Rückmeldungen 2.1.8 Release Patch 4
snoerenberg
Has thanked: 5 times
Been thanked: 5 times
Re: Rückmeldungen 2.1.8 Release Patch 4
Beitrag von snoerenberg »
ich habe ein Problem mit dem MQTT "PlugState".
MainLog: https://paste.openwb.de/clwkYsr43uAfGD9
ChargePointLog: https://paste.openwb.de/z8mSfAfvk1toKV9
MQTTLog: https://paste.openwb.de/9imwFQMrnyw5bCZ
Ich erhalte sporadisch den plug_state "verbunden", "nicht verbunden" und dann wieder "verbunden".
MQTT und InternalChargePoint Log zusammengefasst:
2025-12-26 22:39:58,086 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:226} - {DEBUG:Internal Chargepoint} - Published plug state False
2025-12-26 22:40:01,167 - Topic: openWB/set/chargepoint/28/get/plug_state, Payload: 0
2025-12-26 22:40:01,178 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:226} - {DEBUG:Internal Chargepoint} - Published plug state False
2025-12-26 22:40:01,201 - Topic: openWB/chargepoint/28/get/plug_state, Payload: false
2025-12-26 22:40:01,314 - Topic: openWB/set/internal_chargepoint/0/get/plug_state, Payload: 0
2025-12-26 22:40:04,319 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:226} - {DEBUG:Internal Chargepoint} - Published plug state True
2025-12-26 22:40:01,328 - Topic: openWB/internal_chargepoint/0/get/plug_state, Payload: false
2025-12-26 22:40:04,373 - Topic: openWB/set/chargepoint/28/get/plug_state, Payload: 1
2025-12-26 22:40:04,440 - Topic: openWB/chargepoint/28/get/plug_state, Payload: true
2025-12-26 22:40:04,544 - Topic: openWB/set/internal_chargepoint/0/get/plug_state, Payload: 1
2025-12-26 22:40:04,575 - Topic: openWB/internal_chargepoint/0/get/plug_state, Payload: true
2025-12-26 22:40:04,820 - Topic: openWB/set/chargepoint/28/get/plug_state, Payload: 0
2025-12-26 22:40:04,823 - Topic: openWB/chargepoint/28/get/plug_state, Payload: false
2025-12-26 22:40:05,463 - Topic: openWB/set/chargepoint/28/set/plug_state_prev, Payload: False
2025-12-26 22:40:05,467 - Topic: openWB/chargepoint/28/set/plug_state_prev, Payload: false
2025-12-26 22:40:07,415 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:226} - {DEBUG:Internal Chargepoint} - Published plug state True
2025-12-26 22:40:07,487 - Topic: openWB/set/chargepoint/28/get/plug_state, Payload: 1
2025-12-26 22:40:07,512 - Topic: openWB/chargepoint/28/get/plug_state, Payload: true
2025-12-26 22:40:07,625 - Topic: openWB/set/internal_chargepoint/0/get/plug_state, Payload: 1
2025-12-26 22:40:07,628 - Topic: openWB/internal_chargepoint/0/get/plug_state, Payload: true
2025-12-26 22:40:10,478 - {modules.internal_chargepoint_handler.internal_chargepoint_handler:226} - {DEBUG:Internal Chargepoint} - Published plug state True
2025-12-26 22:40:10,546 - Topic: openWB/set/chargepoint/28/get/plug_state, Payload: 1
2025-12-26 22:40:10,607 - Topic: openWB/chargepoint/28/get/plug_state, Payload: true
2025-12-26 22:40:10,664 - Topic: openWB/set/internal_chargepoint/0/get/plug_state, Payload: 1
2025-12-26 22:40:10,710 - Topic: openWB/internal_chargepoint/0/get/plug_state, Payload: true
Im Chargepoint Log findet man nur die Einträge vom "anstecken". Änderung von plug_state "False" zu "True".
Im MQTT Log findet man aber:
Ich finde nicht, warum dies plötzlich passiert. Dies führt zu einem Problem mit meiner OCPP Anbindung (eigene Middleware).
Im dem Fall befindet sich der "Client" noch in der Autorisierung. Ich werde den eigenen Client noch etwas umstricken um das Problem zu beheben aber die OpenWB verhält sich hier mEn nicht korrekt.
Gruß Stephan
PV: 16.75 kWp, 1x SolarEdge SE15K, 1x SolarEdge SE5000H + 2x 9,6 LG RESU Prime 10H, OpenWB Series 2 custom
Fahrzeug: Tesla Model Y LR AWD
Heizung: Nibe 1155-6 PC mit EME20
Has thanked: 82 times
Been thanked: 404 times
snoerenberg hat geschrieben: So Dez 28, 2025 6:49 am Dies führt zu einem Problem mit meiner OCPP Anbindung (eigene Middleware).
