Regelt manchmal nicht
Verfasst: Do Nov 05, 2020 2:29 pm
Moin, ich beobachte häufig, dass er in der Anzeige auf 6A runter regelt aber dann längere Zeit mit einem höheren Wert weiter läd!
Kann mir wer erklären ob der Fehler bei mir liegt oder woanders?
Ich habe unter Status Debugg dann folgende Fehler:
Do 5. Nov 15:09:51 CET 2020
uberschuss -537 wattbezug 537 ladestatus 1 llsoll 7 pvwatt -2948 mindestuberschussphasen 1600 wattkombiniert 2643 schaltschwelle 230
Do 5. Nov 15:09:42 CET 2020
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
'device reports readiness to read but returned no data '
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 501, in read
result = self.socket.read(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 555, in _recv
return self._recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 88, in recv
result = self.client.recv(size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/framer/rtu_framer.py", line 286, in recvPacket
read_min = self.client.framer.recvPacket(min_size)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 241, in _recv
result = self._recv(response_length, full)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 212, in _transact
full=full
File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 140, in execute
return self.transaction.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/sync.py", line 108, in execute
return self.execute(request)
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 114, in read_holding_registers
rq = client.read_holding_registers(readreg,reganzahl,unit=modbusid)
File "runs/readmodbus.py", line 20, in
hz = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 151, in
uberschuss -400 wattbezug 400 ladestatus 1 llsoll 9 pvwatt -2948 mindestuberschussphasen 1600 wattkombiniert 2779 schaltschwelle 230
Do 5. Nov 15:09:32 CET 2020
voltage = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 133, in
uberschuss -343 wattbezug 343 ladestatus 1 llsoll 9 pvwatt -3097 mindestuberschussphasen 1600 wattkombiniert 2836 schaltschwelle 230
Do 5. Nov 15:09:22 CET 2020
llw1 = struct.unpack('>f',struct.pack('>HH',*resp.registers))[0]
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 117, in
uberschuss -368 wattbezug 368 ladestatus 1 llsoll 11 pvwatt -3191 mindestuberschussphasen 1600 wattkombiniert 2811 schaltschwelle 230
Do 5. Nov 15:09:12 CET 2020
lla2 = float(struct.unpack('>f',struct.pack('>HH',*resp.registers))[0])
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 105, in
uberschuss -286 wattbezug 286 ladestatus 1 llsoll 11 pvwatt -3275 mindestuberschussphasen 1600 wattkombiniert 2893 schaltschwelle 230
Do 5. Nov 15:09:02 CET 2020
1604585334 Modbus EVSE read CP1 issue - using previous state '3'
print(rq.registers[0])
File "runs/readmodbus.py", line 21, in
uberschuss -175 wattbezug 175 ladestatus 1 llsoll 12 pvwatt -3354 mindestuberschussphasen 1600 wattkombiniert 2535 schaltschwelle 230
Do 5. Nov 15:08:51 CET 2020
'ModbusIOException' object has no attribute 'registers' File "/usr/local/lib/python2.7/dist-packages/pymodbus/transaction.py", line 212, in _transact
AttributeError : full=full
File "/usr/local/lib/python2.7/dist-packages/pymodbus/client/common.py", line 103, in write_registers
rq = client.write_registers(1000, lla, unit=evseid)
File "/var/www/html/openWB/runs/evsewritemodbus.py", line 10, in
uberschuss -119 wattbezug 119 ladestatus 1 llsoll 9 pvwatt -3419 mindestuberschussphasen 1600 wattkombiniert 2591 schaltschwelle 230
Do 5. Nov 15:08:42 CET 2020
lla1 = float(struct.unpack('>f',struct.pack('>HH',*resp.registers))[0])
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 99, in
uberschuss -85 wattbezug 85 ladestatus 1 llsoll 13 pvwatt -3409 mindestuberschussphasen 1600 wattkombiniert 2625 schaltschwelle 230
Do 5. Nov 15:08:32 CET 2020
File "/var/www/html/openWB/modules/mpm3pmll/readmpm3pm.py", line 139, in
uberschuss -116 wattbezug 116 ladestatus 1 llsoll 10 pvwatt -3281 mindestuberschussphasen 1600 wattkombiniert 2594 schaltschwelle 230
Do 5. Nov 15:08:22 CET 2020
uberschuss -177 wattbezug 177 ladestatus 1 llsoll 14 pvwatt -3283 mindestuberschussphasen 1600 wattkombiniert 2533 schaltschwelle 230
Do 5. Nov 15:08:12 CET 2020
uberschuss -280 wattbezug 280 ladestatus 1 llsoll 12 pvwatt -3267 mindestuberschussphasen 1600 wattkombiniert 2430 schaltschwelle 230
Do 5. Nov 15:08:02 CET 2020
uberschuss 231 wattbezug -231 ladestatus 1 llsoll 13 pvwatt -3248 mindestuberschussphasen 1600 wattkombiniert 3148 schaltschwelle 230
Do 5. Nov 15:07:52 CET 2020
uberschuss -4 wattbezug 4 ladestatus 1 llsoll 13 pvwatt -3253 mindestuberschussphasen 1600 wattkombiniert 2918 schaltschwelle 230
Do 5. Nov 15:07:42 CET 2020
1604585253 Modbus EVSE read CP1 issue - using previous state '3'
uberschuss 7 wattbezug -7 ladestatus 1 llsoll 13 pvwatt -3256 mindestuberschussphasen 1600 wattkombiniert 2928 schaltschwelle 230
Do 5. Nov 15:07:32 CET 2020
uberschuss 29 wattbezug -29 ladestatus 1 llsoll 13 pvwatt -3262 mindestuberschussphasen 1600 wattkombiniert 2950 schaltschwelle 230
Do 5. Nov 15:07:22 CET 2020
uberschuss 62 wattbezug -62 ladestatus 1 llsoll 13 pvwatt -3198 mindestuberschussphasen 1600 wattkombiniert 2982 schaltschwelle 230
full=full
