Heutiges Update der Sungrow Komponenten hat alles zerschossen, bekomme keine Daten mehr vom WR, Batterie und Zähler, damit WB auch nicht nutzbar. Bis gestern ging alles und auch die Vorzeichen der Batterie machten nie Probleme:
2024-09-25 17:26:00,055 - {root:76} - {INFO:MainThread} - # ***Start***
2024-09-25 17:26:00,094 - {modules.common.component_context:58} - {DEBUG:device0} - Update Komponenten ['Sungrow Zähler', 'Sungrow Wechselrichter', 'Sungrow Speicher']
2024-09-25 17:26:00,097 - {modules.common.component_context:58} - {DEBUG:device1} - Update Komponenten ['Sma Sunny Boy/Tripower Wechselrichter']
2024-09-25 17:26:00,098 - {modules.common.component_context:26} - {DEBUG:set values cp4} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,099 - {modules.common.component_context:26} - {DEBUG:set values cp5} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,115 - {modules.common.component_context:26} - {DEBUG:device1} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2024-09-25 17:26:00,129 - {modules.common.fault_state:49} - {ERROR:device0} - Sungrow Zähler: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> ("'list' object has no attribute 'values'",), Traceback:
File "/var/www/html/openWB/packages/modules/common/configurable_device.py", line 36, in __call__
File "/var/www/html/openWB/packages/modules/devices/sungrow/sungrow/device.py", line 29, in update_components
for component in components.values():
AttributeError: 'list' object has no attribute 'values'
2024-09-25 17:26:00,173 - {modules.common.fault_state:49} - {ERROR:device0} - Sungrow Wechselrichter: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> ("'list' object has no attribute 'values'",), Traceback:
2024-09-25 17:26:00,180 - {modules.common.fault_state:49} - {ERROR:device0} - Sungrow Speicher: FaultState FaultStateLevel.ERROR, FaultStr <class 'AttributeError'> ("'list' object has no attribute 'values'",), Traceback:
2024-09-25 17:26:00,209 - {modules.devices.sma.sma_sunny_boy.inverter:75} - {DEBUG:device1} - WR 10.1.1.116: InverterState(currents=[0.0, 0.0, 0.0], power=-430, exported=36434528, dc_power=-462)
2024-09-25 17:26:00,214 - {modules.common.store._api:26} - {DEBUG:device1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-430, exported=36434528, dc_power=-462)
2024-09-25 17:26:00,265 - {modules.common.utils.component_parser:33} - {ERROR:MainThread} - Fehlerstatus in Komponente Sungrow Speicher. Werte werden nicht aktualisiert.
2024-09-25 17:26:00,307 - {modules.common.utils.component_parser:33} - {ERROR:MainThread} - Fehlerstatus in Komponente Sungrow Wechselrichter. Werte werden nicht aktualisiert.
2024-09-25 17:26:00,309 - {modules.common.component_context:26} - {DEBUG:component3} - Update Komponente ['Sma Sunny Boy/Tripower Wechselrichter']
2024-09-25 17:26:00,310 - {modules.common.store._api:26} - {DEBUG:component3} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-430, exported=36434528, dc_power=None)
2024-09-25 17:26:00,311 - {modules.common.component_context:26} - {DEBUG:update values cp4} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,312 - {modules.common.store._api:31} - {INFO:component3} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-430, exported=36434528, dc_power=None)
2024-09-25 17:26:00,312 - {modules.common.component_context:26} - {DEBUG:update values cp5} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,338 - {modules.common.utils.component_parser:33} - {ERROR:MainThread} - Fehlerstatus in Komponente Sungrow Zähler. Werte werden nicht aktualisiert.
