Die Gesamtladeleistung oben rechts ist bei mir oft falsch, siehe Screenshot. Logfile gefällig?
2022-12-01 10:16:30,926 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2022-12-01 10:16:30,926 - {root:62} - {INFO:MainThread} - # ***Start***
2022-12-01 10:16:30,944 - {modules.devices.openwb_flex.device:50} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.openwb_flex.counter.EvuKitFlex object at 0x7f197008f070>}
2022-12-01 10:16:30,944 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['Hauptzähler']
2022-12-01 10:16:30,945 - {modules.devices.virtual.device:40} - {DEBUG:device1} - Start device reading{'component5': <modules.devices.virtual.counter.VirtualCounter object at 0x7f197008fd00>}
2022-12-01 10:16:30,945 - {soc.modules.common.component_context:24} - {DEBUG:device1} - Update Komponente ['Summenbegrenzung alle Wallboxen']
2022-12-01 10:16:30,945 - {modules.devices.sma_webbox.device:44} - {DEBUG:device2} - Start device reading {'component6': <modules.devices.sma_webbox.inverter.SmaWebboxInverter object at 0x7f197008f910>}
2022-12-01 10:16:30,946 - {modules.common.simcount._simcount:38} - {DEBUG:device1} - Previous state: SimCounterState(timestamp=1669889780.3198657, power=0, imported=3.898388769891527, exported=0)
2022-12-01 10:16:30,946 - {soc.modules.common.component_context:24} - {DEBUG:device2} - Update Komponente ['SMA Wechselrichter Webbox']
2022-12-01 10:16:30,946 - {modules.common.simcount._calculate:13} - {DEBUG:device1} - time passed: 0.0029517, power1: 0, power2: 0
2022-12-01 10:16:30,949 - {modules.common.simcount._calculate:29} - {DEBUG:device1} - power did not change sign. Total energy: 0
2022-12-01 10:16:30,949 - {modules.common.simcount._simcount:47} - {DEBUG:device1} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1669889790.9459755, power=0, imported=3.898388769891527, exported=0)
2022-12-01 10:16:30,948 - {urllib3.connectionpool:227} - {DEBUG:device2} - Starting new HTTP connection (1): 10.10.101.251:80
2022-12-01 10:16:30,946 - {soc.modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:30,946 - {soc.modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:30,949 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:30,949 - {soc.modules.common.store._api:26} - {DEBUG:device1} - Raw data CounterState(voltages=[230.0, 230.0, 230.0], powers=[0.0, 0.0, 0.0], currents=[0.0, 0.0, 0.0], power_factors=[0.0, 0.0, 0.0], imported=3.898388769891527, exported=0, power=0, frequency=50)
2022-12-01 10:16:30,949 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,081 - {urllib3.connectionpool:452} - {DEBUG:device2} - http://10.10.101.251:80 "POST /rpc HTTP/1.1" 200 395
2022-12-01 10:16:31,082 - {soc.modules.common.req:11} - {DEBUG:device2} - Get-Response: {"result":{"overview":[{"meta":"GriPwr","name":"Leistung","unit":"W","value":"899"},{"meta":"GriEgyTdy","name":"Tagesertrag","unit":"kWh","value":"1.262"},{"meta":"GriEgyTot","name":"Gesamtertrag","unit":"kWh","value":"147911.793"},{"meta":"OpStt","name":"Zustand","value":"Ok, Ok"},{"meta":"Msg","name":"Meldung","value":""}]},"format":"JSON","proc":"GetPlantOverview","version":"1.0","id":"1"}
2022-12-01 10:16:31,082 - {soc.modules.common.store._api:26} - {DEBUG:device2} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-899, exported=147911793.0, dc_power=None)
2022-12-01 10:16:31,342 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1669889780.7127616, power=26913.3603515625, imported=481883.3349242092, exported=0)
2022-12-01 10:16:31,342 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00295261, power1: 26913.4, power2: 26893.9
2022-12-01 10:16:31,342 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: 79.436
2022-12-01 10:16:31,342 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 79.436 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1669889791.3421679, power=26893.9072265625, imported=481962.77093870094, exported=0)
