Seite 3 von 3
Re: Peugeot e208 lädt nicht (mehr)
Verfasst: Sa Mär 12, 2022 10:27 am
von fussi24
Um 11:22 Uhr habe ich den Wagen mit dem Schlüssel geöffnet und nun lädt er seit 5 Min wie gewünscht.
2022-03-12 11:25:03: PID: 14227: logfile cleanup triggered (LV1) at 423 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:03: PID: 14227: starting evsecheck (LV1) at 419 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:03:  Load: 2.62 2.44 2.27
2022-03-12 11:25:03: PID: 14227: pingcheck configured; starting (LV1) at 409 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:03: PID: 14227: modbus tcp server already running (LV1) at 401 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: external openWB or daemon mode not configured; checking network setup (LV1) at 336 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: smarthome handler is already running (LV1) at 319 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: legacy_run_server is already running (LV1) at 313 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: mqtt handler is already running (LV1) at 300 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: current ip: 192.168.1.9 (LV1) at 295 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: updating daily yield stats (LV1) at 165 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: electricity provider configured; trigger price update (LV1) at 158 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: Netzschutz konfiguriert; aktuelle Frequenz: 4995 (LV1) at 110 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20220312.csv (LV1) at 102 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14227: ##### cron5min.sh started ##### (LV0) at 23 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:25:02: PID: 14220: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:57: PID: 12601: Nur PV auf Minimalstromstaerke, PV Counter auf 100 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:57: PID: 12601: Abschaltschwelle: -300, Überschuss derzeit: -844 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:57: PID: 12601: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:57: PID: 12601: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:57: PID: 12601: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:57: PID: 12601: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:56: PID: 12601: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: lla3 0	llv3 237.5	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: lla2 0	llv2 236.6	llas12 0 llas22  sofortll 16 hausverbrauch 1251 wattbezug 844 uberschuss -844 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: lla1 5	llv1 236.4	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: pv1watt -3023 pv2watt  pvwatt -3023 ladeleistung 2567 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:56: PID: 12601: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484901.037403618, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:51: PID: 12601: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:47: PID: 11045: Nur PV auf Minimalstromstaerke, PV Counter auf 90 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:47: PID: 11045: Abschaltschwelle: -300, Überschuss derzeit: -1503 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:47: PID: 11045: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:47: PID: 11045: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:47: PID: 11045: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:47: PID: 11045: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:46: PID: 11045: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: EVU 1:V/6A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: lla3 0	llv3 236.9	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: lla2 0	llv2 236.7	llas12 0 llas22  sofortll 16 hausverbrauch 1934 wattbezug 1503 uberschuss -1503 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: lla1 5	llv1 236.5	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: pv1watt -3064 pv2watt  pvwatt -3064 ladeleistung 2585 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:46: PID: 11045: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:45: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484897.7744978075, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:41: PID: 11045: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:37: PID: 9461: Nur PV auf Minimalstromstaerke, PV Counter auf 80 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:37: PID: 9461: Abschaltschwelle: -300, Überschuss derzeit: -788 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:37: PID: 9461: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:36: PID: 9461: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:36: PID: 9461: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:36: PID: 9461: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:36: PID: 9461: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: lla2 0	llv2 236.5	llas12 0 llas22  sofortll 16 hausverbrauch 1191 wattbezug 788 uberschuss -788 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: lla1 5	llv1 235.8	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:36: PID: 9461: pv1watt -3042 pv2watt  pvwatt -3042 ladeleistung 2590 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:35: PID: 9461: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:35: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484894.553168297, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:31: PID: 9461: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:27: PID: 7889: Nur PV auf Minimalstromstaerke, PV Counter auf 70 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:27: PID: 7889: Abschaltschwelle: -300, Überschuss derzeit: -792 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:27: PID: 7889: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:27: PID: 7889: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:27: PID: 7889: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:27: PID: 7889: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:26: PID: 7889: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: lla3 0	llv3 237.2	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: lla2 0	llv2 236.8	llas12 0 llas22  sofortll 16 hausverbrauch 1308 wattbezug 792 uberschuss -792 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: lla1 5	llv1 236.2	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: pv1watt -3047 pv2watt  pvwatt -3047 ladeleistung 2482 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:26: PID: 7889: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484892.41320125, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:21: PID: 7889: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:17: PID: 6299: Nur PV auf Minimalstromstaerke, PV Counter auf 60 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:17: PID: 6299: Abschaltschwelle: -300, Überschuss derzeit: -750 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:17: PID: 6299: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:16: PID: 6299: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:16: PID: 6299: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:16: PID: 6299: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:16: PID: 6299: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: lla3 0	llv3 237.5	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: lla2 0	llv2 236.8	llas12 0 llas22  sofortll 16 hausverbrauch 1280 wattbezug 750 uberschuss -750 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: lla1 5	llv1 236.6	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: pv1watt -3074 pv2watt  pvwatt -3074 ladeleistung 2496 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:16: PID: 6299: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:15: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484890.239905159, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:11: PID: 6299: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:08: PID: 4732: Nur PV auf Minimalstromstaerke, PV Counter auf 50 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:24:08: PID: 4732: Abschaltschwelle: -300, Überschuss derzeit: -725 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:24:08: PID: 4732: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:07: PID: 4732: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:24:07: PID: 4732: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:24:07: PID: 4732: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:24:06: PID: 4732: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: lla3 0	llv3 237.7	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: lla2 0	llv2 235.8	llas12 0 llas22  sofortll 16 hausverbrauch 1266 wattbezug 725 uberschuss -725 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: lla1 5	llv1 236.1	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: pv1watt -3171 pv2watt  pvwatt -3171 ladeleistung 2581 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:24:06: PID: 4732: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:24:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484888.2336416624, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:24:01: PID: 4732: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:59: PID: 3080: **** WARNING **** Regulation loop needs 8 seconds (LV0) at 57 cleanup /var/www/html/openWB/regel.sh
2022-03-12 11:23:59: PID: 3080: Nur PV auf Minimalstromstaerke, PV Counter auf 40 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:23:59: PID: 3080: Abschaltschwelle: -300, Überschuss derzeit: -588 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:23:59: PID: 3080: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:59: PID: 3080: LP1 Modbus 6 korrekt (LV1) at 236 evsemodbuscheck evsedintest.sh