2024-09-25 17:26:00,364 - {modules.common.component_context:26} - {DEBUG:get ripple control receiver} - Update Komponente ['GPIOs auf der AddOn-Platine']
2024-09-25 17:26:00,365 - {modules.ripple_control_receivers.gpio.ripple_control_receiver:35} - {DEBUG:get ripple control receiver} - RSE-Kontakt 1: False, RSE-Kontakt 2: False
2024-09-25 17:26:00,365 - {modules.common.store._api:26} - {DEBUG:get ripple control receiver} - Raw data RcrState(override_value=100)
2024-09-25 17:26:00,368 - {modules.common.component_context:26} - {DEBUG:set ripple control receiver} - Update Komponente ['GPIOs auf der AddOn-Platine']
2024-09-25 17:26:00,369 - {modules.common.store._api:31} - {INFO:set ripple control receiver} - Saving RcrState(override_value=100)
2024-09-25 17:26:00,477 - {control.counter:148} - {INFO:MainThread} - Verbleibende Ströme an Zähler 0: [35.39, 36.28, 36.34]A
2024-09-25 17:26:00,477 - {control.counter:171} - {INFO:MainThread} - Verbleibende Leistung an Zähler 0: 25000W
2024-09-25 17:26:00,480 - {control.chargepoint.chargepoint:84} - {INFO:MainThread} - LP 4: Ladepunkt gesperrt, da keine Werte vom EVU- oder Zwischenzähler-Zähler empfangen wurden und deshalb kein Lastmanagement durchgeführt werden kann. Bitte schaue auf der Status-Seite nach Fehlermeldungen bei den Zählern. Falls Du dennoch laden möchtest, kannst Du als Gerät 'Virtuelles Gerät' mit einer Komponente 'Virtueller Zähler' verwenden.
2024-09-25 17:26:00,484 - {control.chargepoint.chargepoint:84} - {INFO:MainThread} - LP 5: Ladepunkt gesperrt, da keine Werte vom EVU- oder Zwischenzähler-Zähler empfangen wurden und deshalb kein Lastmanagement durchgeführt werden kann. Bitte schaue auf der Status-Seite nach Fehlermeldungen bei den Zählern. Falls Du dennoch laden möchtest, kannst Du als Gerät 'Virtuelles Gerät' mit einer Komponente 'Virtueller Zähler' verwenden.
2024-09-25 17:26:00,486 - {control.counter_all:172} - {WARNING:MainThread} - Komponente inverter1 ist im Fehlerzustand und wird nicht berücksichtigt.
2024-09-25 17:26:00,487 - {control.counter_all:172} - {WARNING:MainThread} - Komponente bat2 ist im Fehlerzustand und wird nicht berücksichtigt.
2024-09-25 17:26:00,489 - {modules.common.simcount._simcount:42} - {DEBUG:MainThread} - Previous state: SimCounterState(timestamp=1727277950.5425885, power=394, imported=6338852.882804225, exported=1224.2447313666344)
2024-09-25 17:26:00,490 - {modules.common.simcount._calculate:11} - {DEBUG:MainThread} - time passed: 0.00276302, power1: 394, power2: 389
2024-09-25 17:26:00,491 - {modules.common.simcount._calculate:27} - {DEBUG:MainThread} - power did not change sign. Total energy: 1.08172
2024-09-25 17:26:00,492 - {modules.common.simcount._simcount:65} - {DEBUG:MainThread} - imported: 1.08172 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1727277960.4894772, power=389, imported=6338853.96452837, exported=1224.2447313666344)
2024-09-25 17:26:00,494 - {control.data:266} - {INFO:MainThread} - bat2
BatData(get=Get(currents=[0.0, 0.0, 0.0], soc=100, daily_exported=2878.0, daily_imported=7355.0, imported=2098567.09, exported=1762737.36, fault_state=2, fault_str='<class \'AttributeError\'> ("\'list\' object has no attribute \'values\'",)', power=0))
2024-09-25 17:26:00,495 - {control.data:236} - {INFO:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=0, daily_exported=2878.0, daily_imported=7355.0, fault_str='Bitte die Statusmeldungen der Speicher prüfen. Es konnte kein aktueller Zählerstand ermittelt werden, da nicht alle Module Werte liefern.', fault_state=2, imported=2098567.09, exported=1762737.36, power=0), set=Set(charging_power_left=0, regulate_up=False))
2024-09-25 17:26:00,496 - {control.data:237} - {INFO:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=316.0, daily_exported=0.0, power=0, imported=8074458.98, exported=0))
2024-09-25 17:26:00,498 - {control.data:266} - {INFO:MainThread} - cp4
