Auszug aus dem Debug Log Level 2 (Passwort und Username geändert, aber Buchstaben/Zahlen Kombinationen korrekt dargestellt)
2021-12-14 11:04:23: PV IP: 192.168.1.200 (LV2) at 22 main modules/wr_powerwall/main.sh
2021-12-14 11:04:23: PV Passwort: A1234 (LV2) at 21 main modules/wr_powerwall/main.sh
2021-12-14 11:04:23: PV User:
vorname.nachname@emailprovider.de (LV2) at 20 main modules/wr_powerwall/main.sh
2021-12-14 11:04:23: PV Login erforderlich: 1 (LV2) at 19 main modules/wr_powerwall/main.sh
2021-12-14 11:04:21: **** Regulation loop start **** (LV1) at 50 main /var/www/html/openWB/regel.sh
2021-12-14 11:04:19: BattLeistung: 0 (LV1) at 31 main modules/speicher_powerwall/main.sh
2021-12-14 11:04:19: RET: 1 (LV2) at 27 main modules/speicher_powerwall/main.sh
TypeError: Can't convert 'int' object to str implicitly
DebugLog('Powerwall Login: ' + speicherpwloginneeded)
File "/var/www/html/openWB/modules/speicher_powerwall/powerwall.py", line 49, in <module>
2021-12-14 11:04:18: PID: 16248: Powerwall Passwort: A1234
2021-12-14 11:04:18: PID: 16248: Powerwall User:
2021-12-14 11:04:18: PID: 16248: Powerwall IP: 192.168.1.200
2021-12-14 11:04:17: Überschuss 0; mindestens 4800 (LV1) at 104 nurpvlademodus nurpv.sh
2021-12-14 11:04:17: uberschuss 0 wattbezug 0 ladestatus 0 llsoll 0 pvwatt 0 mindestuberschussphasen 4800 wattkombiniert 0 schaltschwelle 690 (LV2) at 558 main /var/www/html/openWB/regel.sh
2021-12-14 11:04:17: anzahlphasen 3 (LV1) at 557 main /var/www/html/openWB/regel.sh
2021-12-14 11:04:16: Speicher IP: 192.168.1.200 (LV2) at 22 main modules/speicher_powerwall/main.sh
2021-12-14 11:04:16: Speicher Passwort: A1234 (LV2) at 21 main modules/speicher_powerwall/main.sh
2021-12-14 11:04:16: Speicher User:
vorname.nachname@emailprovider.de (LV2) at 20 main modules/speicher_powerwall/main.sh
2021-12-14 11:04:16: Speicher Login erforderlich: 1 (LV2) at 19 main modules/speicher_powerwall/main.sh
2021-12-14 11:04:16: chargestatlp1 0 chargestatlp2 0 chargestatlp3 0 (LV1) at 1260 loadvars loadvars.sh
2021-12-14 11:04:15: plugstatlp1 0 plugstatlp2 1 plugstatlp3 0 (LV1) at 1259 loadvars loadvars.sh
2021-12-14 11:04:15: lp1enabled 1 lp2enabled 1 lp3enabled 1 (LV1) at 1258 loadvars loadvars.sh
2021-12-14 11:04:15: EVU 1:V/0A 2: V/0A 3: V/0A (LV1) at 1257 loadvars loadvars.sh
2021-12-14 11:04:15: RET: 1 (LV2) at 27 main modules/wr_powerwall/main.sh
2021-12-14 11:04:15: lla3 0 llv3 217 llas13 0 llas23 0 soclp1 0 soclp2 0 (LV1) at 1256 loadvars loadvars.sh
2021-12-14 11:04:15: lla2 0 llv2 219 llas12 0 llas22 0 sofortll 24 hausverbrauch 0 wattbezug 0 uberschuss 0 (LV1) at 1255 loadvars loadvars.sh
2021-12-14 11:04:15: lla1 0 llv1 215 llas11 0 llas21 0 mindestuberschuss 1600 abschaltuberschuss 0 lademodus 2 (LV1) at 1254 loadvars loadvars.sh
2021-12-14 11:04:15: pv1watt 0 pv2watt pvwatt 0 ladeleistung 0 llalt 0 nachtladen 0 nachtladen 0 minimalA 6 maximalA 32 (LV1) at 1253 loadvars loadvars.sh
2021-12-14 11:04:15: speicherleistung 0 speichersoc 0 (LV1) at 1248 loadvars loadvars.sh
File "/var/www/html/openWB/modules/wr_powerwall/powerwall.py", line 49, in <module>
2021-12-14 11:04:15: PID: 16138: Powerwall Passwort: A1234
2021-12-14 11:04:15: PID: 16138: Powerwall User:
2021-12-14 11:04:15: PID: 16138: Powerwall IP: 192.168.1.200
2021-12-14 11:04:15: RET: 1 (LV2) at 22 main modules/bezug_powerwall/main.sh
File "/var/www/html/openWB/modules/bezug_powerwall/powerwall.py", line 53, in <module>
