auch. Da hatte ich aber ein paar Mal den Entwicklungszweig gewechselt. Das hier ist eine komplett neu aufgesetzte Installation.
Was für ein OS Image nutzt Du?
LutzB hat geschrieben: Di Nov 14, 2023 7:08 pm Was für ein OS Image nutzt Du?
Raspian Bullseye. Mit dem Raspberry Imager auf die SD-Karte installiert.
Zuletzt geändert von Gero am Do Nov 16, 2023 8:02 am, insgesamt 1-mal geändert.
Klausiy123
Als zweites Problem, wenn ich aus dem Ladelog, Konfiguration oder ähnliches auf openwb tippe, lande ich auf der Seite http://192.168.178.xx/openWB/web/index.php mit dem Hinweis:
Not Found
The requested URL was not found on this server.
Apache/2.4.56 (Raspbian) Server at 192.168.178.xx Port 80
Erst wenn ich die URL von Hand auf
http://192.168.178.xx/openWB/web/themes/colors
ändere, passt es wieder.
Besten Dank
Candid
Has thanked: 3 times
Beitrag von Candid »
Frage zum Zielladen. Hier kann ich nur den max. Strom einstellen (bis 32 A) aber nicht ob 1 oder mehrphasig. Es scheint, dass er immer nur 1-phasig lädt. Wenn ich also 30 A einstelle würde per Schieflast vom EVU geladen werden?
Meine Konfig:
openWB series2 standard+, openWB Pro
E3DC S10 E Pro
Zusatzwechselrichter E3DC SWR12PR
Tesla Model 3, Renault R5 E-Tech
Nasdero
Beitrag von Nasdero »
Candid hat geschrieben: Do Nov 16, 2023 6:15 am Frage zum Zielladen. Hier kann ich nur den max. Strom einstellen (bis 32 A) aber nicht ob 1 oder mehrphasig. Es scheint, dass er immer nur 1-phasig lädt. Wenn ich also 30 A einstelle würde per Schieflast vom EVU geladen werden?
unter "Ladeeinstellungen - Zielladen" :
Hier kann eingestellt werden, ob Ladevorgänge im Modus "Zielladen" mit nur einer Phase oder dem möglichen Maximum in Abhängigkeit der "Ladepunkt"- und "Fahrzeug"-Einstellungen durchgeführt werden. Im Modus "Automatik" entscheidet die Regelung, welche Einstellung genutzt wird, um das Ziel zu erreichen. Voraussetzung ist die verbaute Umschaltmöglichkeit zwischen 1- und 3-phasig (s.g. 1p3p).
unter "Ladeeinstellungen - Übergreifendes"
Wenn diese Option aktiviert ist, werden nicht-dreiphasige Ladevorgänge so geregelt, dass am Netzanschlusspunkt (EVU-Zähler) die eingestellte Grenze für die Schieflast nicht überschritten wird. Hierfür muss der EVU-Zähler einzelne Phasenströme bereitstellen!
Weiterhin müssen bei den Ladepunkten sowie Fahrzeugen sämtliche Angaben zur Anzahl angeschlossener/unterstützter Phasen und der Phasenrotation hinterlegt werden, damit der Regelung bekannt ist, welcher Ladevorgang welche Phase am Netzanschluss beeinflusst. siehe "Konfiguration - Ladepunkte -> elektrischer Anschluss - Phase 1" und "Konfiguration - Fahrzeuge -> Fahrzeug-Profile"
Dort kannst du einstellen was du brauchst
LarsBr87
Has thanked: 5 times
Beitrag von LarsBr87 »
ich weiss nicht so recht, ob es hier her gehört, aber wäre es möglich den Pullrequest #1231 freizugeben?
Wir haben letzte Woche eine Anlage in Betrieb genommen und genau dieses Phänomen, dass die Batterieentladung als PV-Leistung angezeigt wird. Würde den fix gerne testen und Feedback geben.
Lars
