Rückmeldung Beta 1.74
Has thanked: 196 times
Been thanked: 460 times
Re: Rückmeldung Beta 1.74
Ja unter Status das Mqtt.log
corwin42
Beitrag von corwin42 »
Ich bin jetzt einmal in die Settings für Sofortladen gegangen und habe da Mindeststromstärke und für die ersten beiden Ladepunkte alles eingestellt.
LP1: 22A
LP2: 18A
Folgendes steht im Log:
Message: 52
2020-05-19 12:05:14 Topic: openWB/config/set/sofort/lp/8/energyToCharge
Message: 19
2020-05-19 12:05:14 Topic: openWB/config/set/sofort/lp/8/current
Message: 52
2020-05-19 12:05:13 Topic: openWB/config/set/sofort/lp/7/energyToCharge
Message: 19
2020-05-19 12:05:13 Topic: openWB/config/set/sofort/lp/7/current
Message: 52
2020-05-19 12:05:13 Topic: openWB/config/set/sofort/lp/6/energyToCharge
Message: 19
2020-05-19 12:05:13 Topic: openWB/config/set/sofort/lp/6/current
Message: 52
2020-05-19 12:05:12 Topic: openWB/config/set/sofort/lp/5/energyToCharge
Message: 19
2020-05-19 12:05:12 Topic: openWB/config/set/sofort/lp/5/current
Message: 52
2020-05-19 12:05:12 Topic: openWB/config/set/sofort/lp/4/energyToCharge
Message: 19
2020-05-19 12:05:12 Topic: openWB/config/set/sofort/lp/4/current
Message: 52
2020-05-19 12:05:12 Topic: openWB/config/set/sofort/lp/3/energyToCharge
Message: 19
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/3/current
Message: 100
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/2/socToChargeTo
Message: 16
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/2/energyToCharge
Message: 0
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/2/chargeLimitation
Message: 18
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/2/current
Message: 100
2020-05-19 12:05:11 Topic: openWB/config/set/sofort/lp/1/socToChargeTo
Message: 10
2020-05-19 12:05:10 Topic: openWB/config/set/sofort/lp/1/energyToCharge
Message: 0
2020-05-19 12:05:10 Topic: openWB/config/set/sofort/lp/1/chargeLimitation
Message: 22
2020-05-19 12:05:10 Topic: openWB/config/set/sofort/lp/1/current
Message: 8
2020-05-19 12:05:10 Topic: openWB/config/set/global/minEVSECurrentAllowed
Dann bin ich auf die Hauptseite gewechselt. Erst sind die Werte der Regler korrekt auf die eingestellten Werte gesprungen. Dann aber sofort LP1 auf 10A und LP2 auf 16A.
Kann da irgendwas anderes reinstreuen? openWB-Cloud-Anbindung oder sowas?
Thomas aus W
Has thanked: 156 times
Been thanked: 68 times
GUI lagged bis zu 70 Sekunden
Beitrag von Thomas aus W »
openWB Version 1.7.402Nightly (2020-05-18 13:43:08 +0200 [625ed4f4] )
Bei mir läuft das Update der GUI nicht rund.
Es dauert fast immer länger als 10 Sekunden und und manchmal bis zu 70 Sekunden. Eine parallel laufendes ping auf die OWB zeigt keine Auffälligkeiten und auch ein per SSH auf der OWB ausgeführtes top aktualisiert regelmäßig, so dass ich Netzwerkprobleme ausschließe. Das Problem tritt sowohl auf dem PC wie auch auf dem Handy auf. Browser ist beide male der FireFox. (Nein, ich möchte nicht auf Chrome wechseln...)
Hier sind 2 Minuten Video zur Veranschaulichung:
screenshot vom Video
(330MB auf ufile.io bis 18.6.2020 abrufbar)
Nachtrag:
Löschen des Cache hat nichts gebracht.
Momentan lädt die GUI gar nicht neu (nur der Fortschrittsbalken ohne Fortschritt ist sichtbar) Muss wohl wieder einen Reset machen... :(
Nachtrag2:
Es betrifft nur die GUI, das Laden (nur PV) funktioniert weiterhin. Ich lass es erst mal so.
@Kevin: Willst Du mal bei mir drauf schauen?
Soll ich das bekannte Token wieder aktivieren?
bye
TW
Zuletzt geändert von Thomas aus W am Di Mai 19, 2020 11:21 am, insgesamt 1-mal geändert.
@Thomas aus W
Bitte mal testhalber IPv6 deaktivieren.
Thomas aus W
KevinW hat geschrieben: Di Mai 19, 2020 11:20 am @Thomas aus W
Auf dem pi?
Thomas aus W
Jetzt ist die OWB nicht mehr erreichbar, regelt aber immer noch.
~$ ping openwb | nl
     1	PING openwb.fritz.box (192.168.1.59) 56(84) Bytes Daten.
     2	From myhost.fritz.box (192.168.1.43) icmp_seq=1 Zielhost nicht erreichbar
     3	From myhost.fritz.box (192.168.1.43) icmp_seq=2 Zielhost nicht erreichbar
     4	From myhost.fritz.box (192.168.1.43) icmp_seq=3 Zielhost nicht erreichbar
     5	From myhost.fritz.box (192.168.1.43) icmp_seq=4 Zielhost nicht erreichbar
     6	From myhost.fritz.box (192.168.1.43) icmp_seq=5 Zielhost nicht erreichbar
     7	From myhost.fritz.box (192.168.1.43) icmp_seq=6 Zielhost nicht erreichbar
wie komme ich jetzt wieder auf die OWB?
Reboot (Strom aus/an) und mit ihrem eigenen WLAN verbinden?
bye
TW
IPv6 im Netzwerk deaktivieren.
Danach ggf. noch die openWB Neustarten.
@corwin42
Sollte in der Nightly 1.7.404 gefixt sein
churchi
Beitrag von churchi »
KevinW hat geschrieben: Di Mai 19, 2020 12:38 pm @corwin42
Genau das selbe Problem gibts auch unter Übergreifende Ladeeinstellungen.
Dort sieht man auch den eingestellten Wert nicht.
Ein weiteres Problem das mir aufgefallen ist:
Ich habe unter Übergreifende Ladeeinstellungen 16A eingegeben und kann aber auf der Hauptseite trotzdem bis zu 32A über die Schieberegler einstellen. Ist das Absicht?
Noch was (ist aber schon immer so und nicht erst seit kurzem):
Unter Logging Langzeitansicht sehe ich die letzten Stunden korrekt, aber wenn ich auf Logging Tagesansicht gehe, dann ist bei jedem Tag alles auf 0 bis auf die Leistung der Ladepunkte. Also der Hausverbraucht und der Bezug sind durchgehend 0.
Nun auch gefixt.
Jein, der Slider geht bis 32A, laden kannst du aber dennoch nur bis maximal 16
Das hängt von den gewählten PV /EVU Modulen ab. Kein direktes Problem der Beta. Welche werden genutzt?
