ich wollte während ich auf meine bestellte Box warte schon mal etwas mit der openWB Software spielen und habe
dieser Anleitung folgend
https://openwb.de/main/wp-content/uploa ... nWB_v2.pdf
alles gemacht.
Leider hängt der Raspi nach der Eingabe:
curl -s https://raw.githubusercontent.com/snaptec/openWB/master/openwb-install.sh | sudo sh Die Terminal Ausgabe ist folgende:
pi@openWB:~ $ curl -s https://raw.githubusercontent.com/snaptec/openWB/master/openwb-install.sh | sudo sh
install required packages...
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
Building dependency tree...
Reading state information...
git is already the newest version (1:2.20.1-2+deb10u1).
i2c-tools is already the newest version (4.1-1).
i2c-tools set to manually installed.
python-pip is already the newest version (18.1-5+rpt1).
python3-pip is already the newest version (18.1-5+rpt1).
The following additional packages will be installed:
apache2-bin apache2-data apache2-utils libapache2-mod-php7.3 libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libev4 libjq1 libmosquitto1 libonig5 libwebsockets8 php-common php7.3 php7.3-cli php7.3-common php7.3-curl php7.3-gd
php7.3-json php7.3-opcache php7.3-readline php7.3-xml ssl-cert vim-runtime
Suggested packages:
apache2-doc apache2-suexec-pristine | apache2-suexec-custom php-pear openssl-blacklist ctags vim-doc vim-scripts
The following NEW packages will be installed:
apache2 apache2-bin apache2-data apache2-utils bc jq libapache2-mod-php libapache2-mod-php7.3 libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libev4 libjq1 libmosquitto1 libonig5 libwebsockets8 mosquitto mosquitto-clients php
php-common php-curl php-gd php-json php-xml php7.3 php7.3-cli php7.3-common php7.3-curl php7.3-gd php7.3-json php7.3-opcache php7.3-readline php7.3-xml raspberrypi-kernel-headers socat sshpass ssl-cert vim vim-runtime
0 upgraded, 40 newly installed, 0 to remove and 0 not upgraded.
Need to get 4851 kB/38.0 MB of archives.
After this operation, 220 MB of additional disk space will be used.
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf apache2-bin armhf 2.4.38-3+deb10u3
404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf apache2-data all 2.4.38-3+deb10u3
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf apache2-utils armhf 2.4.38-3+deb10u3
Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf apache2 armhf 2.4.38-3+deb10u3
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-common armhf 7.3.11-1~deb10u1
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-json armhf 7.3.11-1~deb10u1
Err:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-opcache armhf 7.3.11-1~deb10u1
Err:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-readline armhf 7.3.11-1~deb10u1
Err:9 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-cli armhf 7.3.11-1~deb10u1
Err:10 http://raspbian.raspberrypi.org/raspbian buster/main armhf libapache2-mod-php7.3 armhf 7.3.11-1~deb10u1
Err:11 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3 all 7.3.11-1~deb10u1
Err:12 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-curl armhf 7.3.11-1~deb10u1
Err:13 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-gd armhf 7.3.11-1~deb10u1
Err:14 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-xml armhf 7.3.11-1~deb10u1
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/a/apache2/apache2-bin_2.4.38-3+deb10u3_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/a/apache2/apache2-data_2.4.38-3+deb10u3_all.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/a/apache2/apache2-utils_2.4.38-3+deb10u3_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/a/apache2/apache2_2.4.38-3+deb10u3_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-common_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-json_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-opcache_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-readline_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-cli_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/libapache2-mod-php7.3_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3_7.3.11-1~deb10u1_all.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-curl_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-gd_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-xml_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
...done
check for timezone
...ok
check for i2c bus
check for initial git clone
fatal: Zielpfad 'openWB' existiert bereits und ist kein leeres Verzeichnis.
... git cloned
grep: /var/www/html/openWB/openwb.conf: No such file or directory
check for ramdisk
...ok
check for crontab
...ok
Failed to start mosquitto.service: Unit mosquitto.service not found.
updating mosquitto config file
cp: cannot stat '/var/www/html/openWB/web/files/mosquitto.conf': No such file or directory
mosquitto: unrecognized service
disable cronjob logging
...ok
fix upload limit...installing pymodbus
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: pymodbus in /usr/local/lib/python2.7/dist-packages (2.5.3)
Requirement already satisfied, skipping upgrade: six>=1.15.0 in /usr/local/lib/python2.7/dist-packages (from pymodbus) (1.16.0)
Requirement already satisfied, skipping upgrade: pyserial>=3.4 in /usr/lib/python2.7/dist-packages (from pymodbus) (3.4)
check for paho-mqtt
mqtt installed...
check for MCP4725
Adafruit_MCP4725 installed...
chmod: cannot access '/var/www/html/openWB/modules/*': No such file or directory
chmod: cannot access '/var/www/html/openWB/runs/*': No such file or directory
chmod: cannot access '/var/www/html/openWB/*.sh': No such file or directory
sh: 127: /var/www/html/openWB/runs/atreboot.sh: not found
pi@openWB:~ $ Traceback (most recent call last):
File "<string>", line 1, in <module>
ImportError: No module named Adafruit_MCP4725
ModuleNotFoundError: No module named 'paho'