2022-03-12 11:23:57: PID: 3080: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:57: PID: 3080: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:57: PID: 3080: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:56: PID: 3080: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: lla3 0	llv3 237.4	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: lla2 0	llv2 237.2	llas12 0 llas22  sofortll 16 hausverbrauch 1306 wattbezug 588 uberschuss -588 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: lla1 5	llv1 235.4	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: pv1watt -3254 pv2watt  pvwatt -3254 ladeleistung 2487 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 3080: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:56: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484886.4197366089, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:23:51: PID: 3080: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:47: PID: 1467: Nur PV auf Minimalstromstaerke, PV Counter auf 30 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:23:47: PID: 1467: Abschaltschwelle: -300, Überschuss derzeit: -439 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:23:47: PID: 1467: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:46: PID: 1467: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:46: PID: 1467: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:46: PID: 1467: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:46: PID: 1467: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: lla2 0	llv2 236.9	llas12 0 llas22  sofortll 16 hausverbrauch 1181 wattbezug 439 uberschuss -439 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:46: PID: 1467: lla1 5	llv1 236.4	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:45: PID: 1467: pv1watt -3391 pv2watt  pvwatt -3391 ladeleistung 2600 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:45: PID: 1467: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:45: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484884.9514634148, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:23:41: PID: 1467: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:37: PID: 32295: Nur PV auf Minimalstromstaerke, PV Counter auf 20 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:23:37: PID: 32295: Abschaltschwelle: -300, Überschuss derzeit: -423 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:23:37: PID: 32295: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:36: PID: 32295: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:36: PID: 32295: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:36: PID: 32295: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:36: PID: 32295: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: lla3 0	llv3 237.9	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: lla2 0	llv2 236.8	llas12 0 llas22  sofortll 16 hausverbrauch 1201 wattbezug 423 uberschuss -423 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: lla1 5	llv1 236.7	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: pv1watt -3399 pv2watt  pvwatt -3399 ladeleistung 2572 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:36: PID: 32295: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:35: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484883.754457524, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:23:31: PID: 32295: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:27: PID: 30733: Nur PV auf Minimalstromstaerke, PV Counter auf 10 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:23:27: PID: 30733: Abschaltschwelle: -300, Überschuss derzeit: -395 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:23:27: PID: 30733: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:26: PID: 30733: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:26: PID: 30733: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:26: PID: 30733: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:26: PID: 30733: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: EVU 1:V/5A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: lla3 0	llv3 237.9	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: lla2 0	llv2 237.6	llas12 0 llas22  sofortll 16 hausverbrauch 1274 wattbezug 395 uberschuss -395 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: lla1 5	llv1 236.8	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: pv1watt -3458 pv2watt  pvwatt -3458 ladeleistung 2530 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:26: PID: 30733: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484882.624309523, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:23:21: PID: 30733: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:18: PID: 29175: Abschaltschwelle: -300, Überschuss derzeit: -289 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:23:17: PID: 29175: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:17: PID: 29175: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:17: PID: 29175: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:17: PID: 29175: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:16: PID: 29175: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: EVU 1:V/4A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: lla3 0	llv3 237.8	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: lla2 0	llv2 237.3	llas12 0 llas22  sofortll 16 hausverbrauch 1214 wattbezug 289 uberschuss -289 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: lla1 6	llv1 236.5	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: pv1watt -3571 pv2watt  pvwatt -3571 ladeleistung 2597 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:16: PID: 29175: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:15: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484881.6844809437, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:23:11: PID: 29175: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:08: PID: 27604: pv ladung auf 6 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:23:07: PID: 27604: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:07: PID: 27604: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:23:07: PID: 27604: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:23:06: PID: 27604: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:23:06: PID: 27604: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: EVU 1:V/6A 2: V/5A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: lla3 0	llv3 237.4	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: lla2 0	llv2 237.2	llas12 0 llas22  sofortll 16 hausverbrauch 1119 wattbezug 1678 uberschuss -1678 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: lla1 8	llv1 236.4	llas11 8 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: pv1watt -3543 pv2watt  pvwatt -3543 ladeleistung 4053 llalt 9 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:23:06: PID: 27604: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:23:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484878.912681195, Einspeisung[Wh]: 777281.3256754932
2022-03-12 11:23:01: PID: 27604: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:58: PID: 26032: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:57: PID: 26032: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:57: PID: 26032: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:57: PID: 26032: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:56: PID: 26032: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: EVU 1:V/3A 2: V/4A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: lla3 0	llv3 238.6	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: lla2 0	llv2 237.6	llas12 0 llas22  sofortll 16 hausverbrauch 1104 wattbezug -172 uberschuss 172 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: lla1 8	llv1 236.4	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: pv1watt -3436 pv2watt  pvwatt -3436 ladeleistung 2110 llalt 9 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 26032: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:56: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484876.9172222223, Einspeisung[Wh]: 777281.3048074015
2022-03-12 11:22:52: PID: 26032: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:47: PID: 24490: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:47: PID: 24490: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:47: PID: 24490: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:47: PID: 24490: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:46: PID: 24490: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: EVU 1:V/3A 2: V/5A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: lla3 0	llv3 239.0	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: lla2 0	llv2 237.1	llas12 0 llas22  sofortll 16 hausverbrauch 1016 wattbezug -127 uberschuss 127 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: lla1 8	llv1 236.5	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: pv1watt -3336 pv2watt  pvwatt -3336 ladeleistung 2144 llalt 9 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 24490: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:46: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484876.9172222223, Einspeisung[Wh]: 777280.8783366547
2022-03-12 11:22:42: PID: 24490: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:38: PID: 22949: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:37: PID: 22949: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:37: PID: 22949: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:37: PID: 22949: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:36: PID: 22949: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: EVU 1:V/3A 2: V/5A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: lla3 0	llv3 239.0	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: lla2 0	llv2 237.2	llas12 0 llas22  sofortll 16 hausverbrauch 1110 wattbezug -195 uberschuss 195 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: lla1 8	llv1 236.1	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: pv1watt -3419 pv2watt  pvwatt -3419 ladeleistung 2065 llalt 9 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 22949: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:36: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484876.9174996573, Einspeisung[Wh]: 777280.4269790169
2022-03-12 11:22:31: PID: 22949: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:28: PID: 21380: pv ladung auf 9 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:22:28: PID: 21380: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:27: PID: 21380: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:27: PID: 21380: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:27: PID: 21380: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:26: PID: 21380: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: EVU 1:V/3A 2: V/6A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: lla3 0	llv3 238.9	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: lla2 0	llv2 237.3	llas12 0 llas22  sofortll 16 hausverbrauch 1064 wattbezug 134 uberschuss -134 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: lla1 9	llv1 236.2	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: pv1watt -3307 pv2watt  pvwatt -3307 ladeleistung 2328 llalt 10 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 21380: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:26: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484876.8422936695, Einspeisung[Wh]: 777280.2672222222