ChargepointData(control_parameter=ControlParameter(chargemode=<Chargemode.STOP: 'stop'>, current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, min_current=6, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=<ChargepointState.NO_CHARGING_ALLOWED: 0>, submode=<Chargemode.STOP: 'stop'>, timestamp_auto_phase_switch=None, timestamp_charge_start=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=73.0), currents=[0.0, 0.0, 0.0], daily_imported=316.0, daily_exported=0.0, error_timestamp=None, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=6057813.96, phases_in_use=0, plug_state=True, power=0, rfid_timestamp=None, rfid=None, serial_number='20074098', soc=None, soc_timestamp=None, state_str="Ladepunkt gesperrt, da keine Werte vom EVU- oder Zwischenzähler-Zähler empfangen wurden und deshalb kein Lastmanagement durchgeführt werden kann. Bitte schaue auf der Status-Seite nach Fehlermeldungen bei den Zählern. Falls Du dennoch laden möchtest, kannst Du als Gerät 'Virtuelles Gerät' mit einer Komponente 'Virtueller Zähler' verwenden.", vehicle_id=None, voltages=[230.5, 229.98, 231.67]), set=Set(charging_ev=-1, charging_ev_prev=1, current=0, energy_to_charge=0, loadmanagement_available=False, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=6057813.96, imported_at_plugtime=6057497.56, imported_since_mode_switch=0, imported_since_plugged=316.4, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=False, phases_to_use=1, plug_state_prev=True, plug_time=1727276001.445167, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x6f1dc958>), config=Config(configuration={'mode': 'series', 'ip_address': 'localhost', 'duo_num': 0}, ev=1, name='Interne openWB', type='internal_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=4))
2024-09-25 17:26:00,500 - {control.data:266} - {INFO:MainThread} - cp5
ChargepointData(control_parameter=ControlParameter(chargemode='stop', current_plan=None, failed_phase_switches=0, imported_at_plan_start=None, imported_instant_charging=None, limit=None, min_current=6, phases=0, prio=False, required_current=0, required_currents=[0.0, 0.0, 0.0], state=0, submode='stop', timestamp_auto_phase_switch=None, timestamp_charge_start=None, timestamp_perform_phase_switch=None, timestamp_switch_on_off=None), get=Get(charge_state=False, charging_current=0, charging_power=0, charging_voltage=0, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=0), currents=[0.0, 0.0, 0.0], daily_imported=0.0, daily_exported=0.0, error_timestamp=None, evse_current=0, exported=0, fault_str='Kein Fehler.', fault_state=0, imported=2016645.02, phases_in_use=1, plug_state=False, power=0, rfid_timestamp=None, rfid=None, serial_number='21298025', soc=None, soc_timestamp=None, state_str="Ladepunkt gesperrt, da keine Werte vom EVU- oder Zwischenzähler-Zähler empfangen wurden und deshalb kein Lastmanagement durchgeführt werden kann. Bitte schaue auf der Status-Seite nach Fehlermeldungen bei den Zählern. Falls Du dennoch laden möchtest, kannst Du als Gerät 'Virtuelles Gerät' mit einer Komponente 'Virtueller Zähler' verwenden.", vehicle_id=None, voltages=[230.16, 231.78, 230.58]), set=Set(charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=False, log=Log(chargemode_log_entry='_', costs=0, imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None, ev=-1, prio=False, rfid=None, serial_number=None, soc_at_start=None, soc_at_end=None, range_at_start=None, range_at_end=None), manual_lock=True, phases_to_use=1, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0x6f1a1730>), config=Config(configuration={'ip_address': '10.1.5.33', 'duo_num': 0}, ev=2, name='Externe openWB', type='external_openwb', template=0, connected_phases=3, phase_1=2, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=5))
2024-09-25 17:26:00,501 - {control.data:266} - {INFO:MainThread} - cpt0
