Seite 18 von 77
Re: SoC für den neuen Opel Corsa e (ggf. auch Peugeot 208e?)
Verfasst: Di Mär 30, 2021 6:26 am
von miradarya
Irgendwas ist in der aktuellen SoC-Implementierung seltsam. Gestern Abend waren wir unterwegs, und der SoC wurde währenddessen nur sporadisch aktualisiert, obwohl aktuelle Werte über die PSA-API verfügbar waren. Erst vorhin bei PV-Ladebeginn wurde der tatsächliche SoC von der openWB übernommen:
2021-03-30 08:19:39: Lp1: Fetched from Opel: 41% and using it.
2021-03-30 08:19:35: Lp1: Charging started. Fetching SoC from Opel out of order.
2021-03-30 08:19:19: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-30 08:19:15: Lp1: Fetching SoC from Opel
2021-03-30 08:17:49: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-30 08:17:45: Lp1: Fetching SoC from Opel
2021-03-30 08:10:39: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-30 08:10:34: Lp1: Fetching SoC from Opel
2021-03-30 08:00:40: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-30 08:00:36: Lp1: Fetching SoC from Opel
2021-03-29 20:00:38: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-29 20:00:34: Lp1: Fetching SoC from Opel
2021-03-29 19:50:39: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-29 19:50:35: Lp1: Fetching SoC from Opel
2021-03-29 19:40:38: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-29 19:40:35: Lp1: Fetching SoC from Opel
2021-03-29 19:30:41: Lp1: Fetched from Opel: 41% but skipping as not newer than current known SoC.
2021-03-29 19:30:35: Lp1: Fetching SoC from Opel
2021-03-29 19:23:39: Lp1: Fetched from Opel: 42% but skipping as not newer than current known SoC.
2021-03-29 19:23:35: Lp1: Fetching SoC from Opel
2021-03-29 19:13:38: Lp1: Fetched from Opel: 45% but skipping as not newer than current known SoC.
2021-03-29 19:13:35: Lp1: Fetching SoC from Opel
2021-03-29 19:03:40: Lp1: Fetched from Opel: 47% but skipping as not newer than current known SoC.
2021-03-29 19:03:35: Lp1: Fetching SoC from Opel
2021-03-29 18:53:39: Lp1: Fetched from Opel: 49% but skipping as not newer than current known SoC.
2021-03-29 18:53:35: Lp1: Fetching SoC from Opel
2021-03-29 18:43:39: Lp1: Fetched from Opel: 49% but skipping as not newer than current known SoC.
2021-03-29 18:43:35: Lp1: Fetching SoC from Opel
2021-03-29 18:33:40: Lp1: Fetched from Opel: 49% but skipping as not newer than current known SoC.
2021-03-29 18:33:35: Lp1: Fetching SoC from Opel
2021-03-29 18:23:39: Lp1: Fetched from Opel: 52% but skipping as not newer than current known SoC.
2021-03-29 18:23:35: Lp1: Fetching SoC from Opel
2021-03-29 18:13:39: Lp1: Fetched from Opel: 56% but skipping as not newer than current known SoC.
2021-03-29 18:13:35: Lp1: Fetching SoC from Opel
2021-03-29 18:03:39: Lp1: Fetched from Opel: 58% but skipping as not newer than current known SoC.
2021-03-29 18:03:35: Lp1: Fetching SoC from Opel
2021-03-29 17:53:39: Lp1: Fetched from Opel: 60% and using it.
2021-03-29 17:53:35: Lp1: Fetching SoC from Opel
2021-03-29 17:43:39: Lp1: Fetched from Opel: 61% but skipping as not newer than current known SoC.
2021-03-29 17:43:35: Lp1: Fetching SoC from Opel
2021-03-29 17:33:38: Lp1: Fetched from Opel: 62% but skipping as not newer than current known SoC.
2021-03-29 17:33:34: Lp1: Fetching SoC from Opel
2021-03-29 17:23:39: Lp1: Fetched from Opel: 62% but skipping as not newer than current known SoC.