2022-03-12 11:22:22: PID: 21380: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:18: PID: 19812: pv ladung auf 10 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:22:18: PID: 19812: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:17: PID: 19812: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:17: PID: 19812: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:17: PID: 19812: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:16: PID: 19812: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: EVU 1:V/3A 2: V/7A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: lla3 0	llv3 238.9	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: lla2 0	llv2 237.9	llas12 0 llas22  sofortll 16 hausverbrauch 1115 wattbezug 380 uberschuss -380 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: lla1 10	llv1 235.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: pv1watt -3310 pv2watt  pvwatt -3310 ladeleistung 2525 llalt 11 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 19812: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:16: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484876.1317644774, Einspeisung[Wh]: 777280.2672222222
2022-03-12 11:22:11: PID: 19812: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:09: PID: 18231: **** WARNING **** Regulation loop needs 8 seconds (LV0) at 57 cleanup /var/www/html/openWB/regel.sh
2022-03-12 11:22:09: PID: 18231: pv ladung auf 11 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:22:08: PID: 18231: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:07: PID: 18231: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:22:07: PID: 18231: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:22:07: PID: 18231: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:22:06: PID: 18231: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: EVU 1:V/3A 2: V/7A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: lla3 0	llv3 239.2	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: lla2 0	llv2 238.3	llas12 0 llas22  sofortll 16 hausverbrauch 1162 wattbezug 376 uberschuss -376 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: lla1 11	llv1 235.9	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: pv1watt -3604 pv2watt  pvwatt -3604 ladeleistung 2768 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 18231: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:22:06: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484875.0828657704, Einspeisung[Wh]: 777280.2673953547
2022-03-12 11:22:01: PID: 18231: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:57: PID: 16667: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:57: PID: 16667: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:57: PID: 16667: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:56: PID: 16667: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:56: PID: 16667: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: EVU 1:V/4A 2: V/7A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: lla3 0	llv3 238.7	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: lla2 0	llv2 238.6	llas12 0 llas22  sofortll 16 hausverbrauch 1104 wattbezug -73 uberschuss 73 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: lla1 11	llv1 236.2	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: pv1watt -4019 pv2watt  pvwatt -4019 ladeleistung 2792 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:56: PID: 16667: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484874.6283333334, Einspeisung[Wh]: 777280.2504883425
2022-03-12 11:21:51: PID: 16667: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:48: PID: 15125: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:47: PID: 15125: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:47: PID: 15125: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:47: PID: 15125: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:46: PID: 15125: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: EVU 1:V/4A 2: V/7A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: lla3 0	llv3 239.2	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: lla2 0	llv2 238.4	llas12 0 llas22  sofortll 16 hausverbrauch 1095 wattbezug -124 uberschuss 124 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: lla1 11	llv1 235.6	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: pv1watt -4055 pv2watt  pvwatt -4055 ladeleistung 2786 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:46: PID: 15125: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:45: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484874.6283333334, Einspeisung[Wh]: 777279.9812410553
2022-03-12 11:21:41: PID: 15125: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:37: PID: 13586: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:36: PID: 13586: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:36: PID: 13586: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:36: PID: 13586: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:36: PID: 13586: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: EVU 1:V/4A 2: V/7A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: lla3 0	llv3 239.2	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: lla2 0	llv2 238.1	llas12 0 llas22  sofortll 16 hausverbrauch 1078 wattbezug -121 uberschuss 121 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: lla1 11	llv1 236.0	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: pv1watt -4023 pv2watt  pvwatt -4023 ladeleistung 2774 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:36: PID: 13586: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:35: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484874.6285638884, Einspeisung[Wh]: 777279.6357889646
2022-03-12 11:21:31: PID: 13586: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:28: PID: 11999: pv ladung auf 12 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:21:27: PID: 11999: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:27: PID: 11999: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:26: PID: 11999: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:26: PID: 11999: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:26: PID: 11999: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: EVU 1:V/4A 2: V/8A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: lla3 0	llv3 239.2	llas13 0 llas23  soclp1 36 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: lla2 0	llv2 238.5	llas12 0 llas22  sofortll 16 hausverbrauch 1141 wattbezug 283 uberschuss -283 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: lla1 13	llv1 235.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: pv1watt -3959 pv2watt  pvwatt -3959 ladeleistung 3052 llalt 13 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:26: PID: 11999: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484874.3551812652, Einspeisung[Wh]: 777279.5855555555
2022-03-12 11:21:21: PID: 11999: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:18: PID: 10414: pv ladung auf 13 reduziert (LV1) at 340 nurpvlademodus nurpv.sh
2022-03-12 11:21:17: PID: 10414: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:17: PID: 10414: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:17: PID: 10414: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:17: PID: 10414: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:16: PID: 10414: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: EVU 1:V/4A 2: V/8A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: lla3 0	llv3 239.8	llas13 0 llas23  soclp1 33 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: lla2 0	llv2 238.2	llas12 0 llas22  sofortll 16 hausverbrauch 1244 wattbezug 73 uberschuss -73 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: lla1 13	llv1 236.5	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: pv1watt -4482 pv2watt  pvwatt -4482 ladeleistung 3261 llalt 14 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:16: PID: 10414: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:15: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484873.8633730258, Einspeisung[Wh]: 777279.5857149113
2022-03-12 11:21:11: PID: 10414: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:07: PID: 8859: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:07: PID: 8859: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:21:07: PID: 8859: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:21:06: PID: 8859: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:21:06: PID: 8859: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: EVU 1:V/5A 2: V/8A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: lla3 0	llv3 239.9	llas13 0 llas23  soclp1 33 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: lla2 0	llv2 238.4	llas12 0 llas22  sofortll 16 hausverbrauch 1109 wattbezug -272 uberschuss 272 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:21:06: PID: 8859: lla1 13	llv1 236.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:21:05: PID: 8859: pv1watt -4673 pv2watt  pvwatt -4673 ladeleistung 3242 llalt 14 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:21:05: PID: 8859: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:21:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484873.841388889, Einspeisung[Wh]: 777279.2827088844
2022-03-12 11:21:01: PID: 8859: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:20:57: PID: 7296: anzahlphasen 4 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:20:56: PID: 7296: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:20:56: PID: 7296: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:20:56: PID: 7296: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:20:55: PID: 7296: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: EVU 1:V/4A 2: V/8A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: lla3 0	llv3 240.1	llas13 0 llas23  soclp1 33 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: lla2 0	llv2 238.5	llas12 0 llas22  sofortll 16 hausverbrauch 1070 wattbezug -85 uberschuss 85 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: lla1 13	llv1 236.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: pv1watt -4482 pv2watt  pvwatt -4482 ladeleistung 3277 llalt 14 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 7296: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:20:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484873.841388889, Einspeisung[Wh]: 777278.7746667985
Verfasst: Sa Mär 12, 2022 10:35 am
von fussi24
Jetzt ist die Sonne nochmals weg gegangen und die Wallboxen sind wie gewünscht ausgegangen. Danach ist die Garage wieder angegangen und der Schuppen nicht.