CpTemplateData(autolock=Autolock(active=False, plans={'0': AutolockPlan(active=False, frequency=Frequency(selected='daily', once=['2021-11-01', '2021-11-05'], weekly=[False, False, False, False, False, False, False]), time=['06:00', '07:00'], name='Standard Autolock-Plan')}, wait_for_charging_end=False), charging_type='AC', id=0, max_current_multi_phases=16, max_current_single_phase=16, dc_max_current=435, name='Standard Ladepunkt-Profil', disable_after_unplug=True, valid_tags=[])
2024-09-25 17:26:00,502 - {control.data:266} - {INFO:MainThread} - counter0
CounterData(config=Config(max_currents=[35, 35, 35], max_total_power=25000), get=Get(powers=[-91, -296, -311], currents=[-0.39, -1.28, -1.34], voltages=[232.2, 231.6, 232.1], power_factors=[1.0, 1.0, 1.0], frequency=49.96, daily_exported=25346.0, daily_imported=33.0, imported=2376603.807047426, exported=5924585.438760254, fault_state=2, fault_str='<class \'AttributeError\'> ("\'list\' object has no attribute \'values\'",)', power=0), set=Set(error_counter=8, reserved_surplus=0, released_surplus=0, raw_power_left=25000, raw_currents_left=[35.39, 36.28, 36.34], surplus_power_left=0))
2024-09-25 17:26:00,503 - {control.data:241} - {INFO:MainThread} - counter_all_data
CounterAllData(config=Config(home_consumption_source_id=None, consider_less_charging=False), get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'inverter', 'children': []}, {'id': 4, 'type': 'cp', 'children': []}, {'id': 5, 'type': 'cp', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=389, smarthome_power_excluded_from_home_consumption=41, invalid_home_consumption=0, daily_yield_home_consumption=6667.0, imported_home_consumption=6338853.96452837, disengageable_smarthome_power=0))
2024-09-25 17:26:00,505 - {control.data:266} - {INFO:MainThread} - ct0
ChargeTemplateData(name='Standard-Lade-Profil', prio=False, load_default=False, et=Et(active=False, max_price=0.0002), time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='stop', pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, min_soc_current=10, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=10, dc_current=145, limit=Limit(selected='none', amount=1000, soc=50))))
2024-09-25 17:26:00,506 - {control.data:266} - {INFO:MainThread} - ct1
ChargeTemplateData(name='Master-Profil', prio=False, load_default=False, et=Et(active=False, max_price=0.0002), time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, min_soc_current=6, min_current=0, feed_in_limit=False, min_soc=0, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, dc_current=145, limit=Limit(selected='none', amount=1000, soc=100))))
2024-09-25 17:26:00,507 - {control.data:266} - {INFO:MainThread} - ct2
ChargeTemplateData(name='Slave-Profil', prio=False, load_default=False, et=Et(active=False, max_price=0.0002), time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(dc_min_current=145, dc_min_soc_current=145, min_soc_current=6, min_current=0, feed_in_limit=False, min_soc=0, max_soc=101), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=16, dc_current=145, limit=Limit(selected='none', amount=1000, soc=100))))
2024-09-25 17:26:00,508 - {control.data:266} - {INFO:MainThread} - ev0
EvData(set=Set(soc_error_counter=0), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=None, soc_timestamp=None, force_soc_update=False, range=None, fault_state=0, fault_str='Kein Fehler.'))
2024-09-25 17:26:00,515 - {control.data:266} - {INFO:MainThread} - ev1
EvData(set=Set(soc_error_counter=0), charge_template=1, ev_template=1, name='Renault Megane', tag_id=[], get=Get(soc=73.0, soc_timestamp=1727277894.48164, force_soc_update=False, range=292.0, fault_state=0, fault_str='Kein Fehler.'))
2024-09-25 17:26:00,518 - {control.data:266} - {INFO:MainThread} - ev2
EvData(set=Set(soc_error_counter=0), charge_template=2, ev_template=2, name='VW Golf', tag_id=[], get=Get(soc=None, soc_timestamp=None, force_soc_update=True, range=None, fault_state=0, fault_str='Kein Fehler.'))
