Seite 1 von 2
Protoss PE11-H configuration ?
Verfasst: Sa Sep 11, 2021 12:41 pm
von courage2000
Hello!
I have one SDM630Modbus V2 for my EVSE-WIFI, connected to a Protoss PE11-H Modbus- > TCP converter.
That changes I must do to the Protoss configuration?
Thank you.
Here are my settings. Do I need to change something?
Thank you!
Re: Protoss PE11-H configuration ?
Verfasst: Sa Sep 11, 2021 12:52 pm
von HSC
Here is a problem:
Wait pleace 1 min....
Verfasst: Sa Sep 11, 2021 12:56 pm
von HSC
There is a .pdf:
viewtopic.php?p=45047#p45047
The same konfig for the sdm 630: 9600, ID xxx, none.
Verfasst: Sa Sep 11, 2021 12:59 pm
von HSC
Verfasst: Sa Sep 11, 2021 1:00 pm
von courage2000
So
Local port: 8899
Thank you
Verfasst: Sa Sep 11, 2021 1:01 pm
von HSC
Verfasst: Sa Sep 11, 2021 1:02 pm
von derNeueDet
That depends which which module you want to use it.
8899 is usually used in openWB, but you are referencing EVSE Wifi.
Best regards
Verfasst: Sa Sep 11, 2021 1:14 pm
von HSC
For what or in which module do you want to use the SDM 630?
Will it be used with openWB software?
Many greetings
Verfasst: Sa Sep 11, 2021 2:02 pm
von courage2000
I will try OpenWB and EVCC.
Verfasst: Sa Sep 11, 2021 2:41 pm
von derNeueDet
To use it in openWB as a meter to measure the powerflow from or to the grid, you have to use it as
EVU Kit type SDM and that needs a special setup of the IP address and of the unit_id.
IPAddress: 192.168.193.15
Port: 8899
Unit_id: 115
Best regards