Log 1/2
2022-03-12 11:29:51: PID: 27891: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:47: PID: 26355: PV Einschaltverzögerung auf 10 erhöht, Ziel 40 (LV1) at 112 nurpvlademodus nurpv.sh
2022-03-12 11:29:47: PID: 26355: Überschuss 1958; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:47: PID: 26355: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:46: PID: 26355: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:46: PID: 26355: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:46: PID: 26355: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:45: PID: 26355: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: EVU 1:V/3A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: lla3 0	llv3 237.8	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: lla2 0	llv2 237.7	llas12 0 llas22  sofortll 16 hausverbrauch 1143 wattbezug -1958 uberschuss 1958 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: lla1 0	llv1 238.4	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: pv1watt -4529 pv2watt  pvwatt -4529 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 26355: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:45: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777309.671973314
2022-03-12 11:29:41: PID: 26355: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:37: PID: 24770: Überschuss 1672; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:37: PID: 24770: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:36: PID: 24770: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:36: PID: 24770: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:36: PID: 24770: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:35: PID: 24770: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: EVU 1:V/2A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: lla2 0	llv2 237.6	llas12 0 llas22  sofortll 16 hausverbrauch 1121 wattbezug -1672 uberschuss 1672 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: lla1 0	llv1 238.6	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: pv1watt -4208 pv2watt  pvwatt -4208 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 24770: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:35: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777304.6597440824
2022-03-12 11:29:31: PID: 24770: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:27: PID: 23219: Überschuss 1507; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:27: PID: 23219: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:26: PID: 23219: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:26: PID: 23219: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:26: PID: 23219: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:25: PID: 23219: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: EVU 1:V/2A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: lla2 0	llv2 237.3	llas12 0 llas22  sofortll 16 hausverbrauch 1205 wattbezug -1507 uberschuss 1507 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: lla1 0	llv1 238.4	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: pv1watt -4115 pv2watt  pvwatt -4115 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 23219: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777300.136675419
2022-03-12 11:29:21: PID: 23219: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:17: PID: 21653: Überschuss 1450; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:17: PID: 21653: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:17: PID: 21653: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:17: PID: 21653: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:16: PID: 21653: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:16: PID: 21653: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: EVU 1:V/2A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: lla3 0	llv3 237.8	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: lla2 0	llv2 237.7	llas12 0 llas22  sofortll 16 hausverbrauch 1189 wattbezug -1450 uberschuss 1450 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: lla1 0	llv1 237.3	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:16: PID: 21653: pv1watt -4029 pv2watt  pvwatt -4029 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:15: PID: 21653: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:15: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777296.1779404839
2022-03-12 11:29:11: PID: 21653: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:08: PID: 20101: Überschuss 1370; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:08: PID: 20101: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:08: PID: 20101: LP1 Modbus 0 korrekt (LV1) at 236 evsemodbuscheck evsedintest.sh
2022-03-12 11:29:06: PID: 20101: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:06: PID: 20101: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:06: PID: 20101: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:05: PID: 20101: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: EVU 1:V/2A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: lla3 0	llv3 238.0	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: lla2 0	llv2 238.1	llas12 0 llas22  sofortll 16 hausverbrauch 1184 wattbezug -1370 uberschuss 1370 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: lla1 0	llv1 237.5	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: pv1watt -3933 pv2watt  pvwatt -3933 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 20101: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777292.1656505872
2022-03-12 11:29:01: PID: 20101: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:58: PID: 18514: Überschuss 1253; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:28:58: PID: 18514: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:57: PID: 18514: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:57: PID: 18514: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:57: PID: 18514: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:56: PID: 18514: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: EVU 1:V/2A 2: V/3A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: lla3 0	llv3 238.1	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: lla2 0	llv2 237.8	llas12 0 llas22  sofortll 16 hausverbrauch 1156 wattbezug -1253 uberschuss 1253 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: lla1 0	llv1 237.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: pv1watt -3779 pv2watt  pvwatt -3779 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:56: PID: 18514: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777288.6730036864
2022-03-12 11:28:51: PID: 18514: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:49: PID: 16984: **** WARNING **** Regulation loop needs 8 seconds (LV0) at 57 cleanup /var/www/html/openWB/regel.sh
2022-03-12 11:28:49: PID: 16984: Überschuss 1166; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:28:49: PID: 16984: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:48: PID: 16984: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:48: PID: 16984: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:48: PID: 16984: Zeit zum abfragen aller Werte 6 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:47: PID: 16984: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: EVU 1:V/2A 2: V/2A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: lla3 0	llv3 237.9	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: lla2 0	llv2 238.1	llas12 0 llas22  sofortll 16 hausverbrauch 1198 wattbezug -1166 uberschuss 1166 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: lla1 0	llv1 237.6	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: pv1watt -3731 pv2watt  pvwatt -3731 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:47: PID: 16984: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:46: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777285.6541635494
2022-03-12 11:28:42: PID: 16984: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:38: PID: 15400: Überschuss 1197; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:28:38: PID: 15400: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:37: PID: 15400: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:37: PID: 15400: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:37: PID: 15400: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:36: PID: 15400: chargestatlp1 0	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: EVU 1:V/2A 2: V/2A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: lla3 0	llv3 237.8	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: lla2 0	llv2 237.6	llas12 0 llas22  sofortll 16 hausverbrauch 1167 wattbezug -1197 uberschuss 1197 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: lla1 0	llv1 237.5	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: pv1watt -3715 pv2watt  pvwatt -3715 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 15400: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:36: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7355054526, Einspeisung[Wh]: 777282.077550422