2024-09-25 17:26:00,520 - {control.data:266} - {INFO:MainThread} - et0
EvTemplateData(dc_min_current=0, dc_max_current=0, name='Standard-Fahrzeug-Profil', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=16, battery_capacity=82000, efficiency=90, nominal_difference=2, keep_charge_active_duration=40)
2024-09-25 17:26:00,521 - {control.data:266} - {INFO:MainThread} - et1
EvTemplateData(dc_min_current=0, dc_max_current=0, name='Renault Megane-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=4, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17000, min_current=6, max_current_single_phase=16, battery_capacity=60000, efficiency=90, nominal_difference=2, keep_charge_active_duration=40)
2024-09-25 17:26:00,521 - {control.data:266} - {INFO:MainThread} - et2
EvTemplateData(dc_min_current=0, dc_max_current=0, name='VW Golf Hybrid-Vorlage', max_current_multi_phases=16, max_phases=1, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=14000, min_current=6, max_current_single_phase=16, battery_capacity=13000, efficiency=90, nominal_difference=2, keep_charge_active_duration=40)
2024-09-25 17:26:00,522 - {control.data:245} - {INFO:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=1), phase_switch_delay=14, pv_charging=PvCharging(bat_power_reserve=2500, bat_power_reserve_active=True, control_range=[-115, 115], feed_in_yield=0, phase_switch_delay=7, phases_to_use=0, bat_power_discharge=0, bat_power_discharge_active=True, min_bat_soc=95, bat_mode='bat_mode', switch_off_delay=60, switch_off_threshold=50, switch_on_delay=30, switch_on_threshold=1400), retry_failed_phase_switches=True, scheduled_charging=ScheduledCharging(phases_to_use=0, phases_to_use_pv=0), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=20, unbalanced_load=True), control_interval=10, extern_display_mode='primary', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp=None, http_api=False, mqtt_bridge=False, prices=Prices(bat=0.0002, cp=0, grid=0.000248, pv=7e-05), range_unit='km', ripple_control_receiver=RippleControlReceiver(get=RippleControlReceiverGet(fault_state=0, fault_str='Kein Fehler.', override_value=100), module={'name': 'GPIOs auf der AddOn-Platine', 'type': 'gpio', 'configuration': {}}, override_reference=<OverrideReference.CHARGEPOINT: 'chargepoint'>))
2024-09-25 17:26:00,523 - {control.data:246} - {INFO:MainThread} - general_data-display
primary
2024-09-25 17:26:00,524 - {control.data:247} - {INFO:MainThread} - graph_data
2024-09-25 17:26:00,525 - {control.data:248} - {INFO:MainThread} - optional_data
OptionalData(et=Et(get=EtGet(fault_state=0, fault_str='Kein Fehler.', prices={})), int_display=InternalDisplay(active=True, on_if_plugged_in=True, pin_active=False, pin_code='0000', standby=120, theme=<modules.display_themes.cards.config.CardsDisplayTheme object at 0x6f1a5478>), led=Led(active=False), rfid=Rfid(active=False), dc_charging=False)
2024-09-25 17:26:00,525 - {control.data:266} - {INFO:MainThread} - pv1
PvData(config=Config(max_ac_out=10000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=22993.0, monthly_exported=632068.7590000005, yearly_exported=7480236.981000001, exported=7750475.582, fault_state=2, fault_str='<class \'AttributeError\'> ("\'list\' object has no attribute \'values\'",)', power=-731))
2024-09-25 17:26:00,526 - {control.data:266} - {INFO:MainThread} - pv3
PvData(config=Config(max_ac_out=6000), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=15643.0, monthly_exported=435187, yearly_exported=5149746, exported=36434528, fault_state=0, fault_str='Kein Fehler.', power=-430))
2024-09-25 17:26:00,531 - {control.data:250} - {INFO:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=38621.0, fault_str='Bitte die Statusmeldungen der Wechselrichter prüfen. Es konnte kein aktueller Zählerstand ermittelt werden, da nicht alle Module Werte liefern.', fault_state=2, monthly_exported=1067255.7590000005, yearly_exported=12629982.981, exported=44184981.582, power=-430))