2022-12-01 10:16:31,342 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[230.5094451904297, 230.55421447753906, 232.15493774414062], powers=[9496.0009765625, 8435.451171875, 8962.455078125], currents=[41.64834976196289, 36.78620529174805, 38.75075149536133], power_factors=[0.9891387820243835, 0.9946091771125793, 0.9962552189826965], imported=481962.77093870094, exported=0, power=26893.9072265625, frequency=49.995052337646484)
2022-12-01 10:16:31,344 - {soc.modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,344 - {soc.modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,346 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,347 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,351 - {soc.modules.common.component_context:24} - {DEBUG:component5} - Update Komponente ['Summenbegrenzung alle Wallboxen']
2022-12-01 10:16:31,351 - {soc.modules.common.store._api:30} - {DEBUG:component5} - Saving CounterState(voltages=[230.0, 230.0, 230.0], powers=[7146.1, 7226.6, 7178.3], currents=[31.07, 31.42, 31.21], power_factors=[0.0, 0.0, 0.0], imported=1169202.90838877, exported=0, power=21576.1, frequency=50)
2022-12-01 10:16:31,352 - {soc.modules.common.component_context:24} - {DEBUG:component6} - Update Komponente ['SMA Wechselrichter Webbox']
2022-12-01 10:16:31,352 - {soc.modules.common.store._api:26} - {DEBUG:component6} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-899, exported=147911793.0, dc_power=None)
2022-12-01 10:16:31,352 - {soc.modules.common.store._api:30} - {DEBUG:component6} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-899, exported=147911793.0, dc_power=None)
2022-12-01 10:16:31,363 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['Hauptzähler']
2022-12-01 10:16:31,363 - {soc.modules.common.store._api:30} - {DEBUG:component0} - Saving CounterState(voltages=[230.5094451904297, 230.55421447753906, 232.15493774414062], powers=[9496.0009765625, 8435.451171875, 8962.455078125], currents=[41.64834976196289, 36.78620529174805, 38.75075149536133], power_factors=[0.9891387820243835, 0.9946091771125793, 0.9962552189826965], imported=481962.77093870094, exported=0, power=26893.9072265625, frequency=49.995052337646484)
2022-12-01 10:16:31,393 - {control.counter:427} - {DEBUG:MainThread} - 6106.0927734375W EVU-Leistung, die noch bezogen werden kann.
2022-12-01 10:16:31,395 - {control.chargepoint:689} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2022-12-01 10:16:31,395 - {control.chargepoint:680} - {DEBUG:MainThread} - Phasenzahl Lademodus: 3
2022-12-01 10:16:31,396 - {control.ev:387} - {DEBUG:MainThread} - Änderung der Sollstromstärke :False
2022-12-01 10:16:31,397 - {control.ev:362} - {DEBUG:MainThread} - Änderung des Lademodus :False
2022-12-01 10:16:31,397 - {control.chargepoint:848} - {DEBUG:MainThread} - LP 1, EV: Fahrzeug 1 (EV-Nr.1): Theoretisch benötigter Strom 16A, Lademodus instant_charging, Submodus: instant_charging, Phasen: 3, Priorität: False, max. Ist-Strom: 15.95
2022-12-01 10:16:31,397 - {control.chargepoint:689} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2022-12-01 10:16:31,397 - {control.chargepoint:680} - {DEBUG:MainThread} - Phasenzahl Lademodus: 3
2022-12-01 10:16:31,397 - {control.ev:459} - {DEBUG:MainThread} - Anpassen der Sollstromstärke an EV-Vorgaben. Sollstromstärke: 6 neue Sollstromstärke: 8
2022-12-01 10:16:31,398 - {control.ev:387} - {DEBUG:MainThread} - Änderung der Sollstromstärke :False
2022-12-01 10:16:31,398 - {control.ev:362} - {DEBUG:MainThread} - Änderung des Lademodus :True
2022-12-01 10:16:31,398 - {control.chargepoint:848} - {DEBUG:MainThread} - LP 2, EV: Fahrzeug 2 (EV-Nr.2): Theoretisch benötigter Strom 8A, Lademodus instant_charging, Submodus: instant_charging, Phasen: 3, Priorität: False, max. Ist-Strom: 0.0
2022-12-01 10:16:31,398 - {control.chargepoint:346} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2022-12-01 10:16:31,399 - {control.chargepoint:689} - {DEBUG:MainThread} - EV-Phasenzahl beschränkt die nutzbaren Phasen auf 3