2022-03-12 11:28:32: PID: 15400: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:28: PID: 13818: pv ladung beendet (LV1) at 379 nurpvlademodus nurpv.sh
2022-03-12 11:28:28: PID: 13818: Abschaltschwelle: -300, Überschuss derzeit: -1461 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:28:27: PID: 13818: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:27: PID: 13818: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:27: PID: 13818: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:27: PID: 13818: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:26: PID: 13818: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: EVU 1:V/4A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: lla2 0	llv2 238.1	llas12 0 llas22  sofortll 16 hausverbrauch 1185 wattbezug 1461 uberschuss -1461 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: lla1 5	llv1 236.5	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: pv1watt -3655 pv2watt  pvwatt -3655 ladeleistung 2603 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:26: PID: 13818: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484999.6169945113, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:28:22: PID: 13818: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:17: PID: 12230: Nur PV auf Minimalstromstaerke, PV Counter auf 300 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:28:17: PID: 12230: Abschaltschwelle: -300, Überschuss derzeit: -1497 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:28:17: PID: 12230: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:17: PID: 12230: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:17: PID: 12230: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:17: PID: 12230: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:16: PID: 12230: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: EVU 1:V/4A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: lla3 0	llv3 237.6	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: lla2 0	llv2 238.1	llas12 0 llas22  sofortll 16 hausverbrauch 1151 wattbezug 1497 uberschuss -1497 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: lla1 5	llv1 236.7	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: pv1watt -3577 pv2watt  pvwatt -3577 ladeleistung 2605 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 12230: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:16: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484995.5200379016, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:28:11: PID: 12230: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:07: PID: 10669: Nur PV auf Minimalstromstaerke, PV Counter auf 290 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:28:07: PID: 10669: Abschaltschwelle: -300, Überschuss derzeit: -1573 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:28:07: PID: 10669: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:07: PID: 10669: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:28:07: PID: 10669: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:28:07: PID: 10669: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:28:06: PID: 10669: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: lla3 0	llv3 237.4	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: lla2 0	llv2 237.9	llas12 0 llas22  sofortll 16 hausverbrauch 1189 wattbezug 1573 uberschuss -1573 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: lla1 5	llv1 236.6	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: pv1watt -3467 pv2watt  pvwatt -3467 ladeleistung 2548 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 10669: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:28:06: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484991.2668081424, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:28:01: PID: 10669: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:57: PID: 9051: Nur PV auf Minimalstromstaerke, PV Counter auf 280 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:57: PID: 9051: Abschaltschwelle: -300, Überschuss derzeit: -1592 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:57: PID: 9051: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:56: PID: 9051: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:56: PID: 9051: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:56: PID: 9051: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:55: PID: 9051: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: lla3 0	llv3 236.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: lla2 0	llv2 236.7	llas12 0 llas22  sofortll 16 hausverbrauch 1156 wattbezug 1592 uberschuss -1592 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: lla1 5	llv1 235.2	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: pv1watt -3432 pv2watt  pvwatt -3432 ladeleistung 2566 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 9051: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484986.6576383011, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:51: PID: 9051: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:47: PID: 7496: Nur PV auf Minimalstromstaerke, PV Counter auf 270 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:47: PID: 7496: Abschaltschwelle: -300, Überschuss derzeit: -1569 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:47: PID: 7496: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:47: PID: 7496: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:46: PID: 7496: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:46: PID: 7496: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:46: PID: 7496: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: lla3 0	llv3 236.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: lla2 0	llv2 236.8	llas12 0 llas22  sofortll 16 hausverbrauch 1187 wattbezug 1569 uberschuss -1569 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: lla1 5	llv1 235.3	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: pv1watt -3472 pv2watt  pvwatt -3472 ladeleistung 2551 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:46: PID: 7496: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:45: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484982.3574516699, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:41: PID: 7496: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:37: PID: 5906: Nur PV auf Minimalstromstaerke, PV Counter auf 260 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:37: PID: 5906: Abschaltschwelle: -300, Überschuss derzeit: -1647 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:37: PID: 5906: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:36: PID: 5906: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:36: PID: 5906: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:36: PID: 5906: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:36: PID: 5906: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:36: PID: 5906: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:36: PID: 5906: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:36: PID: 5906: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:36: PID: 5906: lla3 0	llv3 236.