2024-09-25 17:26:00,543 - {control.data:266} - {INFO:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'backup_cloud': {'backup_before_update': True}, 'current_commit': '2024-09-25 15:18:09 +0200 [5b3c110fa]', 'current_branch': 'master', 'current_branch_commit': '2024-09-25 15:18:09 +0200 [5b3c110fa]', 'current_missing_commits': [], 'datastore_version': 61, 'dataprotection_acknowledged': True, 'usage_terms_acknowledged': True, 'debug_level': 10, 'ip_address': '10.1.5.32', 'release_train': 'master', 'version': '2.1.6-Alpha.1', 'boot_done': True, 'lastlivevaluesJson': {'timestamp': 1727277950, 'time': '17:25:50', 'house-power': 0.394, 'charging-all': 0.0, 'pv-all': 0.434, 'cp4-power': 0.0, 'cp5-power': 0.0, 'ev1-soc': 73.0, 'bat-all-power': 0.0, 'bat-all-soc': 0}, 'installAssistantDone': True, 'serial_number': 'owba3911138', 'module_update_completed': True}
2024-09-25 17:26:00,550 - {control.data:279} - {INFO:MainThread} - device0
{'name': 'Sungrow', 'type': 'sungrow', 'vendor': 'sungrow', 'id': 0, 'configuration': {'ip_address': '10.1.1.117', 'port': 502, 'modbus_id': 1, 'version': 3}}
2024-09-25 17:26:00,551 - {control.data:281} - {INFO:MainThread} - component0
{'name': 'Sungrow Zähler', 'info': {'manufacturer': None, 'model': None}, 'type': 'counter', 'id': 0, 'configuration': {}}
2024-09-25 17:26:00,552 - {control.data:281} - {INFO:MainThread} - component1
{'name': 'Sungrow Wechselrichter', 'info': {'manufacturer': None, 'model': None}, 'type': 'inverter', 'id': 1, 'configuration': {}}
2024-09-25 17:26:00,554 - {control.data:281} - {INFO:MainThread} - component2
{'name': 'Sungrow Speicher', 'info': {'manufacturer': None, 'model': None}, 'type': 'bat', 'id': 2, 'configuration': {}}
2024-09-25 17:26:00,562 - {control.data:279} - {INFO:MainThread} - device1
{'name': 'SMA Sunny Boy/Tripower', 'type': 'sma_sunny_boy', 'vendor': 'sma', 'id': 1, 'configuration': {'ip_address': '10.1.1.116', 'port': 502}}
2024-09-25 17:26:00,564 - {control.data:281} - {INFO:MainThread} - component3
{'name': 'Sma Sunny Boy/Tripower Wechselrichter', 'info': {'manufacturer': None, 'model': None}, 'type': 'inverter', 'id': 3, 'configuration': {'hybrid': False, 'version': 0, 'modbus_id': 3}}
2024-09-25 17:26:00,565 - {control.data:253} - {INFO:MainThread} -
2024-09-25 17:26:00,573 - {control.algorithm.algorithm:25} - {INFO:MainThread} - # Algorithmus
2024-09-25 17:26:00,574 - {control.algorithm.algorithm:30} - {INFO:MainThread} - **Mindestrom setzen**
2024-09-25 17:26:00,577 - {control.algorithm.algorithm:32} - {INFO:MainThread} - **Soll-Strom setzen**
2024-09-25 17:26:00,579 - {control.counter:235} - {DEBUG:MainThread} - Anpassen des Regelbereichs 0W
2024-09-25 17:26:00,581 - {control.counter:500} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2024-09-25 17:26:00,582 - {control.algorithm.algorithm:43} - {INFO:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2024-09-25 17:26:00,584 - {control.process:24} - {INFO:MainThread} - # Ladung starten.
2024-09-25 17:26:00,603 - {modules.common.component_context:26} - {DEBUG:set current cp4} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,605 - {modules.common.component_context:26} - {DEBUG:set current cp5} - Update Komponente ['Ladepunkt']
2024-09-25 17:26:00,927 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/home_consumption, Payload 389, vorherige Payload: 394
2024-09-25 17:26:00,930 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/set/imported_home_consumption, Payload 6338853.96452837, vorherige Payload: 6338852.882804225
2024-09-25 17:26:00,937 - {helpermodules.changed_values_handler:126} - {DEBUG:MainThread} - Topic openWB/set/counter/0/set/error_counter, Payload 8, vorherige Payload: 7
2024-09-25 17:26:05,957 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2024-09-25 17:26:07,418 - {modules.update_soc:111} - {DEBUG:SoC} - 2 soc_from_cp: None, timestamp_soc_from_cp: None
2024-09-25 17:26:10,974 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=smarthome_handler, args=(), kwargs={})
2024-09-25 17:26:10,976 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