2022-12-01 10:16:31,399 - {control.chargepoint:680} - {DEBUG:MainThread} - Phasenzahl Lademodus: 3
2022-12-01 10:16:31,399 - {control.ev:387} - {DEBUG:MainThread} - Änderung der Sollstromstärke :False
2022-12-01 10:16:31,399 - {control.ev:362} - {DEBUG:MainThread} - Änderung des Lademodus :False
2022-12-01 10:16:31,400 - {control.chargepoint:848} - {DEBUG:MainThread} - LP 4, EV: Fahrzeug 4 (EV-Nr.4): Theoretisch benötigter Strom 16A, Lademodus instant_charging, Submodus: instant_charging, Phasen: 3, Priorität: False, max. Ist-Strom: 15.5
2022-12-01 10:16:31,400 - {control.pv:89} - {DEBUG:MainThread} - -26778.9072265625W EVU-Überschuss, der für die Regelung verfügbar ist, davon 0W für die Einschaltverzögerung reservierte Leistung.
2022-12-01 10:16:31,401 - {control.data:296} - {DEBUG:MainThread} - all
2022-12-01 10:16:31,401 - {control.data:269} - {DEBUG:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=26137.99, daily_exported=0, power=21575.7, imported=1169205.01, exported=0))
2022-12-01 10:16:31,401 - {control.data:296} - {DEBUG:MainThread} - cp1
ChargepointData(get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[15.57, 15.95, 15.8], daily_imported=3341.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=306217.99, phases_in_use=3, plug_state=True, power=10907.93, rfid_timestamp=None, rfid=None, state_str=None, voltages=[230.31, 231.84, 230.29]), set=Set(change_ev_permitted=[True, ''], charging_ev=1, charging_ev_prev=1, current=16.0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='instant_charging', imported_at_mode_switch=302605.01, imported_at_plugtime=302605.01, imported_since_mode_switch=3582.0, imported_since_plugged=3582.0, range_charged=21.070588235294117, time_charged='0:20', timestamp_start_charging='12/01/2022, 09:56:20'), manual_lock=False, phases_to_use=3, plug_state_prev=True, plug_time='12/01/2022, 09:56:01', required_power=11040, rfid=None, charging_ev_data=<control.ev.Ev object at 0x7f19686ff400>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': 'openwb-garage.adwin.de', 'duo_num': 1}}, power_module={}, ev=1, name='Garage rechts/kurz', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=1))
2022-12-01 10:16:31,402 - {control.data:296} - {DEBUG:MainThread} - cp2
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=461152.01, phases_in_use=0, plug_state=True, power=0, rfid_timestamp=None, rfid=None, state_str=None, voltages=[230.27, 230.17, 231.96]), set=Set(change_ev_permitted=[True, ''], charging_ev=2, charging_ev_prev=2, current=8, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=461152.01, imported_at_plugtime=461152.01, imported_since_mode_switch=0, imported_since_plugged=0.0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=3, plug_state_prev=True, plug_time='12/01/2022, 09:11:51', required_power=11040, rfid=None, charging_ev_data=<control.ev.Ev object at 0x7f19686fffd0>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': 'openwb-garage.adwin.de', 'duo_num': 2}}, power_module={}, ev=2, name='Garage links/lang', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=False, id=2))
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=157171.01, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[230.05, 230.17, 231.66]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, charging_ev_data=<control.ev.Ev object at 0x7f1968719e80>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': 'openwb-werkstatt.adwin.de', 'duo_num': 1}}, power_module={}, ev=3, name='Werkstatt links/lang', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=True, id=3))
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - cp4