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:36: PID: 5906: lla2 0	llv2 236.8	llas12 0 llas22  sofortll 16 hausverbrauch 1148 wattbezug 1647 uberschuss -1647 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:35: PID: 5906: lla1 5	llv1 235.2	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:35: PID: 5906: pv1watt -3416 pv2watt  pvwatt -3416 ladeleistung 2586 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:35: PID: 5906: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:35: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484977.8524799494, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:31: PID: 5906: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:27: PID: 4332: Nur PV auf Minimalstromstaerke, PV Counter auf 250 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:27: PID: 4332: Abschaltschwelle: -300, Überschuss derzeit: -1711 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:27: PID: 4332: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:27: PID: 4332: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:27: PID: 4332: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:26: PID: 4332: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:26: PID: 4332: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: lla3 0	llv3 236.1	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: lla2 0	llv2 236.6	llas12 0 llas22  sofortll 16 hausverbrauch 1089 wattbezug 1711 uberschuss -1711 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: lla1 5	llv1 235.1	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: pv1watt -3360 pv2watt  pvwatt -3360 ladeleistung 2617 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:26: PID: 4332: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:25: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484973.216005115, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:21: PID: 4332: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:17: PID: 2741: Nur PV auf Minimalstromstaerke, PV Counter auf 240 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:17: PID: 2741: Abschaltschwelle: -300, Überschuss derzeit: -1752 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:17: PID: 2741: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:16: PID: 2741: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:16: PID: 2741: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:16: PID: 2741: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:15: PID: 2741: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: EVU 1:V/5A 2: V/4A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: lla3 0	llv3 236.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: lla2 0	llv2 236.2	llas12 0 llas22  sofortll 16 hausverbrauch 1121 wattbezug 1752 uberschuss -1752 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: lla1 5	llv1 235.4	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: pv1watt -3334 pv2watt  pvwatt -3334 ladeleistung 2562 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 2741: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:15: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484968.337433778, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:11: PID: 2741: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:07: PID: 1101: Nur PV auf Minimalstromstaerke, PV Counter auf 230 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:27:07: PID: 1101: Abschaltschwelle: -300, Überschuss derzeit: -1891 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:27:07: PID: 1101: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:06: PID: 1101: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:27:06: PID: 1101: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:27:06: PID: 1101: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:27:06: PID: 1101: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:27:06: PID: 1101: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:27:06: PID: 1101: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:27:06: PID: 1101: EVU 1:V/5A 2: V/5A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:27:06: PID: 1101: lla3 0	llv3 236.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:27:05: PID: 1101: lla2 0	llv2 236.7	llas12 0 llas22  sofortll 16 hausverbrauch 1157 wattbezug 1891 uberschuss -1891 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:27:05: PID: 1101: lla1 5	llv1 235.1	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:27:05: PID: 1101: pv1watt -3348 pv2watt  pvwatt -3348 ladeleistung 2579 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:27:05: PID: 1101: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:27:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484963.3324433104, Einspeisung[Wh]: 777281.3255555555
2022-03-12 11:27:01: PID: 1101: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:26:58: PID: 31915: Nur PV auf Minimalstromstaerke, PV Counter auf 220 erhöht (LV1) at 373 nurpvlademodus nurpv.sh
2022-03-12 11:26:58: PID: 31915: Abschaltschwelle: -300, Überschuss derzeit: -1942 (LV1) at 366 nurpvlademodus nurpv.sh
2022-03-12 11:26:58: PID: 31915: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:26:57: PID: 31915: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:26:57: PID: 31915: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:26:57: PID: 31915: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:26:56: PID: 31915: chargestatlp1 1	chargestatlp2 1	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: EVU 1:V/5A 2: V/5A 3: V/1A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: lla3 0	llv3 236.0	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: lla2 0	llv2 236.6	llas12 0 llas22  sofortll 16 hausverbrauch 1192 wattbezug 1942 uberschuss -1942 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: lla1 5	llv1 235.3	llas11 5 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: pv1watt -3327 pv2watt  pvwatt -3327 ladeleistung 2544 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 31915: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:26:56: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1484958.2311997844, Einspeisung[Wh]: 777281.3255555555
Re: Peugeot e208 lädt nicht (mehr)
von fussi24
Log 2/2
2022-03-12 11:32:11: PID: 17681: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:32:07: PID: 16134: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:32:06: PID: 16134: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:32:06: PID: 16134: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:32:06: PID: 16134: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:32:05: PID: 16134: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: EVU 1:V/5A 2: V/7A 3: V/5A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: lla3 0	llv3 238.6	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: lla2 0	llv2 238.9	llas12 0 llas22  sofortll 16 hausverbrauch 1358 wattbezug -444 uberschuss 444 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: lla1 12	llv1 236.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: pv1watt -6200 pv2watt  pvwatt -6200 ladeleistung 2999 llalt 13 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 16134: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:32:05: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777354.4307515653
2022-03-12 11:32:01: PID: 16134: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:59: PID: 14534: pv ladung auf 13 erhoeht (LV1) at 296 nurpvlademodus nurpv.sh
2022-03-12 11:31:58: PID: 14534: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:57: PID: 14534: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:57: PID: 14534: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:57: PID: 14534: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:56: PID: 14534: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: EVU 1:V/5A 2: V/7A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: lla3 0	llv3 237.7	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: lla2 0	llv2 239.3	llas12 0 llas22  sofortll 16 hausverbrauch 1046 wattbezug -585 uberschuss 585 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: lla1 11	llv1 236.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: pv1watt -5972 pv2watt  pvwatt -5972 ladeleistung 2794 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 14534: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:56: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777353.1376037576
2022-03-12 11:31:52: PID: 14534: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:48: PID: 12992: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:47: PID: 12992: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:47: PID: 12992: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:47: PID: 12992: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:46: PID: 12992: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: EVU 1:V/4A 2: V/7A 3: V/5A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: lla3 0	llv3 238.2	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: lla2 0	llv2 238.8	llas12 0 llas22  sofortll 16 hausverbrauch 1194 wattbezug -49 uberschuss 49 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: lla1 11	llv1 236.9	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: pv1watt -5567 pv2watt  pvwatt -5567 ladeleistung 2794 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 12992: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:46: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777352.2661828997
