Seite 64 von 86
Re: Support: Kia
Verfasst: Do Jul 25, 2024 10:22 am
von rleidner
Für unseren Kia EV6 kommen aktuell in 2.x SoC und Range ganz normal.
2024-07-25 12:14:59,457 - {modules.vehicles.kia.api:931} - {INFO:fetch soc_ev5} - Kia/Hyundai: Update starting
2024-07-25 12:14:59,459 - {modules.vehicles.kia.api:939} - {INFO:fetch soc_ev5} - Kia/Hyundai: thread soc_kia_thread not found: starting now
2024-07-25 12:14:59,462 - {modules.vehicles.kia.api:883} - {INFO:soc_kia_thread} - Kia/Hyundai: Thread starting
2024-07-25 12:14:59,469 - {modules.vehicles.kia.api:901} - {INFO:soc_kia_thread} - Kia/Hyundai: AccessToken still valid: 2024-07-25 13:11:26, keep token
2024-07-25 12:14:59,470 - {modules.vehicles.kia.api:717} - {INFO:soc_kia_thread} - Kia/Hyundai: Requesting vehicle list
2024-07-25 12:14:59,490 - {modules.common.store._api:30} - {INFO:store soc_ev5} - Saving CarState(soc=79, range=388.0, soc_timestamp=1721896190.975118)
2024-07-25 12:14:59,646 - {modules.vehicles.kia.api:763} - {INFO:soc_kia_thread} - Kia/Hyundai: Triggering Pre-Wakeup
2024-07-25 12:14:59,838 - {modules.vehicles.kia.api:685} - {INFO:soc_kia_thread} - Kia/Hyundai: Sending PIN
2024-07-25 12:15:00,010 - {modules.vehicles.kia.api:793} - {INFO:soc_kia_thread} - Kia/Hyundai: Triggering Update
2024-07-25 12:15:00,186 - {modules.vehicles.kia.api:822} - {INFO:soc_kia_thread} - Kia/Hyundai: Waiting 130 seconds
2024-07-25 12:17:10,251 - {modules.vehicles.kia.api:825} - {INFO:soc_kia_thread} - Kia/Hyundai: Receiving status
2024-07-25 12:17:10,717 - {modules.vehicles.kia.api:919} - {INFO:soc_kia_thread} - Kia/Hyundai: soc/range changed - push update to store
2024-07-25 12:17:10,718 - {modules.common.store._api:30} - {INFO:soc_kia_thread} - Saving CarState(soc=77, range=380.0, soc_timestamp=1721902630.72)
Nicht wundern über "INFO:soc_kia_thread" - das ist meine Spezialversion, die die Blockierung des soc-threads für 130 sec vermeidet; die Abfrage ist exakt dieselbe.
Re: Support: Kia
Verfasst: Do Jul 25, 2024 7:56 pm
von dkleerba
auch bei mir (Hyundai) funktioniert SOC Abruf der OpenWB 2.1.4 seit heute nicht mehr. Bluelink App geht, war aber disconnected und nach App Neustart wieder Connected.
Im OpenWB Log sehe ich unterschiedliche response codes. Anfänglich 400, dann 401 und nun 503.
Re: Support: Kia
Verfasst: Fr Jul 26, 2024 6:07 am
von Ilchi
Ok, dann bin ich nicht der einzige, bei dem der SoC-Abruf bei Hyundai nicht mehr geht. Auch unser I5 steht auf "0". Hier scheint also die Hyundai/ Kia-Cloud mal wieder geändert worden zu sein...
Re: Support: Kia
Verfasst: Fr Jul 26, 2024 7:41 am
von HansR
Hmmm, scheint (noch) kein flächendeckendes Problem zu sein.
2024-07-26 07:31:35: Received SoC (HV-battery): 78%
2024-07-26 07:29:57: SoC download starting
2024-07-26 04:31:32: Received SoC (HV-battery): 79%
2024-07-26 04:29:56: SoC download starting
2024-07-26 01:30:04: Received SoC (HV-battery): 79%
2024-07-26 01:29:47: SoC download starting
2024-07-25 22:31:24: Received SoC (HV-battery): 79%
2024-07-25 22:29:46: SoC download starting
Bei meinem i5 kein Problem. Habe noch Version 1.9x im Einsatz.