ChargepointData(get=Get(charge_state=True, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[15.5, 15.48, 15.42], daily_imported=22796.99, daily_exported=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=244664.0, phases_in_use=3, plug_state=True, power=10667.77, rfid_timestamp=None, rfid=None, state_str=None, voltages=[231.0, 229.73, 229.82]), set=Set(change_ev_permitted=[True, ''], charging_ev=4, charging_ev_prev=4, current=16.0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='instant_charging', imported_at_mode_switch=221598.01, imported_at_plugtime=221598.01, imported_since_mode_switch=23030.0, imported_since_plugged=23030.0, range_charged=135.47058823529412, time_charged='2:16', timestamp_start_charging='12/01/2022, 08:00:40'), manual_lock=False, phases_to_use=3, plug_state_prev=True, plug_time='12/01/2022, 08:00:31', required_power=11040, rfid=None, charging_ev_data=<control.ev.Ev object at 0x7f19686e67c0>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': 'openwb-werkstatt.adwin.de', 'duo_num': 2}}, power_module={}, ev=4, name='Werkstatt rechts/kurz', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=False, control_pilot_interruption_hw=True, id=4))
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={}, wait_for_charging_end=False), name='Standard Ladepunkt-Vorlage', rfid_enabling=False, valid_tags=[], id=0)
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - counter0
{'set': {'consumption_left': 6106.0927734375, 'currents_used': [41.65, 36.79, 38.75]}, 'get': {'daily_exported': 0, 'daily_imported': 66735.62943409494, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'voltages': [230.51, 230.55, 232.15], 'currents': [41.65, 36.79, 38.75], 'powers': [9496.0, 8435.45, 8962.46], 'power_factors': [0.99, 0.99, 1.0], 'imported': 481962.77093870094, 'exported': 0, 'power': 26893.9072265625, 'frequency': 49.995052337646484}, 'config': {'max_currents': [47, 47, 47], 'max_total_power': 33000}}
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - counter5
{'set': {'currents_used': [31.07, 31.42, 31.21]}, 'get': {'daily_exported': 0, 'daily_imported': 26137.99, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'voltages': [230.0, 230.0, 230.0], 'currents': [31.07, 31.42, 31.21], 'powers': [7146.1, 7226.6, 7178.3], 'power_factors': [0.0, 0.0, 0.0], 'imported': 1169202.90838877, 'exported': 0, 'power': 21576.1, 'frequency': 50}, 'config': {'max_currents': [33, 33, 33], 'max_total_power': 22000}}
2022-12-01 10:16:31,403 - {control.data:273} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 5, 'type': 'counter', 'children': [{'id': 1, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'cp', 'children': []}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}]}, {'id': 6, 'type': 'inverter', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=6216.8072265625015, invalid_home_consumption=0, daily_yield_home_consumption=41823.639434094934))
2022-12-01 10:16:31,403 - {control.data:296} - {DEBUG:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=6, limit=Limit(selected='none', amount=1000, soc=50))))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ct1
ChargeTemplateData(name='Ladeprofil-Vorlage 1', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ct2
ChargeTemplateData(name='Ladeprofil-Vorlage 2', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=6, limit=Limit(selected='none', amount=1000, soc=50))))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ct3
ChargeTemplateData(name='Ladeprofil-Vorlage 3', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ct4
ChargeTemplateData(name='Ladeprofil-Vorlage 4', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='instant_charging', pv_charging=PvCharging(min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, limit=Limit(selected='none', amount=1000, soc=50))))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_one_phase=32, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=0, phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ev1