2022-03-12 11:31:42: PID: 12992: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:38: PID: 11445: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:37: PID: 11445: CP Unterbrechung an LP2 wird durchgeführt (LV0) at 284 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:37: PID: 11445: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:37: PID: 11445: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:37: PID: 11445: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:36: PID: 11445: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: EVU 1:V/4A 2: V/7A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: lla3 0	llv3 238.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: lla2 0	llv2 239.0	llas12 0 llas22  sofortll 16 hausverbrauch 1353 wattbezug 0 uberschuss 0 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: lla1 11	llv1 237.1	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: pv1watt -5533 pv2watt  pvwatt -5533 ladeleistung 2776 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 11445: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:36: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.735279344, Einspeisung[Wh]: 777352.1967139291
2022-03-12 11:31:32: PID: 11445: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:28: PID: 9908: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:27: PID: 9908: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:27: PID: 9908: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:27: PID: 9908: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:26: PID: 9908: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: EVU 1:V/4A 2: V/7A 3: V/5A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: lla3 0	llv3 238.5	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: lla2 0	llv2 239.3	llas12 0 llas22  sofortll 16 hausverbrauch 1327 wattbezug -106 uberschuss 106 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: lla1 11	llv1 237.3	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: pv1watt -5756 pv2watt  pvwatt -5756 ladeleistung 2793 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 9908: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:26: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777352.0533167126
2022-03-12 11:31:22: PID: 9908: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:18: PID: 8369: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:17: PID: 8369: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:17: PID: 8369: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:17: PID: 8369: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:16: PID: 8369: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: EVU 1:V/4A 2: V/7A 3: V/5A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: lla3 0	llv3 238.4	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: lla2 0	llv2 238.6	llas12 0 llas22  sofortll 16 hausverbrauch 1306 wattbezug -91 uberschuss 91 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: lla1 11	llv1 236.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: pv1watt -5696 pv2watt  pvwatt -5696 ladeleistung 2751 llalt 12 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 8369: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:16: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777351.7814026555
2022-03-12 11:31:12: PID: 8369: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:08: PID: 6788: pv ladung auf 12 erhoeht (LV1) at 296 nurpvlademodus nurpv.sh
2022-03-12 11:31:08: PID: 6788: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:07: PID: 6788: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:31:07: PID: 6788: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:31:07: PID: 6788: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:31:06: PID: 6788: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: EVU 1:V/4A 2: V/6A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: lla3 0	llv3 238.2	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: lla2 0	llv2 238.6	llas12 0 llas22  sofortll 16 hausverbrauch 1107 wattbezug -687 uberschuss 687 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: lla1 10	llv1 237.2	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: pv1watt -5701 pv2watt  pvwatt -5701 ladeleistung 2492 llalt 11 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 6788: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:31:06: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777350.6796709369
2022-03-12 11:31:02: PID: 6788: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:58: PID: 5201: pv ladung auf 11 erhoeht (LV1) at 296 nurpvlademodus nurpv.sh
2022-03-12 11:30:58: PID: 5201: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:57: PID: 5201: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:57: PID: 5201: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:57: PID: 5201: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:56: PID: 5201: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: EVU 1:V/4A 2: V/4A 3: V/5A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: lla3 0	llv3 238.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: lla2 0	llv2 238.4	llas12 0 llas22  sofortll 16 hausverbrauch 1369 wattbezug -1093 uberschuss 1093 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: lla1 8	llv1 237.9	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: pv1watt -5948 pv2watt  pvwatt -5948 ladeleistung 2075 llalt 9 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 5201: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:56: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777348.1607179062
2022-03-12 11:30:52: PID: 5201: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:48: PID: 3637: pv ladung auf 9 erhoeht (LV1) at 296 nurpvlademodus nurpv.sh
2022-03-12 11:30:48: PID: 3637: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:47: PID: 3637: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:47: PID: 3637: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:47: PID: 3637: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:46: PID: 3637: chargestatlp1 1	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: EVU 1:V/4A 2: V/2A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: lla3 0	llv3 237.8	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: lla2 0	llv2 238.5	llas12 0 llas22  sofortll 16 hausverbrauch 1099 wattbezug -1447 uberschuss 1447 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: lla1 6	llv1 238.0	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: pv1watt -5396 pv2watt  pvwatt -5396 ladeleistung 1423 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 3637: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:46: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777344.6537556584
2022-03-12 11:30:42: PID: 3637: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:37: PID: 2030: anzahlphasen 1 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:37: PID: 2030: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:37: PID: 2030: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:37: PID: 2030: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:36: PID: 2030: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: EVU 1:V/3A 2: V/4A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: lla3 0	llv3 237.5	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: lla2 0	llv2 238.0	llas12 0 llas22  sofortll 16 hausverbrauch 1152 wattbezug -2111 uberschuss 2111 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: lla1 0	llv1 238.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: pv1watt -4813 pv2watt  pvwatt -4813 ladeleistung 0 llalt 6 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 2030: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:36: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777339.6677538031
2022-03-12 11:30:32: PID: 2030: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:28: PID: 401: nur pv ladung auf 6 starten (LV1) at 115 nurpvlademodus nurpv.sh
2022-03-12 11:30:28: PID: 401: Überschuss 2089; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:30:28: PID: 401: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:27: PID: 401: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:27: PID: 401: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:27: PID: 401: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:26: PID: 401: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: EVU 1:V/3A 2: V/4A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: lla3 0	llv3 237.1	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: lla2 0	llv2 237.6	llas12 0 llas22  sofortll 16 hausverbrauch 1271 wattbezug -2089 uberschuss 2089 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: lla1 0	llv1 238.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: pv1watt -4785 pv2watt  pvwatt -4785 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 401: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:26: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777333.8705678721
