2021-10-01 12:02:25: RET: 0 (LV2) at 29 main modules/wr2_json/main.sh
2021-10-01 12:02:25: PID: 7945: PV2kWh: 7194580.566
2021-10-01 12:02:24: PID: 7945: PV2Watt: 0
2021-10-01 12:02:24: PID: 7945: /var/www/html/openWB/ramdisk/pv2wattW:0
2021-10-01 12:02:24: PID: 7945: Leistung (Watt) nicht numerisch. Bitte Filterausdruck ueberpruefen -->0
2021-10-01 12:02:24: PID: 7945: Leistung: 8154.002441
2021-10-01 12:02:24: PID: 7945: JSON Response: {'status': {'code': 0}, 'session': {'sessionId': 0, 'roleId': 0}, 'dxsEntries': [{'value': 8154.002441, 'dxsId': 67109120}, {'value': 7194.580566, 'dxsId': 251658753}]}
2021-10-01 12:02:24: PID: 7945: PV2 JQ numpv : 2
2021-10-01 12:02:24: PID: 7945: PV2 JQ Wh : (.dxsEntries[]|select(.dxsId==251658753)|.value)*1000
2021-10-01 12:02:24: PID: 7945: PV2 JQ Watt: .dxsEntries[]|select(.dxsId==67109120)|.value
2021-10-01 12:02:22: PV kWh : (.dxsEntries[]|select(.dxsId==251658753)|.value)*1000 (LV2) at 24 main modules/wr2_json/main.sh
2021-10-01 12:02:22: PV Watt: .dxsEntries[]|select(.dxsId==67109120)|.value (LV2) at 23 main modules/wr2_json/main.sh
2021-10-01 12:02:22: PV URL :
http://192.168.178.20/api/dxs.json?dxsE ... =251658753 (LV2) at 22 main modules/wr2_json/main.sh
2021-10-01 12:02:19: Gesamt Anzahl Phasen= 1 (LV0) at 513 main /var/www/html/openWB/regel.sh
2021-10-01 12:02:19: LP1 Anzahl Phasen während Ladung= 0 (LV0) at 434 main /var/www/html/openWB/regel.sh
2021-10-01 12:02:19: Alte Anzahl genutzter Phasen= 0 (LV0) at 419 main /var/www/html/openWB/regel.sh
2021-10-01 12:02:15: RET: 0 (LV2) at 29 main modules/wr2_json/main.sh
2021-10-01 12:02:15: PID: 6781: PV2kWh: 7194580.566
2021-10-01 12:02:14: PID: 6781: PV2Watt: 0
2021-10-01 12:02:14: PID: 6781: /var/www/html/openWB/ramdisk/pv2wattW:0
2021-10-01 12:02:14: PID: 6781: Leistung (Watt) nicht numerisch. Bitte Filterausdruck ueberpruefen -->0