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Fahrzeug-Vorlage 1', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=8, max_current_one_phase=16, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=16, phases=3, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='instant_charging', chargemode='instant_charging', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=1, ev_template=1, name='Fahrzeug 1', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2022-12-01 10:16:31,404 - {control.data:296} - {DEBUG:MainThread} - ev2
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Fahrzeug-Vorlage 2', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=8, max_current_one_phase=16, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=8, phases=3, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='instant_charging', chargemode='instant_charging', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=2, ev_template=2, name='Fahrzeug 2', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - ev3
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_one_phase=32, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=0, phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='stop', chargemode='stop', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=3, ev_template=3, name='Fahrzeug 3', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str=''))
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - ev4
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Fahrzeug-Vorlage 4', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=8, max_current_one_phase=16, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=16, phases=3, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode='instant_charging', chargemode='instant_charging', used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=4, ev_template=4, name='Fahrzeug 4', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=True, range=0, fault_state=0, fault_str=''))
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - et0
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - et1
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - et2
2022-12-01 10:16:31,405 - {control.data:296} - {DEBUG:MainThread} - et3
EvTemplateData(name='Fahrzeug-Vorlage 3', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=8, max_current_one_phase=16, battery_capacity=82, nominal_difference=2)
2022-12-01 10:16:31,406 - {control.data:296} - {DEBUG:MainThread} - et4
2022-12-01 10:16:31,406 - {control.data:277} - {DEBUG:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=3), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=1, rundown_power=1000, rundown_soc=50, switch_off_delay=60, switch_off_soc=40, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=60, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), standby=Standby(phases_to_use=1), stop=Stop(phases_to_use=1), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.55, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2022-12-01 10:16:31,406 - {control.data:296} - {DEBUG:MainThread} - graph
{'config': {'duration': 120}}
2022-12-01 10:16:31,406 - {control.data:279} - {DEBUG:MainThread} - optional_data
2022-12-01 10:16:31,406 - {control.data:296} - {DEBUG:MainThread} - all
{'set': {'overhang_power_left': -26778.9072265625, 'available_power': -26778.9072265625, 'reserved_evu_overhang': 0, 'released_evu_overhang': 0}, 'get': {'power': -899, 'exported': 147911793.0, 'daily_exported': 1226.0, 'monthly_exported': 0, 'yearly_exported': 0}, 'config': {'configured': True}}
2022-12-01 10:16:31,406 - {control.data:296} - {DEBUG:MainThread} - pv6
{'get': {'daily_exported': 1226.0, 'monthly_exported': 0, 'yearly_exported': 0, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'power': -899, 'exported': 147911793.0, 'currents': [0.0, 0.0, 0.0]}, 'config': {'max_ac_out': 12000}}