2022-03-12 11:30:22: PID: 401: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:18: PID: 31314: PV Einschaltverzögerung auf 40 erhöht, Ziel 40 (LV1) at 112 nurpvlademodus nurpv.sh
2022-03-12 11:30:18: PID: 31314: Überschuss 2236; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:30:18: PID: 31314: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:17: PID: 31314: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:17: PID: 31314: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:17: PID: 31314: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:16: PID: 31314: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: EVU 1:V/3A 2: V/4A 3: V/3A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: lla3 0	llv3 237.3	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: lla2 0	llv2 237.8	llas12 0 llas22  sofortll 16 hausverbrauch 1159 wattbezug -2236 uberschuss 2236 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: lla1 0	llv1 238.7	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: pv1watt -4923 pv2watt  pvwatt -4923 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 31314: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:16: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777327.9306580921
2022-03-12 11:30:11: PID: 31314: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:08: PID: 29454: PV Einschaltverzögerung auf 30 erhöht, Ziel 40 (LV1) at 112 nurpvlademodus nurpv.sh
2022-03-12 11:30:08: PID: 29454: Überschuss 2333; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:30:08: PID: 29454: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:07: PID: 29454: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:30:07: PID: 29454: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:30:07: PID: 29454: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:30:06: PID: 29454: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: EVU 1:V/3A 2: V/4A 3: V/4A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: lla3 0	llv3 237.2	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: lla2 0	llv2 237.8	llas12 0 llas22  sofortll 16 hausverbrauch 1144 wattbezug -2333 uberschuss 2333 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: lla1 0	llv1 238.8	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: pv1watt -5004 pv2watt  pvwatt -5004 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 29454: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:30:06: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777321.7186456734
2022-03-12 11:30:04: Modul tibbergetprices.py: Modullaufzeit 0.003344 s
2022-03-12 11:30:04: Modul tibbergetprices.py: Ausreichend zukuenftige Preise in bisheriger Preisliste
2022-03-12 11:30:04: Modul tibbergetprices.py: Bereinige bisherige Preisliste
2022-03-12 11:30:04: Modul tibbergetprices.py: Lese bisherige Preisliste
2022-03-12 11:30:04: PID: 29468: ##### cron5min.sh finished ##### (LV0) at 426 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:03: PID: 29468: logfile cleanup triggered (LV1) at 423 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:03: PID: 29468: starting evsecheck (LV1) at 419 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:03:  Load: 1.34 1.95 2.12
2022-03-12 11:30:03: PID: 29468: pingcheck configured; starting (LV1) at 409 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:03: PID: 29468: modbus tcp server already running (LV1) at 401 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: external openWB or daemon mode not configured; checking network setup (LV1) at 336 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: smarthome handler is already running (LV1) at 319 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: legacy_run_server is already running (LV1) at 313 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: mqtt handler is already running (LV1) at 300 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: current ip: 192.168.1.9 (LV1) at 295 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: updating daily yield stats (LV1) at 165 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: electricity provider configured; trigger price update (LV1) at 158 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: Netzschutz konfiguriert; aktuelle Frequenz: 4995 (LV1) at 110 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: daily csv updated: /var/www/html/openWB/web/logging/data/daily/20220312.csv (LV1) at 102 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:02: PID: 29468: ##### cron5min.sh started ##### (LV0) at 23 main /var/www/html/openWB/runs/cron5min.sh
2022-03-12 11:30:01: PID: 29454: **** Regulation loop start **** (LV1) at 70 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:57: PID: 27891: PV Einschaltverzögerung auf 20 erhöht, Ziel 40 (LV1) at 112 nurpvlademodus nurpv.sh
2022-03-12 11:29:57: PID: 27891: Überschuss 1987; mindestens 1800 (LV1) at 104 nurpvlademodus nurpv.sh
2022-03-12 11:29:57: PID: 27891: anzahlphasen 2 (LV1) at 574 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:56: PID: 27891: Timing Umschaltung: 780 / 180 (LV1) at 15 u1p3pswitch u1p3p.sh
2022-03-12 11:29:56: PID: 27891: automatische Umschaltung aktiv (LV1) at 14 u1p3pswitch u1p3p.sh
2022-03-12 11:29:56: PID: 27891: Zeit zum abfragen aller Werte 5 Sekunden (LV1) at 176 main /var/www/html/openWB/regel.sh
2022-03-12 11:29:55: PID: 27891: chargestatlp1 0	chargestatlp2 0	chargestatlp3 0 (LV1) at 1275 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: plugstatlp1 1	plugstatlp2 1	plugstatlp3 0 (LV1) at 1274 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: lp1enabled 1	lp2enabled 1	lp3enabled 1 (LV1) at 1273 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: EVU 1:V/3A 2: V/3A 3: V/2A (LV1) at 1272 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: lla3 0	llv3 238.1	llas13 0 llas23  soclp1 38 soclp2 94 (LV1) at 1271 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: lla2 0	llv2 238.0	llas12 0 llas22  sofortll 16 hausverbrauch 1208 wattbezug -1987 uberschuss 1987 (LV1) at 1270 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: lla1 0	llv1 238.3	llas11 0 llas21  mindestuberschuss 900 abschaltuberschuss 300 lademodus 2 (LV1) at 1269 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: pv1watt -4622 pv2watt  pvwatt -4622 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1268 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 27891: etproviderprice  etprovidermaxprice  (LV1) at 1266 loadvars loadvars.sh
2022-03-12 11:29:55: PID: 4785: root: simcount Ergebnis: Bezug[Wh]: 1485000.7352777778, Einspeisung[Wh]: 777315.1188419282
Verfasst: Do Mär 17, 2022 12:20 pm
von mrinas
fussi24@web.de hat geschrieben: Sa Mär 12, 2022 10:35 am Log 2/2
Danke für die Logs und Screenshots! Ich konnte ehrlich gesagt nirgends einen Hinweis auf eine CP-Unterbrechung finden, was erklären würde warum der Peugeot nicht zu laden beginnt, ohne CP-U tut sich da ja leider überhaupt gar nichts.
Hintergrund könnte sein dass zwei Ladepunkte vorhanden sind und der zweite Ladepunkt mit einer Ladung begonnen hat. Es gab eine Abfrage auf 'ist eine Ladung aktiv - wenn ja, keine CP-U starten' - allerdings über alle Ladepunkte hinweg, nicht auf den spezielle LP bezogen.
Müsste das hier sein: https://github.com/snaptec/openWB/blob/ ... pv.sh#L141
Kannst Du den zweiten Ladepunkt mal deaktivieren oder das Auto abstöpseln und das beobachten? Sofern meine Theorie stimmt sollte der Löwe nun anfangen zu laden.
Verfasst: So Mär 20, 2022 3:32 pm
von fussi24
Danke für Deine Antwort.
Ich war die ganze Woche unterwegs und der e208 hat nun an der ersten Wallbox gestanden. Hier hat er geladen wie ein Kätzchen. Das komplette Programm inkl Phasenwechsel. Die nächste Woche bin ich auch unterwegs und dann steht er wieder an seinem Platz. Wenn es dann wieder funktioniert, geht es in die Richtung welche Du vermutest.
Verfasst: Fr Aug 12, 2022 4:45 pm
von eRider
Hallo fusi24
Konntest du das Problem lösen. Ich habe das gleiche Problem mit meinem e208. Als ich die Brücke für Zoe noch hatte, hat es funktioniert, nur leider im mit 3Phasen und nun nicht mehr, bzw. wenn ich den Wagen entsperre oder bei Überschuss mit der Peugeot App das laden starte.