2021-03-29 17:23:35: Lp1: Fetching SoC from Opel
2021-03-29 17:13:39: Lp1: Fetched from Opel: 62% but skipping as not newer than current known SoC.
2021-03-29 17:13:35: Lp1: Fetching SoC from Opel
Verfasst: Di Mär 30, 2021 7:54 am
von seran
Ich hab im openWB Log durchgängig den folgenden Fehler:
/var/www/html/openWB/loadconfig.sh: Zeile 8: export: `(WVWZZZ...)': Ist kein gültiger Bezeichner.
Vermute das hat mit dem SoC Modul zu tun. Habt ihr das Problem auch?
Verfasst: Di Mär 30, 2021 8:04 am
von miradarya
Die Meldungen habe ich bei mir nicht. Dafür kontinuierlich "(standard_in) 2: syntax error" und des Öfteren "Modbus EVSE read CP1 issue".
Verfasst: Di Mär 30, 2021 8:42 am
von seran
Die habe ich auch, die haben aber nichts mit dem SoC Modul zu tun, sondern mit dem Lesen vom ModBus des Wechselrichters. Laut Support ist das normal, nur wenn es sich häuft sollte man da auf Ursachenforschung gehen.
Ich frage mich allerdings wie ich meinen Fehler wegbekomme, der spammt bei mir komplett das Logfile zu. Beim SoC Modul ist die WVW Nummer eigentlich nirgends konfiguriert. Vermute, dass ich mit einer alten Version des SoC Moduls einen ungültigen Eintrag in die Config geschrieben habe und der seitdem da drin steht. Bloß wie kriegt man den wieder weg? :?:
von seb351
Die Berechnung der Sommerzeit hatte ich leider falsch implementiert, so dass mit der Zeitumstellung viele korrekte Werte verworfen wurden, da sie zu alt erschienen.
Die Berechnung der Sommerzeit ist in der aktuellen nightly geändert und damit hoffentlich dauerhaft korrigiert.
Bitte einmal updaten, dann sollte das Problem hoffentlich gelöst sein.
Unabhängig davon hat PSA leider scheinbar seit gestern ein Problem mit den Servern, so dass zumindest bei mir nicht mal in der App aktuelle Werte angezeigt werden. Seit gestern Abend zeigt die App nur noch 0% aber 188km Restreichweite. Solange die App nicht funktioniert wird das Modul sicher auch keine korrekten Werte abrufen können.
Dieses WVWZZZ gehört glaube ich zum VAG SoC Modul. Ich hoffe/glaube da gibt es keinen Zusammenhang zum PSA Modul.
Verfasst: Di Mär 30, 2021 8:48 am
von seran
Stimmt, das sieht echt nach VW aus. Deswegen kam mir das bekannt vor. Das heißt das Modul hat die Config aller openWBs kaputt gemacht?
Verfasst: Di Mär 30, 2021 9:07 am
von LutzB
Bitte die Nightly nutzen. Dort wurde das behoben. Eine neue Beta kommt auch in Kürze.
Alternativ einmal das VAG-SoC Modul auswählen und die VIN löschen oder etwas ohne Leerzeichen und Klammern eingeben, speichern. Danach wieder das gewünschte SoC Modul konfigurieren.
Verfasst: Sa Apr 03, 2021 9:33 pm
von mrinas
Ein Detail ist mir noch aufgefallen, im Daily Graph fehlt der SoC während der manuellen Berechnungsphase, im daily CSV ist die SoC Zelle ebenfalls leer während geladen wird. Müsste der errechnete SoC noch irgendwo anders hingeschrieben werden damit er dort auftaucht?
Verfasst: So Apr 04, 2021 6:32 am
von openWB
Er müsste als Integer rausgeschrieben werden damit er im Log auftaucht.
Ich vermute das ist das Problem?
Verfasst: So Apr 04, 2021 11:37 am
von mrinas
Int ist ein guter Punkt, muss ich beim nächsten Ladestart mal kontrollieren. Aktuell läuft die Ladung und ramdisk/soc hat einen Integer Wert.
So wie es aussieht landet der SoC im Log sobald er um einen Punkt erhöht wurde, hier kann man eine Lücke erkennen, danach steigt er schön an.
