Colors-Theme 2.0
Meth
Has thanked: 36 times
Been thanked: 6 times
Re: Colors-Theme 2.0
Beitrag von Meth »
electron hat geschrieben: Sa Nov 29, 2025 6:52 am Auffällig ist, dass die Simcount-Warnungen im Kontext der Speicher-Komponenten angezeigt werden, bei denen die falschen Tageswerte angezeigt werden:
2025-11-29 00:40:18,244 - {modules.common.component_context:29} - {DEBUG:device0} - Update Komponente [' Kostal Plenticore 5.5 Garage']
2025-11-29 00:40:18,250 - {modules.common.simcount._simcount:42} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1764373191.5644138, power=0, imported=0.03649567034500018, exported=23927752.360001095)
2025-11-29 00:40:18,253 - {modules.common.simcount._simcount:51} - {WARNING:device0} - Time difference between previous state and current state is too large. Set time difference to control interval.
Was auch noch auffällt, sind diese Einträge im Log:
BatData(get=Get(currents=[0.0, 0.0, 0.0], soc=4, daily_exported=95.0, daily_imported=7.0, imported=6232920.5, exported=5666650.5, fault_state=0, fault_str='Kein Fehler.', power=0, power_limit_controllable=True), set=Set(power_limit=None))
2025-11-29 00:41:06,971 - {control.data:295} - {INFO:MainThread} - bat9
BatData(get=Get(currents=[0.0, 0.0, 0.0], soc=5, daily_exported=45.0, daily_imported=3.0, imported=7307102, exported=6579255, fault_state=0, fault_str='Kein Fehler.', power=0, power_limit_controllable=True), set=Set(power_limit=None))
2025-11-29 00:41:06,974 - {control.data:295} - {INFO:MainThread} - bat10
BatData(get=Get(currents=[0, 0, 0], soc=12, daily_exported=0.0, daily_imported=1639.0, imported=1761508.12, exported=1492437.25, fault_state=0, fault_str='Kein Fehler.', power=0, power_limit_controllable=True), set=Set(power_limit=None))
2025-11-29 00:41:06,978 - {control.data:295} - {INFO:MainThread} - bat11
BatData(get=Get(currents=[0, 0, 0], soc=4, daily_exported=0.0, daily_imported=0.0, imported=1896950.38, exported=1567041.75, fault_state=0, fault_str='Kein Fehler.', power=0, power_limit_controllable=True), set=Set(power_limit=None))
2025-11-29 00:41:06,981 - {control.data:295} - {INFO:MainThread} - bat7
BatData(get=Get(currents=[0.0, 0.0, 0.0], soc=4, daily_exported=0.0, daily_imported=0.0, imported=15012808.5, exported=13591442, fault_state=0, fault_str='Kein Fehler.', power=0, power_limit_controllable=True), set=Set(power_limit=None))
2025-11-29 00:41:06,985 - {control.data:262} - {INFO:MainThread} - bat_all_data
Da stehen auch jeweils die falschen daily_imported Werte drin.
Ich kenne mich da leider zu wenig aus. Vielleicht liest ja hier jemand mit, der die Simcount-Komponente kennt. Sonst müsstest Du vielleicht mal in einem anderen Thread posten (z.B. der zum aktuellen Master).
Meth hat geschrieben: Sa Nov 29, 2025 12:17 am Hallo
Anbei mal das log
https://paste.openwb.de/ZqZTEOd9nBsoqdh
Das stehen viele Einträge mit simcount und so weiter.
Ich nuss ehrlich sagen ich habe da keine Ahnung
Danke !
Werde ich mal machen
2 x 15 kWh BMZ Hyperion
1 oWb 2.0 im Hauptverteiler
Thomas aus W
Has thanked: 161 times
Been thanked: 69 times
Re: Colors-Theme 2.0 - Gleichnamige Zäher wie SH-Gerät
Beitrag von Thomas aus W »
Sorry für die späte Antwort.
electron hat geschrieben: Do Nov 06, 2025 6:01 am Hm, das sieht in der Tat seltsam aus. Wobei mir noch nicht klar ist, warum dieser Effekt auftritt.
In erster Linie, weil ich neben dem SH-gerät noch einen OWB-Zähler eingerichtet habe, der den selben Hardware-Zähler ab fragt und auch nicht in den Hausverbrauch eingerechnet wird. Das ist ein Workarout um den Verbrauch der WP in der Standard-Ansicht angezeigt zu bekommen.
Daher ja auch mein Wunsch, dass Du nach Zählern suchst, die den selben Namen wie das SH-Gerät haben und die Du dann passend verrechnest.