Re: Support: Kia
Verfasst: Fr Jul 26, 2024 8:09 am
von Scusi83
Hier aus dem Log:
File "/var/www/html/openWB/packages/modules/vehicles/kia/api.py", line 844, in fetch_soc
vehicle_id = getVehicleId(vin, token, brand)
File "/var/www/html/openWB/packages/modules/vehicles/kia/api.py", line 719, in getVehicleId
log.exception("kia.getVehicleId: error: " + response)
UnboundLocalError: local variable 'response' referenced before assignment
2024-07-26 10:08:40,378 - {modules.common.fault_state:49} - {ERROR:fetch soc_ev8} - KIA / Hyundai (experimental): FaultState FaultStateLevel.ERROR, FaultStr <class 'UnboundLocalError'> ("local variable 'response' referenced before assignment",), Traceback:
File "/var/www/html/openWB/packages/modules/vehicles/kia/api.py", line 705, in getVehicleId
response = getHTTP(url=url, headers=headers)
File "/var/www/html/openWB/packages/modules/vehicles/kia/api.py", line 165, in getHTTP
raise RuntimeError
RuntimeError
Mal komplett alles neu gestartet. Jetzt geht es wieder.
Re: Support: Kia
Verfasst: Fr Jul 26, 2024 11:39 am
von dkleerba
Nach Neustart openWB geht bei mir der SOC Abruf auch wieder. @Scusi83: Danke für den Tip.
Re: Support: Kia
Verfasst: Fr Jul 26, 2024 7:14 pm
von SP68
Nach erneutem Neustart heute (gestern auch schon, aber ohne Auswirkung) funktioniert es bei mir jetzt auch wieder, sowohl auf 1.9.304 als auch 2.1.4.
Re: Support: Kia
Verfasst: Mo Jul 29, 2024 4:07 pm
von JHC
Moin, moin,
60 Seiten sind mir dann doch etwas viel zum Nachlesen. ;)
Ich möchte gerne die manuelle Berechnung nutzen, was ist Eure Erfahrung beim Wirkungsgrad für einen IONIQ 5?
Grüße,
Jens
Re: Support: Kia
Verfasst: Mo Jul 29, 2024 4:14 pm
von HansR
ich habe 90% eingestellt. Das passt in der Regel ganz gut.
Ich denke aber, dass es für Winter und Sommer wegen Temperaturunterschied nicht den EINEN richtigen
Wert gibt.
Hans
Re: Support: Kia
Verfasst: Di Jul 30, 2024 11:52 am
von JHC
Moin, moin,
ich habe mal eine Frage zum SOC Update...
Konfiguration:
- Master openWB (SoC IONIQ konfiguriert)
- Slave openWB (SoC Corsa konfiguriert)
Aktueller Status:
- Ioniq nicht angeschlossen
- Corsa an Slave angeschlossen
Eingestellt sind:
- SoC nur Abfragen wenn Auto angesteckt: Nein
- Abfrageintervall: 30 Minuten
- Abrufintervall abgesteckt: 120 Minuten
- Abrufsperre: 30 Minuten
Warum habe ich dann alle 3 Minuten solche Einträge?
2024-07-30 13:34:00: SoC download starting
2024-07-30 13:34:00: Manual update or charge starts
2024-07-30 13:34:00: SoC download triggered externally
2024-07-30 13:34:00: Kia/Hyundai SoC Module starting
2024-07-30 13:34:00: -------------------------------
2024-07-30 13:31:50: Kia/Hyundai SoC Module ending
2024-07-30 13:31:50: Next Update: 93.5 minutes
2024-07-30 13:31:50: Kia/Hyundai SoC Module starting
2024-07-30 13:31:50: -------------------------------
2024-07-30 13:31:31: Kia/Hyundai SoC Module ending
2024-07-30 13:31:31: SoC download ending
2024-07-30 13:31:29: SoC download starting
2024-07-30 13:31:29: Manual update or charge starts
2024-07-30 13:31:29: SoC download triggered externally
2024-07-30 13:31:29: Kia/Hyundai SoC Module starting
2024-07-30 13:31:29: -------------------------------
2024-07-30 13:31:09: Kia/Hyundai SoC Module ending
2024-07-30 13:31:09: Next Update: 94.2 minutes
2024-07-30 13:31:09: Kia/Hyundai SoC Module starting
2024-07-30 13:31:09: -------------------------------
Beim Anstecken okay, aber warum alle 3 Minuten?
Und wieso wird die Abrufsperre ignoriert?
Update 1:
Wenn ich "SoC nur Abfragen wenn Auto angesteckt" auf Ja stelle, hört es auf.
Grüße,
Jens
