Seite 1 von 1
rPi Connection to SimpleEVSE WIFI
Verfasst: So Jul 25, 2021 2:46 pm
von courage2000
Hello!
I have a working installation of Simple EVSE DIN (Modbus active) + Simple EVSE WIfi (Node MCU esp8266) v1.1.1 and is working.
Now I want to install a PV system.
For this, I plan to mount inside the house, on the dedicated EVSE Circuit
- SDM630 Modbus V2
- OpenWB will run on an RPi 3 in a DIN case + USB Modbus adapter for SMD630v2 MB.
OpenWB will be on the same LAN with SimpleEVSE WIFI.
OpenWB is controlling the Simple EVSE Wifi via LAN API?
Re: rPi Connection to SimpleEVSE WIFI
Verfasst: So Jul 25, 2021 3:33 pm
von aiole
courage2000 hat geschrieben: So Jul 25, 2021 2:46 pm OpenWB is controlling the Simple EVSE Wifi via LAN API?
right