2022-12-01 10:16:31,406 - {control.data:296} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'boot_done': True, 'ip_address': '10.10.100.217', 'current_commit': '2022-11-30 10:27:48 +0100 [6be2f11a]', 'current_branch': 'master', 'current_branch_commit': '2022-11-30 10:27:48 +0100 [6be2f11a]', 'current_missing_commits': [], 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.100', 'datastore_version': 4, 'lastlivevaluesJson': {'timestamp': 1669889780, 'time': '10:16:20', 'grid': 26.913, 'counter5-power': 21.558, 'house-power': 6.254, 'charging-all': 21.558, 'pv-all': 0.899, 'cp1-power': 10.895, 'cp2-power': 0.0, 'cp3-power': 0.0, 'cp4-power': 10.663}, 'module_update_completed': True}
2022-12-01 10:16:31,406 - {control.data:309} - {DEBUG:MainThread} - device0
{'name': 'OpenWB-Kit flex', 'type': 'openwb_flex', 'id': 0, 'configuration': {'port': 8899, 'ip_address': 'rs485gw.adwin.de'}}
2022-12-01 10:16:31,407 - {control.data:311} - {DEBUG:MainThread} - component0
{'name': 'Hauptzähler', 'type': 'counter', 'id': 0, 'configuration': {'id': 2, 'version': 2}}
2022-12-01 10:16:31,407 - {control.data:309} - {DEBUG:MainThread} - device1
{'name': 'Virtuelle Zähler', 'type': 'virtual', 'id': 1, 'configuration': {}}
2022-12-01 10:16:31,407 - {control.data:311} - {DEBUG:MainThread} - component5
{'name': 'Summenbegrenzung alle Wallboxen', 'type': 'counter', 'id': 5, 'configuration': {'external_consumption': 0}}
2022-12-01 10:16:31,407 - {control.data:309} - {DEBUG:MainThread} - device2
{'name': 'SMA Webbox', 'type': 'sma_webbox', 'id': 2, 'configuration': {'ip_address': '10.10.101.251'}}
2022-12-01 10:16:31,407 - {control.data:311} - {DEBUG:MainThread} - component6
{'name': 'SMA Wechselrichter Webbox', 'type': 'inverter', 'id': 6, 'configuration': {}}
2022-12-01 10:16:31,407 - {control.data:283} - {DEBUG:MainThread} -
2022-12-01 10:16:31,407 - {control.algorithm:45} - {DEBUG:MainThread} - # Algorithmus-Start
2022-12-01 10:16:31,407 - {control.algorithm:47} - {INFO:MainThread} - EVU-Punkt: Leistung[W] 26893.9072265625, Ströme[A] [41.65, 36.79, 38.75]
2022-12-01 10:16:31,407 - {control.algorithm:85} - {INFO:MainThread} - ## Überschuss-Ladung über Mindeststrom bei PV-Laden zurücknehmen.
2022-12-01 10:16:31,408 - {control.algorithm:205} - {DEBUG:MainThread} - ## Ladung muss nicht wegen aktiven Lastmanagements gestoppt werden.
2022-12-01 10:16:31,408 - {control.algorithm:574} - {INFO:MainThread} - ## Zuteilung des Überschusses
2022-12-01 10:16:31,408 - {control.algorithm:610} - {INFO:MainThread} - ## Zuteilung beendet, da kein Ladepunkt mehr auf Zuteilung wartet.
2022-12-01 10:16:31,408 - {control.algorithm:870} - {INFO:MainThread} - ## Übrigen Überschuss verteilen.
2022-12-01 10:16:31,409 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2022-12-01 10:16:31,409 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 3612.9799999999814 counter 306217.99
2022-12-01 10:16:31,409 - {control.process:108} - {INFO:MainThread} - LP1: set current 16.0 A
2022-12-01 10:16:31,410 - {control.process:108} - {INFO:MainThread} - LP2: set current 8 A
2022-12-01 10:16:31,411 - {control.chargelog:52} - {DEBUG:MainThread} - imported_since_mode_switch 23065.98999999999 counter 244664.0
2022-12-01 10:16:31,411 - {control.process:108} - {INFO:MainThread} - LP4: set current 16.0 A
2022-12-01 10:16:31,411 - {soc.modules.common.component_context:24} - {DEBUG:cp1} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,412 - {soc.modules.common.component_context:24} - {DEBUG:cp2} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,418 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,419 - {soc.modules.common.component_context:24} - {DEBUG:cp4} - Update Komponente ['Ladepunkt']
2022-12-01 10:16:31,428 - {control.pv:434} - {DEBUG:MainThread} - -26778.9072265625W EVU-Überschuss, der für die Regelung verfügbar ist, davon 0W für die Einschaltverzögerung reservierte Leistung.
2022-12-01 10:16:31,428 - {control.counter:446} - {DEBUG:MainThread} - 6106.0927734375W verbleibende EVU-Bezugs-Leistung
2022-12-01 10:16:31,450 - {helpermodules.setdata:524} - {WARNING:Thread-6} - Kein Ladepunkt mit gültiger Konfiguration gefunden.
2022-12-01 10:16:31,451 - {helpermodules.setdata:524} - {WARNING:Thread-6} - Kein Ladepunkt mit gültiger Konfiguration gefunden.