Du weißt, dass in der openWB mittlerweile OCPP zu Loggingzwecken implementiert ist?
snoerenberg
Gero hat geschrieben: So Dez 28, 2025 9:36 am
Ja, hab ich aber noch nicht so hinbekommen.
7 Byte Karte notwendig - habe kein Leser dafür gefunden der die Kartennummer entsprechend überträgt.
viewtopic.php?p=133690&hilit=Ocpp#p133690
Leider keine Antwort mehr, wäre für Hilfe dankbar. Die Middleware läuft schon seit der 1.9 mit Anpassungen, würde gern darauf verzichten.
Gruß Stephan
Has thanked: 142 times
Been thanked: 208 times
Beitrag von ChristophR »
snoerenberg hat geschrieben: So Dez 28, 2025 10:38 am
Gruß Stephan
Wenn es um den Leser geht, hilft dieser Beitrag evtl.?
viewtopic.php?p=136227#p136227
truth
Been thanked: 3 times
Beitrag von truth »
Ich hatte jetzt schon öfter das Problem, dass die OpenWB Pro den SOC nicht aktualisiert, wenn ich das Fahrzeug anstecke, obwohl für beide Autos (ID.3 und Ioniq6) das "Auslesen des SOC direkt aus dem Fahrzeug" aktiviert ist.
(Für beide Fahrzeuge ist außerdem das jeweilige SOC-Modul aktiviert).
Wenn ich dann das Auto nochmal abstecke und nach ca. 1 Minute wieder anstecke, wird mit viel Glück der SOC richtig angezeigt. Das (zweite) Problem ist jedoch, das der neue SOC jetzt für beide Autos angezeigt wird, was keinen Sinn macht.
Irgendwie habe ich den Eindruck, dass die OpenWB Pro die ID der Fahrzeuge nicht mehr richtig unterscheiden kann ... oder so'was in der Art.
Log-files:
Main_log.txt
(2.52 KiB) 70-mal heruntergeladen
Lade_log.txt
(126.36 KiB) 66-mal heruntergeladen
truth
Beitrag von truth »
truth hat geschrieben: Do Jan 01, 2026 4:59 pm Ich hatte jetzt schon öfter das Problem, dass die OpenWB Pro den SOC nicht aktualisiert, wenn ich das Fahrzeug anstecke, obwohl für beide Autos (ID.3 und Ioniq6) das "Auslesen des SOC direkt aus dem Fahrzeug" aktiviert ist.
Sorry, hab' gerade gemerkt, dass ich noch auf Version 2.1.8 Patch 1 bin ... vermute aber mal, das das Problem trotzdem noch aktuell ist.
Been thanked: 172 times
Beitrag von LenaK »
steffel25 hat geschrieben: So Dez 21, 2025 8:38 am Hallo,
mein Main-Log ist geflutet mit dieser Meldung:
{helpermodules.setdata:301} - {ERROR:Setdata} - Payload ungültig: Topic openWB/set/pv/2/get/exported, Payload -1.2963217219534723e+31 liegt in keinem der angegebenen Wertebereiche.
(siehe auch https://paste.openwb.de/uxK6WbSNWJziTNW)
Hat jemand eine Idee, wie ich das beheben kann? (I.e. irgendwie durch Ändern einer Konfiguration)?
Bitte das Debug-Level auf Details stellen und dann nochmal einen Logauszug posten.
Beitrag von LenaK »
HansR hat geschrieben: Fr Dez 26, 2025 4:33 pm Hallo,
mir ist heute, durch Zufall, aufgefallen, dass die Ladekosten m. E. nicht korrekt berechnet werden. Siehe die beiden letzten Zeilen im Anhang von der Ladung heute am 26.12.2025. Habe ich gerade einen Denkfehler oder ist die Berechnung schlichtweg falsch?
Hans
Hast Du das Log auf Details gehabt? Dann bitte http://<ipderopenwb>/openWB/ramdisk/chargelog.log posten.
Hast Du dynamische Strompreise aktiviert? Welche Strompreise hast Du eingetragen?
HansR
Been thanked: 8 times
Beitrag von HansR »
LenaK hat geschrieben: Di Jan 06, 2026 10:28 am
Hans
Hallo Lena,
dynamische Strompreise ist bei mir nicht aktiviert und war es auch noch nie.
Loglevel ist leider nur auf Warnung/Fehler.
Kann ich sonst noch Infos liefern?
Hans
12,8 kWP
steffel25
Been thanked: 4 times
Beitrag von steffel25 »
LenaK hat geschrieben: Mo Jan 05, 2026 12:25 pm
Hier noch mal ein Log mit Debug Level "Detail": https://paste.openwb.de/yymBJf5rfmcsXse
2 x openWB Series 2 Standard+, SW-Version 2
SolarEdge SE10K-RWS, BYD LVS 14, 10 kWp.