[{"id": 2, "type": "counter", "children": [{"id": 12, "type": "inverter", "children": [{"id": 13, "type": "bat", "children": []}]}, {"id": 10, "type": "counter", "children": []}, {"id": 11, "type": "counter", "children": [{"id": 5, "type": "cp", "children": []}, {"id": 6, "type": "cp", "children": []}]}]}]
electron hat geschrieben: Do Nov 06, 2025 6:01 am Das sieht fast so aus, als würde die WP zweimal vom Hausverbrauch abgezogen und damit einen negativen Hausverbrauch erzeugen. In den Daten von der openwb sieht aber alles ok aus. Könntest Du den Debug-Modus aktivieren und in der Console die Daten kopieren, die an den Graphen gehen (die ersten 7-8 Elemente sollten reichen):.
Die Stelle, Die Du möchtest finde ich im MQTT-Viewer irgendwie nicht, daher hier der Log-Eintrag:
https://paste.openwb.de/raWBUspPemrBXtu
und noch mal die aktuellen Ansicht:
bye
TW
Extrahirn
Has thanked: 3 times
Been thanked: 7 times
Beitrag von Extrahirn »
Ich verwende den manuellen SOC.
Bei der Eingabe des SOC habe ich zwei Probleme:
- bei der Eingabe „schlägt“ anscheinend alle paar Sekunden ein Timer zu und
Sorgt dafür, dass die Eingabe wieder mit den vorherigen Werten überschrieben wird,
Weil ich nicht schnell genug war und die Eingbe über „Ok“ abgespeichert habe…
Kann man den manuellen SOC während der Eingabe von der Aktualisierung ausnehmen ?
- Ich muss den neuen SOC Wert immer zwei Mal eingeben. Wenn ich nach der ersten Werteingabe den OK-Button drücke und
dann Die Browseranzeige aktualisiere, steht wieder der vorherige Wert drin.
Nach dem zweiten Mal werden die Eingaben übernommen.
OpenWB Version Release 2.1.8-Patch.4, Safari-Browser auf dem iPad
OpenWB standard Series 2+ | MINI SE
electron
Been thanked: 136 times
Beitrag von electron »
Danke für den Hinweis. Ich schaue mal, wie ich das beheben kann.
Extrahirn hat geschrieben: Di Dez 02, 2025 6:42 pm Hi,
openWB Serie 2 11 kW
Solaredge WR
Tesla Model 3
Philip
Has thanked: 132 times
Been thanked: 39 times
Beitrag von Philip »
Das ist super, @electron. Ich habe dieses Problem der "frickeligen" Eingabe auch - selbst am Display der openWB...
phelix
Beitrag von phelix »
Ich weiß nicht, ob es schon irgendwo angesprochen wurde oder gar in einer nightly-Version gefixt wurde: Mir ist heute aufgefallen, dass in der Monatsanzeige
- die letzten Tage keine Datumszahl (28 / 29 / 30 / 31, je nach länge des Monats) aufweisen.
- der letzte Tag des Monats fehlt und ggf. mit dem Tag davor verrechnet wird. Die Balken sind am vorletzten Tag immer deutlich höher, als der Rest.
Betrifft die 2.1.8-Patch.4
Schönen Gruß!
SolarEdge SE8k, 9,77 kWp;
Nissan Leaf Ze1 MY19 Tekna, 62 kWh;
openWB Series2 Standard
electron
Ja, das ist in den aktuellen Nightly-Versionen gefixt.
phelix hat geschrieben: So Dez 07, 2025 7:43 pm Ich weiß nicht, ob es schon irgendwo angesprochen wurde oder gar in einer nightly-Version gefixt wurde: Mir ist heute aufgefallen, dass in der Monatsanzeige
Schönen Gruß!
Solaredge WR
Tesla Model 3
Philip
Philip hat geschrieben: Fr Dez 05, 2025 7:58 am Das ist super, @electron. Ich habe dieses Problem der "frickeligen" Eingabe auch - selbst am Display der openWB...
@electron: Wenn ich dazu noch einen Wunsch äußern darf: Wenn man am Display nicht nur den aktuellen SoC des Autos eingeben könnte, sondern auch den einmaligen Ziel-Ladestand, wäre das ein Träumchen!
Anwendungsfall: Ich habe im Winter Zielladen i.d.R. auf 60% SoC gestellt, weil wir den meistens benötigen, wenn wir laden. Wenn der Strompreis günstig ist, lade ich aber auch gerne mal auf 90%. Um diese Einstellung zu ändern, muss ich dann tief ins openWB-Menü einsteigen. Und wenn ich's dort ändere, ist die Einstellung dauerhaft geändert, nicht nur für den einen Ladevorgang (ich muss es also wieder zurückstellen...).
Danke sehr!
Philip
Powersup
Beitrag von Powersup »
früher konnte man bei den Ladepunkten, wenn man auf die 3 Punkte geklickt hatte, in einem der Reiter die Ladeprofile wechseln. Jetzt finde ich das nicht mehr.
Wäre das bitte möglich wieder zu implementieren - war sehr praktisch!
DANKE für dieses tolle Theme - für mich mit Abstand die beste GUI!!!
OpenWB series2 standard+ | OpenWB Pro
electron
Mit dem Update von heute sollte das behoben sein.
Solaredge WR
Tesla Model 3
